[mpich2-commits] r7487 - in mpich2/branches/release/mpich2-1.3.x: . confdb doc/windev maint src/binding/f77 src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp src/mpl/src
jayesh at mcs.anl.gov
Tue Nov 23 13:05:11 CST 2010
Author: jayesh
Date: 2010-11-23 13:05:11 -0600 (Tue, 23 Nov 2010)
New Revision: 7487
Added:
mpich2/branches/release/mpich2-1.3.x/maint/makegcclibs_64.bat
Modified:
mpich2/branches/release/mpich2-1.3.x/confdb/
mpich2/branches/release/mpich2-1.3.x/doc/windev/windev.tex.vin
mpich2/branches/release/mpich2-1.3.x/maint/Version
mpich2/branches/release/mpich2-1.3.x/maint/mpich2x64i.vdproj
mpich2/branches/release/mpich2-1.3.x/makewindist.bat
mpich2/branches/release/mpich2-1.3.x/mpich2.sln
mpich2/branches/release/mpich2-1.3.x/src/binding/f77/mpich2fg.def
mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
Log:
Merging r7442, r7443, r7444, r7445, r7459, r7460, r7469, r7478 from trunk
Property changes on: mpich2/branches/release/mpich2-1.3.x
___________________________________________________________________
Modified: svn:mergeinfo
- /mpich2/branches/dev/ckpt:5050
/mpich2/branches/dev/ckpt2:5057-6537
/mpich2/branches/dev/ftb:5661-5730
/mpich2/branches/dev/lapi:5817
/mpich2/branches/dev/wintcp_async_progress:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2:5406
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7448,7462,7470,7473-7477,7484-7485
+ /mpich2/branches/dev/ckpt:5050
/mpich2/trunk:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485
Property changes on: mpich2/branches/release/mpich2-1.3.x/confdb
- /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/branches/dev/ftb/confdb:5661-5730
/mpich2/branches/dev/lapi/confdb:5817
/mpich2/branches/dev/wintcp_async_progress/confdb:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/confdb:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/confdb:5406
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7448,7462,7470,7473-7477,7484-7485
+ /mpich2/branches/dev/ckpt2/confdb:5180,5182,5196,5198
/mpich2/trunk/confdb:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485
Modified: mpich2/branches/release/mpich2-1.3.x/doc/windev/windev.tex.vin
--- mpich2/branches/release/mpich2-1.3.x/doc/windev/windev.tex.vin 2010-11-23 07:30:29 UTC (rev 7486)
+++ mpich2/branches/release/mpich2-1.3.x/doc/windev/windev.tex.vin 2010-11-23 19:05:11 UTC (rev 7487)
@@ -1215,9 +1215,8 @@
\item Compile your application.
\end{enumerate}
-\subsubsection{Cygwin gcc}
-You can compile your MPI programs using gcc/g++ from Cygwin and the MPICH2 header files/libraries installed with MPICH2 on windows. Compile using the header files in \texttt{C:$\backslash$Program Files$\backslash$MPICH2$\backslash$include}
-and link using the libs, lib*.a, in \texttt{C:$\backslash$Program Files$\backslash$MPICH2$\backslash$lib}. Note that you should use the ``-localroot'' option when running programs compiled using gcc/g++ from Cygwin.
+\subsubsection{Cygwin and MinGW GNU compilers}
+You can compile your MPI programs using gcc/g++/g77/gfortran from Cygwin or MinGW using the MPICH2 header files/libraries installed with MPICH2 on windows. Compile using the header files in \texttt{C:$\backslash$Program Files$\backslash$MPICH2$\backslash$include} and link using the libs, lib*.a, in \texttt{C:$\backslash$Program Files$\backslash$MPICH2$\backslash$lib}. Note that you should use the ``-localroot'' option when running programs compiled using gcc/g++ from Cygwin.
\subsection{Performance Analysis}
MPICH2 includes the Multi-Processing Environment (MPE), which is a
Property changes on: mpich2/branches/release/mpich2-1.3.x/maint/Version
- /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/branches/dev/ckpt2/maint/Version:5057-6537
/mpich2/branches/dev/ftb/maint/Version:5661-5730
/mpich2/branches/dev/lapi/maint/Version:5817
/mpich2/branches/dev/wintcp_async_progress/maint/Version:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/maint/Version:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/maint/Version:5406
/mpich2/trunk/maint/Version:7422-7424,7429-7433,7435,7437-7438,7462,7470,7473-7477,7484-7485
/mpich2/trunk/src/pm/hydra/VERSION:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416
+ /mpich2/branches/dev/ckpt/maint/Version:5050
/mpich2/trunk/maint/Version:7422-7424,7429-7433,7435,7437-7438,7442-7446,7459-7460,7462,7469-7470,7473-7478,7484-7485
Copied: mpich2/branches/release/mpich2-1.3.x/maint/makegcclibs_64.bat (from rev 7445, mpich2/trunk/maint/makegcclibs_64.bat)
--- mpich2/branches/release/mpich2-1.3.x/maint/makegcclibs_64.bat (rev 0)
+++ mpich2/branches/release/mpich2-1.3.x/maint/makegcclibs_64.bat 2010-11-23 19:05:11 UTC (rev 7487)
@@ -0,0 +1,12 @@
+ at echo off
+..\winbuild\x64\Release\gcc\impgen.exe ..\winbuild\x64\Release\mpi\mpich2mpi.dll > ..\winbuild\x64\Release\gcc\mpich2mpigcc.def
+..\winbuild\x64\Release\gcc\impgen.exe ..\winbuild\x64\Release\gfortran\fmpich2g.dll > ..\winbuild\x64\Release\gcc\fmpich2gcc.def
+x86_64-w64-mingw32-dlltool --dllname mpich2mpi.dll --def ..\winbuild\x64\Release\gcc\mpich2mpigcc.def --output-lib ..\winbuild\x64\Release\gcc\libmpi.a >> ..\make.log
+x86_64-w64-mingw32-dlltool --dllname fmpich2g.dll --def ..\winbuild\x64\Release\gcc\fmpich2gcc.def --output-lib ..\winbuild\x64\Release\gcc\libfmpich2g.a >> ..\make.log
+REM Building MPI CXX Interface lib
+bash -c "x86_64-w64-mingw32-g++ -I ../src/include -I ../src/include/win64 -c ../src/binding/cxx/initcxx.cxx -o ../winbuild/x64/Release/gcc/initcxx.o" >> ..\make.log
+x86_64-w64-mingw32-ar rvs ../winbuild/x64/Release/gcc/libmpicxx.a ../winbuild/x64/Release/gcc/initcxx.o >> ..\make.log
+del ..\winbuild\x64\Release\gcc\mpich2mpigcc.def
+del ..\winbuild\x64\Release\gcc\fmpich2gcc.def
Modified: mpich2/branches/release/mpich2-1.3.x/maint/mpich2x64i.vdproj
--- mpich2/branches/release/mpich2-1.3.x/maint/mpich2x64i.vdproj 2010-11-23 07:30:29 UTC (rev 7486)
+++ mpich2/branches/release/mpich2-1.3.x/maint/mpich2x64i.vdproj 2010-11-23 19:05:11 UTC (rev 7487)
@@ -63,6 +63,12 @@
"Entry"
+ "MsmKey" = "8:_204DB77A62174C2C900B75BA7782596A"
+ "OwnerKey" = "8:_UNDEFINED"
+ "MsmSig" = "8:_UNDEFINED"
+ "Entry"
"MsmKey" = "8:_2A131B743AAD4CC99C6926BDEAB87CB2"
@@ -81,6 +87,12 @@
"Entry"
+ "MsmKey" = "8:_2ED4D01C4AB04611862206AEB490440A"
+ "Entry"
"MsmKey" = "8:_328D583D55BC4B38A679F9ACF3DCE98A"
@@ -345,6 +357,12 @@
"Entry"
+ "MsmKey" = "8:_F8734FE1E95D489C99076694D4F5C387"
+ "Entry"
"MsmKey" = "8:_FA7FEB4E019147ABB551882DD956CA32"
@@ -697,6 +715,26 @@
"IsDependency" = "11:FALSE"
"IsolateTo" = "8:"
+ "{1FB2D0AE-D3B9-43D4-B9DD-F88EC61E35DE}:_204DB77A62174C2C900B75BA7782596A"
+ "SourcePath" = "8:..\\winbuild\\x64\\Release\\gcc\\libmpicxx.a"
+ "TargetName" = "8:libmpicxx.a"
+ "Tag" = "8:"
+ "Folder" = "8:_21FB2EC726254C54839F05E4290C1045"
+ "Condition" = "8:"
+ "Transitive" = "11:FALSE"
+ "Vital" = "11:TRUE"
+ "ReadOnly" = "11:FALSE"
+ "Hidden" = "11:FALSE"
+ "System" = "11:FALSE"
+ "Permanent" = "11:FALSE"
+ "SharedLegacy" = "11:FALSE"
+ "PackageAs" = "3:1"
+ "Register" = "3:1"
+ "Exclude" = "11:FALSE"
+ "IsDependency" = "11:FALSE"
+ "IsolateTo" = "8:"
"{1FB2D0AE-D3B9-43D4-B9DD-F88EC61E35DE}:_2A131B743AAD4CC99C6926BDEAB87CB2"
"SourcePath" = "8:..\\winbuild\\x64\\Release\\mpe_wrap\\mpich2mpe.dll"
@@ -721,7 +759,7 @@
"AssemblyRegister" = "3:1"
"AssemblyIsInGAC" = "11:FALSE"
- "AssemblyAsmDisplayName" = "8:wmpiregister, Version=1.0.3898.24477, Culture=neutral, processorArchitecture=MSIL"
+ "AssemblyAsmDisplayName" = "8:wmpiregister, Version=1.0.3947.19215, Culture=neutral, processorArchitecture=MSIL"
"ScatterAssemblies"
@@ -763,6 +801,26 @@
"IsolateTo" = "8:"
+ "{1FB2D0AE-D3B9-43D4-B9DD-F88EC61E35DE}:_2ED4D01C4AB04611862206AEB490440A"
+ "SourcePath" = "8:..\\winbuild\\x64\\Release\\gcc\\libmpi.a"
+ "TargetName" = "8:libmpi.a"
+ "Tag" = "8:"
"{1FB2D0AE-D3B9-43D4-B9DD-F88EC61E35DE}:_328D583D55BC4B38A679F9ACF3DCE98A"
"SourcePath" = "8:..\\winbuild\\x64\\Release\\bin\\smpd.exe"
@@ -787,7 +845,7 @@
- "AssemblyAsmDisplayName" = "8:wmpiexec, Version=1.0.3898.24476, Culture=neutral, processorArchitecture=MSIL"
+ "AssemblyAsmDisplayName" = "8:wmpiexec, Version=1.0.3947.19214, Culture=neutral, processorArchitecture=MSIL"
"ScatterAssemblies"
@@ -1649,11 +1707,31 @@
"IsolateTo" = "8:"
+ "{1FB2D0AE-D3B9-43D4-B9DD-F88EC61E35DE}:_F8734FE1E95D489C99076694D4F5C387"
+ "SourcePath" = "8:..\\winbuild\\x64\\Release\\gcc\\libfmpich2g.a"
+ "TargetName" = "8:libfmpich2g.a"
+ "Tag" = "8:"
"{9F6F8455-1EF1-4B85-886A-4223BCC8E7F7}:_FA7FEB4E019147ABB551882DD956CA32"
- "AssemblyAsmDisplayName" = "8:wmpiconfig, Version=1.0.3898.24477, Culture=neutral, processorArchitecture=MSIL"
+ "AssemblyAsmDisplayName" = "8:wmpiconfig, Version=1.0.3947.19213, Culture=neutral, processorArchitecture=MSIL"
"ScatterAssemblies"
@@ -1848,7 +1926,7 @@
"ProductName" = "8:MPICH2 64-bit"
"ProductCode" = "8:{B91EB9DA-98D2-4241-87EA-3D889B58D564}"
"PackageCode" = "8:{F55A402E-C195-4398-ABA6-870074B69FEC}"
- "UpgradeCode" = "8:{1B3E5756-D592-462D-9826-D56FFD29DA91}"
+ "UpgradeCode" = "8:{45D2D7E2-81B1-4B17-9907-6B451D30E9A0}"
"RestartWWWService" = "11:FALSE"
"RemovePreviousVersions" = "11:TRUE"
"DetectNewerInstalledVersion" = "11:TRUE"
Modified: mpich2/branches/release/mpich2-1.3.x/makewindist.bat
--- mpich2/branches/release/mpich2-1.3.x/makewindist.bat 2010-11-23 07:30:29 UTC (rev 7486)
+++ mpich2/branches/release/mpich2-1.3.x/makewindist.bat 2010-11-23 19:05:11 UTC (rev 7487)
@@ -194,8 +194,10 @@
:BUILD_WIN64
if "%CPU%" == "X64" goto AFTER_WIN64_SANITY_CHECK
if "%CPU%" == "AMD64" goto AFTER_WIN64_SANITY_CHECK
-echo ERROR: WIN64 Build environment not setup correctly ...
-GOTO END
+echo WARNING: WIN64 Build environment setup manually ...
+set CPU=x64
+set NODEBUG=1
+set APPVER=5.02
:AFTER_WIN64_SANITY_CHECK
echo Building MPICH2 x64 ...
REM Adding hpc sdk import libs to PATH so that VS can detect it
@@ -209,6 +211,12 @@
devenv.com examples\examples.sln /project cpi /build "Release|x64" >> make_x64.log
if %errorlevel% NEQ 0 goto BUILDERROR
echo .....................................................SUCCESS
+echo Building GNU libs ...
+cd maint
+CALL makegcclibs_64.bat
+if %errorlevel% NEQ 0 goto BUILDERROR
+echo .....................................................SUCCESS
+cd ..
