[mpich2-commits] r7926 - in mpich2/trunk/src/mpi/romio: adio/ad_lustre adio/ad_nfs adio/common adio/include mpi-io
robl at mcs.anl.gov robl at mcs.anl.gov
Thu Feb 10 14:34:53 CST 2011
Author: robl
Date: 2011-02-10 14:34:52 -0600 (Thu, 10 Feb 2011)
New Revision: 7926
Modified:
   mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrstr.c
   mpich2/trunk/src/mpi/romio/adio/ad_nfs/ad_nfs_read.c
   mpich2/trunk/src/mpi/romio/adio/ad_nfs/ad_nfs_write.c
   mpich2/trunk/src/mpi/romio/adio/common/ad_read_str.c
   mpich2/trunk/src/mpi/romio/adio/common/ad_write_str.c
   mpich2/trunk/src/mpi/romio/adio/include/adioi.h
   mpich2/trunk/src/mpi/romio/mpi-io/iwrite_sh.c
   mpich2/trunk/src/mpi/romio/mpi-io/read_sh.c
   mpich2/trunk/src/mpi/romio/mpi-io/write_sh.c
Log:
partial revert and redo of r7923: as daveg point's out better approach to fix
the macro instead of the N places macro gets used..
Modified: mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrstr.c
--- mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrstr.c	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/adio/ad_lustre/ad_lustre_wrstr.c	2011-02-10 20:34:52 UTC (rev 7926)
@@ -18,9 +18,8 @@
            ADIO_WriteContig(fd, writebuf, writebuf_len, MPI_BYTE, \
                              ADIO_EXPLICIT_OFFSET, writebuf_off,        \
                              &status1, error_code);                     \
-           if (!(fd->atomicity)) {						  \
+           if (!(fd->atomicity)) \
                 ADIOI_UNLOCK(fd, writebuf_off, SEEK_SET, writebuf_len); \
            if (*error_code != MPI_SUCCESS) { \
                *error_code = MPIO_Err_create_code(*error_code, \
                                                    MPIR_ERR_RECOVERABLE, \
@@ -36,9 +35,8 @@
         writebuf_len = (unsigned) ADIOI_MIN(end_offset - writebuf_off + 1, \
                                        (writebuf_off / stripe_size + 1) * \
                                             stripe_size - writebuf_off); \
             ADIOI_WRITE_LOCK(fd, writebuf_off, SEEK_SET, writebuf_len); \
         ADIO_ReadContig(fd, writebuf, writebuf_len, MPI_BYTE,           \
                         ADIO_EXPLICIT_OFFSET,                           \
                         writebuf_off, &status1, error_code); \
@@ -60,9 +58,8 @@
     while (write_sz != req_len) {                                       \
                          ADIO_EXPLICIT_OFFSET, writebuf_off, &status1, error_code); \
                                                MPIR_ERR_RECOVERABLE, myname, \
@@ -78,9 +75,8 @@
@@ -226,9 +222,8 @@
         writebuf_len = 0;
         /* if atomicity is true, lock the region to be accessed */
-	if (fd->atomicity) {
+	if (fd->atomicity)
 	    ADIOI_WRITE_LOCK(fd, start_off, SEEK_SET, bufsize);
 	for (j = 0; j < count; j++) {
 	    for (i = 0; i < flat_buf->count; i++) {
@@ -246,9 +241,8 @@
 			 error_code);
 	    ADIOI_UNLOCK(fd, start_off, SEEK_SET, bufsize);
             ADIOI_Free(writebuf);
 	    return;
@@ -385,9 +379,8 @@
             ADIOI_WRITE_LOCK(fd, start_off, SEEK_SET, end_offset-start_off+1);
 	    writebuf_off = 0;
 	    writebuf_len = 0;
@@ -512,14 +505,12 @@
             if (*error_code != MPI_SUCCESS) return;
