[mpich2-commits] r7992 - in mpich2/trunk/test/mpi/f77: coll ext info init
gropp at mcs.anl.gov gropp at mcs.anl.gov
Sun Feb 20 17:50:10 CST 2011
Author: gropp
Date: 2011-02-20 17:50:10 -0600 (Sun, 20 Feb 2011)
New Revision: 7992
Modified:
   mpich2/trunk/test/mpi/f77/coll/reducelocalf.f
   mpich2/trunk/test/mpi/f77/ext/Makefile.sm
   mpich2/trunk/test/mpi/f77/ext/c2f2c.c
   mpich2/trunk/test/mpi/f77/info/Makefile.sm
   mpich2/trunk/test/mpi/f77/init/Makefile.sm
Log:
Fixes for the case where MPI_Fint is not the same as int, for the test suite only
Modified: mpich2/trunk/test/mpi/f77/coll/reducelocalf.f
--- mpich2/trunk/test/mpi/f77/coll/reducelocalf.f	2011-02-18 21:57:23 UTC (rev 7991)
+++ mpich2/trunk/test/mpi/f77/coll/reducelocalf.f	2011-02-20 23:50:10 UTC (rev 7992)
@@ -71,7 +71,7 @@
             vin(ii) = ii
             vout(ii) = ii
          enddo
-         call mpi_reduce_Local( vin, vout, count,
+         call mpi_reduce_local( vin, vout, count,
      &                          MPI_INTEGER, myop, ierr )
 C        Check if the result is correct
          do ii = 1, count
Modified: mpich2/trunk/test/mpi/f77/ext/Makefile.sm
--- mpich2/trunk/test/mpi/f77/ext/Makefile.sm	2011-02-18 21:57:23 UTC (rev 7991)
+++ mpich2/trunk/test/mpi/f77/ext/Makefile.sm	2011-02-20 23:50:10 UTC (rev 7992)
@@ -23,6 +23,11 @@
 # need to add this to get it to appear in ../../f90/ext/Makefile.sm
 c2f90mult_LDADD = ../../util/mtest.o
+testing:
+	../../runtests -srcdir=$(srcdir) -tests=testlist \
+			-mpiexec=$(bindir)/mpiexec \
+		   	-xmlfile=summary.xml
 ../util/mtestf.o:
 	(cd ../util && $(MAKE) mtestf.o)
Modified: mpich2/trunk/test/mpi/f77/ext/c2f2c.c
--- mpich2/trunk/test/mpi/f77/ext/c2f2c.c	2011-02-18 21:57:23 UTC (rev 7991)
+++ mpich2/trunk/test/mpi/f77/ext/c2f2c.c	2011-02-20 23:50:10 UTC (rev 7992)
@@ -83,24 +83,24 @@
 #endif
 /* Prototypes to keep compilers happy */
-int c2fcomm_( int * );
-int c2fgroup_( int * );
-int c2finfo_( int * );
-int c2frequest_( int * );
-int c2ftype_( int * );
-int c2fop_( int * );
-int c2ferrhandler_( int * );
+MPI_Fint c2fcomm_( MPI_Fint * );
+MPI_Fint c2fgroup_( MPI_Fint * );
+MPI_Fint c2finfo_( MPI_Fint * );
+MPI_Fint c2frequest_( MPI_Fint * );
+MPI_Fint c2ftype_( MPI_Fint * );
+MPI_Fint c2fop_( MPI_Fint * );
+MPI_Fint c2ferrhandler_( MPI_Fint * );
-void f2ccomm_( int * );
-void f2cgroup_( int * );
-void f2cinfo_( int * );
-void f2crequest_( int * );
-void f2ctype_( int * );
-void f2cop_( int * );
-void f2cerrhandler_( int * );
+void f2ccomm_( MPI_Fint * );
+void f2cgroup_( MPI_Fint * );
+void f2cinfo_( MPI_Fint * );
+void f2crequest_( MPI_Fint * );
+void f2ctype_( MPI_Fint * );
+void f2cop_( MPI_Fint * );
+void f2cerrhandler_( MPI_Fint * );
-int c2fcomm_ (int *comm)
+MPI_Fint c2fcomm_ (MPI_Fint *comm)
     MPI_Comm cComm = MPI_Comm_f2c(*comm);
