[mpich2-commits] r7910 - mpich2/trunk/src/mpi/attr
gropp at mcs.anl.gov
Fri Feb 4 09:51:03 CST 2011
Author: gropp
Date: 2011-02-04 09:51:03 -0600 (Fri, 04 Feb 2011)
New Revision: 7910
Modified:
mpich2/trunk/src/mpi/attr/attrutil.c
mpich2/trunk/src/mpi/attr/comm_get_attr.c
Log:
Fix for incorrect handling of Fortran predefined attribute values on bigendian/64 bit systems, see ticket #1158
Modified: mpich2/trunk/src/mpi/attr/attrutil.c
--- mpich2/trunk/src/mpi/attr/attrutil.c 2011-02-04 15:47:09 UTC (rev 7909)
+++ mpich2/trunk/src/mpi/attr/attrutil.c 2011-02-04 15:51:03 UTC (rev 7910)
@@ -352,7 +352,7 @@
return ret;
+/* FIXME: Missing routine description */
void
MPIR_Keyval_set_proxy(
int keyval,
Modified: mpich2/trunk/src/mpi/attr/comm_get_attr.c
--- mpich2/trunk/src/mpi/attr/comm_get_attr.c 2011-02-04 15:47:09 UTC (rev 7909)
+++ mpich2/trunk/src/mpi/attr/comm_get_attr.c 2011-02-04 15:51:03 UTC (rev 7910)
@@ -194,11 +194,16 @@
it here. */
if (*flag) {
/* Use the internal pointer-sized-int for systems (e.g., BG/P)
- * that define MPI_Aint as a different size that MPIR_Pint */
+ that define MPI_Aint as a different size than MPIR_Pint.
+ The casts must be as they are:
+ On the right, the value is a pointer to an int, so to
+ get the correct value, we need to extract the int.
+ On the left, the output type is given by the argument
+ outAttrType - and the cast must match the intended results */
if (outAttrType == MPIR_ATTR_AINT)
- *(MPIR_Pint*)attr_val_p = *(MPIR_Pint*)*(void **)attr_val_p;
+ *(MPIR_Pint*)attr_val_p = *(int*)*(void **)attr_val_p;
else if (outAttrType == MPIR_ATTR_INT)
- *(MPIR_Pint*)attr_val_p = *(int *)*(void **)attr_val_p;
+ *(int*)attr_val_p = *(int *)*(void **)attr_val_p;
else {
More information about the mpich2-commits
