[mpich2-commits] r7521 - in mpich2/trunk/test/mpi: . cxx cxx/attr cxx/datatype cxx/errhan cxx/init cxx/rma
gropp at mcs.anl.gov gropp at mcs.anl.gov
Mon Nov 29 13:22:10 CST 2010
Author: gropp
Date: 2010-11-29 13:22:10 -0600 (Mon, 29 Nov 2010)
New Revision: 7521
Added:
   mpich2/trunk/test/mpi/cxx/attr/attricx.cxx
   mpich2/trunk/test/mpi/cxx/datatype/packsizex.cxx
   mpich2/trunk/test/mpi/cxx/errhan/
   mpich2/trunk/test/mpi/cxx/errhan/Makefile.sm
   mpich2/trunk/test/mpi/cxx/errhan/commcallx.cxx
   mpich2/trunk/test/mpi/cxx/errhan/testlist
   mpich2/trunk/test/mpi/cxx/init/initstat2x.cxx
   mpich2/trunk/test/mpi/cxx/rma/wincallx.cxx
Modified:
   mpich2/trunk/test/mpi/configure.in
   mpich2/trunk/test/mpi/cxx/Makefile.sm
   mpich2/trunk/test/mpi/cxx/attr/Makefile.sm
   mpich2/trunk/test/mpi/cxx/attr/testlist
   mpich2/trunk/test/mpi/cxx/datatype/Makefile.sm
   mpich2/trunk/test/mpi/cxx/datatype/testlist
   mpich2/trunk/test/mpi/cxx/init/Makefile.sm
   mpich2/trunk/test/mpi/cxx/init/testlist
   mpich2/trunk/test/mpi/cxx/rma/Makefile.sm
   mpich2/trunk/test/mpi/cxx/rma/testlist
   mpich2/trunk/test/mpi/cxx/testlist.in
Log:
Added some C++ tests to provide better test coverage (and discovered a bug in call_errhandler)
Modified: mpich2/trunk/test/mpi/configure.in
--- mpich2/trunk/test/mpi/configure.in	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/configure.in	2010-11-29 19:22:10 UTC (rev 7521)
@@ -1078,6 +1078,7 @@
           cxx/pt2pt/Makefile \
           cxx/comm/Makefile \
           cxx/coll/Makefile \
+	  cxx/errhan/Makefile \
           cxx/info/Makefile \
           cxx/datatype/Makefile \
           cxx/io/Makefile \
Modified: mpich2/trunk/test/mpi/cxx/Makefile.sm
--- mpich2/trunk/test/mpi/cxx/Makefile.sm	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/Makefile.sm	2010-11-29 19:22:10 UTC (rev 7521)
@@ -1,4 +1,4 @@
-SUBDIRS = util attr pt2pt init info comm coll datatype io rma spawn
+SUBDIRS = util attr pt2pt init info comm coll datatype errhan io rma spawn
 # A special testing target to simplify testing just the C++ code
 testing:
Modified: mpich2/trunk/test/mpi/cxx/attr/Makefile.sm
--- mpich2/trunk/test/mpi/cxx/attr/Makefile.sm	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/attr/Makefile.sm	2010-11-29 19:22:10 UTC (rev 7521)
@@ -4,7 +4,7 @@
 smvar_do_sharedlibs = 0
 attrtx_SOURCES = attrtx.cxx
-#attricx_SOURCES = attricx.cxx
+attricx_SOURCES = attricx.cxx
 #attrerrx_SOURCES = attrerrx.cxx
 #attrerrcommx_SOURCES = attrerrcommx.cxx
 #attrerrtypex_SOURCES = attrerrtypex.cxx
@@ -20,3 +20,9 @@
 ../util/mtest.o:
 	(cd ../util && $(MAKE) mtest.o)
+testing:
+	../../runtests -srcdir=$(srcdir) -tests=testlist \
+			-mpiexec=@MPIEXEC@ \
+		   	-xmlfile=summary.xml
+clean-local:
+	-rm -f summary.xml
Added: mpich2/trunk/test/mpi/cxx/attr/attricx.cxx
--- mpich2/trunk/test/mpi/cxx/attr/attricx.cxx	                        (rev 0)
+++ mpich2/trunk/test/mpi/cxx/attr/attricx.cxx	2010-11-29 19:22:10 UTC (rev 7521)
@@ -0,0 +1,186 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ *  (C) 2001 by Argonne National Laboratory.
