[mpich2-commits] r7489 - mpich2/trunk/src/pm/hydra/ui/mpich
balaji at mcs.anl.gov
Wed Nov 24 00:45:15 CST 2010
Author: balaji
Date: 2010-11-24 00:45:15 -0600 (Wed, 24 Nov 2010)
New Revision: 7489
Modified:
mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
mpich2/trunk/src/pm/hydra/ui/mpich/utils.c
Log:
Reorder code to initialize parts that don't rely on user input first.
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2010-11-24 06:45:05 UTC (rev 7488)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2010-11-24 06:45:15 UTC (rev 7489)
@@ -159,9 +159,22 @@
HYDU_FUNC_ENTER();
+ /* Initialize engines that don't require use to know anything
+ * about the user preferences first */
status = HYDU_dbg_init("mpiexec");
HYDU_ERR_POP(status, "unable to initialization debugging\n");
+ status = HYDU_set_common_signals(signal_cb);
+ HYDU_ERR_POP(status, "unable to set signal\n");
+ if (pipe(HYD_handle.cleanup_pipe) < 0)
+ HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "pipe error\n");
+ status = HYDT_ftb_init();
+ HYDU_ERR_POP(status, "unable to initialize FTB\n");
+ /* Get user preferences*/
status = HYD_uii_mpx_get_parameters(argv);
if (status == HYD_GRACEFUL_ABORT) {
exit(0);
@@ -171,23 +184,14 @@
goto fn_fail;
- /* if the user set the checkpoint prefix, set env var to enable
- * checkpointing on the processes */
- if (HYD_handle.user_global.ckpoint_prefix)
- HYDU_append_env_to_list("MPICH_ENABLE_CKPOINT", "1",
- &HYD_handle.user_global.global_env.system);
- status = HYDU_set_common_signals(signal_cb);
- HYDU_ERR_POP(status, "unable to set signal\n");
+ /* Now we initialize engines that require us to know user
+ * preferences */
#if HAVE_ALARM
if (HYD_handle.ckpoint_int != -1)
alarm(HYD_handle.ckpoint_int);
#endif /* HAVE_ALARM */
- if (pipe(HYD_handle.cleanup_pipe) < 0)
- HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "pipe error\n");
status = HYDT_dmx_init(&HYD_handle.user_global.demux);
HYDU_ERR_POP(status, "unable to initialize the demux engine\n");
@@ -199,9 +203,6 @@
HYD_handle.user_global.enablex, HYD_handle.user_global.debug);
HYDU_ERR_POP(status, "unable to initialize the bootstrap server\n");
- status = HYDT_ftb_init();
- HYDU_ERR_POP(status, "unable to initialize FTB\n");
if (HYD_handle.node_list == NULL) {
/* Node list is not created yet. The user might not have
* provided the host file. Query the RMK. */
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/utils.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/utils.c 2010-11-24 06:45:05 UTC (rev 7488)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/utils.c 2010-11-24 06:45:15 UTC (rev 7489)
@@ -1088,6 +1088,12 @@
status = set_default_values();
HYDU_ERR_POP(status, "setting default values failed\n");
+ /* If the user set the checkpoint prefix, set env var to enable
+ * checkpointing on the processes */
+ if (HYD_handle.user_global.ckpoint_prefix)
+ HYDU_append_env_to_list("MPICH_ENABLE_CKPOINT", "1",
+ &HYD_handle.user_global.global_env.system);
fn_exit:
HYDU_FUNC_EXIT();
return status;
More information about the mpich2-commits