             ADIOI_UNLOCK(fd, start_off, SEEK_SET, end_offset-start_off+1);
Modified: mpich2/trunk/src/mpi/romio/adio/ad_nfs/ad_nfs_read.c
--- mpich2/trunk/src/mpi/romio/adio/ad_nfs/ad_nfs_read.c	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/adio/ad_nfs/ad_nfs_read.c	2011-02-10 20:34:52 UTC (rev 7926)
@@ -28,9 +28,9 @@
             MPE_Log_event( ADIOI_MPE_lseek_b, 0, NULL );
 #endif
 	    ADIOI_WRITE_LOCK(fd, offset, SEEK_SET, len);
-	} else ADIOI_READ_LOCK(fd, offset, SEEK_SET, len);
+	else ADIOI_READ_LOCK(fd, offset, SEEK_SET, len);
 #ifdef ADIOI_MPE_LOGGING
         MPE_Log_event( ADIOI_MPE_read_a, 0, NULL );
 #endif
@@ -53,9 +53,9 @@
 #endif
 #endif
@@ -132,9 +132,9 @@
 	readbuf_off = req_off; \
 	readbuf_len = (int) (ADIOI_MIN(max_bufsize, end_offset-readbuf_off+1));\
 	lseek(fd->fd_sys, readbuf_off, SEEK_SET);\
-	 if (!(fd->atomicity)) {ADIOI_READ_LOCK(fd, readbuf_off, SEEK_SET, readbuf_len);} \
+        if (!(fd->atomicity)) ADIOI_READ_LOCK(fd, readbuf_off, SEEK_SET, readbuf_len);\
         err = read(fd->fd_sys, readbuf, readbuf_len);\
-        if (!(fd->atomicity)) {ADIOI_UNLOCK(fd, readbuf_off, SEEK_SET, readbuf_len);} \
+        if (!(fd->atomicity)) ADIOI_UNLOCK(fd, readbuf_off, SEEK_SET, readbuf_len);\
         if (err == -1) err_flag = 1; \
     while (req_len > readbuf_off + readbuf_len - req_off) { \
@@ -149,9 +149,9 @@
 	readbuf_len = (int) (partial_read + ADIOI_MIN(max_bufsize, \
 				       end_offset-readbuf_off+1)); \
 	lseek(fd->fd_sys, readbuf_off+partial_read, SEEK_SET);\
-	 if (!(fd->atomicity)) {ADIOI_READ_LOCK(fd, readbuf_off+partial_read, SEEK_SET, readbuf_len-partial_read);} \
+        if (!(fd->atomicity)) ADIOI_READ_LOCK(fd, readbuf_off+partial_read, SEEK_SET, readbuf_len-partial_read);\
         err = read(fd->fd_sys, readbuf+partial_read, readbuf_len-partial_read);\
-        if (!(fd->atomicity)) {ADIOI_UNLOCK(fd, readbuf_off+partial_read, SEEK_SET, readbuf_len-partial_read);}	\
+        if (!(fd->atomicity)) ADIOI_UNLOCK(fd, readbuf_off+partial_read, SEEK_SET, readbuf_len-partial_read);\
     memcpy((char *)buf + userbuf_off, readbuf+req_off-readbuf_off, req_len); \
@@ -224,9 +224,8 @@
 /* if atomicity is true, lock (exclusive) the region to be accessed */
         MPE_Log_event( ADIOI_MPE_lseek_a, 0, NULL );
@@ -235,7 +234,7 @@
 #endif
 #endif
@@ -243,7 +242,7 @@
         MPE_Log_event( ADIOI_MPE_read_b, 0, NULL );
 #endif
         for (j=0; j<count; j++)
@@ -255,9 +254,8 @@
                 off += flat_buf->blocklens[i];
         if (file_ptr_type == ADIO_INDIVIDUAL) fd->fp_ind = off;
@@ -385,9 +383,8 @@
         /* initial read into readbuf */
 	readbuf_off = offset;
@@ -401,7 +398,7 @@
 #endif
-        if (!(fd->atomicity)) {ADIOI_READ_LOCK(fd, offset, SEEK_SET, readbuf_len);}
+        if (!(fd->atomicity)) ADIOI_READ_LOCK(fd, offset, SEEK_SET, readbuf_len);
 #endif
@@ -409,7 +406,7 @@
 #endif
-        if (!(fd->atomicity)) {ADIOI_UNLOCK(fd, offset, SEEK_SET, readbuf_len);}
+        if (!(fd->atomicity)) ADIOI_UNLOCK(fd, offset, SEEK_SET, readbuf_len);
@@ -522,9 +519,8 @@
Modified: mpich2/trunk/src/mpi/romio/adio/ad_nfs/ad_nfs_write.c
--- mpich2/trunk/src/mpi/romio/adio/ad_nfs/ad_nfs_write.c	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/adio/ad_nfs/ad_nfs_write.c	2011-02-10 20:34:52 UTC (rev 7926)