+ *      See COPYRIGHT in top-level directory.
+  Exercise communicator routines for intercommunicators
+  This C++ version derived from the C version, attric
+#include "mpi.h"
+#include "mpitestconf.h"
+#ifdef HAVE_IOSTREAM
+// Not all C++ compilers have iostream instead of iostream.h
+#include <iostream>
+#ifdef HAVE_NAMESPACE_STD
+// Those that do often need the std namespace; otherwise, a bare "cout"
+// is likely to fail to compile
+using namespace std;
+#endif
+#else
+#include <iostream.h>
+#endif
+#include <stdio.h>
+#include "mpitestcxx.h"
+#ifdef HAVE_STRING_H
+#include <string.h>
+#endif
+/* #define DEBUG */
+static int verbose = 0;
+int test_communicators ( void );
+int copy_fn ( const MPI::Comm &, int, void *, void *, void *, bool & );
+int delete_fn ( MPI::Comm &, int, void *, void * );
+#ifdef DEBUG
+#define FFLUSH fflush(stdout);
+#else
+#define FFLUSH
+#endif
+int main( int argc, char **argv )
+    int errs = 0;
+    MTest_Init();
+    errs = test_communicators();
+    MTest_Finalize( errs );
+    MPI::Finalize();
+    return 0;
+int copy_fn( const MPI::Comm &oldcomm, int keyval, void *extra_state,
+	     void *attribute_val_in, void *attribute_val_out, bool &flag)
+    /* Note that if (sizeof(int) < sizeof(void *), just setting the int
+       part of attribute_val_out may leave some dirty bits
+    *(MPI::Aint *)attribute_val_out = (MPI::Aint)attribute_val_in;
+    flag = 1;
+    return MPI_SUCCESS;
+int delete_fn( MPI::Comm &comm, int keyval, void *attribute_val,
+	       void *extra_state)
+    int world_rank;
+    world_rank = MPI::COMM_WORLD.Get_rank();
+    if ((MPI::Aint)attribute_val != (MPI::Aint)world_rank) {
+	cout << "incorrect attribute value %d\n" << *(int*)attribute_val << "\n";
+	MPI::COMM_WORLD.Abort( 1005 );
+int test_communicators( void )
+    MPI::Intercomm dup_comm, comm;
+    void *vvalue;
+    int flag, world_rank, world_size, key_1, key_3;
+    int errs = 0;
+    MPI::Aint value;
+    int      isLeft;
+    world_size = MPI::COMM_WORLD.Get_size();
+#ifdef DEBUG
+    if (world_rank == 0) {
+	cout << "*** Communicators ***\n";
+#endif
+    while (MTestGetIntercomm( comm, isLeft, 2 )) {
+	if (verbose) {
+	    cout << "start while loop, isLeft=" << isLeft << "\n";
+	if (comm == MPI::COMM_NULL) {
+	    if (verbose) {
+		cout << "got COMM_NULL, skipping\n";
+            continue;
+	  Check Comm_dup by adding attributes to comm & duplicating
+	value = 9;
+	key_1 = MPI::Comm::Create_keyval(copy_fn,     delete_fn,   &value );
+	if (verbose) {
+	    cout << "Keyval_create key=" << key_1 << " value=" << value << "\n";
+	value = 7;
+	key_3 = MPI::Comm::Create_keyval(MPI::Comm::NULL_COPY_FN,
+					 MPI::Comm::NULL_DELETE_FN,
+					 &value );
+	if (verbose) {
