[mpich2-commits] r7946 - mpich2/trunk
buntinas at mcs.anl.gov
Fri Feb 11 17:40:10 CST 2011
Author: buntinas
Date: 2011-02-11 17:40:10 -0600 (Fri, 11 Feb 2011)
New Revision: 7946
Modified:
mpich2/trunk/configure.in
Log:
fix bug where --disable-checkpointing didn't
Modified: mpich2/trunk/configure.in
--- mpich2/trunk/configure.in 2011-02-11 23:36:33 UTC (rev 7945)
+++ mpich2/trunk/configure.in 2011-02-11 23:40:10 UTC (rev 7946)
@@ -5895,11 +5895,11 @@
# Checkpointing
AC_ARG_ENABLE(checkpointing,
[AC_HELP_STRING([--enable-checkpointing], [Enable application checkpointing])],
+ [ if test "$enableval" != "no" ; then
PAC_SET_HEADER_LIB_PATH(blcr)
PAC_CHECK_HEADER_LIB_FATAL(blcr, libcr.h, cr, cr_init)
AC_DEFINE(ENABLE_CHECKPOINTING,1,[Application checkpointing enabled])
+ fi ],
# Update the cache first with the results of the previous configure steps
More information about the mpich2-commits