echo Building Wrapper utils
devenv.com mpich2.sln /build "wrapperUtilRelease" >> make_x64.log
Modified: mpich2/branches/release/mpich2-1.3.x/mpich2.sln
--- mpich2/branches/release/mpich2-1.3.x/mpich2.sln 2010-11-23 07:30:29 UTC (rev 7486)
+++ mpich2/branches/release/mpich2-1.3.x/mpich2.sln 2010-11-23 19:05:11 UTC (rev 7487)
@@ -478,7 +478,6 @@
{0FACD81A-FE33-4845-ACF6-A1D50BD35991}.wrapperUtilRelease|Any CPU.ActiveCfg = ch3sockRelease|Win32
{0FACD81A-FE33-4845-ACF6-A1D50BD35991}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = ch3sockRelease|Win32
{0FACD81A-FE33-4845-ACF6-A1D50BD35991}.wrapperUtilRelease|Win32.ActiveCfg = ch3sockRelease|Win32
- {0FACD81A-FE33-4845-ACF6-A1D50BD35991}.wrapperUtilRelease|Win32.Build.0 = ch3sockRelease|Win32
{0FACD81A-FE33-4845-ACF6-A1D50BD35991}.wrapperUtilRelease|x64.ActiveCfg = fortDebugConfig_1_0_5|Win32
{7FBADF88-70AB-4415-B7DA-248EFA299A86}.ch3nemesisDebug|Any CPU.ActiveCfg = ch3sockDebug|Win32
{7FBADF88-70AB-4415-B7DA-248EFA299A86}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = ch3sockDebug|Win32
@@ -682,7 +681,6 @@
{7FBADF88-70AB-4415-B7DA-248EFA299A86}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{7FBADF88-70AB-4415-B7DA-248EFA299A86}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = ch3sockRelease|Win32
{7FBADF88-70AB-4415-B7DA-248EFA299A86}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {7FBADF88-70AB-4415-B7DA-248EFA299A86}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{7FBADF88-70AB-4415-B7DA-248EFA299A86}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{88CF50C7-ECDC-4423-9332-8A0647374428}.ch3nemesisDebug|Any CPU.ActiveCfg = ch3sockDebug|Win32
{88CF50C7-ECDC-4423-9332-8A0647374428}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = ch3sockDebug|Win32
@@ -888,7 +886,6 @@
{88CF50C7-ECDC-4423-9332-8A0647374428}.wrapperUtilRelease|Any CPU.ActiveCfg = ch3sockmtPRelease|Win32
{88CF50C7-ECDC-4423-9332-8A0647374428}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = ch3sockRelease|Win32
{88CF50C7-ECDC-4423-9332-8A0647374428}.wrapperUtilRelease|Win32.ActiveCfg = ch3sockmtPRelease|Win32
- {88CF50C7-ECDC-4423-9332-8A0647374428}.wrapperUtilRelease|Win32.Build.0 = ch3sockmtPRelease|Win32
{88CF50C7-ECDC-4423-9332-8A0647374428}.wrapperUtilRelease|x64.ActiveCfg = fmpe|Win32
{BB4554EE-65E6-4936-B4A5-83D1583F0BFC}.ch3nemesisDebug|Any CPU.ActiveCfg = ch3sockDebug|Win32
{BB4554EE-65E6-4936-B4A5-83D1583F0BFC}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = ch3sockDebug|Win32
@@ -1105,7 +1102,6 @@
{BB4554EE-65E6-4936-B4A5-83D1583F0BFC}.wrapperUtilRelease|Any CPU.ActiveCfg = ch3sockmtPRelease|Win32
{BB4554EE-65E6-4936-B4A5-83D1583F0BFC}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = ch3sockRelease|Win32
{BB4554EE-65E6-4936-B4A5-83D1583F0BFC}.wrapperUtilRelease|Win32.ActiveCfg = ch3sockmtPRelease|Win32
- {BB4554EE-65E6-4936-B4A5-83D1583F0BFC}.wrapperUtilRelease|Win32.Build.0 = ch3sockmtPRelease|Win32
{BB4554EE-65E6-4936-B4A5-83D1583F0BFC}.wrapperUtilRelease|x64.ActiveCfg = ch3nemesisPRelease|Win32
{DFFFA925-D59C-4480-8094-1B7E9D12BC02}.ch3nemesisDebug|Any CPU.ActiveCfg = ch3sockDebug|Win32
{DFFFA925-D59C-4480-8094-1B7E9D12BC02}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = ch3sockDebug|Win32
@@ -1329,7 +1325,6 @@
{DFFFA925-D59C-4480-8094-1B7E9D12BC02}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{DFFFA925-D59C-4480-8094-1B7E9D12BC02}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{DFFFA925-D59C-4480-8094-1B7E9D12BC02}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {DFFFA925-D59C-4480-8094-1B7E9D12BC02}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{DFFFA925-D59C-4480-8094-1B7E9D12BC02}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{A611626E-E8FF-44A7-8105-149AB9CA5D20}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{A611626E-E8FF-44A7-8105-149AB9CA5D20}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -1547,7 +1542,6 @@
{A611626E-E8FF-44A7-8105-149AB9CA5D20}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{A611626E-E8FF-44A7-8105-149AB9CA5D20}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{A611626E-E8FF-44A7-8105-149AB9CA5D20}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {A611626E-E8FF-44A7-8105-149AB9CA5D20}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{A611626E-E8FF-44A7-8105-149AB9CA5D20}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{3DE857FA-6F20-4214-8D99-811165354D3F}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{3DE857FA-6F20-4214-8D99-811165354D3F}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -1764,7 +1758,6 @@
{3DE857FA-6F20-4214-8D99-811165354D3F}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{3DE857FA-6F20-4214-8D99-811165354D3F}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{3DE857FA-6F20-4214-8D99-811165354D3F}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {3DE857FA-6F20-4214-8D99-811165354D3F}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{3DE857FA-6F20-4214-8D99-811165354D3F}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{D45A7472-5ECD-481D-A26D-98D88ED44305}.ch3nemesisDebug|Any CPU.ActiveCfg = gfortRelease|Win32
{D45A7472-5ECD-481D-A26D-98D88ED44305}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = fortDebug|Win32
@@ -1968,7 +1961,6 @@
{D45A7472-5ECD-481D-A26D-98D88ED44305}.wrapperUtilRelease|Any CPU.ActiveCfg = gfortRelease|Win32
{D45A7472-5ECD-481D-A26D-98D88ED44305}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = gfortRelease|Win32
{D45A7472-5ECD-481D-A26D-98D88ED44305}.wrapperUtilRelease|Win32.ActiveCfg = gfortRelease|Win32
- {D45A7472-5ECD-481D-A26D-98D88ED44305}.wrapperUtilRelease|Win32.Build.0 = gfortRelease|Win32
{D45A7472-5ECD-481D-A26D-98D88ED44305}.wrapperUtilRelease|x64.ActiveCfg = ch3nemesisPRelease|Win32
{EFAF72A2-7154-410B-9235-460444894A38}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{EFAF72A2-7154-410B-9235-460444894A38}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -2173,7 +2165,6 @@
{EFAF72A2-7154-410B-9235-460444894A38}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{EFAF72A2-7154-410B-9235-460444894A38}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{EFAF72A2-7154-410B-9235-460444894A38}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {EFAF72A2-7154-410B-9235-460444894A38}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{EFAF72A2-7154-410B-9235-460444894A38}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{73DC517A-212E-4C8C-8B13-D5CA120C7B5C}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{73DC517A-212E-4C8C-8B13-D5CA120C7B5C}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -2378,7 +2369,6 @@
{73DC517A-212E-4C8C-8B13-D5CA120C7B5C}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{73DC517A-212E-4C8C-8B13-D5CA120C7B5C}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{73DC517A-212E-4C8C-8B13-D5CA120C7B5C}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {73DC517A-212E-4C8C-8B13-D5CA120C7B5C}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{73DC517A-212E-4C8C-8B13-D5CA120C7B5C}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{0703FA94-8B8C-49AC-BFCE-91F67B599E51}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{0703FA94-8B8C-49AC-BFCE-91F67B599E51}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -2604,7 +2594,6 @@
{0703FA94-8B8C-49AC-BFCE-91F67B599E51}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{0703FA94-8B8C-49AC-BFCE-91F67B599E51}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{0703FA94-8B8C-49AC-BFCE-91F67B599E51}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {0703FA94-8B8C-49AC-BFCE-91F67B599E51}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{0703FA94-8B8C-49AC-BFCE-91F67B599E51}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{97B727A6-0F41-4E8E-A524-FC0F30D3AC8A}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{97B727A6-0F41-4E8E-A524-FC0F30D3AC8A}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -2833,7 +2822,6 @@
{97B727A6-0F41-4E8E-A524-FC0F30D3AC8A}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{97B727A6-0F41-4E8E-A524-FC0F30D3AC8A}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{97B727A6-0F41-4E8E-A524-FC0F30D3AC8A}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {97B727A6-0F41-4E8E-A524-FC0F30D3AC8A}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{97B727A6-0F41-4E8E-A524-FC0F30D3AC8A}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{F2B709B4-AB53-4E39-8025-00060DA5279D}.ch3nemesisDebug|Any CPU.ActiveCfg = gfortRelease|Win32
{F2B709B4-AB53-4E39-8025-00060DA5279D}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = gfortRelease|Win32
@@ -3279,9 +3267,7 @@
{3B6F7528-9943-46B3-9609-5ED0D7C31EFE}.wrapperUtilRelease|Any CPU.ActiveCfg = Release
{3B6F7528-9943-46B3-9609-5ED0D7C31EFE}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release
{3B6F7528-9943-46B3-9609-5ED0D7C31EFE}.wrapperUtilRelease|Win32.ActiveCfg = Release
- {3B6F7528-9943-46B3-9609-5ED0D7C31EFE}.wrapperUtilRelease|Win32.Build.0 = Release
{3B6F7528-9943-46B3-9609-5ED0D7C31EFE}.wrapperUtilRelease|x64.ActiveCfg = Release
- {3B6F7528-9943-46B3-9609-5ED0D7C31EFE}.wrapperUtilRelease|x64.Build.0 = Release
{68A6C7AD-9713-4315-9ABE-B47E22E5E0A9}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{68A6C7AD-9713-4315-9ABE-B47E22E5E0A9}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Release|Win32
{68A6C7AD-9713-4315-9ABE-B47E22E5E0A9}.ch3nemesisDebug|Win32.ActiveCfg = Debug|Win32
@@ -3490,7 +3476,6 @@
{68A6C7AD-9713-4315-9ABE-B47E22E5E0A9}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{68A6C7AD-9713-4315-9ABE-B47E22E5E0A9}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{68A6C7AD-9713-4315-9ABE-B47E22E5E0A9}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {68A6C7AD-9713-4315-9ABE-B47E22E5E0A9}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{68A6C7AD-9713-4315-9ABE-B47E22E5E0A9}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{EAC12E9B-4B5D-4D26-8FAE-2425A48E3804}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{EAC12E9B-4B5D-4D26-8FAE-2425A48E3804}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -3717,7 +3702,6 @@
{EAC12E9B-4B5D-4D26-8FAE-2425A48E3804}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{EAC12E9B-4B5D-4D26-8FAE-2425A48E3804}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{EAC12E9B-4B5D-4D26-8FAE-2425A48E3804}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {EAC12E9B-4B5D-4D26-8FAE-2425A48E3804}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{EAC12E9B-4B5D-4D26-8FAE-2425A48E3804}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{23709B5A-153D-422B-B006-17CC05552B57}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{23709B5A-153D-422B-B006-17CC05552B57}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -3923,7 +3907,6 @@
{23709B5A-153D-422B-B006-17CC05552B57}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{23709B5A-153D-422B-B006-17CC05552B57}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{23709B5A-153D-422B-B006-17CC05552B57}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {23709B5A-153D-422B-B006-17CC05552B57}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{23709B5A-153D-422B-B006-17CC05552B57}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{AA0AAB17-BDC9-45DD-8FF0-01F8D384FB18}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{AA0AAB17-BDC9-45DD-8FF0-01F8D384FB18}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -4130,7 +4113,6 @@
{AA0AAB17-BDC9-45DD-8FF0-01F8D384FB18}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{AA0AAB17-BDC9-45DD-8FF0-01F8D384FB18}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{AA0AAB17-BDC9-45DD-8FF0-01F8D384FB18}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {AA0AAB17-BDC9-45DD-8FF0-01F8D384FB18}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{AA0AAB17-BDC9-45DD-8FF0-01F8D384FB18}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{B0365633-1495-4C2C-8FD6-6943F5208D5C}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Any CPU
{B0365633-1495-4C2C-8FD6-6943F5208D5C}.ch3nemesisDebug|Any CPU.Build.0 = Debug|Any CPU
@@ -4343,6 +4325,7 @@
{B0365633-1495-4C2C-8FD6-6943F5208D5C}.wrapperUtilRelease|Mixed Platforms.Build.0 = Release|Any CPU
{B0365633-1495-4C2C-8FD6-6943F5208D5C}.wrapperUtilRelease|Win32.ActiveCfg = Release|Any CPU
{B0365633-1495-4C2C-8FD6-6943F5208D5C}.wrapperUtilRelease|x64.ActiveCfg = Release|Any CPU
+ {B0365633-1495-4C2C-8FD6-6943F5208D5C}.wrapperUtilRelease|x64.Build.0 = Release|Any CPU
{8E126FE2-6F09-42FF-B17C-9C73BF3B74B9}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Any CPU
{8E126FE2-6F09-42FF-B17C-9C73BF3B74B9}.ch3nemesisDebug|Any CPU.Build.0 = Debug|Any CPU
{8E126FE2-6F09-42FF-B17C-9C73BF3B74B9}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Any CPU
@@ -4554,6 +4537,7 @@
{8E126FE2-6F09-42FF-B17C-9C73BF3B74B9}.wrapperUtilRelease|Mixed Platforms.Build.0 = Release|Any CPU
{8E126FE2-6F09-42FF-B17C-9C73BF3B74B9}.wrapperUtilRelease|Win32.ActiveCfg = Release|Any CPU
{8E126FE2-6F09-42FF-B17C-9C73BF3B74B9}.wrapperUtilRelease|x64.ActiveCfg = Release|Any CPU
+ {8E126FE2-6F09-42FF-B17C-9C73BF3B74B9}.wrapperUtilRelease|x64.Build.0 = Release|Any CPU
{1C99A11B-39CF-454A-BA19-5CA9BE9A1A70}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Any CPU
{1C99A11B-39CF-454A-BA19-5CA9BE9A1A70}.ch3nemesisDebug|Any CPU.Build.0 = Debug|Any CPU
{1C99A11B-39CF-454A-BA19-5CA9BE9A1A70}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Any CPU