     int cSize, wSize, cRank, wRank;
@@ -118,7 +118,7 @@
     return 0;
-int c2fgroup_ (int *group)
+MPI_Fint c2fgroup_ (MPI_Fint *group)
     MPI_Group cGroup = MPI_Group_f2c(*group);
@@ -137,7 +137,7 @@
     return 0;
-int c2ftype_ ( int *type )
+MPI_Fint c2ftype_ ( MPI_Fint *type )
     MPI_Datatype dtype = MPI_Type_f2c( *type );
@@ -148,12 +148,12 @@
     return 0;
-int c2finfo_ ( int *info )
+MPI_Fint c2finfo_ ( MPI_Fint *info )
     MPI_Info cInfo = MPI_Info_f2c( *info );
     int flag;
     char value[100];
-    int errs = 0;
+    MPI_Fint errs = 0;
     MPI_Info_get( cInfo, "host", sizeof(value), value, &flag );
     if (!flag || strcmp(value,"myname") != 0) {
@@ -169,7 +169,7 @@
     return errs;
-int c2frequest_ ( int *request )
+MPI_Fint c2frequest_ ( MPI_Fint *request )
     MPI_Request req = MPI_Request_f2c( *request );
     MPI_Status status;
@@ -186,7 +186,7 @@
     return 0;
-int c2fop_ ( int *op )
+MPI_Fint c2fop_ ( MPI_Fint *op )
     MPI_Op cOp = MPI_Op_f2c( *op );
@@ -197,7 +197,7 @@
     return 0;
-int c2ferrhandler_ ( int *errh )
+MPI_Fint c2ferrhandler_ ( MPI_Fint *errh )
     MPI_Errhandler errhand = MPI_Errhandler_f2c( *errh );
@@ -212,24 +212,24 @@
  * The following routines provide handles to the calling Fortran program
-void f2ccomm_( int * comm )
+void f2ccomm_( MPI_Fint * comm )
     *comm = MPI_Comm_c2f( MPI_COMM_WORLD );
-void f2cgroup_( int * group )
+void f2cgroup_( MPI_Fint * group )
     MPI_Group wgroup;
     MPI_Comm_group( MPI_COMM_WORLD, &wgroup );
     *group = MPI_Group_c2f( wgroup );
-void f2ctype_( int * type )
+void f2ctype_( MPI_Fint * type )
     *type = MPI_Type_c2f( MPI_INTEGER );
-void f2cinfo_( int * info )
+void f2cinfo_( MPI_Fint * info )
     MPI_Info cinfo;
@@ -240,7 +240,7 @@
     *info = MPI_Info_c2f( cinfo );
-void f2crequest_( int * req )
+void f2crequest_( MPI_Fint * req )
     MPI_Request cReq;
@@ -251,12 +251,12 @@
-void f2cop_( int * op )
+void f2cop_( MPI_Fint * op )
     *op = MPI_Op_c2f( MPI_SUM );
-void f2cerrhandler_( int *errh )
+void f2cerrhandler_( MPI_Fint *errh )
     *errh = MPI_Errhandler_c2f( MPI_ERRORS_RETURN );
Modified: mpich2/trunk/test/mpi/f77/info/Makefile.sm
--- mpich2/trunk/test/mpi/f77/info/Makefile.sm	2011-02-18 21:57:23 UTC (rev 7991)
+++ mpich2/trunk/test/mpi/f77/info/Makefile.sm	2011-02-20 23:50:10 UTC (rev 7992)
@@ -5,5 +5,10 @@
 infotestf_SOURCES = infotestf.f
 infotest2f_SOURCES = infotest2f.f
+testing:
 ../util/mtestf.o:
Modified: mpich2/trunk/test/mpi/f77/init/Makefile.sm
--- mpich2/trunk/test/mpi/f77/init/Makefile.sm	2011-02-18 21:57:23 UTC (rev 7991)
+++ mpich2/trunk/test/mpi/f77/init/Makefile.sm	2011-02-20 23:50:10 UTC (rev 7992)
@@ -10,5 +10,10 @@
 checksizes_SOURCES = checksizes.c
 checksizes_LDADD =
+testing:
 ../util/mtestf.o:
More information about the mpich2-commits mailing list