+	    cout << "Keyval_create key=" << key_3 << " value=" << value << "\n";
+	/* This may generate a compilation warning; it is, however, an
+	   easy way to cache a value instead of a pointer */
+	/* printf( "key1 = %x key3 = %x\n", key_1, key_3 ); */
+	comm.Set_attr( key_1, (void *) (MPI::Aint) world_rank );
+	comm.Set_attr( key_3, (void *)0 );
+	if (verbose) {
+	    cout << "Comm_dup\n";
+	dup_comm = comm.Dup();
+	/* Note that if sizeof(int) < sizeof(void *), we can't use
+	   (void **)&value to get the value we passed into Attr_put.  To avoid
+	   problems (e.g., alignment errors), we recover the value into
+	   a (void *) and cast to int. Note that this may generate warning
+	   messages from the compiler.  */
+	flag = dup_comm.Get_attr( key_1, (void **)&vvalue );
+	value = (MPI::Aint)vvalue;
+	if (! flag) {
+	    errs++;
+	    cout << "dup_comm key_1 not found on " << world_rank << "\n";
+	    MPI::COMM_WORLD.Abort( 3004 );
+	if (value != world_rank) {
+	    errs++;
+	    cout << "dup_comm key_1 value incorrect: " << (long)value << "\n";
+	    MPI::COMM_WORLD.Abort( 3005 );
+	flag = dup_comm.Get_attr( key_3, (void **)&vvalue );
+	if (flag) {
+	    errs++;
+	    cout << "dup_comm key_3 found!\n";
+	    MPI::COMM_WORLD.Abort( 3008 );
+	if (verbose) {
+	    cout << "Keyval_free key=" << key_1 << "\n";
+	MPI::Comm::Free_keyval( key_1 );
+	if (verbose) {
+	    cout << "Keyval_free key=" << key_3 << "\n";
+	MPI::Comm::Free_keyval( key_3 );
+	  Free all communicators created
+	if (verbose) {
+	    cout << "Comm_free comm\n";
+	comm.Free();
+	if (verbose) {
+	    cout << "Comm_free dup_comm\n";
+	dup_comm.Free();
+    return errs;
Modified: mpich2/trunk/test/mpi/cxx/attr/testlist
--- mpich2/trunk/test/mpi/cxx/attr/testlist	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/attr/testlist	2010-11-29 19:22:10 UTC (rev 7521)
@@ -1,5 +1,5 @@
 attrtx 2
-#attricx 4
+attricx 4
 #attrerrx 1
 #attrerrcommx 1
 #attrerrtypex 1
Modified: mpich2/trunk/test/mpi/cxx/datatype/Makefile.sm
--- mpich2/trunk/test/mpi/cxx/datatype/Makefile.sm	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/datatype/Makefile.sm	2010-11-29 19:22:10 UTC (rev 7521)
@@ -3,6 +3,7 @@
 LDADD = ../util/mtest.o
 DEPADD = @MPILIBLOC@ ../util/mtest.o
+packsizex_SOURCES  = packsizex.cxx
 typecntsx_SOURCES  = typecntsx.cxx
 typenamex_SOURCES  = typenamex.cxx
 typemiscx_SOURCES  = typemiscx.cxx
Added: mpich2/trunk/test/mpi/cxx/datatype/packsizex.cxx
--- mpich2/trunk/test/mpi/cxx/datatype/packsizex.cxx	                        (rev 0)
+++ mpich2/trunk/test/mpi/cxx/datatype/packsizex.cxx	2010-11-29 19:22:10 UTC (rev 7521)
@@ -0,0 +1,87 @@
+/* -*- Mode: C++; c-basic-offset:4 ; -*- */
+ *  (C) 2010 by Argonne National Laboratory.
