[mpich2-commits] r7897 - mpich2/trunk/src/binding/cxx
gropp at mcs.anl.gov gropp at mcs.anl.gov
Thu Feb 3 15:32:18 CST 2011
Author: gropp
Date: 2011-02-03 15:32:18 -0600 (Thu, 03 Feb 2011)
New Revision: 7897
Modified:
   mpich2/trunk/src/binding/cxx/buildiface
Log:
Use __attribute__((unused)) if GNU compiler to suppress argument unused messages (true but irrelevant)
Modified: mpich2/trunk/src/binding/cxx/buildiface
--- mpich2/trunk/src/binding/cxx/buildiface	2011-02-03 21:23:53 UTC (rev 7896)
+++ mpich2/trunk/src/binding/cxx/buildiface	2011-02-03 21:32:18 UTC (rev 7897)
@@ -1367,6 +1367,22 @@
 #  endif
 # endif
 #endif\n";
+    print $OUTFD "
+ * Because the API is defined, some methods have parameters that are
+ * not used.  The following definition allows us to suppress warnings
+ * about unused arguments in methods when -Wall -Wextra are specified.
+ * this definition is removed at the end of this file.
+#ifdef MPIR_ARGUNUSED
+#error MPIR_ARGUNUSED defined
+#endif
+#if __GNUC__ > 4
+#define MPIR_ARGUNUSED __attribute__((unused))
+#else
+#endif\n";
 # Use this after the MPI namespace is defined
@@ -2854,6 +2870,8 @@
 }\n";
     print $OUTFD "} // namespace MPI\n";
+    print $OUTFD "#undef MPIR_ARGUNUSED\n";
     close ($OUTFD);
     &ReplaceIfDifferent( $filename, "${filename}.new" );
@@ -3284,6 +3302,8 @@
     # To accommodate C++ compilers that don't support
     print $OUTFD "    virtual Comm &Clone(void) const = 0;\n";
+    # The MPIR_ARGUNUSED provides a way to use __attribute__((unused)) for
+    # the unused args
     # Typedefs
     print $OUTFD <<EOT;
     typedef int Copy_attr_function(const Comm& oldcomm, int comm_keyval, void* extra_state, void* attribute_val_in, void* attribute_val_out, bool& flag);
@@ -3294,13 +3314,17 @@
     static int Create_keyval( Copy_attr_function *, Delete_attr_function *,
                               void * );
-    static int NULL_COPY_FN( const Comm &oldcomm, int keyval, void *ex,
-    void *attr_in, void *attr_out, bool &flag ) { flag = 0; return 0;}
-    static int NULL_DELETE_FN( Comm &comm, int keyval, void * attr, void *ex )
-	{ return 0; }
-    static int DUP_FN( const Comm &oldcomm, int keyval, void *ex,
-    void *attr_in, void *attr_out, bool &flag ) { flag = 1;
-    *(void **)attr_out = attr_in; return 0;}
+    static int NULL_COPY_FN( const Comm &oldcomm MPIR_ARGUNUSED,
+           int keyval MPIR_ARGUNUSED, void *ex MPIR_ARGUNUSED,
+           void *attr_in MPIR_ARGUNUSED, void *attr_out MPIR_ARGUNUSED,
+	   bool &flag ) { flag = 0; return 0;}
+    static int NULL_DELETE_FN( Comm &comm MPIR_ARGUNUSED,
+	   int keyval MPIR_ARGUNUSED, void * attr MPIR_ARGUNUSED,
+	   void *ex MPIR_ARGUNUSED ) { return 0; }
+    static int DUP_FN( const Comm &oldcomm MPIR_ARGUNUSED,
+           void *attr_in, void *attr_out, bool &flag ) { flag = 1;
+                    *(void **)attr_out = attr_in; return 0;}
     static Errhandler Create_errhandler( Errhandler_function * );
 EOT
@@ -3334,15 +3358,18 @@
                               void * );
     // These functions are *not* part of MPI-2 but are provided
     // because they should have been included
-    static int NULL_COPY_FN( const Win &oldwin, int keyval, void *ex,
-    void *attr_in, void *attr_out, bool &flag ) { flag = 1; return 0;}
-    static int NULL_DELETE_FN( Win &win, int keyval, void * attr,
-         void *ex ) { return 0; }
-    static int DUP_FN( const Win &oldwin, int keyval, void *ex,
+    static int NULL_COPY_FN( const Win &oldwin MPIR_ARGUNUSED,
+        bool &flag ) { flag = 1; return 0;}
+    static int NULL_DELETE_FN( Win &win MPIR_ARGUNUSED,
+    static int DUP_FN( const Win &oldwin MPIR_ARGUNUSED,
 EOT
 sub Nullcomm_methods {
@@ -3482,7 +3509,7 @@
     print $OUTFD "\
     void Unpack( const void *, int, void *, int, int &, const Comm & ) const;\n";
 #    void Pack( const void *, int, void *, int, int &, const Comm & ) const;\n";
-    print $OUTFD "\
+    print $OUTFD <<EOT;
     typedef int Copy_attr_function(const Datatype& oldtype, int type_keyval, void* extra_state, void* attribute_val_in, void* attribute_val_out, bool& flag);
     typedef int Delete_attr_function(Datatype& type, int type_keyval, void* attribute_val, void* extra_state);
@@ -3490,15 +3517,19 @@
                               void * );
-    static int NULL_COPY_FN( const Datatype &oldtype, int keyval, void *ex,
-    static int NULL_DELETE_FN( Datatype &type, int keyval, void * attr,
-    static int DUP_FN( const Datatype &oldtype, int keyval, void *ex,
+    static int NULL_COPY_FN( const Datatype &oldtype MPIR_ARGUNUSED,
+    static int NULL_DELETE_FN( Datatype &type MPIR_ARGUNUSED,
+    static int DUP_FN( const Datatype &oldtype MPIR_ARGUNUSED,
-\n";
+EOT
 # We may eventually want to build separate files for each class rather than
More information about the mpich2-commits mailing list
