[mpich2-commits] r7509 - in mpich2/branches/release/mpich2-1.3.x: . confdb maint src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp src/mpl/src src/pm/hydra src/pm/hydra/examples src/pm/hydra/include src/pm/hydra/pm src/pm/hydra/pm/pmiserv src/pm/hydra/tools src/pm/hydra/tools/bootstrap/external src/pm/hydra/tools/bootstrap/src src/pm/hydra/tools/bootstrap/utils src/pm/hydra/ui src/pm/hydra/utils
balaji at mcs.anl.gov balaji at mcs.anl.gov
Thu Nov 25 06:58:01 CST 2010
Author: balaji
Date: 2010-11-25 06:58:00 -0600 (Thu, 25 Nov 2010)
New Revision: 7509
Modified:
   mpich2/branches/release/mpich2-1.3.x/
   mpich2/branches/release/mpich2-1.3.x/RELEASE_NOTES
   mpich2/branches/release/mpich2-1.3.x/confdb/
   mpich2/branches/release/mpich2-1.3.x/maint/Version
   mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
   mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui/
   mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils/
   mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
Log:
Merge r7507 and r7508 from trunk.
Property changes on: mpich2/branches/release/mpich2-1.3.x
___________________________________________________________________
Modified: svn:mergeinfo
   - /mpich2/branches/dev/ckpt:5050
/mpich2/branches/dev/ckpt2:5057-6537
/mpich2/branches/dev/ftb:5661-5730
/mpich2/branches/dev/lapi:5817
/mpich2/branches/dev/wintcp_async_progress:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2:5406
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt:5050
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7507-7508
Modified: mpich2/branches/release/mpich2-1.3.x/RELEASE_NOTES
--- mpich2/branches/release/mpich2-1.3.x/RELEASE_NOTES	2010-11-25 12:47:54 UTC (rev 7508)
+++ mpich2/branches/release/mpich2-1.3.x/RELEASE_NOTES	2010-11-25 12:58:00 UTC (rev 7509)
@@ -63,12 +63,6 @@
 ### Process Managers
- * Hydra's prepend-rank option has some known problems. You might be
-   able to use it most, but not all times.
- * Running Hydra's mpiexec as a background process does not work
-   correctly at this time.
  * The MPD process manager can only handle relatively small amounts of
    data on stdin and may also have problems if there is data on stdin
    that is not consumed by the program.
@@ -77,12 +71,7 @@
    processes. MPI_Comm_spawn() does not currently work for >= 256
    arguments with smpd.
- * The hwloc process binding support within the Hydra process manager
-   does not build correctly with PGI compilers in some
-   environments. hwloc support can be disabled using the configure
-   option "--without-hydra-bindlib".
 ### Performance issues
  * SMP-aware collectives do not perform as well, in select cases, as
Property changes on: mpich2/branches/release/mpich2-1.3.x/confdb
   - /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/branches/dev/ftb/confdb:5661-5730
/mpich2/branches/dev/lapi/confdb:5817
/mpich2/branches/dev/wintcp_async_progress/confdb:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/confdb:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/confdb:5406
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/maint/Version
   - /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/branches/dev/ckpt2/maint/Version:5057-6537
/mpich2/branches/dev/ftb/maint/Version:5661-5730
/mpich2/branches/dev/lapi/maint/Version:5817
/mpich2/branches/dev/wintcp_async_progress/maint/Version:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/maint/Version:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/maint/Version:5406
/mpich2/trunk/maint/Version:7422-7424,7429-7433,7435,7437-7438,7442-7446,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502
/mpich2/trunk/src/pm/hydra/VERSION:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7447
   + /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/trunk/maint/Version:7422-7424,7429-7433,7435,7437-7438,7442-7446,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
   - /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/branches/dev/ckpt2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5057-6537
/mpich2/branches/dev/ftb/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5661-5730
/mpich2/branches/dev/lapi/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5817
/mpich2/branches/dev/win_rrvm/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:6416,6428
/mpich2/branches/dev/wintcp_async_progress/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5406
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
   - /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/branches/dev/ftb/src/mpl/src/mplstr.c:5661-5730
/mpich2/branches/dev/lapi/src/mpl/src/mplstr.c:5817
/mpich2/branches/release/mpich2-1.1.1/src/mpl/src/string/mplstr.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpl/src/string/mplstr.c:5406
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra
   - /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra:5406
/mpich2/trunk/src/pm/hydra:7355-7359*,7366-7367*,7371-7402*,7406-7409*,7411-7416*,7419-7420*,7422-7424*,7429-7433*,7435*,7437-7438,7447-7448*,7462*,7470*,7473-7477*,7484-7485*,7488-7491*,7493-7502*
   + /mpich2/branches/dev/ckpt/src/pm/hydra:5050
/mpich2/trunk/src/pm/hydra:7355-7359*,7366-7367*,7371-7402*,7406-7409*,7411-7416*,7419-7420*,7422-7424*,7429-7433*,7435*,7437-7438,7447-7448*,7462*,7470*,7473-7477*,7484-7485*,7488-7491*,7493-7502*,7507-7508*
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/Makefile.am
   - /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/Makefile.am:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/Makefile.am:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/Makefile.am:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/Makefile.am:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/Makefile.am:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/Makefile.am:5406
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/Makefile.am:5050
/mpich2/trunk/src/pm/hydra/Makefile.am:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/README
   - /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/README:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/README:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/README:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/README:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/README:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/README:5406
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/README:5050
/mpich2/trunk/src/pm/hydra/README:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/autogen.sh
   - /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/autogen.sh:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/autogen.sh:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/autogen.sh:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/autogen.sh:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/autogen.sh:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/autogen.sh:5406
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/autogen.sh:5050
/mpich2/trunk/src/pm/hydra/autogen.sh:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/configure.in
