[mpich2-commits] r7988 - in mpich2/trunk/src/pm/hydra: include ui/mpich utils/args
balaji at mcs.anl.gov
Thu Feb 17 17:54:10 CST 2011
Author: balaji
Date: 2011-02-17 17:54:10 -0600 (Thu, 17 Feb 2011)
New Revision: 7988
Modified:
mpich2/trunk/src/pm/hydra/include/hydra.h
mpich2/trunk/src/pm/hydra/ui/mpich/Makefile.mk
mpich2/trunk/src/pm/hydra/ui/mpich/utils.c
mpich2/trunk/src/pm/hydra/utils/args/args.c
Log:
Initial code to check for a default configuration file for Hydra. We
now check for sysconfdir/mpiexec.hydra.conf and ~/.mpiexec.hydra.conf
for any default mpiexec configuration to use.
Reviewed by buntinas.
Modified: mpich2/trunk/src/pm/hydra/include/hydra.h
--- mpich2/trunk/src/pm/hydra/include/hydra.h 2011-02-17 22:48:02 UTC (rev 7987)
+++ mpich2/trunk/src/pm/hydra/include/hydra.h 2011-02-17 23:54:10 UTC (rev 7988)
@@ -441,7 +441,7 @@
HYD_status HYDU_set_int_and_incr(char *arg, char ***argv, int *var);
char *HYDU_getcwd(void);
HYD_status HYDU_process_mfile_token(char *token, int newline, struct HYD_node **node_list);
-HYD_status HYDU_parse_hostfile(char *hostfile, struct HYD_node **node_list,
+HYD_status HYDU_parse_hostfile(const char *hostfile, struct HYD_node **node_list,
HYD_status(*process_token) (char *token, int newline,
struct HYD_node ** node_list));
char *HYDU_find_full_path(const char *execname);
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/Makefile.mk
--- mpich2/trunk/src/pm/hydra/ui/mpich/Makefile.mk 2011-02-17 22:48:02 UTC (rev 7987)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/Makefile.mk 2011-02-17 23:54:10 UTC (rev 7988)
@@ -4,7 +4,7 @@
# See COPYRIGHT in top-level directory.
-AM_CPPFLAGS += -I$(top_srcdir)/ui/utils
+AM_CPPFLAGS += -I$(top_srcdir)/ui/utils -DHYDRA_CONF_FILE=\"@sysconfdir@/mpiexec.hydra.conf\"
bin_PROGRAMS += mpiexec.hydra
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/utils.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/utils.c 2011-02-17 22:48:02 UTC (rev 7987)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/utils.c 2011-02-17 23:54:10 UTC (rev 7988)
@@ -437,11 +437,11 @@
printf(" launch, except ':' is replaced with a new line character\n");
-static HYD_status config_fn(char *arg, char ***argv)
+static HYD_status parse_config_file(const char *config_file)
HYD_status status = HYD_SUCCESS;
- status = HYDU_parse_hostfile(**argv, NULL, process_config_token);
+ status = HYDU_parse_hostfile(config_file, NULL, process_config_token);
HYDU_ERR_POP(status, "error parsing config file\n");
status = parse_config_argv();
@@ -454,6 +454,20 @@
goto fn_exit;
+static HYD_status config_fn(char *arg, char ***argv)
+ HYD_status status = HYD_SUCCESS;
+ status = parse_config_file(**argv);
+ HYDU_ERR_POP(status, "unable to parse config file %s\n", **argv);
+ fn_exit:
+ return status;
+ fn_fail:
+ goto fn_exit;
static void env_help_fn(void)
printf("\n");
@@ -1114,10 +1128,11 @@
HYD_status HYD_uii_mpx_get_parameters(char **t_argv)
- int i;
+ int i, ret;
char **argv = t_argv;
char *progname = *argv;
- char *post, *loc, *tmp[HYD_NUM_TMP_STRINGS];
+ char *post, *loc, *tmp[HYD_NUM_TMP_STRINGS], *conf_file;
+ const char *home;
struct HYD_exec *exec;
@@ -1157,6 +1172,29 @@
} while (++argv && *argv);
} while (1);
+ ret = MPL_env2str("HOME", &home);
+ if (ret) {
+ int len = strlen(home) + strlen("/.mpiexec.hydra.conf") + 1;
+ HYDU_MALLOC(conf_file, char *, len, status);
+ MPL_snprintf(conf_file, len, "%s/.mpiexec.hydra.conf", home);
+ ret = open(conf_file, O_RDONLY);
+ if (ret < 0) {
+ HYDU_FREE(conf_file);
+ conf_file = HYDU_strdup(HYDRA_CONF_FILE);
+ if (ret >= 0) {
+ /* We have successfully opened the file */
+ close(ret);
+ parse_config_file(conf_file);
/* Get the base path */
/* Find the last '/' in the executable name */
post = HYDU_strdup(progname);
Modified: mpich2/trunk/src/pm/hydra/utils/args/args.c
--- mpich2/trunk/src/pm/hydra/utils/args/args.c 2011-02-17 22:48:02 UTC (rev 7987)
+++ mpich2/trunk/src/pm/hydra/utils/args/args.c 2011-02-17 23:54:10 UTC (rev 7988)
@@ -310,7 +310,7 @@
goto fn_exit;
More information about the mpich2-commits
