[mpich2-commits] r7919 - mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad
mercierg at mcs.anl.gov mercierg at mcs.anl.gov
Tue Feb 8 10:26:27 CST 2011
Author: mercierg
Date: 2011-02-08 10:26:26 -0600 (Tue, 08 Feb 2011)
New Revision: 7919
Modified:
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h
   mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_probe.c
Log:
Fix for probe with any_source
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h	2011-02-05 01:19:00 UTC (rev 7918)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h	2011-02-08 16:26:26 UTC (rev 7919)
@@ -151,12 +151,12 @@
     ((_match) |= (((nm_tag_t)((_tag)&(NEM_NMAD_MAX_TAG))) << SHIFT_TAG)); \
     }while(0)
 #define NEM_NMAD_SET_SRC(_match, _src) do {               \
-    MPIU_Assert(_src >= 0)&&(_src<=(NEM_NMAD_MAX_RANK))); \
+    MPIU_Assert((_src >= 0)&&(_src<=(NEM_NMAD_MAX_RANK)));\
     ((_match) |= (((nm_tag_t)(_src)) << SHIFT_RANK));     \
     }while(0)
-#define NEM_NMAD_SET_CTXT(_match, _ctxt) do {              \
-    MPIU_Assert(_ctxt >= 0)&&(_ctxt<=(NEM_NMAD_MAX_CTXT)));\
-    ((_match) |= (((nm_tag_t)(_ctxt)) << SHIFT_CTXT));	   \
+#define NEM_NMAD_SET_CTXT(_match, _ctxt) do {               \
+    MPIU_Assert((_ctxt >= 0)&&(_ctxt<=(NEM_NMAD_MAX_CTXT)));\
+    ((_match) |= (((nm_tag_t)(_ctxt)) << SHIFT_CTXT));	    \
     }while(0)
 #define NEM_NMAD_SET_PGRANK(_match, _pg_rank)  do {        \
     ((_match) |= (((nm_tag_t)(_pg_rank)) << SHIFT_PGRANK));\
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_probe.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_probe.c	2011-02-05 01:19:00 UTC (rev 7918)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_probe.c	2011-02-08 16:26:26 UTC (rev 7919)
@@ -20,7 +20,15 @@
     int mpi_errno = MPI_SUCCESS;
     int ret;
-    NEM_NMAD_DIRECT_MATCH(match_info,0,source,comm->context_id + context_offset);
+    NEM_NMAD_SET_CTXT(match_info,comm->context_id + context_offset);
+    if( source  == MPI_ANY_SOURCE)
+       NEM_NMAD_SET_ANYSRC(match_info);
+       NEM_NMAD_SET_ANYSRC(match_mask);
+   else
+     NEM_NMAD_SET_SRC(match_info,source);
     if (tag != MPI_ANY_TAG)
         NEM_NMAD_SET_TAG(match_info,tag);
@@ -60,7 +68,15 @@
     int ret;
+   else
More information about the mpich2-commits mailing list