+#include "mpi.h"
+#endif
+#else
+#endif
+int main( int argc, char *argv[] )
+    int errs = 0;
+    MPI::Datatype  type;
+    MPI::Intracomm comm;
+    MTestDatatype mstype, mrtype;
+    char dtypename[MPI_MAX_OBJECT_NAME];
+    int size1, size2, tnlen;
+    MTest_Init();
+    comm = MPI::COMM_WORLD;
+    while (MTestGetDatatypes( &mstype, &mrtype, 1 )) {
+	type = mstype.datatype;
+	// Testing the pack size is tricky, since this is the
+	// size that is stored when packed with type.Pack, and
+	// is not easily defined.  We look for consistency
+	size1 = type.Pack_size( 1, comm );
+	size2 = type.Pack_size( 2, comm );
+	if (size1 <= 0 || size2 <= 0) {
+	    errs++;
+	    type.Get_name( dtypename, tnlen );
+	    cout << "Pack size of datatype " << dtypename <<
+		" is not positive\n";
+	if (size1 >= size2) {
+	    errs++;
+	    cout << "Pack size of 2 of " << dtypename <<
+		" is smaller or the same as the pack size of 1 instance\n";
+	if (mrtype.datatype != mstype.datatype) {
+	    type = mrtype.datatype;
+		errs++;
+		errs++;
+        MTestFreeDatatype(&mrtype);
+	MTestFreeDatatype(&mstype);
+    MPI::Finalize();
+    return 0;
Modified: mpich2/trunk/test/mpi/cxx/datatype/testlist
--- mpich2/trunk/test/mpi/cxx/datatype/testlist	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/datatype/testlist	2010-11-29 19:22:10 UTC (rev 7521)
@@ -1,3 +1,4 @@
+packsizex 1
 typecntsx 1
 typenamex 1
 typemiscx 1
Property changes on: mpich2/trunk/test/mpi/cxx/errhan
___________________________________________________________________
Added: svn:ignore
   + Makefile.in
Makefile
Added: mpich2/trunk/test/mpi/cxx/errhan/Makefile.sm
--- mpich2/trunk/test/mpi/cxx/errhan/Makefile.sm	                        (rev 0)
+++ mpich2/trunk/test/mpi/cxx/errhan/Makefile.sm	2010-11-29 19:22:10 UTC (rev 7521)
@@ -0,0 +1,21 @@
+INCLUDES = -I../../include -I${top_srcdir}/include
+LDADD = ../util/mtest.o
+DEPADD = @MPILIBLOC@ ../util/mtest.o
+smvar_do_sharedlibs = 0
+#adderr_SOURCES = adderr.c
+#errstring_SOURCES = errstring.c
+#errcode_SOURCES = errcode.c errmsg.c
+#errring_SOURCES = errring.c
+commcallx_SOURCES = commcallx.cxx
+#errfatal_SOURCES = errfatal.c
+EXTRA_PROGRAMS = errcode errring errstring
+../util/mtest.o:
+	(cd ../util && make mtest.o)
+testing:
Added: mpich2/trunk/test/mpi/cxx/errhan/commcallx.cxx
--- mpich2/trunk/test/mpi/cxx/errhan/commcallx.cxx	                        (rev 0)
+++ mpich2/trunk/test/mpi/cxx/errhan/commcallx.cxx	2010-11-29 19:22:10 UTC (rev 7521)
@@ -0,0 +1,113 @@
+ *  (C) 2003 by Argonne National Laboratory.
