[mpich2-commits] r8033 - mpich2/trunk/test/mpi
chan at mcs.anl.gov chan at mcs.anl.gov
Wed Feb 23 15:21:27 CST 2011
Author: chan
Date: 2011-02-23 15:21:26 -0600 (Wed, 23 Feb 2011)
New Revision: 8033
Modified:
   mpich2/trunk/test/mpi/configure.in
Log:
moved Fortran 90 freeform test before cray-pointer test because some compiler's freeform flag does not allow cray-pointer flag, this is true for "gcc version 4.0.3 (g95 0.92!) Jun 24 2009" as in req#1439.
Modified: mpich2/trunk/test/mpi/configure.in
--- mpich2/trunk/test/mpi/configure.in	2011-02-23 21:15:49 UTC (rev 8032)
+++ mpich2/trunk/test/mpi/configure.in	2011-02-23 21:21:26 UTC (rev 8033)
@@ -746,6 +746,11 @@
         AC_LANG_POP([Fortran])
     fi
+    # The Fortran90 tests rely on free-form input which needs to be tested
+    # before any test that may modify FCFLAGS, e.g. the cray-pointer test.
+    # The order of the tests is important in compiler like g95.
+    AC_FC_FREEFORM
     # See if the compiler supports the Cray-style pointers
     ALLOCMEMFC=""
     PAC_PROG_FC_CRAY_POINTER([
@@ -762,9 +767,6 @@
         fi
         cp f77/init/checksizes.c f90/init
     fi
-    # The Fortran90 tests rely on free-form input
-    AC_FC_FREEFORM
 fi
 if test "$FROM_MPICH2" = yes ; then
More information about the mpich2-commits mailing list