@@ -4765,6 +4749,7 @@
{1C99A11B-39CF-454A-BA19-5CA9BE9A1A70}.wrapperUtilRelease|Mixed Platforms.Build.0 = Release|Any CPU
{1C99A11B-39CF-454A-BA19-5CA9BE9A1A70}.wrapperUtilRelease|Win32.ActiveCfg = Release|Any CPU
{1C99A11B-39CF-454A-BA19-5CA9BE9A1A70}.wrapperUtilRelease|x64.ActiveCfg = Release|Any CPU
+ {1C99A11B-39CF-454A-BA19-5CA9BE9A1A70}.wrapperUtilRelease|x64.Build.0 = Release|Any CPU
{6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug
{6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.ch3nemesisDebug|Any CPU.Build.0 = Debug
{6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug
@@ -5056,9 +5041,7 @@
{6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.wrapperUtilRelease|Any CPU.ActiveCfg = Release
{6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release
{6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.wrapperUtilRelease|Win32.ActiveCfg = Release
- {6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.wrapperUtilRelease|Win32.Build.0 = Release
{6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.wrapperUtilRelease|x64.ActiveCfg = Release
- {6460CD1F-66E3-40FF-A9C9-A48CDA9B6EBD}.wrapperUtilRelease|x64.Build.0 = Release
{D9B35828-6D2D-4661-827E-80FDBB3C07C5}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{D9B35828-6D2D-4661-827E-80FDBB3C07C5}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
{D9B35828-6D2D-4661-827E-80FDBB3C07C5}.ch3nemesisDebug|Win32.ActiveCfg = Debug|Win32
@@ -5275,7 +5258,6 @@
{D9B35828-6D2D-4661-827E-80FDBB3C07C5}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{D9B35828-6D2D-4661-827E-80FDBB3C07C5}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{D9B35828-6D2D-4661-827E-80FDBB3C07C5}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {D9B35828-6D2D-4661-827E-80FDBB3C07C5}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{D9B35828-6D2D-4661-827E-80FDBB3C07C5}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{10115F75-1A40-4155-BCD4-9521609DFFEC}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{10115F75-1A40-4155-BCD4-9521609DFFEC}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = ch3nemesisDebug|Win32
@@ -5490,7 +5472,6 @@
{10115F75-1A40-4155-BCD4-9521609DFFEC}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{10115F75-1A40-4155-BCD4-9521609DFFEC}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{10115F75-1A40-4155-BCD4-9521609DFFEC}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {10115F75-1A40-4155-BCD4-9521609DFFEC}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{10115F75-1A40-4155-BCD4-9521609DFFEC}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{ACB7CE11-E708-49CD-9DC5-6022B1BF730B}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{ACB7CE11-E708-49CD-9DC5-6022B1BF730B}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -5703,7 +5684,6 @@
{ACB7CE11-E708-49CD-9DC5-6022B1BF730B}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{ACB7CE11-E708-49CD-9DC5-6022B1BF730B}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{ACB7CE11-E708-49CD-9DC5-6022B1BF730B}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {ACB7CE11-E708-49CD-9DC5-6022B1BF730B}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{ACB7CE11-E708-49CD-9DC5-6022B1BF730B}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
{8A501EEE-94AD-4FAA-A67F-EE5E6D9E5CD2}.ch3nemesisDebug|Any CPU.ActiveCfg = Debug|Win32
{8A501EEE-94AD-4FAA-A67F-EE5E6D9E5CD2}.ch3nemesisDebug|Mixed Platforms.ActiveCfg = Debug|Win32
@@ -5941,7 +5921,6 @@
{8A501EEE-94AD-4FAA-A67F-EE5E6D9E5CD2}.wrapperUtilRelease|Any CPU.ActiveCfg = Release|Win32
{8A501EEE-94AD-4FAA-A67F-EE5E6D9E5CD2}.wrapperUtilRelease|Mixed Platforms.ActiveCfg = Release|Win32
{8A501EEE-94AD-4FAA-A67F-EE5E6D9E5CD2}.wrapperUtilRelease|Win32.ActiveCfg = Release|Win32
- {8A501EEE-94AD-4FAA-A67F-EE5E6D9E5CD2}.wrapperUtilRelease|Win32.Build.0 = Release|Win32
{8A501EEE-94AD-4FAA-A67F-EE5E6D9E5CD2}.wrapperUtilRelease|x64.ActiveCfg = Release|Win32
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
Modified: mpich2/branches/release/mpich2-1.3.x/src/binding/f77/mpich2fg.def
--- mpich2/branches/release/mpich2-1.3.x/src/binding/f77/mpich2fg.def 2010-11-23 07:30:29 UTC (rev 7486)
+++ mpich2/branches/release/mpich2-1.3.x/src/binding/f77/mpich2fg.def 2010-11-23 19:05:11 UTC (rev 7487)
@@ -2,254 +2,750 @@
EXPORTS
pmpi_abort__
+ pmpi_abort_=pmpi_abort__
+ _pmpi_abort_=pmpi_abort__
mpi_abort__=pmpi_abort__
+ _mpi_abort_=pmpi_abort__
+ mpi_abort_=pmpi_abort__
pmpi_accumulate__
+ pmpi_accumulate_=pmpi_accumulate__
+ _pmpi_accumulate_=pmpi_accumulate__
mpi_accumulate__=pmpi_accumulate__
+ _mpi_accumulate_=pmpi_accumulate__
+ mpi_accumulate_=pmpi_accumulate__
pmpi_add_error_class__
+ pmpi_add_error_class_=pmpi_add_error_class__
+ _pmpi_add_error_class_=pmpi_add_error_class__
mpi_add_error_class__=pmpi_add_error_class__
+ _mpi_add_error_class_=pmpi_add_error_class__
+ mpi_add_error_class_=pmpi_add_error_class__
pmpi_add_error_code__
+ pmpi_add_error_code_=pmpi_add_error_code__
+ _pmpi_add_error_code_=pmpi_add_error_code__
mpi_add_error_code__=pmpi_add_error_code__
+ _mpi_add_error_code_=pmpi_add_error_code__
+ mpi_add_error_code_=pmpi_add_error_code__
pmpi_add_error_string__
+ pmpi_add_error_string_=pmpi_add_error_string__
+ _pmpi_add_error_string_=pmpi_add_error_string__
mpi_add_error_string__=pmpi_add_error_string__
+ _mpi_add_error_string_=pmpi_add_error_string__
+ mpi_add_error_string_=pmpi_add_error_string__
pmpi_address__
+ pmpi_address_=pmpi_address__
+ _pmpi_address_=pmpi_address__
mpi_address__=pmpi_address__
+ _mpi_address_=pmpi_address__
+ mpi_address_=pmpi_address__
pmpi_allgather__
+ pmpi_allgather_=pmpi_allgather__
+ _pmpi_allgather_=pmpi_allgather__
mpi_allgather__=pmpi_allgather__
+ _mpi_allgather_=pmpi_allgather__
+ mpi_allgather_=pmpi_allgather__
pmpi_allgatherv__
+ pmpi_allgatherv_=pmpi_allgatherv__
+ _pmpi_allgatherv_=pmpi_allgatherv__
mpi_allgatherv__=pmpi_allgatherv__
+ _mpi_allgatherv_=pmpi_allgatherv__
+ mpi_allgatherv_=pmpi_allgatherv__
pmpi_alloc_mem__
+ pmpi_alloc_mem_=pmpi_alloc_mem__
+ _pmpi_alloc_mem_=pmpi_alloc_mem__
mpi_alloc_mem__=pmpi_alloc_mem__
+ _mpi_alloc_mem_=pmpi_alloc_mem__
+ mpi_alloc_mem_=pmpi_alloc_mem__
pmpi_allreduce__
+ pmpi_allreduce_=pmpi_allreduce__
+ _pmpi_allreduce_=pmpi_allreduce__
mpi_allreduce__=pmpi_allreduce__
+ _mpi_allreduce_=pmpi_allreduce__
+ mpi_allreduce_=pmpi_allreduce__
pmpi_alltoall__
+ pmpi_alltoall_=pmpi_alltoall__
+ _pmpi_alltoall_=pmpi_alltoall__
mpi_alltoall__=pmpi_alltoall__
+ _mpi_alltoall_=pmpi_alltoall__
+ mpi_alltoall_=pmpi_alltoall__
pmpi_alltoallv__
+ pmpi_alltoallv_=pmpi_alltoallv__
+ _pmpi_alltoallv_=pmpi_alltoallv__
mpi_alltoallv__=pmpi_alltoallv__
+ _mpi_alltoallv_=pmpi_alltoallv__
+ mpi_alltoallv_=pmpi_alltoallv__
pmpi_alltoallw__
+ pmpi_alltoallw_=pmpi_alltoallw__
+ _pmpi_alltoallw_=pmpi_alltoallw__
mpi_alltoallw__=pmpi_alltoallw__
+ _mpi_alltoallw_=pmpi_alltoallw__
+ mpi_alltoallw_=pmpi_alltoallw__
pmpi_attr_delete__
+ pmpi_attr_delete_=pmpi_attr_delete__
+ _pmpi_attr_delete_=pmpi_attr_delete__
mpi_attr_delete__=pmpi_attr_delete__
+ _mpi_attr_delete_=pmpi_attr_delete__
+ mpi_attr_delete_=pmpi_attr_delete__
pmpi_attr_get__
+ pmpi_attr_get_=pmpi_attr_get__
+ _pmpi_attr_get_=pmpi_attr_get__
mpi_attr_get__=pmpi_attr_get__
+ _mpi_attr_get_=pmpi_attr_get__
+ mpi_attr_get_=pmpi_attr_get__
pmpi_attr_put__
+ pmpi_attr_put_=pmpi_attr_put__
+ _pmpi_attr_put_=pmpi_attr_put__
mpi_attr_put__=pmpi_attr_put__
+ _mpi_attr_put_=pmpi_attr_put__
+ mpi_attr_put_=pmpi_attr_put__
pmpi_barrier__
+ pmpi_barrier_=pmpi_barrier__
+ _pmpi_barrier_=pmpi_barrier__
mpi_barrier__=pmpi_barrier__
+ _mpi_barrier_=pmpi_barrier__
+ mpi_barrier_=pmpi_barrier__
pmpi_bcast__
+ pmpi_bcast_=pmpi_bcast__
+ _pmpi_bcast_=pmpi_bcast__
mpi_bcast__=pmpi_bcast__
+ _mpi_bcast_=pmpi_bcast__
+ mpi_bcast_=pmpi_bcast__
pmpi_bsend__
+ pmpi_bsend_=pmpi_bsend__
+ _pmpi_bsend_=pmpi_bsend__
mpi_bsend__=pmpi_bsend__
+ _mpi_bsend_=pmpi_bsend__
+ mpi_bsend_=pmpi_bsend__
pmpi_bsend_init__
+ pmpi_bsend_init_=pmpi_bsend_init__
+ _pmpi_bsend_init_=pmpi_bsend_init__
mpi_bsend_init__=pmpi_bsend_init__
+ _mpi_bsend_init_=pmpi_bsend_init__
+ mpi_bsend_init_=pmpi_bsend_init__
pmpi_buffer_attach__
+ pmpi_buffer_attach_=pmpi_buffer_attach__
+ _pmpi_buffer_attach_=pmpi_buffer_attach__
mpi_buffer_attach__=pmpi_buffer_attach__
+ _mpi_buffer_attach_=pmpi_buffer_attach__
+ mpi_buffer_attach_=pmpi_buffer_attach__
pmpi_buffer_detach__
+ pmpi_buffer_detach_=pmpi_buffer_detach__
+ _pmpi_buffer_detach_=pmpi_buffer_detach__
mpi_buffer_detach__=pmpi_buffer_detach__
+ _mpi_buffer_detach_=pmpi_buffer_detach__
+ mpi_buffer_detach_=pmpi_buffer_detach__
pmpi_cancel__
+ pmpi_cancel_=pmpi_cancel__
+ _pmpi_cancel_=pmpi_cancel__
mpi_cancel__=pmpi_cancel__
+ _mpi_cancel_=pmpi_cancel__
+ mpi_cancel_=pmpi_cancel__
pmpi_cart_coords__
+ pmpi_cart_coords_=pmpi_cart_coords__
+ _pmpi_cart_coords_=pmpi_cart_coords__
mpi_cart_coords__=pmpi_cart_coords__
+ _mpi_cart_coords_=pmpi_cart_coords__
+ mpi_cart_coords_=pmpi_cart_coords__
pmpi_cart_create__
+ pmpi_cart_create_=pmpi_cart_create__
+ _pmpi_cart_create_=pmpi_cart_create__
mpi_cart_create__=pmpi_cart_create__
+ _mpi_cart_create_=pmpi_cart_create__
+ mpi_cart_create_=pmpi_cart_create__
pmpi_cart_get__
+ pmpi_cart_get_=pmpi_cart_get__
+ _pmpi_cart_get_=pmpi_cart_get__
mpi_cart_get__=pmpi_cart_get__
+ _mpi_cart_get_=pmpi_cart_get__
+ mpi_cart_get_=pmpi_cart_get__
pmpi_cart_map__
+ pmpi_cart_map_=pmpi_cart_map__
+ _pmpi_cart_map_=pmpi_cart_map__
mpi_cart_map__=pmpi_cart_map__
+ _mpi_cart_map_=pmpi_cart_map__
+ mpi_cart_map_=pmpi_cart_map__
pmpi_cart_rank__
+ pmpi_cart_rank_=pmpi_cart_rank__
+ _pmpi_cart_rank_=pmpi_cart_rank__
mpi_cart_rank__=pmpi_cart_rank__
+ _mpi_cart_rank_=pmpi_cart_rank__
+ mpi_cart_rank_=pmpi_cart_rank__
pmpi_cart_shift__
+ pmpi_cart_shift_=pmpi_cart_shift__
+ _pmpi_cart_shift_=pmpi_cart_shift__
mpi_cart_shift__=pmpi_cart_shift__
+ _mpi_cart_shift_=pmpi_cart_shift__
+ mpi_cart_shift_=pmpi_cart_shift__
pmpi_cart_sub__
+ pmpi_cart_sub_=pmpi_cart_sub__
+ _pmpi_cart_sub_=pmpi_cart_sub__
mpi_cart_sub__=pmpi_cart_sub__
+ _mpi_cart_sub_=pmpi_cart_sub__
+ mpi_cart_sub_=pmpi_cart_sub__
pmpi_cartdim_get__
+ pmpi_cartdim_get_=pmpi_cartdim_get__
+ _pmpi_cartdim_get_=pmpi_cartdim_get__
mpi_cartdim_get__=pmpi_cartdim_get__
+ _mpi_cartdim_get_=pmpi_cartdim_get__
+ mpi_cartdim_get_=pmpi_cartdim_get__
pmpi_close_port__
+ pmpi_close_port_=pmpi_close_port__
+ _pmpi_close_port_=pmpi_close_port__
mpi_close_port__=pmpi_close_port__
+ _mpi_close_port_=pmpi_close_port__
+ mpi_close_port_=pmpi_close_port__
pmpi_comm_accept__
+ pmpi_comm_accept_=pmpi_comm_accept__
+ _pmpi_comm_accept_=pmpi_comm_accept__
mpi_comm_accept__=pmpi_comm_accept__
+ _mpi_comm_accept_=pmpi_comm_accept__
+ mpi_comm_accept_=pmpi_comm_accept__
pmpi_comm_call_errhandler__
+ pmpi_comm_call_errhandler_=pmpi_comm_call_errhandler__
+ _pmpi_comm_call_errhandler_=pmpi_comm_call_errhandler__
mpi_comm_call_errhandler__=pmpi_comm_call_errhandler__
+ _mpi_comm_call_errhandler_=pmpi_comm_call_errhandler__
+ mpi_comm_call_errhandler_=pmpi_comm_call_errhandler__
pmpi_comm_compare__
+ pmpi_comm_compare_=pmpi_comm_compare__
+ _pmpi_comm_compare_=pmpi_comm_compare__
mpi_comm_compare__=pmpi_comm_compare__
+ _mpi_comm_compare_=pmpi_comm_compare__
+ mpi_comm_compare_=pmpi_comm_compare__
pmpi_comm_connect__
+ pmpi_comm_connect_=pmpi_comm_connect__
+ _pmpi_comm_connect_=pmpi_comm_connect__
mpi_comm_connect__=pmpi_comm_connect__
+ _mpi_comm_connect_=pmpi_comm_connect__
+ mpi_comm_connect_=pmpi_comm_connect__
pmpi_comm_create__
+ pmpi_comm_create_=pmpi_comm_create__
+ _pmpi_comm_create_=pmpi_comm_create__
mpi_comm_create__=pmpi_comm_create__
+ _mpi_comm_create_=pmpi_comm_create__
+ mpi_comm_create_=pmpi_comm_create__
pmpi_comm_create_errhandler__
+ pmpi_comm_create_errhandler_=pmpi_comm_create_errhandler__
+ _pmpi_comm_create_errhandler_=pmpi_comm_create_errhandler__
mpi_comm_create_errhandler__=pmpi_comm_create_errhandler__
+ _mpi_comm_create_errhandler_=pmpi_comm_create_errhandler__
+ mpi_comm_create_errhandler_=pmpi_comm_create_errhandler__
pmpi_comm_create_keyval__
+ pmpi_comm_create_keyval_=pmpi_comm_create_keyval__
+ _pmpi_comm_create_keyval_=pmpi_comm_create_keyval__
mpi_comm_create_keyval__=pmpi_comm_create_keyval__
+ _mpi_comm_create_keyval_=pmpi_comm_create_keyval__
+ mpi_comm_create_keyval_=pmpi_comm_create_keyval__
pmpi_comm_delete_attr__
+ pmpi_comm_delete_attr_=pmpi_comm_delete_attr__
+ _pmpi_comm_delete_attr_=pmpi_comm_delete_attr__
mpi_comm_delete_attr__=pmpi_comm_delete_attr__
+ _mpi_comm_delete_attr_=pmpi_comm_delete_attr__
+ mpi_comm_delete_attr_=pmpi_comm_delete_attr__
pmpi_comm_disconnect__
+ pmpi_comm_disconnect_=pmpi_comm_disconnect__
+ _pmpi_comm_disconnect_=pmpi_comm_disconnect__
mpi_comm_disconnect__=pmpi_comm_disconnect__
+ _mpi_comm_disconnect_=pmpi_comm_disconnect__
+ mpi_comm_disconnect_=pmpi_comm_disconnect__
pmpi_comm_dup__
+ pmpi_comm_dup_=pmpi_comm_dup__
+ _pmpi_comm_dup_=pmpi_comm_dup__
mpi_comm_dup__=pmpi_comm_dup__
+ _mpi_comm_dup_=pmpi_comm_dup__
+ mpi_comm_dup_=pmpi_comm_dup__
pmpi_comm_free__
+ pmpi_comm_free_=pmpi_comm_free__
+ _pmpi_comm_free_=pmpi_comm_free__
mpi_comm_free__=pmpi_comm_free__
+ _mpi_comm_free_=pmpi_comm_free__
+ mpi_comm_free_=pmpi_comm_free__
pmpi_comm_free_keyval__
+ pmpi_comm_free_keyval_=pmpi_comm_free_keyval__
+ _pmpi_comm_free_keyval_=pmpi_comm_free_keyval__
mpi_comm_free_keyval__=pmpi_comm_free_keyval__
