[mpich2-commits] r7906 - in mpich2/trunk/test/mpi: f77/attr f77/pt2pt f77/spawn f90/pt2pt
gropp at mcs.anl.gov
Fri Feb 4 07:44:51 CST 2011
Author: gropp
Date: 2011-02-04 07:44:51 -0600 (Fri, 04 Feb 2011)
New Revision: 7906
Added:
mpich2/trunk/test/mpi/f77/pt2pt/dummyf.f
Modified:
mpich2/trunk/test/mpi/f77/attr/
mpich2/trunk/test/mpi/f77/pt2pt/Makefile.sm
mpich2/trunk/test/mpi/f77/pt2pt/greqf.f
mpich2/trunk/test/mpi/f77/spawn/
mpich2/trunk/test/mpi/f90/pt2pt/
Log:
Added dummy routine call to suppress compiler optimization of extrastate in Fortran greq test, fixes #1162
Property changes on: mpich2/trunk/test/mpi/f77/attr
___________________________________________________________________
Modified: svn:ignore
- Makefile.in
Makefile
*.o
baseattr
attraints.h
*ebug*
*elease*
*.vfproj
*.gcda
*.gcno
+ Makefile.in
Makefile
*.o
baseattr
attraints.h
*ebug*
*elease*
*.vfproj
*.gcda
*.gcno
summary.xml
Modified: mpich2/trunk/test/mpi/f77/pt2pt/Makefile.sm
--- mpich2/trunk/test/mpi/f77/pt2pt/Makefile.sm 2011-02-04 00:05:28 UTC (rev 7905)
+++ mpich2/trunk/test/mpi/f77/pt2pt/Makefile.sm 2011-02-04 13:44:51 UTC (rev 7906)
@@ -4,7 +4,7 @@
smvar_do_sharedlibs = 0
statusesf_SOURCES = statusesf.f
-greqf_SOURCES = greqf.f
+greqf_SOURCES = greqf.f dummyf.f
testing:
../../runtests -srcdir=$(srcdir) -tests=testlist \
Added: mpich2/trunk/test/mpi/f77/pt2pt/dummyf.f
--- mpich2/trunk/test/mpi/f77/pt2pt/dummyf.f (rev 0)
+++ mpich2/trunk/test/mpi/f77/pt2pt/dummyf.f 2011-02-04 13:44:51 UTC (rev 7906)
@@ -0,0 +1,18 @@
+C -*- Mode: Fortran; -*-
+C
+C (C) 2010 by Argonne National Laboratory.
+C See COPYRIGHT in top-level directory.
+C
+C
+C This file is used to disable certain compiler optimizations that
+C can cause incorrect results with the test in greqf.f. It provides a
+C point where extrastate may be modified, limiting the compilers ability
+C to move code around.
+C The include of mpif.h is not needed in the F77 case but in the
+C F90 case it is, because in that case, extrastate is defined as an
+C integer (kind=MPI_ADDRESS_KIND), and the script that creates the
+C F90 tests from the F77 tests looks for mpif.h
+ subroutine dummyupdate( extrastate )
+ include 'mpif.h'
+ include 'attr1aints.h'
+ end
Modified: mpich2/trunk/test/mpi/f77/pt2pt/greqf.f
--- mpich2/trunk/test/mpi/f77/pt2pt/greqf.f 2011-02-04 00:05:28 UTC (rev 7905)
+++ mpich2/trunk/test/mpi/f77/pt2pt/greqf.f 2011-02-04 13:44:51 UTC (rev 7906)
@@ -92,6 +92,9 @@
call mpi_grequest_complete( request, ierr )
call mpi_wait( request, MPI_STATUS_IGNORE, ierr )
C
+C The following routine may prevent an optimizing compiler from
+C just remembering that extrastate was set in grequest_start
+ call dummyupdate(extrastate)
if (extrastate .ne. 0) then
errs = errs + 1
if (freefncall .eq. 0) then
@@ -105,3 +108,4 @@
call MTest_Finalize( errs )
call mpi_finalize( ierr )
end
+C
Property changes on: mpich2/trunk/test/mpi/f77/spawn
- Makefile.in
Makefile
*.o
*ebug*
*elease*
*.vfproj
*.gcda
*.gcno
type1aint.h
connaccf
namepubf
spawnargvf
spawnmultf
spawnf
spawnmult2f
+ Makefile.in
Makefile
*.o
*ebug*
*elease*
*.vfproj
*.gcda
*.gcno
type1aint.h
connaccf
namepubf
spawnargvf
spawnmultf
spawnf
spawnmult2f
summary.xml
Property changes on: mpich2/trunk/test/mpi/f90/pt2pt
- Makefile.sm
Makefile
Makefile.in
testlist
statusesf90.f90
greqf90.f90
greqf90
statusesf90
*.gcda
*.gcno
+ Makefile.sm
Makefile
Makefile.in
testlist
statusesf90.f90
greqf90.f90
greqf90
dummyf90.f90
statusesf90
*.gcda
*.gcno
More information about the mpich2-commits
