[mpich2-commits] r8026 - mpich2/trunk/src/binding/cxx
gropp at mcs.anl.gov gropp at mcs.anl.gov
Wed Feb 23 13:26:25 CST 2011
Author: gropp
Date: 2011-02-23 13:26:25 -0600 (Wed, 23 Feb 2011)
New Revision: 8026
Modified:
   mpich2/trunk/src/binding/cxx/buildiface
Log:
Use 0, not NULL, in C++
Modified: mpich2/trunk/src/binding/cxx/buildiface
--- mpich2/trunk/src/binding/cxx/buildiface	2011-02-23 18:38:56 UTC (rev 8025)
+++ mpich2/trunk/src/binding/cxx/buildiface	2011-02-23 19:26:25 UTC (rev 8026)
@@ -47,6 +47,12 @@
 #            Values are string indicating processing:
 #            returnvalue-arg (0 if void, type if unique, position if not)
 #   Pass by reference to process routine
+# Notes:
+#   "NULL" isn't the rigth way to specify a NULL pointer in C++; use "0" (this
+#   will have the correct type and some C++ compilers don't recognize NULL
+#   unless you include header files that needed it and are otherwise unneeded
+#   by the C++ interface)
 # TODO:
 #    The derived classes (such as Intracomm) must *not* have their own
@@ -2206,7 +2212,7 @@
     void* extra_state
-    void *value = NULL;
+    void *value = 0;
     /* Make sure that the attribute value is delivered as a pointer */
     if(MPIR_ATTR_KIND(attrib_type) == MPIR_ATTR_KIND(MPIR_ATTR_INT)){
         value = &attrib;
@@ -2257,7 +2263,7 @@
     int* flag
+    void *value = 0;
         value = &attrib;
@@ -2330,7 +2336,7 @@
     MPI::Datatype d = datatype;
     MPI::Datatype::Delete_attr_function* f = (MPI::Datatype::Delete_attr_function*)user_function;
+    void *value = 0;
         value = &attrib;
@@ -2357,7 +2363,7 @@
     *flag = 0;
     MPI::Datatype::Copy_attr_function* f = (MPI::Datatype::Copy_attr_function*)user_function;
+    void *value = 0;
         value = &attrib;
@@ -2400,7 +2406,7 @@
     MPI::Win w = win;
     MPI::Win::Delete_attr_function* f = (MPI::Win::Delete_attr_function*)user_function;
+    void *value = 0;
         value = &attrib;
@@ -2427,7 +2433,7 @@
     *flag = 0;
     MPI::Win w = win;
     MPI::Win::Copy_attr_function* f = (MPI::Win::Copy_attr_function*)user_function;
+    void *value = 0;
         value = &attrib;
More information about the mpich2-commits mailing list