+ _mpi_comm_free_keyval_=pmpi_comm_free_keyval__
+ mpi_comm_free_keyval_=pmpi_comm_free_keyval__
pmpi_comm_get_attr__
+ pmpi_comm_get_attr_=pmpi_comm_get_attr__
+ _pmpi_comm_get_attr_=pmpi_comm_get_attr__
mpi_comm_get_attr__=pmpi_comm_get_attr__
+ _mpi_comm_get_attr_=pmpi_comm_get_attr__
+ mpi_comm_get_attr_=pmpi_comm_get_attr__
pmpi_comm_get_errhandler__
+ pmpi_comm_get_errhandler_=pmpi_comm_get_errhandler__
+ _pmpi_comm_get_errhandler_=pmpi_comm_get_errhandler__
mpi_comm_get_errhandler__=pmpi_comm_get_errhandler__
+ _mpi_comm_get_errhandler_=pmpi_comm_get_errhandler__
+ mpi_comm_get_errhandler_=pmpi_comm_get_errhandler__
pmpi_comm_get_name__
+ pmpi_comm_get_name_=pmpi_comm_get_name__
+ _pmpi_comm_get_name_=pmpi_comm_get_name__
mpi_comm_get_name__=pmpi_comm_get_name__
+ _mpi_comm_get_name_=pmpi_comm_get_name__
+ mpi_comm_get_name_=pmpi_comm_get_name__
pmpi_comm_get_parent__
+ pmpi_comm_get_parent_=pmpi_comm_get_parent__
+ _pmpi_comm_get_parent_=pmpi_comm_get_parent__
mpi_comm_get_parent__=pmpi_comm_get_parent__
+ _mpi_comm_get_parent_=pmpi_comm_get_parent__
+ mpi_comm_get_parent_=pmpi_comm_get_parent__
pmpi_comm_group__
+ pmpi_comm_group_=pmpi_comm_group__
+ _pmpi_comm_group_=pmpi_comm_group__
mpi_comm_group__=pmpi_comm_group__
+ _mpi_comm_group_=pmpi_comm_group__
+ mpi_comm_group_=pmpi_comm_group__
pmpi_comm_join__
+ pmpi_comm_join_=pmpi_comm_join__
+ _pmpi_comm_join_=pmpi_comm_join__
mpi_comm_join__=pmpi_comm_join__
+ _mpi_comm_join_=pmpi_comm_join__
+ mpi_comm_join_=pmpi_comm_join__
pmpi_comm_rank__
+ pmpi_comm_rank_=pmpi_comm_rank__
+ _pmpi_comm_rank_=pmpi_comm_rank__
mpi_comm_rank__=pmpi_comm_rank__
+ _mpi_comm_rank_=pmpi_comm_rank__
+ mpi_comm_rank_=pmpi_comm_rank__
pmpi_comm_remote_group__
+ pmpi_comm_remote_group_=pmpi_comm_remote_group__
+ _pmpi_comm_remote_group_=pmpi_comm_remote_group__
mpi_comm_remote_group__=pmpi_comm_remote_group__
+ _mpi_comm_remote_group_=pmpi_comm_remote_group__
+ mpi_comm_remote_group_=pmpi_comm_remote_group__
pmpi_comm_remote_size__
+ pmpi_comm_remote_size_=pmpi_comm_remote_size__
+ _pmpi_comm_remote_size_=pmpi_comm_remote_size__
mpi_comm_remote_size__=pmpi_comm_remote_size__
+ _mpi_comm_remote_size_=pmpi_comm_remote_size__
+ mpi_comm_remote_size_=pmpi_comm_remote_size__
pmpi_comm_set_attr__
+ pmpi_comm_set_attr_=pmpi_comm_set_attr__
+ _pmpi_comm_set_attr_=pmpi_comm_set_attr__
mpi_comm_set_attr__=pmpi_comm_set_attr__
+ _mpi_comm_set_attr_=pmpi_comm_set_attr__
+ mpi_comm_set_attr_=pmpi_comm_set_attr__
pmpi_comm_set_errhandler__
+ pmpi_comm_set_errhandler_=pmpi_comm_set_errhandler__
+ _pmpi_comm_set_errhandler_=pmpi_comm_set_errhandler__
mpi_comm_set_errhandler__=pmpi_comm_set_errhandler__
+ _mpi_comm_set_errhandler_=pmpi_comm_set_errhandler__
+ mpi_comm_set_errhandler_=pmpi_comm_set_errhandler__
pmpi_comm_set_name__
+ pmpi_comm_set_name_=pmpi_comm_set_name__
+ _pmpi_comm_set_name_=pmpi_comm_set_name__
mpi_comm_set_name__=pmpi_comm_set_name__
+ _mpi_comm_set_name_=pmpi_comm_set_name__
+ mpi_comm_set_name_=pmpi_comm_set_name__
pmpi_comm_size__
+ pmpi_comm_size_=pmpi_comm_size__
+ _pmpi_comm_size_=pmpi_comm_size__
mpi_comm_size__=pmpi_comm_size__
+ _mpi_comm_size_=pmpi_comm_size__
+ mpi_comm_size_=pmpi_comm_size__
pmpi_comm_spawn__
+ pmpi_comm_spawn_=pmpi_comm_spawn__
+ _pmpi_comm_spawn_=pmpi_comm_spawn__
mpi_comm_spawn__=pmpi_comm_spawn__
+ _mpi_comm_spawn_=pmpi_comm_spawn__
+ mpi_comm_spawn_=pmpi_comm_spawn__
pmpi_comm_spawn_multiple__
+ pmpi_comm_spawn_multiple_=pmpi_comm_spawn_multiple__
+ _pmpi_comm_spawn_multiple_=pmpi_comm_spawn_multiple__
mpi_comm_spawn_multiple__=pmpi_comm_spawn_multiple__
+ _mpi_comm_spawn_multiple_=pmpi_comm_spawn_multiple__
+ mpi_comm_spawn_multiple_=pmpi_comm_spawn_multiple__
pmpi_comm_split__
+ pmpi_comm_split_=pmpi_comm_split__
+ _pmpi_comm_split_=pmpi_comm_split__
mpi_comm_split__=pmpi_comm_split__
+ _mpi_comm_split_=pmpi_comm_split__
+ mpi_comm_split_=pmpi_comm_split__
pmpi_comm_test_inter__
+ pmpi_comm_test_inter_=pmpi_comm_test_inter__
+ _pmpi_comm_test_inter_=pmpi_comm_test_inter__
mpi_comm_test_inter__=pmpi_comm_test_inter__
+ _mpi_comm_test_inter_=pmpi_comm_test_inter__
+ mpi_comm_test_inter_=pmpi_comm_test_inter__
pmpi_dims_create__
+ pmpi_dims_create_=pmpi_dims_create__
+ _pmpi_dims_create_=pmpi_dims_create__
mpi_dims_create__=pmpi_dims_create__
+ _mpi_dims_create_=pmpi_dims_create__
+ mpi_dims_create_=pmpi_dims_create__
pmpi_errhandler_create__
+ pmpi_errhandler_create_=pmpi_errhandler_create__
+ _pmpi_errhandler_create_=pmpi_errhandler_create__
mpi_errhandler_create__=pmpi_errhandler_create__
+ _mpi_errhandler_create_=pmpi_errhandler_create__
+ mpi_errhandler_create_=pmpi_errhandler_create__
pmpi_errhandler_free__
+ pmpi_errhandler_free_=pmpi_errhandler_free__
+ _pmpi_errhandler_free_=pmpi_errhandler_free__
mpi_errhandler_free__=pmpi_errhandler_free__
+ _mpi_errhandler_free_=pmpi_errhandler_free__
+ mpi_errhandler_free_=pmpi_errhandler_free__
pmpi_errhandler_get__
+ pmpi_errhandler_get_=pmpi_errhandler_get__
+ _pmpi_errhandler_get_=pmpi_errhandler_get__
mpi_errhandler_get__=pmpi_errhandler_get__
+ _mpi_errhandler_get_=pmpi_errhandler_get__
+ mpi_errhandler_get_=pmpi_errhandler_get__
pmpi_errhandler_set__
+ pmpi_errhandler_set_=pmpi_errhandler_set__
+ _pmpi_errhandler_set_=pmpi_errhandler_set__
mpi_errhandler_set__=pmpi_errhandler_set__
+ _mpi_errhandler_set_=pmpi_errhandler_set__
+ mpi_errhandler_set_=pmpi_errhandler_set__
pmpi_error_class__
+ pmpi_error_class_=pmpi_error_class__
+ _pmpi_error_class_=pmpi_error_class__
mpi_error_class__=pmpi_error_class__
+ _mpi_error_class_=pmpi_error_class__
+ mpi_error_class_=pmpi_error_class__
pmpi_error_string__
+ pmpi_error_string_=pmpi_error_string__
+ _pmpi_error_string_=pmpi_error_string__
mpi_error_string__=pmpi_error_string__
+ _mpi_error_string_=pmpi_error_string__
+ mpi_error_string_=pmpi_error_string__
pmpi_exscan__
+ pmpi_exscan_=pmpi_exscan__
+ _pmpi_exscan_=pmpi_exscan__
mpi_exscan__=pmpi_exscan__
+ _mpi_exscan_=pmpi_exscan__
+ mpi_exscan_=pmpi_exscan__
; pmpi first versions
pmpi_file_call_errhandler__
+ pmpi_file_call_errhandler_=pmpi_file_call_errhandler__
+ _pmpi_file_call_errhandler_=pmpi_file_call_errhandler__
mpi_file_call_errhandler__=pmpi_file_call_errhandler__
+ _mpi_file_call_errhandler_=pmpi_file_call_errhandler__
+ mpi_file_call_errhandler_=pmpi_file_call_errhandler__
pmpi_file_close__
+ pmpi_file_close_=pmpi_file_close__
+ _pmpi_file_close_=pmpi_file_close__
mpi_file_close__=pmpi_file_close__
+ _mpi_file_close_=pmpi_file_close__
+ mpi_file_close_=pmpi_file_close__
pmpi_file_create_errhandler__
+ pmpi_file_create_errhandler_=pmpi_file_create_errhandler__
+ _pmpi_file_create_errhandler_=pmpi_file_create_errhandler__
mpi_file_create_errhandler__=pmpi_file_create_errhandler__
+ _mpi_file_create_errhandler_=pmpi_file_create_errhandler__
+ mpi_file_create_errhandler_=pmpi_file_create_errhandler__
pmpi_file_delete__
+ pmpi_file_delete_=pmpi_file_delete__
+ _pmpi_file_delete_=pmpi_file_delete__
mpi_file_delete__=pmpi_file_delete__
+ _mpi_file_delete_=pmpi_file_delete__
+ mpi_file_delete_=pmpi_file_delete__
pmpi_file_get_amode__
+ pmpi_file_get_amode_=pmpi_file_get_amode__
+ _pmpi_file_get_amode_=pmpi_file_get_amode__
mpi_file_get_amode__=pmpi_file_get_amode__
+ _mpi_file_get_amode_=pmpi_file_get_amode__
+ mpi_file_get_amode_=pmpi_file_get_amode__
pmpi_file_get_atomicity__
+ pmpi_file_get_atomicity_=pmpi_file_get_atomicity__
+ _pmpi_file_get_atomicity_=pmpi_file_get_atomicity__
mpi_file_get_atomicity__=pmpi_file_get_atomicity__
+ _mpi_file_get_atomicity_=pmpi_file_get_atomicity__
+ mpi_file_get_atomicity_=pmpi_file_get_atomicity__
pmpi_file_get_byte_offset__
+ pmpi_file_get_byte_offset_=pmpi_file_get_byte_offset__
+ _pmpi_file_get_byte_offset_=pmpi_file_get_byte_offset__
mpi_file_get_byte_offset__=pmpi_file_get_byte_offset__
+ _mpi_file_get_byte_offset_=pmpi_file_get_byte_offset__
+ mpi_file_get_byte_offset_=pmpi_file_get_byte_offset__
pmpi_file_get_errhandler__
+ pmpi_file_get_errhandler_=pmpi_file_get_errhandler__
+ _pmpi_file_get_errhandler_=pmpi_file_get_errhandler__
mpi_file_get_errhandler__=pmpi_file_get_errhandler__
+ _mpi_file_get_errhandler_=pmpi_file_get_errhandler__
+ mpi_file_get_errhandler_=pmpi_file_get_errhandler__
pmpi_file_get_group__
+ pmpi_file_get_group_=pmpi_file_get_group__
+ _pmpi_file_get_group_=pmpi_file_get_group__
mpi_file_get_group__=pmpi_file_get_group__
+ _mpi_file_get_group_=pmpi_file_get_group__
+ mpi_file_get_group_=pmpi_file_get_group__
pmpi_file_get_info__
+ pmpi_file_get_info_=pmpi_file_get_info__
+ _pmpi_file_get_info_=pmpi_file_get_info__
mpi_file_get_info__=pmpi_file_get_info__
+ _mpi_file_get_info_=pmpi_file_get_info__
+ mpi_file_get_info_=pmpi_file_get_info__
pmpi_file_get_position__
+ pmpi_file_get_position_=pmpi_file_get_position__
+ _pmpi_file_get_position_=pmpi_file_get_position__
mpi_file_get_position__=pmpi_file_get_position__
+ _mpi_file_get_position_=pmpi_file_get_position__
+ mpi_file_get_position_=pmpi_file_get_position__
pmpi_file_get_position_shared__
+ pmpi_file_get_position_shared_=pmpi_file_get_position_shared__
+ _pmpi_file_get_position_shared_=pmpi_file_get_position_shared__
mpi_file_get_position_shared__=pmpi_file_get_position_shared__
+ _mpi_file_get_position_shared_=pmpi_file_get_position_shared__
+ mpi_file_get_position_shared_=pmpi_file_get_position_shared__
pmpi_file_get_size__
+ pmpi_file_get_size_=pmpi_file_get_size__
+ _pmpi_file_get_size_=pmpi_file_get_size__
mpi_file_get_size__=pmpi_file_get_size__
+ _mpi_file_get_size_=pmpi_file_get_size__
+ mpi_file_get_size_=pmpi_file_get_size__
pmpi_file_get_type_extent__
+ pmpi_file_get_type_extent_=pmpi_file_get_type_extent__
+ _pmpi_file_get_type_extent_=pmpi_file_get_type_extent__
mpi_file_get_type_extent__=pmpi_file_get_type_extent__
+ _mpi_file_get_type_extent_=pmpi_file_get_type_extent__
+ mpi_file_get_type_extent_=pmpi_file_get_type_extent__
pmpi_file_get_view__
+ pmpi_file_get_view_=pmpi_file_get_view__
+ _pmpi_file_get_view_=pmpi_file_get_view__
mpi_file_get_view__=pmpi_file_get_view__
+ _mpi_file_get_view_=pmpi_file_get_view__
+ mpi_file_get_view_=pmpi_file_get_view__
pmpi_file_iread__
+ pmpi_file_iread_=pmpi_file_iread__
+ _pmpi_file_iread_=pmpi_file_iread__
mpi_file_iread__=pmpi_file_iread__
+ _mpi_file_iread_=pmpi_file_iread__
+ mpi_file_iread_=pmpi_file_iread__
pmpi_file_iread_at__
+ pmpi_file_iread_at_=pmpi_file_iread_at__
+ _pmpi_file_iread_at_=pmpi_file_iread_at__
mpi_file_iread_at__=pmpi_file_iread_at__
+ _mpi_file_iread_at_=pmpi_file_iread_at__
+ mpi_file_iread_at_=pmpi_file_iread_at__
pmpi_file_iread_shared__
+ pmpi_file_iread_shared_=pmpi_file_iread_shared__
+ _pmpi_file_iread_shared_=pmpi_file_iread_shared__
mpi_file_iread_shared__=pmpi_file_iread_shared__
+ _mpi_file_iread_shared_=pmpi_file_iread_shared__
+ mpi_file_iread_shared_=pmpi_file_iread_shared__
pmpi_file_iwrite__
+ pmpi_file_iwrite_=pmpi_file_iwrite__
+ _pmpi_file_iwrite_=pmpi_file_iwrite__
mpi_file_iwrite__=pmpi_file_iwrite__
+ _mpi_file_iwrite_=pmpi_file_iwrite__
+ mpi_file_iwrite_=pmpi_file_iwrite__
pmpi_file_iwrite_at__
+ pmpi_file_iwrite_at_=pmpi_file_iwrite_at__
+ _pmpi_file_iwrite_at_=pmpi_file_iwrite_at__
mpi_file_iwrite_at__=pmpi_file_iwrite_at__
+ _mpi_file_iwrite_at_=pmpi_file_iwrite_at__
+ mpi_file_iwrite_at_=pmpi_file_iwrite_at__
pmpi_file_iwrite_shared__
+ pmpi_file_iwrite_shared_=pmpi_file_iwrite_shared__
+ _pmpi_file_iwrite_shared_=pmpi_file_iwrite_shared__
mpi_file_iwrite_shared__=pmpi_file_iwrite_shared__
+ _mpi_file_iwrite_shared_=pmpi_file_iwrite_shared__
+ mpi_file_iwrite_shared_=pmpi_file_iwrite_shared__
pmpi_file_open__
+ pmpi_file_open_=pmpi_file_open__
+ _pmpi_file_open_=pmpi_file_open__
mpi_file_open__=pmpi_file_open__
+ _mpi_file_open_=pmpi_file_open__
+ mpi_file_open_=pmpi_file_open__
pmpi_file_preallocate__
+ pmpi_file_preallocate_=pmpi_file_preallocate__
+ _pmpi_file_preallocate_=pmpi_file_preallocate__
mpi_file_preallocate__=pmpi_file_preallocate__
+ _mpi_file_preallocate_=pmpi_file_preallocate__
+ mpi_file_preallocate_=pmpi_file_preallocate__
pmpi_file_read__
+ pmpi_file_read_=pmpi_file_read__
+ _pmpi_file_read_=pmpi_file_read__
mpi_file_read__=pmpi_file_read__
+ _mpi_file_read_=pmpi_file_read__
+ mpi_file_read_=pmpi_file_read__
pmpi_file_read_all__
+ pmpi_file_read_all_=pmpi_file_read_all__
+ _pmpi_file_read_all_=pmpi_file_read_all__
mpi_file_read_all__=pmpi_file_read_all__
+ _mpi_file_read_all_=pmpi_file_read_all__
+ mpi_file_read_all_=pmpi_file_read_all__
pmpi_file_read_all_begin__
+ pmpi_file_read_all_begin_=pmpi_file_read_all_begin__
+ _pmpi_file_read_all_begin_=pmpi_file_read_all_begin__
mpi_file_read_all_begin__=pmpi_file_read_all_begin__
+ _mpi_file_read_all_begin_=pmpi_file_read_all_begin__
+ mpi_file_read_all_begin_=pmpi_file_read_all_begin__
pmpi_file_read_all_end__
+ pmpi_file_read_all_end_=pmpi_file_read_all_end__
+ _pmpi_file_read_all_end_=pmpi_file_read_all_end__
mpi_file_read_all_end__=pmpi_file_read_all_end__
+ _mpi_file_read_all_end_=pmpi_file_read_all_end__
+ mpi_file_read_all_end_=pmpi_file_read_all_end__
pmpi_file_read_at__
+ pmpi_file_read_at_=pmpi_file_read_at__
+ _pmpi_file_read_at_=pmpi_file_read_at__
mpi_file_read_at__=pmpi_file_read_at__
+ _mpi_file_read_at_=pmpi_file_read_at__
+ mpi_file_read_at_=pmpi_file_read_at__
pmpi_file_read_at_all__
+ pmpi_file_read_at_all_=pmpi_file_read_at_all__
+ _pmpi_file_read_at_all_=pmpi_file_read_at_all__
mpi_file_read_at_all__=pmpi_file_read_at_all__
