[mpich2-commits] r7514 - in mpich2/trunk/src/pm/hydra: tools/bind tools/bind/hwloc tools/demux ui/mpich
balaji at mcs.anl.gov
Mon Nov 29 02:03:48 CST 2010
Author: balaji
Date: 2010-11-29 02:03:48 -0600 (Mon, 29 Nov 2010)
New Revision: 7514
Modified:
mpich2/trunk/src/pm/hydra/tools/bind/bind.c
mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
mpich2/trunk/src/pm/hydra/tools/demux/demux.c
mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
Log:
White space cleanup.
Modified: mpich2/trunk/src/pm/hydra/tools/bind/bind.c
--- mpich2/trunk/src/pm/hydra/tools/bind/bind.c 2010-11-29 08:03:34 UTC (rev 7513)
+++ mpich2/trunk/src/pm/hydra/tools/bind/bind.c 2010-11-29 08:03:48 UTC (rev 7514)
@@ -177,10 +177,10 @@
if (use_topo_obj[i])
use_topo_obj[i - 1] = 1;
- /* We should have at least one process on the node; otherwise,
- the mapping makes no sense */
- for (i = HYDT_BIND_OBJ_MACHINE; i < HYDT_BIND_OBJ_NODE; i++)
- use_topo_obj[i] = 1;
+ /* We should have at least one process on the node; otherwise,
+ * the mapping makes no sense */
+ for (i = HYDT_BIND_OBJ_MACHINE; i < HYDT_BIND_OBJ_NODE; i++)
+ use_topo_obj[i] = 1;
topo_end = HYDT_BIND_OBJ_END;
for (i = HYDT_BIND_OBJ_MACHINE; i < HYDT_BIND_OBJ_END; i++) {
@@ -204,7 +204,7 @@
bindentry = strtok(bindstr, ":");
bindentry = strtok(NULL, ":");
- /* Don't share any cache to start with */
+ /* Don't share any cache to start with */
use_cache_level = HYDT_INVALID_CACHE_DEPTH;
if (bindentry == NULL) {
/* No extension option specified; use all resources */
@@ -239,10 +239,10 @@
break_out = 0;
for (j = 0; j < obj->mem.num_caches; j++) {
- /* If the cache level is lower than what I'm allowed
- to share, and there are more than one OS indices
- below this level (there is actually sharing) mark
- this as the lowest level I can get to */
+ /* If the cache level is lower than what I'm allowed
+ * to share, and there are more than one OS indices
+ * below this level (there is actually sharing) mark
+ * this as the lowest level I can get to */
if (obj->mem.cache_depth[j] == use_cache_level) {
topo_end = (HYDT_bind_obj_type_t) (i + 1);
break_out = 1;
@@ -266,8 +266,8 @@
for (; j < topo_end - 1; j++)
obj = obj->children;
- HYDT_bind_cpuset_dup(obj->cpuset, &HYDT_bind_info.bindmap[i]);
- i++;
+ HYDT_bind_cpuset_dup(obj->cpuset, &HYDT_bind_info.bindmap[i]);
+ i++;
child_id = HYDT_BIND_OBJ_CHILD_ID(obj);
if (child_id < obj->parent->num_children - 1) {
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c 2010-11-29 08:03:34 UTC (rev 7513)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c 2010-11-29 08:03:48 UTC (rev 7514)
@@ -83,13 +83,13 @@
obj->mem.num_caches = count_attached_caches(hobj, hobj->cpuset);
if (obj->mem.num_caches) {
- HYDU_MALLOC(obj->mem.cache_size, size_t *, obj->mem.num_caches * sizeof(size_t),
- status);
- memset(obj->mem.cache_size, 0, obj->mem.num_caches * sizeof(size_t));
- HYDU_MALLOC(obj->mem.cache_depth, int *, obj->mem.num_caches * sizeof(int), status);
- memset(obj->mem.cache_depth, 0, obj->mem.num_caches * sizeof(int));
+ HYDU_MALLOC(obj->mem.cache_size, size_t *, obj->mem.num_caches * sizeof(size_t),
+ status);
+ memset(obj->mem.cache_size, 0, obj->mem.num_caches * sizeof(size_t));
+ HYDU_MALLOC(obj->mem.cache_depth, int *, obj->mem.num_caches * sizeof(int), status);
+ memset(obj->mem.cache_depth, 0, obj->mem.num_caches * sizeof(int));
- gather_attached_caches(obj, hobj, hobj->cpuset, 0);
+ gather_attached_caches(obj, hobj, hobj->cpuset, 0);
fn_exit:
Modified: mpich2/trunk/src/pm/hydra/tools/demux/demux.c
--- mpich2/trunk/src/pm/hydra/tools/demux/demux.c 2010-11-29 08:03:34 UTC (rev 7513)
+++ mpich2/trunk/src/pm/hydra/tools/demux/demux.c 2010-11-29 08:03:48 UTC (rev 7514)
@@ -10,6 +10,7 @@
int HYDT_dmxu_num_cb_fds = 0;
struct HYDT_dmxu_callback *HYDT_dmxu_cb_list = NULL;
struct HYDT_dmxu_fns HYDT_dmxu_fns = { 0 };
int HYDT_dmxu_got_sigttin = 0;
#if defined(SIGTTIN) && defined(HAVE_ISATTY)
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2010-11-29 08:03:34 UTC (rev 7513)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2010-11-29 08:03:48 UTC (rev 7514)
@@ -174,7 +174,7 @@
HYDU_ERR_POP(status, "unable to initialize FTB\n");
- /* Get user preferences*/
+ /* Get user preferences */
status = HYD_uii_mpx_get_parameters(argv);
if (status == HYD_GRACEFUL_ABORT) {
exit(0);
More information about the mpich2-commits
