[mpich2-commits] r7940 - in mpich2/trunk/src/pm/hydra: pm/pmiserv tools/bootstrap/include tools/bootstrap/src
balaji at mcs.anl.gov
Fri Feb 11 17:34:19 CST 2011
Author: balaji
Date: 2011-02-11 17:34:19 -0600 (Fri, 11 Feb 2011)
New Revision: 7940
Modified:
mpich2/trunk/src/pm/hydra/pm/pmiserv/common.h
mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c
mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h
mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_init.c.in
Log:
White space cleanup.
No reviewer.
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/common.h
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/common.h 2011-02-11 23:34:14 UTC (rev 7939)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/common.h 2011-02-11 23:34:19 UTC (rev 7940)
@@ -21,7 +21,7 @@
struct HYD_pmcd_pmi_kvs {
- char kvs_name[PMI_MAXKVSLEN]; /* Name of this kvs */
+ char kvs_name[PMI_MAXKVSLEN]; /* Name of this kvs */
struct HYD_pmcd_pmi_kvs_pair *key_pair;
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c 2011-02-11 23:34:14 UTC (rev 7939)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_cb.c 2011-02-11 23:34:19 UTC (rev 7940)
@@ -355,7 +355,8 @@
if (e->start == e->end)
HYDU_snprintf(run, PMI_MAXVALLEN, "%s,%d", str, e->start);
else
- HYDU_snprintf(run, PMI_MAXVALLEN, "%s,%d-%d", str, e->start, e->end);
+ HYDU_snprintf(run, PMI_MAXVALLEN, "%s,%d-%d", str, e->start,
+ e->end);
else {
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h 2011-02-11 23:34:14 UTC (rev 7939)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/include/bsci.h 2011-02-11 23:34:19 UTC (rev 7940)
@@ -27,10 +27,10 @@
const char *launcher_exec;
/** \brief Enable/disable X-forwarding */
- int enablex;
+ int enablex;
/** \brief Enable/disable debugging */
- int debug;
+ int debug;
@@ -43,7 +43,7 @@
HYD_status(*query_native_int) (int *ret);
/** \brief Query for node list information */
- HYD_status(*query_node_list) (struct HYD_node **node_list);
+ HYD_status(*query_node_list) (struct HYD_node ** node_list);
/** \brief Query for job ID information */
HYD_status(*query_jobid) (char **jobid);
@@ -54,7 +54,7 @@
/* Launcher functions */
/** \brief Launch processes */
- HYD_status(*launch_procs) (char **args, struct HYD_node *node_list, int *control_fd);
+ HYD_status(*launch_procs) (char **args, struct HYD_node * node_list, int *control_fd);
/** \brief Finalize the bootstrap control device */
HYD_status(*launcher_finalize) (void);
@@ -89,8 +89,7 @@
* pointers in this function to be used by later BSCI calls.
HYD_status HYDT_bsci_init(const char *rmk, const char *launcher,
- const char *launcher_exec, int enablex,
- int debug);
+ const char *launcher_exec, int enablex, int debug);
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_init.c.in
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_init.c.in 2011-02-11 23:34:14 UTC (rev 7939)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_init.c.in 2011-02-11 23:34:19 UTC (rev 7940)
@@ -11,10 +11,12 @@
struct HYDT_bsci_fns HYDT_bsci_fns = { 0 };
struct HYDT_bsci_info HYDT_bsci_info = { 0 };
+/* *INDENT-OFF* */
static const char *launcher_array[] = { @hydra_launcher_array@ };
static const char *rmk_array[] = { @hydra_rmk_array@ };
static HYD_status(*launcher_init_array[])(void) = { @hydra_launcher_init_array@ };
static HYD_status(*rmk_init_array[])(void) = { @hydra_rmk_init_array@ };
+/* *INDENT-ON* */
static void init_rmk_fns(void)
@@ -53,7 +55,7 @@
HYDT_bsci_info.rmk = HYDU_strdup(rmk_array[i]);
HYDT_bsci_info.debug = debug;
- status = (*rmk_init_array[i])();
+ status = (*rmk_init_array[i]) ();
HYDU_ERR_POP(status, "bootstrap device returned error initializing\n");
status = HYDT_bsci_query_native_int(&ret);
@@ -136,7 +138,7 @@
/* Initialize the RMK */
for (i = 0; rmk_array[i]; i++) {
if (!strcmp(HYDT_bsci_info.rmk, rmk_array[i])) {
HYDU_ERR_POP(status, "RMK init returned error\n");
break;
@@ -166,7 +168,7 @@
/* Make sure the launcher we found is valid */
for (i = 0; launcher_array[i]; i++) {
if (!strcmp(HYDT_bsci_info.launcher, launcher_array[i])) {
- status = (*launcher_init_array[i])();
+ status = (*launcher_init_array[i]) ();
HYDU_ERR_POP(status, "launcher init returned error\n");
break;
More information about the mpich2-commits