@@ -152,11 +152,11 @@
     if (req_off >= writebuf_off + writebuf_len) { \
 	lseek(fd->fd_sys, writebuf_off, SEEK_SET); \
 	err = write(fd->fd_sys, writebuf, writebuf_len); \
-	 if (!(fd->atomicity)) {ADIOI_UNLOCK(fd, writebuf_off, SEEK_SET, writebuf_len);} \
+        if (!(fd->atomicity)) ADIOI_UNLOCK(fd, writebuf_off, SEEK_SET, writebuf_len); \
 	writebuf_off = req_off; \
         writebuf_len = (int) (ADIOI_MIN(max_bufsize,end_offset-writebuf_off+1));\
-	if (!(fd->atomicity)) {ADIOI_WRITE_LOCK(fd, writebuf_off, SEEK_SET, writebuf_len);} \
+	if (!(fd->atomicity)) ADIOI_WRITE_LOCK(fd, writebuf_off, SEEK_SET, writebuf_len); \
 	err = read(fd->fd_sys, writebuf, writebuf_len); \
         if (err == -1) { \
@@ -172,13 +172,13 @@
         req_len -= write_sz; \
         userbuf_off += write_sz; \
         writebuf_off += writebuf_len; \
         if (err == -1) { \
@@ -203,11 +203,11 @@
         MPE_Log_event( ADIOI_MPE_lseek_a, 0, NULL ); \
         MPE_Log_event( ADIOI_MPE_lseek_b, 0, NULL ); \
         MPE_Log_event( ADIOI_MPE_write_a, 0, NULL ); \
         MPE_Log_event( ADIOI_MPE_write_b, 0, NULL ); \
@@ -218,11 +218,11 @@
@@ -237,9 +237,9 @@
@@ -248,9 +248,9 @@
     memcpy(writebuf+req_off-writebuf_off, (char *)buf +userbuf_off, write_sz);\
@@ -327,9 +327,8 @@
             for (i=0; i<flat_buf->count; i++) {
@@ -348,7 +347,7 @@
 #endif
 #endif
@@ -356,12 +355,11 @@
 #endif
 	ADIOI_Free(writebuf); /* malloced in the buffered_write macro */
@@ -488,15 +486,14 @@
         /* initial read for the read-modify-write */
         writebuf_off = offset;
         writebuf = (char *) ADIOI_Malloc(max_bufsize);
         writebuf_len = (int)(ADIOI_MIN(max_bufsize,end_offset-writebuf_off+1));
 #endif
@@ -638,7 +635,7 @@
 #endif
 #endif
Modified: mpich2/trunk/src/mpi/romio/adio/common/ad_read_str.c
--- mpich2/trunk/src/mpi/romio/adio/common/ad_read_str.c	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/adio/common/ad_read_str.c	2011-02-10 20:34:52 UTC (rev 7926)
@@ -126,9 +126,8 @@
         readbuf_len = (unsigned) (ADIOI_MIN(max_bufsize, end_offset-readbuf_off+1));
-        if ((fd->atomicity) && ADIO_Feature(fd, ADIO_LOCKS)) {
+        if ((fd->atomicity) && ADIO_Feature(fd, ADIO_LOCKS))
         ADIO_ReadContig(fd, readbuf, readbuf_len, MPI_BYTE,
             ADIO_EXPLICIT_OFFSET, readbuf_off, &status1, error_code);
@@ -145,9 +144,8 @@
@@ -267,9 +265,8 @@
 	readbuf_off = 0;
 	readbuf_len = 0;
@@ -385,9 +382,8 @@
Modified: mpich2/trunk/src/mpi/romio/adio/common/ad_write_str.c
--- mpich2/trunk/src/mpi/romio/adio/common/ad_write_str.c	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/adio/common/ad_write_str.c	2011-02-10 20:34:52 UTC (rev 7926)
@@ -14,7 +14,7 @@
         if (writebuf_len) { \
@@ -25,7 +25,7 @@
         writebuf_len = (unsigned) (ADIOI_MIN(max_bufsize,end_offset-writebuf_off+1));\
@@ -42,7 +42,7 @@
@@ -54,7 +54,7 @@
@@ -191,9 +191,8 @@
         writebuf_len = (unsigned) (ADIOI_MIN(max_bufsize, end_offset-writebuf_off+1));
@@ -210,9 +209,8 @@
         ADIO_WriteContig(fd, writebuf, writebuf_len, MPI_BYTE, ADIO_EXPLICIT_OFFSET,
@@ -336,9 +334,8 @@
         writebuf_off = 0;
         writebuf_len = 0;
