[mpich2-commits] r8005 - mpich2/trunk/test/mpi/manual
goodell at mcs.anl.gov
Tue Feb 22 08:24:06 CST 2011
Author: goodell
Date: 2011-02-22 08:24:05 -0600 (Tue, 22 Feb 2011)
New Revision: 8005
Added:
mpich2/trunk/test/mpi/manual/segfault.c
Modified:
mpich2/trunk/test/mpi/manual/Makefile.sm
mpich2/trunk/test/mpi/manual/README
Log:
add test/mpi/manual/segfault.c, for checking mpiexec error output
See the description in test/mpi/manual/README for more info.
Reviewed by balaji at .
Modified: mpich2/trunk/test/mpi/manual/Makefile.sm
--- mpich2/trunk/test/mpi/manual/Makefile.sm 2011-02-21 23:00:50 UTC (rev 8004)
+++ mpich2/trunk/test/mpi/manual/Makefile.sm 2011-02-22 14:24:05 UTC (rev 8005)
@@ -8,6 +8,7 @@
dimsbalanced_SOURCES = dimsbalanced.c
spawntest_master_SOURCES = spawntest_master.c
spawntest_child_SOURCES = spawntest_child.c
+segfault_SOURCES = segfault.c
testconnectserial.o: testconnectserial.c
$(C_COMPILE) -c -DMPICHLIBSTR=\"$(MPIDIR)\" $<
Modified: mpich2/trunk/test/mpi/manual/README
--- mpich2/trunk/test/mpi/manual/README 2011-02-21 23:00:50 UTC (rev 8004)
+++ mpich2/trunk/test/mpi/manual/README 2011-02-22 14:24:05 UTC (rev 8005)
@@ -27,3 +27,8 @@
works correctly, the spawned children (4 by default),
should exit roughly 30 seconds before the master.
+segfault - a simple test that intentionally segfaults if its rank is 0,
+ otherwise does nothing. The output from mpiexec should make it clear
+ that one of the processes segfaulted (not just terminated badly), and
+ ideally indicate which process. Make sure to run it with a range of
+ comm_world sizes, including 1 and 2.
Added: mpich2/trunk/test/mpi/manual/segfault.c
--- mpich2/trunk/test/mpi/manual/segfault.c (rev 0)
+++ mpich2/trunk/test/mpi/manual/segfault.c 2011-02-22 14:24:05 UTC (rev 8005)
@@ -0,0 +1,20 @@
+#include <stdlib.h>
+#include <stdio.h>
+#include "mpi.h"
+int main(int argc, char **argv)
+ int *ptr = NULL;
+ int rank;
+ MPI_Init(&argc, &argv);
+ MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+ if (rank == 0) {
+ (*ptr)++; /* will segfault */
+ /* never get below here, just present to prevent dead-code elimination */
+ printf("*ptr=%d\n", (*ptr));
+ MPI_Finalize();
+ return 0;
More information about the mpich2-commits