+#include "mpi.h"
+#endif
+#else
+#endif
+#include <stdio.h>
+#endif
+static char MTEST_Descrip[] = "Test comm_call_errhandler";
+static int calls = 0;
+static int errs = 0;
+static MPI::Intracomm mycomm;
+void eh( MPI::Comm &comm, int *err, ... )
+    if (*err != MPI_ERR_OTHER) {
+	errs++;
+	cout << "Unexpected error code\n";
+    if (comm != mycomm) {
+	char cname[MPI_MAX_OBJECT_NAME];
+	int len;
+	errs++;
+	cout << "Unexpected communicator\n";
+	comm.Get_name( cname, len );
+	cout << "Comm is " << cname << "\n";
+	mycomm.Get_name( cname, len );
+	cout << "mycomm is " << cname << "\n";
+    calls++;
+    return;
+    MPI::Errhandler newerr;
+    int            i;
+    int            reset_handler;
+    MTest_Init( );
+    mycomm = comm;
+    mycomm.Set_name( "dup of comm_world" );
+    newerr = MPI::Comm::Create_errhandler( eh );
+    comm.Set_errhandler( newerr );
+    comm.Call_errhandler( MPI_ERR_OTHER );
+    newerr.Free();
+    if (calls != 1) {
+	errs++;
+	cout << "Error handler not called\n";
+    // Here we apply the test to many copies of a communicator
+    for (reset_handler = 0; reset_handler <= 1; ++reset_handler) {
+        for (i=0; i<1000; i++) {
+            MPI::Intracomm comm2;
+            calls = 0;
+	    comm = MPI::COMM_WORLD.Dup();
+            mycomm = comm;
+            if (calls != 1) {
+                errs++;
+	    comm2 = comm.Dup();
+            calls = 0;
+            mycomm = comm2;
+	    mycomm.Set_name( "dup of dup of comm_world" );
+            // comm2 must inherit the error handler from comm
+	    comm2.Call_errhandler( MPI_ERR_OTHER );
+            if (calls != 1) {
+                errs++;
+            if (reset_handler) {
+                // extra checking of the reference count handling
+		comm.Set_errhandler( MPI::ERRORS_THROW_EXCEPTIONS );
+	    newerr.Free();
+	    comm.Free();
+	    comm2.Free();
+    MPI::Finalize();
+    return 0;
Added: mpich2/trunk/test/mpi/cxx/errhan/testlist
--- mpich2/trunk/test/mpi/cxx/errhan/testlist	                        (rev 0)
+++ mpich2/trunk/test/mpi/cxx/errhan/testlist	2010-11-29 19:22:10 UTC (rev 7521)
@@ -0,0 +1,3 @@
+#adderr 1
+commcallx 2
+#errfatal 1 resultTest=TestErrFatal
Modified: mpich2/trunk/test/mpi/cxx/init/Makefile.sm
--- mpich2/trunk/test/mpi/cxx/init/Makefile.sm	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/init/Makefile.sm	2010-11-29 19:22:10 UTC (rev 7521)
@@ -5,6 +5,7 @@
 baseenv_SOURCES = baseenv.cxx
 initstatx_SOURCES = initstatx.cxx
+initstat2x_SOURCES = initstat2x.cxx
 ../util/mtest.o:
Added: mpich2/trunk/test/mpi/cxx/init/initstat2x.cxx
--- mpich2/trunk/test/mpi/cxx/init/initstat2x.cxx	                        (rev 0)
+++ mpich2/trunk/test/mpi/cxx/init/initstat2x.cxx	2010-11-29 19:22:10 UTC (rev 7521)
@@ -0,0 +1,64 @@
+#include "mpi.h"
+#endif
+#else
+#endif
+    int errs = 0;
+    bool flag;
+    int provided, claimed;
+    // This test must be invoked with two arguments: myarg1 myarg2
+    provided = MPI::Init_thread( argc, argv, MPI::THREAD_MULTIPLE );
+    if (argc != 3) {
+	errs++;
+	cout << "Expected argc=3 but saw argc=" << argc << "\n";
+    else {
+	if (strcmp( argv[1], "myarg1" ) != 0) {