   - /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/configure.in:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/configure.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/configure.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/configure.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/configure.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/configure.in:5406
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/configure.in:5050
/mpich2/trunk/src/pm/hydra/configure.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/examples
   - /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/examples:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/examples:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/examples:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/examples:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/examples:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/examples:5406
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/examples:5050
/mpich2/trunk/src/pm/hydra/examples:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/hydra-doxygen.cfg.in
   - /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/hydra-doxygen.cfg.in:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/hydra-doxygen.cfg.in:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/hydra-doxygen.cfg.in:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/hydra-doxygen.cfg.in:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/hydra-doxygen.cfg.in:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/hydra-doxygen.cfg.in:5406
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/hydra-doxygen.cfg.in:5050
/mpich2/trunk/src/pm/hydra/hydra-doxygen.cfg.in:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/include
   - /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/include:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/include:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/include:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/include:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/include:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/include:5406
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/include:5050
/mpich2/trunk/src/pm/hydra/include:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/mpich2prereq
   - /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/mpich2prereq:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/mpich2prereq:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/mpich2prereq:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/mpich2prereq:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/mpich2prereq:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/mpich2prereq:5406
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/mpich2prereq:5050
/mpich2/trunk/src/pm/hydra/mpich2prereq:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm
   - /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/pm:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/pm:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/pm:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/pm:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/pm:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/pm:5406
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/pm:5050
/mpich2/trunk/src/pm/hydra/pm:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Modified: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c
--- mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c	2010-11-25 12:47:54 UTC (rev 7508)
+++ mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c	2010-11-25 12:58:00 UTC (rev 7509)
@@ -670,7 +670,7 @@
     HYDU_ERR_POP(status, "error while looking up service\n");
     i = 0;
-    tmp[i++] = HYDU_strdup("cmd=lookup_result info=ok rc=0 msg=success");
+    tmp[i++] = HYDU_strdup("cmd=lookup_result info=ok");
     if (value) {
         tmp[i++] = HYDU_strdup("value=");
         tmp[i++] = HYDU_strdup(value);
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools
   - /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/tools:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/tools:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/tools:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/tools:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/tools:5406
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/tools:5050
/mpich2/trunk/src/pm/hydra/tools:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c
   - /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/slurm/slurm_query_proxy_id.c:5661-5730
/mpich2/trunk/src/pm/hydra/tools/bootstrap/external/slurm_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c
   - /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:5661-5730
/mpich2/trunk/src/pm/hydra/tools/bootstrap/src/bsci_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c
   - /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5817
/mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ftb/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:5661-5730
/mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_query_proxy_id.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/ui
   - /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/ui:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/ui:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/ui:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/ui:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/ui:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/ui:5406
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/ui:5050
/mpich2/trunk/src/pm/hydra/ui:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/pm/hydra/utils
   - /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/branches/dev/ckpt2/src/pm/hydra/utils:5057-6537
/mpich2/branches/dev/ftb/src/pm/hydra/utils:5661-5730
/mpich2/branches/dev/lapi/src/pm/hydra/utils:5817
/mpich2/branches/dev/wintcp_async_progress/src/pm/hydra/utils:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/pm/hydra/utils:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/pm/hydra/utils:5406
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/src/pm/hydra/utils:5050
/mpich2/trunk/src/pm/hydra/utils:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7447-7448,7462,7470,7473-7477,7484-7485,7488-7491,7493-7502,7507-7508
Property changes on: mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
   - /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/branches/dev/ckpt2/winconfigure.wsf:5057-6537
/mpich2/branches/dev/ftb/winconfigure.wsf:5661-5730
/mpich2/branches/dev/lapi/winconfigure.wsf:5817
/mpich2/branches/dev/win_rrvm/winconfigure.wsf:6404,6407-6408,6420,6422-6423
/mpich2/branches/dev/wintcp_async_progress/winconfigure.wsf:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/winconfigure.wsf:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/winconfigure.wsf:5406
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502
   + /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485,7488-7491,7493-7502,7507-7508
More information about the mpich2-commits mailing list