+ _mpi_file_read_at_all_=pmpi_file_read_at_all__
+ mpi_file_read_at_all_=pmpi_file_read_at_all__
pmpi_file_read_at_all_begin__
+ pmpi_file_read_at_all_begin_=pmpi_file_read_at_all_begin__
+ _pmpi_file_read_at_all_begin_=pmpi_file_read_at_all_begin__
mpi_file_read_at_all_begin__=pmpi_file_read_at_all_begin__
+ _mpi_file_read_at_all_begin_=pmpi_file_read_at_all_begin__
+ mpi_file_read_at_all_begin_=pmpi_file_read_at_all_begin__
pmpi_file_read_at_all_end__
+ pmpi_file_read_at_all_end_=pmpi_file_read_at_all_end__
+ _pmpi_file_read_at_all_end_=pmpi_file_read_at_all_end__
mpi_file_read_at_all_end__=pmpi_file_read_at_all_end__
+ _mpi_file_read_at_all_end_=pmpi_file_read_at_all_end__
+ mpi_file_read_at_all_end_=pmpi_file_read_at_all_end__
pmpi_file_read_ordered__
+ pmpi_file_read_ordered_=pmpi_file_read_ordered__
+ _pmpi_file_read_ordered_=pmpi_file_read_ordered__
mpi_file_read_ordered__=pmpi_file_read_ordered__
+ _mpi_file_read_ordered_=pmpi_file_read_ordered__
+ mpi_file_read_ordered_=pmpi_file_read_ordered__
pmpi_file_read_ordered_begin__
+ pmpi_file_read_ordered_begin_=pmpi_file_read_ordered_begin__
+ _pmpi_file_read_ordered_begin_=pmpi_file_read_ordered_begin__
mpi_file_read_ordered_begin__=pmpi_file_read_ordered_begin__
+ _mpi_file_read_ordered_begin_=pmpi_file_read_ordered_begin__
+ mpi_file_read_ordered_begin_=pmpi_file_read_ordered_begin__
pmpi_file_read_ordered_end__
+ pmpi_file_read_ordered_end_=pmpi_file_read_ordered_end__
+ _pmpi_file_read_ordered_end_=pmpi_file_read_ordered_end__
mpi_file_read_ordered_end__=pmpi_file_read_ordered_end__
+ _mpi_file_read_ordered_end_=pmpi_file_read_ordered_end__
+ mpi_file_read_ordered_end_=pmpi_file_read_ordered_end__
pmpi_file_read_shared__
+ pmpi_file_read_shared_=pmpi_file_read_shared__
+ _pmpi_file_read_shared_=pmpi_file_read_shared__
mpi_file_read_shared__=pmpi_file_read_shared__
+ _mpi_file_read_shared_=pmpi_file_read_shared__
+ mpi_file_read_shared_=pmpi_file_read_shared__
pmpi_file_seek__
+ pmpi_file_seek_=pmpi_file_seek__
+ _pmpi_file_seek_=pmpi_file_seek__
mpi_file_seek__=pmpi_file_seek__
+ _mpi_file_seek_=pmpi_file_seek__
+ mpi_file_seek_=pmpi_file_seek__
pmpi_file_seek_shared__
+ pmpi_file_seek_shared_=pmpi_file_seek_shared__
+ _pmpi_file_seek_shared_=pmpi_file_seek_shared__
mpi_file_seek_shared__=pmpi_file_seek_shared__
+ _mpi_file_seek_shared_=pmpi_file_seek_shared__
+ mpi_file_seek_shared_=pmpi_file_seek_shared__
pmpi_file_set_atomicity__
+ pmpi_file_set_atomicity_=pmpi_file_set_atomicity__
+ _pmpi_file_set_atomicity_=pmpi_file_set_atomicity__
mpi_file_set_atomicity__=pmpi_file_set_atomicity__
+ _mpi_file_set_atomicity_=pmpi_file_set_atomicity__
+ mpi_file_set_atomicity_=pmpi_file_set_atomicity__
pmpi_file_set_errhandler__
+ pmpi_file_set_errhandler_=pmpi_file_set_errhandler__
+ _pmpi_file_set_errhandler_=pmpi_file_set_errhandler__
mpi_file_set_errhandler__=pmpi_file_set_errhandler__
+ _mpi_file_set_errhandler_=pmpi_file_set_errhandler__
+ mpi_file_set_errhandler_=pmpi_file_set_errhandler__
pmpi_file_set_info__
+ pmpi_file_set_info_=pmpi_file_set_info__
+ _pmpi_file_set_info_=pmpi_file_set_info__
mpi_file_set_info__=pmpi_file_set_info__
+ _mpi_file_set_info_=pmpi_file_set_info__
+ mpi_file_set_info_=pmpi_file_set_info__
pmpi_file_set_size__
+ pmpi_file_set_size_=pmpi_file_set_size__
+ _pmpi_file_set_size_=pmpi_file_set_size__
mpi_file_set_size__=pmpi_file_set_size__
+ _mpi_file_set_size_=pmpi_file_set_size__
+ mpi_file_set_size_=pmpi_file_set_size__
pmpi_file_set_view__
+ pmpi_file_set_view_=pmpi_file_set_view__
+ _pmpi_file_set_view_=pmpi_file_set_view__
mpi_file_set_view__=pmpi_file_set_view__
+ _mpi_file_set_view_=pmpi_file_set_view__
+ mpi_file_set_view_=pmpi_file_set_view__
pmpi_file_sync__
+ pmpi_file_sync_=pmpi_file_sync__
+ _pmpi_file_sync_=pmpi_file_sync__
mpi_file_sync__=pmpi_file_sync__
+ _mpi_file_sync_=pmpi_file_sync__
+ mpi_file_sync_=pmpi_file_sync__
pmpi_file_write__
+ pmpi_file_write_=pmpi_file_write__
+ _pmpi_file_write_=pmpi_file_write__
mpi_file_write__=pmpi_file_write__
+ _mpi_file_write_=pmpi_file_write__
+ mpi_file_write_=pmpi_file_write__
pmpi_file_write_all__
+ pmpi_file_write_all_=pmpi_file_write_all__
+ _pmpi_file_write_all_=pmpi_file_write_all__
mpi_file_write_all__=pmpi_file_write_all__
+ _mpi_file_write_all_=pmpi_file_write_all__
+ mpi_file_write_all_=pmpi_file_write_all__
pmpi_file_write_all_begin__
+ pmpi_file_write_all_begin_=pmpi_file_write_all_begin__
+ _pmpi_file_write_all_begin_=pmpi_file_write_all_begin__
mpi_file_write_all_begin__=pmpi_file_write_all_begin__
+ _mpi_file_write_all_begin_=pmpi_file_write_all_begin__
+ mpi_file_write_all_begin_=pmpi_file_write_all_begin__
pmpi_file_write_all_end__
+ pmpi_file_write_all_end_=pmpi_file_write_all_end__
+ _pmpi_file_write_all_end_=pmpi_file_write_all_end__
mpi_file_write_all_end__=pmpi_file_write_all_end__
+ _mpi_file_write_all_end_=pmpi_file_write_all_end__
+ mpi_file_write_all_end_=pmpi_file_write_all_end__
pmpi_file_write_at__
+ pmpi_file_write_at_=pmpi_file_write_at__
+ _pmpi_file_write_at_=pmpi_file_write_at__
mpi_file_write_at__=pmpi_file_write_at__
+ _mpi_file_write_at_=pmpi_file_write_at__
+ mpi_file_write_at_=pmpi_file_write_at__
pmpi_file_write_at_all__
+ pmpi_file_write_at_all_=pmpi_file_write_at_all__
+ _pmpi_file_write_at_all_=pmpi_file_write_at_all__
mpi_file_write_at_all__=pmpi_file_write_at_all__
+ _mpi_file_write_at_all_=pmpi_file_write_at_all__
+ mpi_file_write_at_all_=pmpi_file_write_at_all__
pmpi_file_write_at_all_begin__
+ pmpi_file_write_at_all_begin_=pmpi_file_write_at_all_begin__
+ _pmpi_file_write_at_all_begin_=pmpi_file_write_at_all_begin__
mpi_file_write_at_all_begin__=pmpi_file_write_at_all_begin__
+ _mpi_file_write_at_all_begin_=pmpi_file_write_at_all_begin__
+ mpi_file_write_at_all_begin_=pmpi_file_write_at_all_begin__
pmpi_file_write_at_all_end__
+ pmpi_file_write_at_all_end_=pmpi_file_write_at_all_end__
+ _pmpi_file_write_at_all_end_=pmpi_file_write_at_all_end__
mpi_file_write_at_all_end__=pmpi_file_write_at_all_end__
+ _mpi_file_write_at_all_end_=pmpi_file_write_at_all_end__
+ mpi_file_write_at_all_end_=pmpi_file_write_at_all_end__
pmpi_file_write_ordered__
+ pmpi_file_write_ordered_=pmpi_file_write_ordered__
+ _pmpi_file_write_ordered_=pmpi_file_write_ordered__
mpi_file_write_ordered__=pmpi_file_write_ordered__
+ _mpi_file_write_ordered_=pmpi_file_write_ordered__
+ mpi_file_write_ordered_=pmpi_file_write_ordered__
pmpi_file_write_ordered_begin__
+ pmpi_file_write_ordered_begin_=pmpi_file_write_ordered_begin__
+ _pmpi_file_write_ordered_begin_=pmpi_file_write_ordered_begin__
mpi_file_write_ordered_begin__=pmpi_file_write_ordered_begin__
+ _mpi_file_write_ordered_begin_=pmpi_file_write_ordered_begin__
+ mpi_file_write_ordered_begin_=pmpi_file_write_ordered_begin__
pmpi_file_write_ordered_end__
+ pmpi_file_write_ordered_end_=pmpi_file_write_ordered_end__
+ _pmpi_file_write_ordered_end_=pmpi_file_write_ordered_end__
mpi_file_write_ordered_end__=pmpi_file_write_ordered_end__
+ _mpi_file_write_ordered_end_=pmpi_file_write_ordered_end__
+ mpi_file_write_ordered_end_=pmpi_file_write_ordered_end__
pmpi_file_write_shared__
+ pmpi_file_write_shared_=pmpi_file_write_shared__
+ _pmpi_file_write_shared_=pmpi_file_write_shared__
mpi_file_write_shared__=pmpi_file_write_shared__
+ _mpi_file_write_shared_=pmpi_file_write_shared__
+ mpi_file_write_shared_=pmpi_file_write_shared__
; pmpi_file_f2c__
; mpi_file_f2c__=pmpi_file_f2c__
; pmpi_file_c2f__
@@ -371,217 +867,625 @@
; pmpi_file_c2f__=mpi_file_c2f__
; end mpi first versions
pmpi_finalize__
+ pmpi_finalize_=pmpi_finalize__
+ _pmpi_finalize_=pmpi_finalize__
mpi_finalize__=pmpi_finalize__
+ _mpi_finalize_=pmpi_finalize__
+ mpi_finalize_=pmpi_finalize__
pmpi_finalized__
+ pmpi_finalized_=pmpi_finalized__
+ _pmpi_finalized_=pmpi_finalized__
mpi_finalized__=pmpi_finalized__
+ _mpi_finalized_=pmpi_finalized__
+ mpi_finalized_=pmpi_finalized__
pmpi_free_mem__
+ pmpi_free_mem_=pmpi_free_mem__
+ _pmpi_free_mem_=pmpi_free_mem__
mpi_free_mem__=pmpi_free_mem__
+ _mpi_free_mem_=pmpi_free_mem__
+ mpi_free_mem_=pmpi_free_mem__
pmpi_gather__
+ pmpi_gather_=pmpi_gather__
+ _pmpi_gather_=pmpi_gather__
mpi_gather__=pmpi_gather__
+ _mpi_gather_=pmpi_gather__
+ mpi_gather_=pmpi_gather__
pmpi_gatherv__
+ pmpi_gatherv_=pmpi_gatherv__
+ _pmpi_gatherv_=pmpi_gatherv__
mpi_gatherv__=pmpi_gatherv__
+ _mpi_gatherv_=pmpi_gatherv__
+ mpi_gatherv_=pmpi_gatherv__
pmpi_get__
+ pmpi_get_=pmpi_get__
+ _pmpi_get_=pmpi_get__
mpi_get__=pmpi_get__
+ _mpi_get_=pmpi_get__
+ mpi_get_=pmpi_get__
pmpi_get_address__
+ pmpi_get_address_=pmpi_get_address__
+ _pmpi_get_address_=pmpi_get_address__
mpi_get_address__=pmpi_get_address__
+ _mpi_get_address_=pmpi_get_address__
+ mpi_get_address_=pmpi_get_address__
pmpi_get_count__
+ pmpi_get_count_=pmpi_get_count__
+ _pmpi_get_count_=pmpi_get_count__
mpi_get_count__=pmpi_get_count__
+ _mpi_get_count_=pmpi_get_count__
+ mpi_get_count_=pmpi_get_count__
pmpi_get_elements__
+ pmpi_get_elements_=pmpi_get_elements__
+ _pmpi_get_elements_=pmpi_get_elements__
mpi_get_elements__=pmpi_get_elements__
+ _mpi_get_elements_=pmpi_get_elements__
+ mpi_get_elements_=pmpi_get_elements__
pmpi_get_processor_name__
+ pmpi_get_processor_name_=pmpi_get_processor_name__
+ _pmpi_get_processor_name_=pmpi_get_processor_name__
mpi_get_processor_name__=pmpi_get_processor_name__
+ _mpi_get_processor_name_=pmpi_get_processor_name__
+ mpi_get_processor_name_=pmpi_get_processor_name__
pmpi_get_version__
+ pmpi_get_version_=pmpi_get_version__
+ _pmpi_get_version_=pmpi_get_version__
mpi_get_version__=pmpi_get_version__
+ _mpi_get_version_=pmpi_get_version__
+ mpi_get_version_=pmpi_get_version__
pmpi_graph_create__
+ pmpi_graph_create_=pmpi_graph_create__
+ _pmpi_graph_create_=pmpi_graph_create__
mpi_graph_create__=pmpi_graph_create__
+ _mpi_graph_create_=pmpi_graph_create__
+ mpi_graph_create_=pmpi_graph_create__
pmpi_dist_graph_create__
+ pmpi_dist_graph_create_=pmpi_dist_graph_create__
+ _pmpi_dist_graph_create_=pmpi_dist_graph_create__
mpi_dist_graph_create__=pmpi_dist_graph_create__
+ _mpi_dist_graph_create_=pmpi_dist_graph_create__
+ mpi_dist_graph_create_=pmpi_dist_graph_create__
pmpi_dist_graph_create_adjacent__
+ pmpi_dist_graph_create_adjacent_=pmpi_dist_graph_create_adjacent__
+ _pmpi_dist_graph_create_adjacent_=pmpi_dist_graph_create_adjacent__
mpi_dist_graph_create_adjacent__=pmpi_dist_graph_create_adjacent__
+ _mpi_dist_graph_create_adjacent_=pmpi_dist_graph_create_adjacent__
+ mpi_dist_graph_create_adjacent_=pmpi_dist_graph_create_adjacent__
pmpi_graph_get__
+ pmpi_graph_get_=pmpi_graph_get__
+ _pmpi_graph_get_=pmpi_graph_get__
mpi_graph_get__=pmpi_graph_get__
+ _mpi_graph_get_=pmpi_graph_get__
+ mpi_graph_get_=pmpi_graph_get__
pmpi_graph_map__
+ pmpi_graph_map_=pmpi_graph_map__
+ _pmpi_graph_map_=pmpi_graph_map__
mpi_graph_map__=pmpi_graph_map__
+ _mpi_graph_map_=pmpi_graph_map__
+ mpi_graph_map_=pmpi_graph_map__
pmpi_graph_neighbors__
+ pmpi_graph_neighbors_=pmpi_graph_neighbors__
+ _pmpi_graph_neighbors_=pmpi_graph_neighbors__
mpi_graph_neighbors__=pmpi_graph_neighbors__
+ _mpi_graph_neighbors_=pmpi_graph_neighbors__
+ mpi_graph_neighbors_=pmpi_graph_neighbors__
pmpi_dist_graph_neighbors__
+ pmpi_dist_graph_neighbors_=pmpi_dist_graph_neighbors__
+ _pmpi_dist_graph_neighbors_=pmpi_dist_graph_neighbors__
mpi_dist_graph_neighbors__=pmpi_dist_graph_neighbors__
+ _mpi_dist_graph_neighbors_=pmpi_dist_graph_neighbors__
+ mpi_dist_graph_neighbors_=pmpi_dist_graph_neighbors__
pmpi_graph_neighbors_count__
+ pmpi_graph_neighbors_count_=pmpi_graph_neighbors_count__
+ _pmpi_graph_neighbors_count_=pmpi_graph_neighbors_count__
mpi_graph_neighbors_count__=pmpi_graph_neighbors_count__
+ _mpi_graph_neighbors_count_=pmpi_graph_neighbors_count__
+ mpi_graph_neighbors_count_=pmpi_graph_neighbors_count__
pmpi_dist_graph_neighbors_count__
+ pmpi_dist_graph_neighbors_count_=pmpi_dist_graph_neighbors_count__
+ _pmpi_dist_graph_neighbors_count_=pmpi_dist_graph_neighbors_count__
mpi_dist_graph_neighbors_count__=pmpi_dist_graph_neighbors_count__
+ _mpi_dist_graph_neighbors_count_=pmpi_dist_graph_neighbors_count__
+ mpi_dist_graph_neighbors_count_=pmpi_dist_graph_neighbors_count__
pmpi_graphdims_get__
+ pmpi_graphdims_get_=pmpi_graphdims_get__
+ _pmpi_graphdims_get_=pmpi_graphdims_get__
mpi_graphdims_get__=pmpi_graphdims_get__
+ _mpi_graphdims_get_=pmpi_graphdims_get__
+ mpi_graphdims_get_=pmpi_graphdims_get__
pmpi_grequest_complete__
+ pmpi_grequest_complete_=pmpi_grequest_complete__
+ _pmpi_grequest_complete_=pmpi_grequest_complete__
mpi_grequest_complete__=pmpi_grequest_complete__
+ _mpi_grequest_complete_=pmpi_grequest_complete__
+ mpi_grequest_complete_=pmpi_grequest_complete__
pmpi_grequest_start__
+ pmpi_grequest_start_=pmpi_grequest_start__
+ _pmpi_grequest_start_=pmpi_grequest_start__
mpi_grequest_start__=pmpi_grequest_start__
+ _mpi_grequest_start_=pmpi_grequest_start__
+ mpi_grequest_start_=pmpi_grequest_start__
pmpi_group_compare__
+ pmpi_group_compare_=pmpi_group_compare__
+ _pmpi_group_compare_=pmpi_group_compare__
mpi_group_compare__=pmpi_group_compare__
+ _mpi_group_compare_=pmpi_group_compare__
+ mpi_group_compare_=pmpi_group_compare__
pmpi_group_difference__
+ pmpi_group_difference_=pmpi_group_difference__
+ _pmpi_group_difference_=pmpi_group_difference__
mpi_group_difference__=pmpi_group_difference__
+ _mpi_group_difference_=pmpi_group_difference__
