[mpich2-commits] r7915 - in mpich2/trunk/src: include mpi/comm
goodell at mcs.anl.gov
Fri Feb 4 16:55:46 CST 2011
Author: goodell
Date: 2011-02-04 16:55:46 -0600 (Fri, 04 Feb 2011)
New Revision: 7915
Modified:
mpich2/trunk/src/include/mpiimpl.h
mpich2/trunk/src/mpi/comm/commutil.c
Log:
performance: inline MPIR_Comm_release based on feedback from IBM
This change improves message rate by >5% for some benchmarks.
Reviewed by buntinas at .
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h 2011-02-04 22:55:44 UTC (rev 7914)
+++ mpich2/trunk/src/include/mpiimpl.h 2011-02-04 22:55:46 UTC (rev 7915)
@@ -1177,19 +1177,52 @@
} MPID_Comm;
extern MPIU_Object_alloc_t MPID_Comm_mem;
-/* MPIR_Comm_release is a helper routine that releases references to a comm.
- The second arg is false unless this is called as part of
- MPI_Comm_disconnect .
-int MPIR_Comm_release(MPID_Comm *, int );
-int MPIR_Comm_release_always(MPID_Comm *comm_ptr, int isDisconnect);
+/* this function should not be called by normal code! */
+int MPIR_Comm_delete_internal(MPID_Comm * comm_ptr, int isDisconnect);
#define MPIR_Comm_add_ref(_comm) \
do { MPIU_Object_add_ref((_comm)); } while (0)
#define MPIR_Comm_release_ref( _comm, _inuse ) \
do { MPIU_Object_release_ref( _comm, _inuse ); } while (0)
+/* Release a reference to a communicator. If there are no pending
+ references, delete the communicator and recover all storage and
+ context ids.
+ This routine has been inlined because keeping it as a separate routine
+ results in a >5% performance hit for the SQMR benchmark.
+#undef FUNCNAME
+#define FUNCNAME MPIR_Comm_release
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+static inline int MPIR_Comm_release(MPID_Comm * comm_ptr, int isDisconnect)
+ int mpi_errno = MPI_SUCCESS;
+ int in_use;
+ MPIR_Comm_release_ref(comm_ptr, &in_use);
+ if (unlikely(!in_use)) {
+ /* the following routine should only be called by this function and its
+ * "_always" variant. */
+ mpi_errno = MPIR_Comm_delete_internal(comm_ptr, isDisconnect);
+ /* not ERR_POPing here to permit simpler inlining. Our caller will
+ * still report the error from the comm_delete level. */
+ fn_exit:
+ return mpi_errno;
+#undef FUNCNAME
+#undef FCNAME
+/* MPIR_Comm_release_always is the same as MPIR_Comm_release except it uses
+ MPIR_Comm_release_ref_always instead.
+int MPIR_Comm_release_always(MPID_Comm *comm_ptr, int isDisconnect);
/* Preallocated comm objects. There are 3: comm_world, comm_self, and
a private (non-user accessible) dup of comm world that is provided
if needed in MPI_Finalize. Having a separate version of comm_world
Modified: mpich2/trunk/src/mpi/comm/commutil.c
--- mpich2/trunk/src/mpi/comm/commutil.c 2011-02-04 22:55:44 UTC (rev 7914)
+++ mpich2/trunk/src/mpi/comm/commutil.c 2011-02-04 22:55:46 UTC (rev 7915)
@@ -1225,18 +1225,21 @@
* helper function frees the actual MPID_Comm structure and any associated
* storage. It also releases any refernces to other objects, such as the VCRT.
* This function should only be called when the communicator's reference count
- * has dropped to 0. */
+ * has dropped to 0.
+ * !!! This routine should *never* be called outside of MPIR_Comm_release{,_always} !!!
#undef FUNCNAME
-#define FUNCNAME comm_delete
+#define FUNCNAME MPIR_Comm_delete_internal
#undef FCNAME
-static int comm_delete(MPID_Comm * comm_ptr, int isDisconnect)
int in_use;
- MPID_MPI_STATE_DECL(MPID_STATE_COMM_DELETE);
+ MPID_MPI_STATE_DECL(MPID_STATE_COMM_DELETE_INTERNAL);
- MPID_MPI_FUNC_ENTER(MPID_STATE_COMM_DELETE);
+ MPID_MPI_FUNC_ENTER(MPID_STATE_COMM_DELETE_INTERNAL);
MPIU_Assert(MPIU_Object_get_ref(comm_ptr) == 0); /* sanity check */
@@ -1347,41 +1350,13 @@
fn_exit:
- MPID_MPI_FUNC_EXIT(MPID_STATE_COMM_DELETE);
+ MPID_MPI_FUNC_EXIT(MPID_STATE_COMM_DELETE_INTERNAL);
return mpi_errno;
fn_fail:
goto fn_exit;
- references, delete the communicator and recover all storage and
- context ids */
-#undef FUNCNAME
-#define FUNCNAME MPIR_Comm_release
-#undef FCNAME
-#define FCNAME "MPIR_Comm_release"
-int MPIR_Comm_release(MPID_Comm * comm_ptr, int isDisconnect)
- int mpi_errno = MPI_SUCCESS;
- int in_use;
- MPID_MPI_STATE_DECL(MPID_STATE_MPIR_COMM_RELEASE);
- MPID_MPI_FUNC_ENTER(MPID_STATE_MPIR_COMM_RELEASE);
- MPIR_Comm_release_ref(comm_ptr, &in_use);
- if (!in_use) {
- mpi_errno = comm_delete(comm_ptr, isDisconnect);
- if (mpi_errno) MPIU_ERR_POP(mpi_errno);
- fn_exit:
- MPID_MPI_FUNC_EXIT(MPID_STATE_MPIR_COMM_RELEASE);
- return mpi_errno;
- fn_fail:
- goto fn_exit;
-/* Release a reference to a communicator. If there are no pending
context ids. This version of the function always manipulates the reference
counts, even for predefined objects. */
@@ -1401,7 +1376,7 @@
* predefined communicators, such as MPI_COMM_WORLD or MPI_COMM_SELF. */
MPIU_Object_release_ref_always(comm_ptr, &in_use);
if (!in_use) {
More information about the mpich2-commits