+	    errs++;
+	    cout << "Expected myarg1 for 1st argument but saw " << argv[1]
+		 << "\n";
+	if (strcmp( argv[2], "myarg2" ) != 0) {
+	    errs++;
+	    cout << "Expected myarg2 for 1st argument but saw " << argv[2]
+		 << "\n";
+    // Confirm that MPI is properly initialized
+    flag = MPI::Is_thread_main();
+    if (!flag) {
+	errs++;
+	cout << "This thread call init_thread but Is_thread_main gave false\n";
+    claimed = MPI::Query_thread();
+    if (claimed != provided) {
+	errs++;
+	cout << "Query thread gave thread level " << claimed <<
+	    " but Init_thread gave " << provided << "\n";
+    MPI::Finalize();
+    return 0;
Modified: mpich2/trunk/test/mpi/cxx/init/testlist
--- mpich2/trunk/test/mpi/cxx/init/testlist	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/init/testlist	2010-11-29 19:22:10 UTC (rev 7521)
@@ -1,2 +1,3 @@
 baseenv 1
 initstatx 1
+initstat2x 1 arg=myarg1 arg=myarg2
Modified: mpich2/trunk/test/mpi/cxx/rma/Makefile.sm
--- mpich2/trunk/test/mpi/cxx/rma/Makefile.sm	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/rma/Makefile.sm	2010-11-29 19:22:10 UTC (rev 7521)
@@ -8,7 +8,15 @@
 winfencex_SOURCES = winfencex.cxx
 winscale1x_SOURCES = winscale1x.cxx
 winscale2x_SOURCES = winscale2x.cxx
+wincallx_SOURCES = wincallx.cxx
 fkeyvalwinx_SOURCES = fkeyvalwinx.cxx
 ../util/mtest.o:
+testing:
+clean-local:
Modified: mpich2/trunk/test/mpi/cxx/rma/testlist
--- mpich2/trunk/test/mpi/cxx/rma/testlist	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/rma/testlist	2010-11-29 19:22:10 UTC (rev 7521)
@@ -1,4 +1,5 @@
 winnamex 1
+wincallx 1
 getgroupx 4
 winfencex 4
 winscale1x 4
Added: mpich2/trunk/test/mpi/cxx/rma/wincallx.cxx
--- mpich2/trunk/test/mpi/cxx/rma/wincallx.cxx	                        (rev 0)
+++ mpich2/trunk/test/mpi/cxx/rma/wincallx.cxx	2010-11-29 19:22:10 UTC (rev 7521)
@@ -0,0 +1,78 @@
+#include "mpi.h"
+#endif
+#else
+#endif
+#include <stdio.h>
+#endif
+static char MTEST_Descrip[] = "Test win_call_errhandler";
+static MPI::Win mywin;
+void eh( MPI::Win &win, int *err, ... )
+	errs++;
+    if (win != mywin) {
+	int len;
+	errs++;
+	cout << "Unexpected window\n";
+	win.Get_name( cname, len );
+	cout << "Win is " << cname << "\n";
+	mywin.Get_name( cname, len );
+	cout << "Mywin is " << cname << "\n";
+    calls++;
+    return;
+    MPI::Win        win;
+    int            i;
+    int            buf[10];
+    MTest_Init( );
+    win  = MPI::Win::Create( buf, sizeof(buf), 1, MPI::INFO_NULL, MPI::COMM_WORLD );
+    mywin = win;
+    mywin.Set_name( "dup of win_world" );
+    newerr = MPI::Win::Create_errhandler( eh );
+    win.Set_errhandler( newerr );
+    win.Call_errhandler( MPI_ERR_OTHER );
+    newerr.Free();
+    if (calls != 1) {
+	errs++;
+    win.Free();
+    MPI::Finalize();
+    return 0;
Modified: mpich2/trunk/test/mpi/cxx/testlist.in
--- mpich2/trunk/test/mpi/cxx/testlist.in	2010-11-29 19:18:54 UTC (rev 7520)
+++ mpich2/trunk/test/mpi/cxx/testlist.in	2010-11-29 19:22:10 UTC (rev 7521)
@@ -1,7 +1,8 @@
 attr
 pt2pt
-comm
-coll
+comm
+coll
+errhan
 init
 info
 datatype
More information about the mpich2-commits mailing list