@@ -460,14 +457,12 @@
 	if (writebuf_len) {
Modified: mpich2/trunk/src/mpi/romio/adio/include/adioi.h
--- mpich2/trunk/src/mpi/romio/adio/include/adioi.h	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/adio/include/adioi.h	2011-02-10 20:34:52 UTC (rev 7926)
@@ -664,19 +664,19 @@
 #if (defined(ROMIO_HFS) || defined(ROMIO_XFS))
 # define ADIOI_WRITE_LOCK(fd, offset, whence, len) \
-   if (((fd)->file_system == ADIO_XFS) || ((fd)->file_system == ADIO_HFS)) \
+   do {if (((fd)->file_system == ADIO_XFS) || ((fd)->file_system == ADIO_HFS)) \
      ADIOI_Set_lock64((fd)->fd_sys, F_SETLKW64, F_WRLCK, offset, whence, len);\
-   else ADIOI_Set_lock((fd)->fd_sys, F_SETLKW, F_WRLCK, offset, whence, len)
+   else ADIOI_Set_lock((fd)->fd_sys, F_SETLKW, F_WRLCK, offset, whence, len) } while (0)
 # define ADIOI_READ_LOCK(fd, offset, whence, len) \
      ADIOI_Set_lock64((fd)->fd_sys, F_SETLKW64, F_RDLCK, offset, whence, len);\
-   else ADIOI_Set_lock((fd)->fd_sys, F_SETLKW, F_RDLCK, offset, whence, len)
+   else ADIOI_Set_lock((fd)->fd_sys, F_SETLKW, F_RDLCK, offset, whence, len) while (0)
 # define ADIOI_UNLOCK(fd, offset, whence, len) \
      ADIOI_Set_lock64((fd)->fd_sys, F_SETLK64, F_UNLCK, offset, whence, len); \
-   else ADIOI_Set_lock((fd)->fd_sys, F_SETLK, F_UNLCK, offset, whence, len)
+   else ADIOI_Set_lock((fd)->fd_sys, F_SETLK, F_UNLCK, offset, whence, len) while (0)
 #elif (defined(ROMIO_NTFS))
Modified: mpich2/trunk/src/mpi/romio/mpi-io/iwrite_sh.c
--- mpich2/trunk/src/mpi/romio/mpi-io/iwrite_sh.c	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/mpi-io/iwrite_sh.c	2011-02-10 20:34:52 UTC (rev 7926)
@@ -93,16 +93,14 @@
             /* to maintain strict atomicity semantics with other concurrent
               operations, lock (exclusive) and call blocking routine */
-		if (fh->file_system != ADIO_NFS) {
+            if (fh->file_system != ADIO_NFS)
                 ADIOI_WRITE_LOCK(fh, off, SEEK_SET, bufsize);
             ADIO_WriteContig(fh, buf, count, datatype, ADIO_EXPLICIT_OFFSET,
 			     off, &status, &error_code);
                 ADIOI_UNLOCK(fh, off, SEEK_SET, bufsize);
 	    MPIO_Completed_request_create(&fh, bufsize, &error_code, request);
Modified: mpich2/trunk/src/mpi/romio/mpi-io/read_sh.c
--- mpich2/trunk/src/mpi/romio/mpi-io/read_sh.c	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/mpi-io/read_sh.c	2011-02-10 20:34:52 UTC (rev 7926)
@@ -106,16 +106,14 @@
            could be a concurrent noncontiguous request. On NFS, locking
            is done in the ADIO_ReadContig.*/
-        if ((fh->atomicity) && (fh->file_system != ADIO_NFS)) {
+        if ((fh->atomicity) && (fh->file_system != ADIO_NFS))
         ADIO_ReadContig(fh, buf, count, datatype, ADIO_EXPLICIT_OFFSET,
                         off, status, &error_code);
     else
Modified: mpich2/trunk/src/mpi/romio/mpi-io/write_sh.c
--- mpich2/trunk/src/mpi/romio/mpi-io/write_sh.c	2011-02-10 20:30:04 UTC (rev 7925)
+++ mpich2/trunk/src/mpi/romio/mpi-io/write_sh.c	2011-02-10 20:34:52 UTC (rev 7926)
            could be a concurrent noncontiguous request. On NFS, locking is
            done in the ADIO_WriteContig.*/
     else
More information about the mpich2-commits mailing list
