[mpich2-commits] r8012 - mpich2/trunk/src/pm/hydra/pm/pmiserv
balaji at mcs.anl.gov
Tue Feb 22 14:23:30 CST 2011
Author: balaji
Date: 2011-02-22 14:23:30 -0600 (Tue, 22 Feb 2011)
New Revision: 8012
Modified:
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip.h
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_utils.c
Log:
Keep track of forced cleanups. If we force-killed all processes, their
exit statuses are not useful.
No reviewer.
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip.c 2011-02-22 20:23:29 UTC (rev 8011)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip.c 2011-02-22 20:23:30 UTC (rev 8012)
@@ -44,6 +44,7 @@
HYD_pmcd_pmip.downstream.exit_status = NULL;
HYD_pmcd_pmip.downstream.pmi_rank = NULL;
HYD_pmcd_pmip.downstream.pmi_fd = NULL;
+ HYD_pmcd_pmip.downstream.forced_cleanup = 0;
HYD_pmcd_pmip.local.id = -1;
HYD_pmcd_pmip.local.pgid = -1;
@@ -237,13 +238,19 @@
if (pid > 0)
for (i = 0; i < HYD_pmcd_pmip.local.proxy_process_count; i++)
if (HYD_pmcd_pmip.downstream.pid[i] == pid) {
- /* We store the new return status if either the
- * exit status is uninitialized, or if the return
- * status is non-zero. If the return status is
- * zero, and the exit status has already been set
- * to a different value, we use that. */
- if (ret_status || HYD_pmcd_pmip.downstream.exit_status[i] == -1)
+ if (HYD_pmcd_pmip.downstream.forced_cleanup) {
+ /* If it is a forced cleanup, the exit status
+ * is either already set or we have to ignore
+ * it */
+ if (HYD_pmcd_pmip.downstream.exit_status[i] == -1)
+ HYD_pmcd_pmip.downstream.exit_status[i] = 0;
+ else
+ HYD_pmcd_pmip.downstream.exit_status[i] = ret_status;
+ else {
done++;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip.h
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip.h 2011-02-22 20:23:29 UTC (rev 8011)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip.h 2011-02-22 20:23:30 UTC (rev 8012)
@@ -54,6 +54,8 @@
int *pmi_rank;
int *pmi_fd;
int *pmi_fd_active;
+ int forced_cleanup;
} downstream;
/* Proxy details */
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c 2011-02-22 20:23:29 UTC (rev 8011)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_cb.c 2011-02-22 20:23:30 UTC (rev 8012)
@@ -253,10 +253,11 @@
status = HYDT_ftb_publish("FTB_MPI_PROCS_DEAD", ftb_event_payload);
HYDU_ERR_POP(status, "FTB publish failed\n");
- /* Store a temporary erroneous exit status. In case the
- * application does not return a non-zero exit status, we
- * will use this. */
- HYD_pmcd_pmip.downstream.exit_status[pid] = 1;
+ /* If this is not a forced cleanup, store a temporary
+ * erroneous exit status. In case the application does not
+ * return a non-zero exit status, we will use this. */
+ if (HYD_pmcd_pmip.downstream.forced_cleanup == 0)
+ HYD_pmcd_pmip.downstream.exit_status[pid] = 1;
/* Deregister failed socket */
status = HYDT_dmx_deregister_fd(fd);
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_utils.c 2011-02-22 20:23:29 UTC (rev 8011)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmip_utils.c 2011-02-22 20:23:30 UTC (rev 8012)
@@ -27,6 +27,8 @@
+ HYD_pmcd_pmip.downstream.forced_cleanup = 1;
HYDU_FUNC_EXIT();
More information about the mpich2-commits