+ mpi_group_difference_=pmpi_group_difference__
pmpi_group_excl__
+ pmpi_group_excl_=pmpi_group_excl__
+ _pmpi_group_excl_=pmpi_group_excl__
mpi_group_excl__=pmpi_group_excl__
+ _mpi_group_excl_=pmpi_group_excl__
+ mpi_group_excl_=pmpi_group_excl__
pmpi_group_free__
+ pmpi_group_free_=pmpi_group_free__
+ _pmpi_group_free_=pmpi_group_free__
mpi_group_free__=pmpi_group_free__
+ _mpi_group_free_=pmpi_group_free__
+ mpi_group_free_=pmpi_group_free__
pmpi_group_incl__
+ pmpi_group_incl_=pmpi_group_incl__
+ _pmpi_group_incl_=pmpi_group_incl__
mpi_group_incl__=pmpi_group_incl__
+ _mpi_group_incl_=pmpi_group_incl__
+ mpi_group_incl_=pmpi_group_incl__
pmpi_group_intersection__
+ pmpi_group_intersection_=pmpi_group_intersection__
+ _pmpi_group_intersection_=pmpi_group_intersection__
mpi_group_intersection__=pmpi_group_intersection__
+ _mpi_group_intersection_=pmpi_group_intersection__
+ mpi_group_intersection_=pmpi_group_intersection__
pmpi_group_range_excl__
+ pmpi_group_range_excl_=pmpi_group_range_excl__
+ _pmpi_group_range_excl_=pmpi_group_range_excl__
mpi_group_range_excl__=pmpi_group_range_excl__
+ _mpi_group_range_excl_=pmpi_group_range_excl__
+ mpi_group_range_excl_=pmpi_group_range_excl__
pmpi_group_range_incl__
+ pmpi_group_range_incl_=pmpi_group_range_incl__
+ _pmpi_group_range_incl_=pmpi_group_range_incl__
mpi_group_range_incl__=pmpi_group_range_incl__
+ _mpi_group_range_incl_=pmpi_group_range_incl__
+ mpi_group_range_incl_=pmpi_group_range_incl__
pmpi_group_rank__
+ pmpi_group_rank_=pmpi_group_rank__
+ _pmpi_group_rank_=pmpi_group_rank__
mpi_group_rank__=pmpi_group_rank__
+ _mpi_group_rank_=pmpi_group_rank__
+ mpi_group_rank_=pmpi_group_rank__
pmpi_group_size__
+ pmpi_group_size_=pmpi_group_size__
+ _pmpi_group_size_=pmpi_group_size__
mpi_group_size__=pmpi_group_size__
+ _mpi_group_size_=pmpi_group_size__
+ mpi_group_size_=pmpi_group_size__
pmpi_group_translate_ranks__
+ pmpi_group_translate_ranks_=pmpi_group_translate_ranks__
+ _pmpi_group_translate_ranks_=pmpi_group_translate_ranks__
mpi_group_translate_ranks__=pmpi_group_translate_ranks__
+ _mpi_group_translate_ranks_=pmpi_group_translate_ranks__
+ mpi_group_translate_ranks_=pmpi_group_translate_ranks__
pmpi_group_union__
+ pmpi_group_union_=pmpi_group_union__
+ _pmpi_group_union_=pmpi_group_union__
mpi_group_union__=pmpi_group_union__
+ _mpi_group_union_=pmpi_group_union__
+ mpi_group_union_=pmpi_group_union__
pmpi_ibsend__
+ pmpi_ibsend_=pmpi_ibsend__
+ _pmpi_ibsend_=pmpi_ibsend__
mpi_ibsend__=pmpi_ibsend__
+ _mpi_ibsend_=pmpi_ibsend__
+ mpi_ibsend_=pmpi_ibsend__
pmpi_info_create__
+ pmpi_info_create_=pmpi_info_create__
+ _pmpi_info_create_=pmpi_info_create__
mpi_info_create__=pmpi_info_create__
+ _mpi_info_create_=pmpi_info_create__
+ mpi_info_create_=pmpi_info_create__
pmpi_info_delete__
+ pmpi_info_delete_=pmpi_info_delete__
+ _pmpi_info_delete_=pmpi_info_delete__
mpi_info_delete__=pmpi_info_delete__
+ _mpi_info_delete_=pmpi_info_delete__
+ mpi_info_delete_=pmpi_info_delete__
pmpi_info_dup__
+ pmpi_info_dup_=pmpi_info_dup__
+ _pmpi_info_dup_=pmpi_info_dup__
mpi_info_dup__=pmpi_info_dup__
+ _mpi_info_dup_=pmpi_info_dup__
+ mpi_info_dup_=pmpi_info_dup__
pmpi_info_free__
+ pmpi_info_free_=pmpi_info_free__
+ _pmpi_info_free_=pmpi_info_free__
mpi_info_free__=pmpi_info_free__
+ _mpi_info_free_=pmpi_info_free__
+ mpi_info_free_=pmpi_info_free__
pmpi_info_get__
+ pmpi_info_get_=pmpi_info_get__
+ _pmpi_info_get_=pmpi_info_get__
mpi_info_get__=pmpi_info_get__
+ _mpi_info_get_=pmpi_info_get__
+ mpi_info_get_=pmpi_info_get__
pmpi_info_get_nkeys__
+ pmpi_info_get_nkeys_=pmpi_info_get_nkeys__
+ _pmpi_info_get_nkeys_=pmpi_info_get_nkeys__
mpi_info_get_nkeys__=pmpi_info_get_nkeys__
+ _mpi_info_get_nkeys_=pmpi_info_get_nkeys__
+ mpi_info_get_nkeys_=pmpi_info_get_nkeys__
pmpi_info_get_nthkey__
+ pmpi_info_get_nthkey_=pmpi_info_get_nthkey__
+ _pmpi_info_get_nthkey_=pmpi_info_get_nthkey__
mpi_info_get_nthkey__=pmpi_info_get_nthkey__
+ _mpi_info_get_nthkey_=pmpi_info_get_nthkey__
+ mpi_info_get_nthkey_=pmpi_info_get_nthkey__
pmpi_info_get_valuelen__
+ pmpi_info_get_valuelen_=pmpi_info_get_valuelen__
+ _pmpi_info_get_valuelen_=pmpi_info_get_valuelen__
mpi_info_get_valuelen__=pmpi_info_get_valuelen__
+ _mpi_info_get_valuelen_=pmpi_info_get_valuelen__
+ mpi_info_get_valuelen_=pmpi_info_get_valuelen__
pmpi_info_set__
+ pmpi_info_set_=pmpi_info_set__
+ _pmpi_info_set_=pmpi_info_set__
mpi_info_set__=pmpi_info_set__
+ _mpi_info_set_=pmpi_info_set__
+ mpi_info_set_=pmpi_info_set__
pmpi_init__
+ pmpi_init_=pmpi_init__
+ _pmpi_init_=pmpi_init__
mpi_init__=pmpi_init__
+ _mpi_init_=pmpi_init__
+ mpi_init_=pmpi_init__
pmpi_init_thread__
+ pmpi_init_thread_=pmpi_init_thread__
+ _pmpi_init_thread_=pmpi_init_thread__
mpi_init_thread__=pmpi_init_thread__
+ _mpi_init_thread_=pmpi_init_thread__
+ mpi_init_thread_=pmpi_init_thread__
pmpi_initialized__
+ pmpi_initialized_=pmpi_initialized__
+ _pmpi_initialized_=pmpi_initialized__
mpi_initialized__=pmpi_initialized__
+ _mpi_initialized_=pmpi_initialized__
+ mpi_initialized_=pmpi_initialized__
pmpi_intercomm_create__
+ pmpi_intercomm_create_=pmpi_intercomm_create__
+ _pmpi_intercomm_create_=pmpi_intercomm_create__
mpi_intercomm_create__=pmpi_intercomm_create__
+ _mpi_intercomm_create_=pmpi_intercomm_create__
+ mpi_intercomm_create_=pmpi_intercomm_create__
pmpi_intercomm_merge__
+ pmpi_intercomm_merge_=pmpi_intercomm_merge__
+ _pmpi_intercomm_merge_=pmpi_intercomm_merge__
mpi_intercomm_merge__=pmpi_intercomm_merge__
+ _mpi_intercomm_merge_=pmpi_intercomm_merge__
+ mpi_intercomm_merge_=pmpi_intercomm_merge__
pmpi_iprobe__
+ pmpi_iprobe_=pmpi_iprobe__
+ _pmpi_iprobe_=pmpi_iprobe__
mpi_iprobe__=pmpi_iprobe__
+ _mpi_iprobe_=pmpi_iprobe__
+ mpi_iprobe_=pmpi_iprobe__
pmpi_irecv__
+ pmpi_irecv_=pmpi_irecv__
+ _pmpi_irecv_=pmpi_irecv__
mpi_irecv__=pmpi_irecv__
+ _mpi_irecv_=pmpi_irecv__
+ mpi_irecv_=pmpi_irecv__
pmpi_irsend__
+ pmpi_irsend_=pmpi_irsend__
+ _pmpi_irsend_=pmpi_irsend__
mpi_irsend__=pmpi_irsend__
+ _mpi_irsend_=pmpi_irsend__
+ mpi_irsend_=pmpi_irsend__
pmpi_is_thread_main__
+ pmpi_is_thread_main_=pmpi_is_thread_main__
+ _pmpi_is_thread_main_=pmpi_is_thread_main__
mpi_is_thread_main__=pmpi_is_thread_main__
+ _mpi_is_thread_main_=pmpi_is_thread_main__
+ mpi_is_thread_main_=pmpi_is_thread_main__
pmpi_isend__
+ pmpi_isend_=pmpi_isend__
+ _pmpi_isend_=pmpi_isend__
mpi_isend__=pmpi_isend__
+ _mpi_isend_=pmpi_isend__
+ mpi_isend_=pmpi_isend__
pmpi_issend__
+ pmpi_issend_=pmpi_issend__
+ _pmpi_issend_=pmpi_issend__
mpi_issend__=pmpi_issend__
+ _mpi_issend_=pmpi_issend__
+ mpi_issend_=pmpi_issend__
pmpi_keyval_create__
+ pmpi_keyval_create_=pmpi_keyval_create__
+ _pmpi_keyval_create_=pmpi_keyval_create__
mpi_keyval_create__=pmpi_keyval_create__
+ _mpi_keyval_create_=pmpi_keyval_create__
+ mpi_keyval_create_=pmpi_keyval_create__
pmpi_keyval_free__
+ pmpi_keyval_free_=pmpi_keyval_free__
+ _pmpi_keyval_free_=pmpi_keyval_free__
mpi_keyval_free__=pmpi_keyval_free__
+ _mpi_keyval_free_=pmpi_keyval_free__
+ mpi_keyval_free_=pmpi_keyval_free__
pmpi_lookup_name__
+ pmpi_lookup_name_=pmpi_lookup_name__
+ _pmpi_lookup_name_=pmpi_lookup_name__
mpi_lookup_name__=pmpi_lookup_name__
+ _mpi_lookup_name_=pmpi_lookup_name__
+ mpi_lookup_name_=pmpi_lookup_name__
pmpi_op_create__
+ pmpi_op_create_=pmpi_op_create__
+ _pmpi_op_create_=pmpi_op_create__
mpi_op_create__=pmpi_op_create__
+ _mpi_op_create_=pmpi_op_create__
+ mpi_op_create_=pmpi_op_create__
pmpi_op_free__
+ pmpi_op_free_=pmpi_op_free__
+ _pmpi_op_free_=pmpi_op_free__
mpi_op_free__=pmpi_op_free__
+ _mpi_op_free_=pmpi_op_free__
+ mpi_op_free_=pmpi_op_free__
pmpi_open_port__
+ pmpi_open_port_=pmpi_open_port__
+ _pmpi_open_port_=pmpi_open_port__
mpi_open_port__=pmpi_open_port__
+ _mpi_open_port_=pmpi_open_port__
+ mpi_open_port_=pmpi_open_port__
pmpi_pack__
+ pmpi_pack_=pmpi_pack__
+ _pmpi_pack_=pmpi_pack__
mpi_pack__=pmpi_pack__
+ _mpi_pack_=pmpi_pack__
+ mpi_pack_=pmpi_pack__
pmpi_pack_external__
+ pmpi_pack_external_=pmpi_pack_external__
+ _pmpi_pack_external_=pmpi_pack_external__
mpi_pack_external__=pmpi_pack_external__
+ _mpi_pack_external_=pmpi_pack_external__
+ mpi_pack_external_=pmpi_pack_external__
pmpi_pack_external_size__
+ pmpi_pack_external_size_=pmpi_pack_external_size__
+ _pmpi_pack_external_size_=pmpi_pack_external_size__
mpi_pack_external_size__=pmpi_pack_external_size__
+ _mpi_pack_external_size_=pmpi_pack_external_size__
+ mpi_pack_external_size_=pmpi_pack_external_size__
pmpi_pack_size__
+ pmpi_pack_size_=pmpi_pack_size__
+ _pmpi_pack_size_=pmpi_pack_size__
mpi_pack_size__=pmpi_pack_size__
+ _mpi_pack_size_=pmpi_pack_size__
+ mpi_pack_size_=pmpi_pack_size__
pmpi_pcontrol__
+ pmpi_pcontrol_=pmpi_pcontrol__
+ _pmpi_pcontrol_=pmpi_pcontrol__
mpi_pcontrol__=pmpi_pcontrol__
+ _mpi_pcontrol_=pmpi_pcontrol__
+ mpi_pcontrol_=pmpi_pcontrol__
pmpi_probe__
+ pmpi_probe_=pmpi_probe__
+ _pmpi_probe_=pmpi_probe__
mpi_probe__=pmpi_probe__
+ _mpi_probe_=pmpi_probe__
+ mpi_probe_=pmpi_probe__
pmpi_publish_name__
+ pmpi_publish_name_=pmpi_publish_name__
+ _pmpi_publish_name_=pmpi_publish_name__
mpi_publish_name__=pmpi_publish_name__
+ _mpi_publish_name_=pmpi_publish_name__
+ mpi_publish_name_=pmpi_publish_name__
pmpi_put__
+ pmpi_put_=pmpi_put__
+ _pmpi_put_=pmpi_put__
mpi_put__=pmpi_put__
+ _mpi_put_=pmpi_put__
+ mpi_put_=pmpi_put__
pmpi_query_thread__
+ pmpi_query_thread_=pmpi_query_thread__
+ _pmpi_query_thread_=pmpi_query_thread__
mpi_query_thread__=pmpi_query_thread__
+ _mpi_query_thread_=pmpi_query_thread__
+ mpi_query_thread_=pmpi_query_thread__
pmpi_recv__
+ pmpi_recv_=pmpi_recv__
+ _pmpi_recv_=pmpi_recv__
mpi_recv__=pmpi_recv__
+ _mpi_recv_=pmpi_recv__
+ mpi_recv_=pmpi_recv__
pmpi_recv_init__
+ pmpi_recv_init_=pmpi_recv_init__
+ _pmpi_recv_init_=pmpi_recv_init__
mpi_recv_init__=pmpi_recv_init__
+ _mpi_recv_init_=pmpi_recv_init__
+ mpi_recv_init_=pmpi_recv_init__
pmpi_reduce__
+ pmpi_reduce_=pmpi_reduce__
+ _pmpi_reduce_=pmpi_reduce__
mpi_reduce__=pmpi_reduce__
+ _mpi_reduce_=pmpi_reduce__
+ mpi_reduce_=pmpi_reduce__
pmpi_reduce_scatter__
+ pmpi_reduce_scatter_=pmpi_reduce_scatter__
+ _pmpi_reduce_scatter_=pmpi_reduce_scatter__
mpi_reduce_scatter__=pmpi_reduce_scatter__
+ _mpi_reduce_scatter_=pmpi_reduce_scatter__
+ mpi_reduce_scatter_=pmpi_reduce_scatter__
pmpi_register_datarep__
+ pmpi_register_datarep_=pmpi_register_datarep__
+ _pmpi_register_datarep_=pmpi_register_datarep__
mpi_register_datarep__=pmpi_register_datarep__
+ _mpi_register_datarep_=pmpi_register_datarep__
+ mpi_register_datarep_=pmpi_register_datarep__
pmpi_request_free__
+ pmpi_request_free_=pmpi_request_free__
+ _pmpi_request_free_=pmpi_request_free__
mpi_request_free__=pmpi_request_free__
+ _mpi_request_free_=pmpi_request_free__
+ mpi_request_free_=pmpi_request_free__
pmpi_request_get_status__
+ pmpi_request_get_status_=pmpi_request_get_status__
+ _pmpi_request_get_status_=pmpi_request_get_status__
mpi_request_get_status__=pmpi_request_get_status__
+ _mpi_request_get_status_=pmpi_request_get_status__
+ mpi_request_get_status_=pmpi_request_get_status__
pmpi_rsend__
+ pmpi_rsend_=pmpi_rsend__
+ _pmpi_rsend_=pmpi_rsend__
mpi_rsend__=pmpi_rsend__
+ _mpi_rsend_=pmpi_rsend__
+ mpi_rsend_=pmpi_rsend__
pmpi_rsend_init__
+ pmpi_rsend_init_=pmpi_rsend_init__
+ _pmpi_rsend_init_=pmpi_rsend_init__
mpi_rsend_init__=pmpi_rsend_init__
+ _mpi_rsend_init_=pmpi_rsend_init__
+ mpi_rsend_init_=pmpi_rsend_init__
pmpi_scan__
+ pmpi_scan_=pmpi_scan__
+ _pmpi_scan_=pmpi_scan__
mpi_scan__=pmpi_scan__
+ _mpi_scan_=pmpi_scan__
+ mpi_scan_=pmpi_scan__
pmpi_scatter__
+ pmpi_scatter_=pmpi_scatter__
+ _pmpi_scatter_=pmpi_scatter__
mpi_scatter__=pmpi_scatter__
+ _mpi_scatter_=pmpi_scatter__
+ mpi_scatter_=pmpi_scatter__
pmpi_scatterv__
+ pmpi_scatterv_=pmpi_scatterv__
+ _pmpi_scatterv_=pmpi_scatterv__
mpi_scatterv__=pmpi_scatterv__
+ _mpi_scatterv_=pmpi_scatterv__
+ mpi_scatterv_=pmpi_scatterv__
pmpi_send__
+ pmpi_send_=pmpi_send__
+ _pmpi_send_=pmpi_send__
mpi_send__=pmpi_send__
+ _mpi_send_=pmpi_send__
+ mpi_send_=pmpi_send__
pmpi_send_init__
+ pmpi_send_init_=pmpi_send_init__
+ _pmpi_send_init_=pmpi_send_init__
mpi_send_init__=pmpi_send_init__
+ _mpi_send_init_=pmpi_send_init__
+ mpi_send_init_=pmpi_send_init__
pmpi_sendrecv__
+ pmpi_sendrecv_=pmpi_sendrecv__
+ _pmpi_sendrecv_=pmpi_sendrecv__
mpi_sendrecv__=pmpi_sendrecv__
+ _mpi_sendrecv_=pmpi_sendrecv__
+ mpi_sendrecv_=pmpi_sendrecv__
pmpi_sendrecv_replace__
+ pmpi_sendrecv_replace_=pmpi_sendrecv_replace__
+ _pmpi_sendrecv_replace_=pmpi_sendrecv_replace__
mpi_sendrecv_replace__=pmpi_sendrecv_replace__
+ _mpi_sendrecv_replace_=pmpi_sendrecv_replace__
+ mpi_sendrecv_replace_=pmpi_sendrecv_replace__
pmpi_ssend__
+ pmpi_ssend_=pmpi_ssend__
+ _pmpi_ssend_=pmpi_ssend__
mpi_ssend__=pmpi_ssend__
+ _mpi_ssend_=pmpi_ssend__
+ mpi_ssend_=pmpi_ssend__
pmpi_ssend_init__
+ pmpi_ssend_init_=pmpi_ssend_init__
+ _pmpi_ssend_init_=pmpi_ssend_init__
mpi_ssend_init__=pmpi_ssend_init__
+ _mpi_ssend_init_=pmpi_ssend_init__
+ mpi_ssend_init_=pmpi_ssend_init__
pmpi_start__
+ pmpi_start_=pmpi_start__
+ _pmpi_start_=pmpi_start__
mpi_start__=pmpi_start__
+ _mpi_start_=pmpi_start__
+ mpi_start_=pmpi_start__
pmpi_startall__
+ pmpi_startall_=pmpi_startall__
+ _pmpi_startall_=pmpi_startall__
mpi_startall__=pmpi_startall__
+ _mpi_startall_=pmpi_startall__
+ mpi_startall_=pmpi_startall__
; pmpi_status_c2f__
; mpi_status_c2f__=pmpi_status_c2f__
; pmpi_status_f2c__
