[mpich2-commits] r7884 - mpich2/trunk/src/pm/hydra/pm/pmiserv
balaji at mcs.anl.gov balaji at mcs.anl.gov
Tue Feb 1 15:42:02 CST 2011
Author: balaji
Date: 2011-02-01 15:42:02 -0600 (Tue, 01 Feb 2011)
New Revision: 7884
Modified:
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_utils.c
Log:
Bug-fix: Fixes to the PMI_process_mapping string calculation.
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_utils.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_utils.c	2011-02-01 20:04:12 UTC (rev 7883)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmiserv_utils.c	2011-02-01 21:42:02 UTC (rev 7884)
@@ -118,13 +118,17 @@
      * Blocks are of the format: (start node ID, number of blocks,
-     * block size)
+     * block size): (sid, nb, bz)
-     *   1. If two contiguous blocks have the same start node ID, and
-     *      the block size, we merge them.
+     * Assume B1 and B2 are neighboring blocks. The following blocks
+     * can be merged:
-     *   2. If two contiguous blocks are contiguous in node ID values,
-     *      and have the same block size, we merge them.
+     *   1. [B1(sid) + B1(nb) == B2(sid)] && [B1(bz) == B2(bz)]
+     *   2. [B1(sid) == B2(sid)] && [B1(nb) == 1]
+     * Special case: If all blocks are exactly the same, we delete all
+     *               except one.
     blocklist_head = NULL;
     for (proxy = pg->proxy_list; proxy; proxy = proxy->next) {
@@ -137,10 +141,6 @@
             blocklist_tail = blocklist_head = block;
-        else if (blocklist_tail->start_idx == proxy->proxy_id &&
-                 blocklist_tail->block_size == proxy->node.core_count) {
-            blocklist_tail->num_blocks++;
         else {
             /* Check if this proxy hostname existed earlier */
             for (tproxy = pg->proxy_list; tproxy; tproxy = tproxy->next) {
@@ -150,8 +150,12 @@
             if (blocklist_tail->start_idx + blocklist_tail->num_blocks == tproxy->proxy_id &&
+                    blocklist_tail->num_blocks++;
+            else if (blocklist_tail->start_idx == tproxy->proxy_id &&
+                     blocklist_tail->num_blocks == 1) {
+                blocklist_tail->block_size += proxy->node.core_count;
             else {
                 HYDU_MALLOC(blocklist_tail->next, struct block *, sizeof(struct block),
                             status);
@@ -184,22 +188,6 @@
         blocklist_tail = blocklist_head;
-    /* Case 2: If two contiguous blocks represent the same set of
-     * nodes, merge them */
-    for (block = blocklist_head; block->next;) {
-        blocklist_tail = block;
-        if (block->start_idx == block->next->start_idx &&
-            block->block_size == block->next->block_size) {
-            block->num_blocks += block->next->num_blocks;
-            nblock = block->next;
-            block->next = nblock->next;
-            HYDU_FREE(nblock);
-        else {
-            block = block->next;
     /* Create the mapping out of the blocks */
     i = 0;
     tmp[i++] = HYDU_strdup("(");
More information about the mpich2-commits mailing list