; mpi_status_f2c__=pmpi_status_f2c__
pmpi_status_set_cancelled__
+ pmpi_status_set_cancelled_=pmpi_status_set_cancelled__
+ _pmpi_status_set_cancelled_=pmpi_status_set_cancelled__
mpi_status_set_cancelled__=pmpi_status_set_cancelled__
+ _mpi_status_set_cancelled_=pmpi_status_set_cancelled__
+ mpi_status_set_cancelled_=pmpi_status_set_cancelled__
pmpi_status_set_elements__
+ pmpi_status_set_elements_=pmpi_status_set_elements__
+ _pmpi_status_set_elements_=pmpi_status_set_elements__
mpi_status_set_elements__=pmpi_status_set_elements__
+ _mpi_status_set_elements_=pmpi_status_set_elements__
+ mpi_status_set_elements_=pmpi_status_set_elements__
; pmpi_statuses_c2f__
; mpi_statuses_c2f__=pmpi_statuses_c2f__
; pmpi_statuses_f2c__
; mpi_statuses_f2c__=pmpi_statuses_f2c__
pmpi_test__
+ pmpi_test_=pmpi_test__
+ _pmpi_test_=pmpi_test__
mpi_test__=pmpi_test__
+ _mpi_test_=pmpi_test__
+ mpi_test_=pmpi_test__
pmpi_test_cancelled__
+ pmpi_test_cancelled_=pmpi_test_cancelled__
+ _pmpi_test_cancelled_=pmpi_test_cancelled__
mpi_test_cancelled__=pmpi_test_cancelled__
+ _mpi_test_cancelled_=pmpi_test_cancelled__
+ mpi_test_cancelled_=pmpi_test_cancelled__
pmpi_testall__
+ pmpi_testall_=pmpi_testall__
+ _pmpi_testall_=pmpi_testall__
mpi_testall__=pmpi_testall__
+ _mpi_testall_=pmpi_testall__
+ mpi_testall_=pmpi_testall__
pmpi_testany__
+ pmpi_testany_=pmpi_testany__
+ _pmpi_testany_=pmpi_testany__
mpi_testany__=pmpi_testany__
+ _mpi_testany_=pmpi_testany__
+ mpi_testany_=pmpi_testany__
pmpi_testsome__
+ pmpi_testsome_=pmpi_testsome__
+ _pmpi_testsome_=pmpi_testsome__
mpi_testsome__=pmpi_testsome__
+ _mpi_testsome_=pmpi_testsome__
+ mpi_testsome_=pmpi_testsome__
pmpi_topo_test__
+ pmpi_topo_test_=pmpi_topo_test__
+ _pmpi_topo_test_=pmpi_topo_test__
mpi_topo_test__=pmpi_topo_test__
+ _mpi_topo_test_=pmpi_topo_test__
+ mpi_topo_test_=pmpi_topo_test__
pmpi_type_commit__
+ pmpi_type_commit_=pmpi_type_commit__
+ _pmpi_type_commit_=pmpi_type_commit__
mpi_type_commit__=pmpi_type_commit__
+ _mpi_type_commit_=pmpi_type_commit__
+ mpi_type_commit_=pmpi_type_commit__
pmpi_type_contiguous__
+ pmpi_type_contiguous_=pmpi_type_contiguous__
+ _pmpi_type_contiguous_=pmpi_type_contiguous__
mpi_type_contiguous__=pmpi_type_contiguous__
+ _mpi_type_contiguous_=pmpi_type_contiguous__
+ mpi_type_contiguous_=pmpi_type_contiguous__
pmpi_type_create_darray__
+ pmpi_type_create_darray_=pmpi_type_create_darray__
+ _pmpi_type_create_darray_=pmpi_type_create_darray__
mpi_type_create_darray__=pmpi_type_create_darray__
+ _mpi_type_create_darray_=pmpi_type_create_darray__
+ mpi_type_create_darray_=pmpi_type_create_darray__
; pmpi_type_create_f90_complex__
; mpi_type_create_f90_complex__=pmpi_type_create_f90_complex__
; pmpi_type_create_f90_integer__
@@ -589,150 +1493,440 @@
; pmpi_type_create_f90_real__
; mpi_type_create_f90_real__=pmpi_type_create_f90_real__
pmpi_type_create_hindexed__
+ pmpi_type_create_hindexed_=pmpi_type_create_hindexed__
+ _pmpi_type_create_hindexed_=pmpi_type_create_hindexed__
mpi_type_create_hindexed__=pmpi_type_create_hindexed__
+ _mpi_type_create_hindexed_=pmpi_type_create_hindexed__
+ mpi_type_create_hindexed_=pmpi_type_create_hindexed__
pmpi_type_create_hvector__
+ pmpi_type_create_hvector_=pmpi_type_create_hvector__
+ _pmpi_type_create_hvector_=pmpi_type_create_hvector__
mpi_type_create_hvector__=pmpi_type_create_hvector__
+ _mpi_type_create_hvector_=pmpi_type_create_hvector__
+ mpi_type_create_hvector_=pmpi_type_create_hvector__
pmpi_type_create_indexed_block__
+ pmpi_type_create_indexed_block_=pmpi_type_create_indexed_block__
+ _pmpi_type_create_indexed_block_=pmpi_type_create_indexed_block__
mpi_type_create_indexed_block__=pmpi_type_create_indexed_block__
+ _mpi_type_create_indexed_block_=pmpi_type_create_indexed_block__
+ mpi_type_create_indexed_block_=pmpi_type_create_indexed_block__
pmpi_type_create_keyval__
+ pmpi_type_create_keyval_=pmpi_type_create_keyval__
+ _pmpi_type_create_keyval_=pmpi_type_create_keyval__
mpi_type_create_keyval__=pmpi_type_create_keyval__
+ _mpi_type_create_keyval_=pmpi_type_create_keyval__
+ mpi_type_create_keyval_=pmpi_type_create_keyval__
pmpi_type_create_resized__
+ pmpi_type_create_resized_=pmpi_type_create_resized__
+ _pmpi_type_create_resized_=pmpi_type_create_resized__
mpi_type_create_resized__=pmpi_type_create_resized__
+ _mpi_type_create_resized_=pmpi_type_create_resized__
+ mpi_type_create_resized_=pmpi_type_create_resized__
pmpi_type_create_struct__
+ pmpi_type_create_struct_=pmpi_type_create_struct__
+ _pmpi_type_create_struct_=pmpi_type_create_struct__
mpi_type_create_struct__=pmpi_type_create_struct__
+ _mpi_type_create_struct_=pmpi_type_create_struct__
+ mpi_type_create_struct_=pmpi_type_create_struct__
pmpi_type_create_subarray__
+ pmpi_type_create_subarray_=pmpi_type_create_subarray__
+ _pmpi_type_create_subarray_=pmpi_type_create_subarray__
mpi_type_create_subarray__=pmpi_type_create_subarray__
+ _mpi_type_create_subarray_=pmpi_type_create_subarray__
+ mpi_type_create_subarray_=pmpi_type_create_subarray__
pmpi_type_delete_attr__
+ pmpi_type_delete_attr_=pmpi_type_delete_attr__
+ _pmpi_type_delete_attr_=pmpi_type_delete_attr__
mpi_type_delete_attr__=pmpi_type_delete_attr__
+ _mpi_type_delete_attr_=pmpi_type_delete_attr__
+ mpi_type_delete_attr_=pmpi_type_delete_attr__
pmpi_type_dup__
+ pmpi_type_dup_=pmpi_type_dup__
+ _pmpi_type_dup_=pmpi_type_dup__
mpi_type_dup__=pmpi_type_dup__
+ _mpi_type_dup_=pmpi_type_dup__
+ mpi_type_dup_=pmpi_type_dup__
pmpi_type_extent__
+ pmpi_type_extent_=pmpi_type_extent__
+ _pmpi_type_extent_=pmpi_type_extent__
mpi_type_extent__=pmpi_type_extent__
+ _mpi_type_extent_=pmpi_type_extent__
+ mpi_type_extent_=pmpi_type_extent__
pmpi_type_free__
+ pmpi_type_free_=pmpi_type_free__
+ _pmpi_type_free_=pmpi_type_free__
mpi_type_free__=pmpi_type_free__
+ _mpi_type_free_=pmpi_type_free__
+ mpi_type_free_=pmpi_type_free__
pmpi_type_free_keyval__
+ pmpi_type_free_keyval_=pmpi_type_free_keyval__
+ _pmpi_type_free_keyval_=pmpi_type_free_keyval__
mpi_type_free_keyval__=pmpi_type_free_keyval__
+ _mpi_type_free_keyval_=pmpi_type_free_keyval__
+ mpi_type_free_keyval_=pmpi_type_free_keyval__
pmpi_type_get_attr__
+ pmpi_type_get_attr_=pmpi_type_get_attr__
+ _pmpi_type_get_attr_=pmpi_type_get_attr__
mpi_type_get_attr__=pmpi_type_get_attr__
+ _mpi_type_get_attr_=pmpi_type_get_attr__
+ mpi_type_get_attr_=pmpi_type_get_attr__
pmpi_type_get_contents__
+ pmpi_type_get_contents_=pmpi_type_get_contents__
+ _pmpi_type_get_contents_=pmpi_type_get_contents__
mpi_type_get_contents__=pmpi_type_get_contents__
+ _mpi_type_get_contents_=pmpi_type_get_contents__
+ mpi_type_get_contents_=pmpi_type_get_contents__
pmpi_type_get_envelope__
+ pmpi_type_get_envelope_=pmpi_type_get_envelope__
+ _pmpi_type_get_envelope_=pmpi_type_get_envelope__
mpi_type_get_envelope__=pmpi_type_get_envelope__
+ _mpi_type_get_envelope_=pmpi_type_get_envelope__
+ mpi_type_get_envelope_=pmpi_type_get_envelope__
pmpi_type_get_extent__
+ pmpi_type_get_extent_=pmpi_type_get_extent__
+ _pmpi_type_get_extent_=pmpi_type_get_extent__
mpi_type_get_extent__=pmpi_type_get_extent__
+ _mpi_type_get_extent_=pmpi_type_get_extent__
+ mpi_type_get_extent_=pmpi_type_get_extent__
pmpi_type_get_name__
+ pmpi_type_get_name_=pmpi_type_get_name__
+ _pmpi_type_get_name_=pmpi_type_get_name__
mpi_type_get_name__=pmpi_type_get_name__
+ _mpi_type_get_name_=pmpi_type_get_name__
+ mpi_type_get_name_=pmpi_type_get_name__
pmpi_type_get_true_extent__
+ pmpi_type_get_true_extent_=pmpi_type_get_true_extent__
+ _pmpi_type_get_true_extent_=pmpi_type_get_true_extent__
mpi_type_get_true_extent__=pmpi_type_get_true_extent__
+ _mpi_type_get_true_extent_=pmpi_type_get_true_extent__
+ mpi_type_get_true_extent_=pmpi_type_get_true_extent__
pmpi_type_hindexed__
+ pmpi_type_hindexed_=pmpi_type_hindexed__
+ _pmpi_type_hindexed_=pmpi_type_hindexed__
mpi_type_hindexed__=pmpi_type_hindexed__
+ _mpi_type_hindexed_=pmpi_type_hindexed__
+ mpi_type_hindexed_=pmpi_type_hindexed__
pmpi_type_hvector__
+ pmpi_type_hvector_=pmpi_type_hvector__
+ _pmpi_type_hvector_=pmpi_type_hvector__
mpi_type_hvector__=pmpi_type_hvector__
+ _mpi_type_hvector_=pmpi_type_hvector__
+ mpi_type_hvector_=pmpi_type_hvector__
pmpi_type_indexed__
+ pmpi_type_indexed_=pmpi_type_indexed__
+ _pmpi_type_indexed_=pmpi_type_indexed__
mpi_type_indexed__=pmpi_type_indexed__
+ _mpi_type_indexed_=pmpi_type_indexed__
+ mpi_type_indexed_=pmpi_type_indexed__
pmpi_type_lb__
+ pmpi_type_lb_=pmpi_type_lb__
+ _pmpi_type_lb_=pmpi_type_lb__
mpi_type_lb__=pmpi_type_lb__
+ _mpi_type_lb_=pmpi_type_lb__
+ mpi_type_lb_=pmpi_type_lb__
pmpi_type_match_size__
+ pmpi_type_match_size_=pmpi_type_match_size__
+ _pmpi_type_match_size_=pmpi_type_match_size__
mpi_type_match_size__=pmpi_type_match_size__
+ _mpi_type_match_size_=pmpi_type_match_size__
+ mpi_type_match_size_=pmpi_type_match_size__
pmpi_type_set_attr__
+ pmpi_type_set_attr_=pmpi_type_set_attr__
+ _pmpi_type_set_attr_=pmpi_type_set_attr__
mpi_type_set_attr__=pmpi_type_set_attr__
+ _mpi_type_set_attr_=pmpi_type_set_attr__
+ mpi_type_set_attr_=pmpi_type_set_attr__
pmpi_type_set_name__
+ pmpi_type_set_name_=pmpi_type_set_name__
+ _pmpi_type_set_name_=pmpi_type_set_name__
mpi_type_set_name__=pmpi_type_set_name__
+ _mpi_type_set_name_=pmpi_type_set_name__
+ mpi_type_set_name_=pmpi_type_set_name__
pmpi_type_size__
+ pmpi_type_size_=pmpi_type_size__
+ _pmpi_type_size_=pmpi_type_size__
mpi_type_size__=pmpi_type_size__
+ _mpi_type_size_=pmpi_type_size__
+ mpi_type_size_=pmpi_type_size__
pmpi_type_struct__
+ pmpi_type_struct_=pmpi_type_struct__
+ _pmpi_type_struct_=pmpi_type_struct__
mpi_type_struct__=pmpi_type_struct__
+ _mpi_type_struct_=pmpi_type_struct__
+ mpi_type_struct_=pmpi_type_struct__
pmpi_type_ub__
+ pmpi_type_ub_=pmpi_type_ub__
+ _pmpi_type_ub_=pmpi_type_ub__
mpi_type_ub__=pmpi_type_ub__
+ _mpi_type_ub_=pmpi_type_ub__
+ mpi_type_ub_=pmpi_type_ub__
pmpi_type_vector__
+ pmpi_type_vector_=pmpi_type_vector__
+ _pmpi_type_vector_=pmpi_type_vector__
mpi_type_vector__=pmpi_type_vector__
+ _mpi_type_vector_=pmpi_type_vector__
+ mpi_type_vector_=pmpi_type_vector__
pmpi_unpack__
+ pmpi_unpack_=pmpi_unpack__
+ _pmpi_unpack_=pmpi_unpack__
mpi_unpack__=pmpi_unpack__
+ _mpi_unpack_=pmpi_unpack__
+ mpi_unpack_=pmpi_unpack__
pmpi_unpack_external__
+ pmpi_unpack_external_=pmpi_unpack_external__
+ _pmpi_unpack_external_=pmpi_unpack_external__
mpi_unpack_external__=pmpi_unpack_external__
+ _mpi_unpack_external_=pmpi_unpack_external__
+ mpi_unpack_external_=pmpi_unpack_external__
pmpi_unpublish_name__
+ pmpi_unpublish_name_=pmpi_unpublish_name__
+ _pmpi_unpublish_name_=pmpi_unpublish_name__
mpi_unpublish_name__=pmpi_unpublish_name__
+ _mpi_unpublish_name_=pmpi_unpublish_name__
+ mpi_unpublish_name_=pmpi_unpublish_name__
pmpi_wait__
+ pmpi_wait_=pmpi_wait__
+ _pmpi_wait_=pmpi_wait__
mpi_wait__=pmpi_wait__
+ _mpi_wait_=pmpi_wait__
+ mpi_wait_=pmpi_wait__
pmpi_waitall__
+ pmpi_waitall_=pmpi_waitall__
+ _pmpi_waitall_=pmpi_waitall__
mpi_waitall__=pmpi_waitall__
+ _mpi_waitall_=pmpi_waitall__
+ mpi_waitall_=pmpi_waitall__
pmpi_waitany__
+ pmpi_waitany_=pmpi_waitany__
+ _pmpi_waitany_=pmpi_waitany__
mpi_waitany__=pmpi_waitany__
+ _mpi_waitany_=pmpi_waitany__
+ mpi_waitany_=pmpi_waitany__
pmpi_waitsome__
+ pmpi_waitsome_=pmpi_waitsome__
+ _pmpi_waitsome_=pmpi_waitsome__
mpi_waitsome__=pmpi_waitsome__
+ _mpi_waitsome_=pmpi_waitsome__
+ mpi_waitsome_=pmpi_waitsome__
pmpi_win_call_errhandler__
+ pmpi_win_call_errhandler_=pmpi_win_call_errhandler__
+ _pmpi_win_call_errhandler_=pmpi_win_call_errhandler__
mpi_win_call_errhandler__=pmpi_win_call_errhandler__
+ _mpi_win_call_errhandler_=pmpi_win_call_errhandler__
+ mpi_win_call_errhandler_=pmpi_win_call_errhandler__
pmpi_win_complete__
+ pmpi_win_complete_=pmpi_win_complete__
+ _pmpi_win_complete_=pmpi_win_complete__
mpi_win_complete__=pmpi_win_complete__
+ _mpi_win_complete_=pmpi_win_complete__
+ mpi_win_complete_=pmpi_win_complete__
pmpi_win_create__
+ pmpi_win_create_=pmpi_win_create__
+ _pmpi_win_create_=pmpi_win_create__
mpi_win_create__=pmpi_win_create__
+ _mpi_win_create_=pmpi_win_create__
+ mpi_win_create_=pmpi_win_create__
pmpi_win_create_errhandler__
+ pmpi_win_create_errhandler_=pmpi_win_create_errhandler__
+ _pmpi_win_create_errhandler_=pmpi_win_create_errhandler__
mpi_win_create_errhandler__=pmpi_win_create_errhandler__
+ _mpi_win_create_errhandler_=pmpi_win_create_errhandler__
+ mpi_win_create_errhandler_=pmpi_win_create_errhandler__
pmpi_win_create_keyval__
+ pmpi_win_create_keyval_=pmpi_win_create_keyval__
+ _pmpi_win_create_keyval_=pmpi_win_create_keyval__
mpi_win_create_keyval__=pmpi_win_create_keyval__
+ _mpi_win_create_keyval_=pmpi_win_create_keyval__
+ mpi_win_create_keyval_=pmpi_win_create_keyval__
pmpi_win_delete_attr__
+ pmpi_win_delete_attr_=pmpi_win_delete_attr__
+ _pmpi_win_delete_attr_=pmpi_win_delete_attr__
mpi_win_delete_attr__=pmpi_win_delete_attr__
+ _mpi_win_delete_attr_=pmpi_win_delete_attr__
+ mpi_win_delete_attr_=pmpi_win_delete_attr__
pmpi_win_fence__
+ pmpi_win_fence_=pmpi_win_fence__
+ _pmpi_win_fence_=pmpi_win_fence__
mpi_win_fence__=pmpi_win_fence__
+ _mpi_win_fence_=pmpi_win_fence__
+ mpi_win_fence_=pmpi_win_fence__
pmpi_win_free__
+ pmpi_win_free_=pmpi_win_free__
+ _pmpi_win_free_=pmpi_win_free__
mpi_win_free__=pmpi_win_free__
+ _mpi_win_free_=pmpi_win_free__
+ mpi_win_free_=pmpi_win_free__
pmpi_win_free_keyval__
+ pmpi_win_free_keyval_=pmpi_win_free_keyval__
+ _pmpi_win_free_keyval_=pmpi_win_free_keyval__
mpi_win_free_keyval__=pmpi_win_free_keyval__
+ _mpi_win_free_keyval_=pmpi_win_free_keyval__
+ mpi_win_free_keyval_=pmpi_win_free_keyval__
pmpi_win_get_attr__
+ pmpi_win_get_attr_=pmpi_win_get_attr__
+ _pmpi_win_get_attr_=pmpi_win_get_attr__
mpi_win_get_attr__=pmpi_win_get_attr__
+ _mpi_win_get_attr_=pmpi_win_get_attr__
+ mpi_win_get_attr_=pmpi_win_get_attr__
pmpi_win_get_errhandler__
+ pmpi_win_get_errhandler_=pmpi_win_get_errhandler__
+ _pmpi_win_get_errhandler_=pmpi_win_get_errhandler__
mpi_win_get_errhandler__=pmpi_win_get_errhandler__
+ _mpi_win_get_errhandler_=pmpi_win_get_errhandler__
+ mpi_win_get_errhandler_=pmpi_win_get_errhandler__
pmpi_win_get_group__
+ pmpi_win_get_group_=pmpi_win_get_group__
+ _pmpi_win_get_group_=pmpi_win_get_group__
mpi_win_get_group__=pmpi_win_get_group__
+ _mpi_win_get_group_=pmpi_win_get_group__
+ mpi_win_get_group_=pmpi_win_get_group__
pmpi_win_get_name__
+ pmpi_win_get_name_=pmpi_win_get_name__
+ _pmpi_win_get_name_=pmpi_win_get_name__
mpi_win_get_name__=pmpi_win_get_name__
+ _mpi_win_get_name_=pmpi_win_get_name__
+ mpi_win_get_name_=pmpi_win_get_name__
pmpi_win_lock__
+ pmpi_win_lock_=pmpi_win_lock__
+ _pmpi_win_lock_=pmpi_win_lock__
mpi_win_lock__=pmpi_win_lock__
+ _mpi_win_lock_=pmpi_win_lock__
+ mpi_win_lock_=pmpi_win_lock__
pmpi_win_post__
+ pmpi_win_post_=pmpi_win_post__
+ _pmpi_win_post_=pmpi_win_post__
mpi_win_post__=pmpi_win_post__
+ _mpi_win_post_=pmpi_win_post__
+ mpi_win_post_=pmpi_win_post__
pmpi_win_set_attr__
+ pmpi_win_set_attr_=pmpi_win_set_attr__
+ _pmpi_win_set_attr_=pmpi_win_set_attr__
mpi_win_set_attr__=pmpi_win_set_attr__
+ _mpi_win_set_attr_=pmpi_win_set_attr__
+ mpi_win_set_attr_=pmpi_win_set_attr__
pmpi_win_set_errhandler__
+ pmpi_win_set_errhandler_=pmpi_win_set_errhandler__
+ _pmpi_win_set_errhandler_=pmpi_win_set_errhandler__
mpi_win_set_errhandler__=pmpi_win_set_errhandler__
+ _mpi_win_set_errhandler_=pmpi_win_set_errhandler__
+ mpi_win_set_errhandler_=pmpi_win_set_errhandler__
pmpi_win_set_name__
+ pmpi_win_set_name_=pmpi_win_set_name__
+ _pmpi_win_set_name_=pmpi_win_set_name__
mpi_win_set_name__=pmpi_win_set_name__
+ _mpi_win_set_name_=pmpi_win_set_name__
+ mpi_win_set_name_=pmpi_win_set_name__
pmpi_win_start__
+ pmpi_win_start_=pmpi_win_start__
+ _pmpi_win_start_=pmpi_win_start__
mpi_win_start__=pmpi_win_start__
+ _mpi_win_start_=pmpi_win_start__
+ mpi_win_start_=pmpi_win_start__
pmpi_win_test__
+ pmpi_win_test_=pmpi_win_test__
+ _pmpi_win_test_=pmpi_win_test__
mpi_win_test__=pmpi_win_test__
+ _mpi_win_test_=pmpi_win_test__
+ mpi_win_test_=pmpi_win_test__
pmpi_win_unlock__
+ pmpi_win_unlock_=pmpi_win_unlock__
+ _pmpi_win_unlock_=pmpi_win_unlock__
mpi_win_unlock__=pmpi_win_unlock__
+ _mpi_win_unlock_=pmpi_win_unlock__
+ mpi_win_unlock_=pmpi_win_unlock__
pmpi_win_wait__
+ pmpi_win_wait_=pmpi_win_wait__
+ _pmpi_win_wait_=pmpi_win_wait__
mpi_win_wait__=pmpi_win_wait__
+ _mpi_win_wait_=pmpi_win_wait__
+ mpi_win_wait_=pmpi_win_wait__
pmpi_wtick__
+ pmpi_wtick_=pmpi_wtick__
+ _pmpi_wtick_=pmpi_wtick__
mpi_wtick__=pmpi_wtick__
+ _mpi_wtick_=pmpi_wtick__
+ mpi_wtick_=pmpi_wtick__
pmpi_wtime__
+ pmpi_wtime_=pmpi_wtime__
+ _pmpi_wtime_=pmpi_wtime__
mpi_wtime__=pmpi_wtime__
+ _mpi_wtime_=pmpi_wtime__
+ mpi_wtime_=pmpi_wtime__
pmpi_dup_fn__
+ pmpi_dup_fn_=pmpi_dup_fn__
+ _pmpi_dup_fn_=pmpi_dup_fn__
mpi_dup_fn__=pmpi_dup_fn__
+ _mpi_dup_fn_=pmpi_dup_fn__
+ mpi_dup_fn_=pmpi_dup_fn__
pmpi_null_delete_fn__
+ pmpi_null_delete_fn_=pmpi_null_delete_fn__
+ _pmpi_null_delete_fn_=pmpi_null_delete_fn__
mpi_null_delete_fn__=pmpi_null_delete_fn__
+ _mpi_null_delete_fn_=pmpi_null_delete_fn__
+ mpi_null_delete_fn_=pmpi_null_delete_fn__
pmpi_null_copy_fn__
+ pmpi_null_copy_fn_=pmpi_null_copy_fn__
+ _pmpi_null_copy_fn_=pmpi_null_copy_fn__
mpi_null_copy_fn__=pmpi_null_copy_fn__
+ _mpi_null_copy_fn_=pmpi_null_copy_fn__
+ mpi_null_copy_fn_=pmpi_null_copy_fn__
pmpi_comm_dup_fn__
+ pmpi_comm_dup_fn_=pmpi_comm_dup_fn__
+ _pmpi_comm_dup_fn_=pmpi_comm_dup_fn__
mpi_comm_dup_fn__=pmpi_comm_dup_fn__
+ _mpi_comm_dup_fn_=pmpi_comm_dup_fn__
+ mpi_comm_dup_fn_=pmpi_comm_dup_fn__
pmpi_comm_null_delete_fn__
+ pmpi_comm_null_delete_fn_=pmpi_comm_null_delete_fn__
+ _pmpi_comm_null_delete_fn_=pmpi_comm_null_delete_fn__
mpi_comm_null_delete_fn__=pmpi_comm_null_delete_fn__
+ _mpi_comm_null_delete_fn_=pmpi_comm_null_delete_fn__
+ mpi_comm_null_delete_fn_=pmpi_comm_null_delete_fn__
pmpi_comm_null_copy_fn__
+ pmpi_comm_null_copy_fn_=pmpi_comm_null_copy_fn__
+ _pmpi_comm_null_copy_fn_=pmpi_comm_null_copy_fn__
mpi_comm_null_copy_fn__=pmpi_comm_null_copy_fn__
+ _mpi_comm_null_copy_fn_=pmpi_comm_null_copy_fn__
+ mpi_comm_null_copy_fn_=pmpi_comm_null_copy_fn__
pmpi_win_dup_fn__
+ pmpi_win_dup_fn_=pmpi_win_dup_fn__
+ _pmpi_win_dup_fn_=pmpi_win_dup_fn__
mpi_win_dup_fn__=pmpi_win_dup_fn__
+ _mpi_win_dup_fn_=pmpi_win_dup_fn__
+ mpi_win_dup_fn_=pmpi_win_dup_fn__
pmpi_win_null_delete_fn__
+ pmpi_win_null_delete_fn_=pmpi_win_null_delete_fn__
+ _pmpi_win_null_delete_fn_=pmpi_win_null_delete_fn__
mpi_win_null_delete_fn__=pmpi_win_null_delete_fn__
+ _mpi_win_null_delete_fn_=pmpi_win_null_delete_fn__
+ mpi_win_null_delete_fn_=pmpi_win_null_delete_fn__
pmpi_win_null_copy_fn__
+ pmpi_win_null_copy_fn_=pmpi_win_null_copy_fn__
+ _pmpi_win_null_copy_fn_=pmpi_win_null_copy_fn__
mpi_win_null_copy_fn__=pmpi_win_null_copy_fn__
+ _mpi_win_null_copy_fn_=pmpi_win_null_copy_fn__
+ mpi_win_null_copy_fn_=pmpi_win_null_copy_fn__
pmpi_type_dup_fn__
+ pmpi_type_dup_fn_=pmpi_type_dup_fn__
+ _pmpi_type_dup_fn_=pmpi_type_dup_fn__
mpi_type_dup_fn__=pmpi_type_dup_fn__
+ _mpi_type_dup_fn_=pmpi_type_dup_fn__
+ mpi_type_dup_fn_=pmpi_type_dup_fn__
pmpi_type_null_delete_fn__
+ pmpi_type_null_delete_fn_=pmpi_type_null_delete_fn__
+ _pmpi_type_null_delete_fn_=pmpi_type_null_delete_fn__
mpi_type_null_delete_fn__=pmpi_type_null_delete_fn__
+ _mpi_type_null_delete_fn_=pmpi_type_null_delete_fn__
+ mpi_type_null_delete_fn_=pmpi_type_null_delete_fn__
pmpi_type_null_copy_fn__
+ pmpi_type_null_copy_fn_=pmpi_type_null_copy_fn__
+ _pmpi_type_null_copy_fn_=pmpi_type_null_copy_fn__
mpi_type_null_copy_fn__=pmpi_type_null_copy_fn__
+ _mpi_type_null_copy_fn_=pmpi_type_null_copy_fn__
+ mpi_type_null_copy_fn_=pmpi_type_null_copy_fn__
mpi_conversion_fn_null__
+ mpi_conversion_fn_null_=mpi_conversion_fn_null__
+ _mpi_conversion_fn_null_=mpi_conversion_fn_null__
; pmpi_status_c2f__
; pmpi_status_f2c__
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c
___________________________________________________________________
Modified: svn:mergeinfo
- /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/branches/dev/ckpt2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5057-6537
/mpich2/branches/dev/ftb/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5661-5730
/mpich2/branches/dev/lapi/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5817
/mpich2/branches/dev/win_rrvm/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:6416,6428
/mpich2/branches/dev/wintcp_async_progress/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5406
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7448,7462,7470,7473-7477,7484-7485
+ /mpich2/branches/dev/ckpt/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:5050
/mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/wintcp/socksm.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7425,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485
Property changes on: mpich2/branches/release/mpich2-1.3.x/src/mpl/src/mplstr.c
- /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/branches/dev/ftb/src/mpl/src/mplstr.c:5661-5730
/mpich2/branches/dev/lapi/src/mpl/src/mplstr.c:5817
/mpich2/branches/release/mpich2-1.1.1/src/mpl/src/string/mplstr.c:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/src/mpl/src/string/mplstr.c:5406
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7448,7462,7470,7473-7477,7484-7485
+ /mpich2/branches/dev/ckpt2/src/mpl/src/string/mplstr.c:5182,5196,5198
/mpich2/trunk/src/mpl/src/mplstr.c:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485
Modified: mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
--- mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf 2010-11-23 07:30:29 UTC (rev 7486)
+++ mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf 2010-11-23 19:05:11 UTC (rev 7487)
@@ -246,7 +246,11 @@
' Miscellaneous settings
MPI_MAX_PROCESSOR_NAME = "128"
-MPI_AINT64 = "__int64"
+' Use the decorated MPI_AINT64_TYPE with MPI_AINT64_TYPEDEF_BEGIN & *END decos
+' for user exposed headers
+MPI_AINT64_TYPE = "MPI_AINT64_TYPE"
+' Use MPI_AINT64 for internal headers
+MPI_AINT64 = "__int64"
MPI_AINT64_FMT_DEC_SPEC = "%I64d"
MPIR_PINT64_FMT_DEC_SPEC = """%I64d"""
MPIR_UPINT64_FMT_DEC_SPEC = """%I64u"""
@@ -265,6 +269,8 @@
'MPI_OFFSET_TYPEDEF = "typedef __int64 MPI_Offset;"
'MPI_OFFSET_TYPEDEF = "typedef long long MPI_Offset;"
MPI_OFFSET_TYPEDEF = "#if defined(USE_GCC) || defined(__GNUC__)" + vbCrLf + "typedef long long MPI_Offset;" + vbCrLf + "#else" + vbCrLf + "typedef __int64 MPI_Offset;" + vbCrLf + "#endif"
+MPI_AINT64_TYPEDEF_BEGIN = "#ifdef MPI_AINT64_TYPE" + vbCrLf + "#undef MPI_AINT64_TYPE" + vbCrLf + "#endif" + vbCrLf + "#if defined(USE_GCC) || defined(__GNUC__)" + vbCrLf + "#define MPI_AINT64_TYPE long long" + vbCrLf + "#else" + vbCrLf + "#define MPI_AINT64_TYPE __int64" + vbCrLf + "#endif" + vbCrLf
+MPI_AINT64_TYPEDEF_END = vbCrLf + "#undef MPI_AINT64_TYPE" + vbCrLf
EXTRA_STATUS_DECL = ""
HAVE_ROMIO = "#include ""mpio.h"""
mpi_dll_spec_definition = "#ifdef USE_MPI_STATIC_LIBRARY" + vbCrLf + "# define MPIU_DLL_SPEC" + vbCrLf + "#else" + vbCrLf + "# ifdef MPI_EXPORTS" + vbCrLf + "# define MPIU_DLL_SPEC __declspec(dllexport)" + vbCrLf + "# else" + vbCrLf + "# define MPIU_DLL_SPEC __declspec(dllimport)" + vbCrLf + "# endif" + vbCrLf + "#endif" + vbCrLf + "#define MPI_CALL __cdecl" + vbCrLf
@@ -1609,6 +1615,27 @@
End If
End Function
+Function ReplaceAtsWithDecoration(ByVal str, use_f77, b64 )
+ Dim regEx, Match, Matches
+ Set regEx = New RegExp
+ regEx.Pattern = "@.[0-9a-z_]*@"
+ regEx.IgnoreCase = True
+ regEx.Global = True
+ Set Matches = regEx.Execute(str)
+ For Each Match in Matches
+ Select Case Match
+ Case "@MPI_AINT@"
+ if b64 then
+ str = Replace(str, "@MPI_AINT@", MPI_AINT64_TYPE)
+ str = MPI_AINT64_TYPEDEF_BEGIN & str & MPI_AINT64_TYPEDEF_END
+ else
+ str = Replace(str, "@MPI_AINT@", MPI_AINT32)
+ end if
+ End Select
+ Next
+ ReplaceAtsWithDecoration = str
+End Function
Function ReplaceAts( str, use_f77, b64 )
@@ -3837,6 +3864,8 @@
fout.WriteLine("/* #undef LT_OBJDIR */")
Case "USE_MPIU_INSTR"
fout.WriteLine("/* #undef USE_MPIU_INSTR */")
+ Case "HAVE_QSORT"
+ fout.WriteLine("#define HAVE_QSORT 1")
Case Else
Dim useCustomDefDict
useCustomDefDict = False
@@ -3886,9 +3915,16 @@
set fout32 = f.CreateTextFile("src\include\win32\mpi.h")
set fin = f.OpenTextFile("src\include\mpi.h.in")
-contents32 = fin.ReadAll()
-contents64 = contents32
+contents32=""
+contents64=""
+do until fin.AtEndOfStream = True
+ line = fin.ReadLine()
+ contents32 = contents32 + ReplaceAtsWithDecoration(line, false, false) + vbCrLf
+ contents64 = contents64 + ReplaceAtsWithDecoration(line, false, true) + vbCrLf
+loop
fin.Close()
contents32 = ReplaceAts(contents32, false, false)
contents64 = ReplaceAts(contents64, false, true)
if bAddDllDecoration then
@@ -4479,6 +4515,8 @@
If bForce Or Not f.FileExists("src\binding\cxx\mpicxx.h.in") Then
Set WshShell = CreateObject("WScript.Shell")
+ Set userEnv = WshShell.Environment("USER")
+ userEnv("nodosfilewarning") = 1
WshShell.CurrentDirectory = "src\binding\cxx"
printMsg "VERBOSE", WshShell.CurrentDirectory & ">perl buildiface -nosep"
WshShell.Run "perl buildiface -nosep", 0, true
@@ -4550,6 +4588,8 @@
If bForce Or Not f.FileExists("src\binding\mcxx\mpimcxx.h.in") Then
WshShell.CurrentDirectory = "src\binding\mcxx"
@@ -4592,6 +4632,8 @@
If bForce Or Not f.FileExists("src\binding\f77\mpif.h.in") Then
WshShell.CurrentDirectory = "src\binding\f77"
printMsg "VERBOSE", WshShell.CurrentDirectory & ">perl buildiface"
WshShell.Run "perl buildiface", 0, true
@@ -4683,6 +4725,8 @@
If bForce Or Not f.FileExists("src\binding\f90\mpi.f90") Then
WshShell.CurrentDirectory = "src\binding\f90"
@@ -6440,6 +6484,7 @@
bfile.WriteLine("nmake %SILENT% /NOLOGO irlog2rlog")
bfile.WriteLine("nmake %SILENT% /NOLOGO TraceInput")
bfile.WriteLine("nmake %SILENT% /NOLOGO gcc_libs")
+ bfile.WriteLine("nmake %SILENT% /NOLOGO impgen")
bfile.Close()
Set mfile = f.CreateTextFile("winbuild\makefile", true)
Property changes on: mpich2/branches/release/mpich2-1.3.x/winconfigure.wsf
- /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/branches/dev/ckpt2/winconfigure.wsf:5057-6537
/mpich2/branches/dev/ftb/winconfigure.wsf:5661-5730
/mpich2/branches/dev/lapi/winconfigure.wsf:5817
/mpich2/branches/dev/win_rrvm/winconfigure.wsf:6404,6407-6408,6420,6422-6423
/mpich2/branches/dev/wintcp_async_progress/winconfigure.wsf:5008-5009,5123,5555-5559,5561-5564,5566-5567,5570,5577-5581,5613-5616,5619
/mpich2/branches/release/mpich2-1.1.1/winconfigure.wsf:5022,5032,5110,5113,5140-5141
/mpich2/branches/release/mpich2-1.2/winconfigure.wsf:5406
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7448,7462,7470,7473-7477,7484-7485
+ /mpich2/branches/dev/ckpt/winconfigure.wsf:5050
/mpich2/trunk/winconfigure.wsf:7355-7359,7366-7367,7371-7402,7406-7409,7411-7416,7419-7420,7422-7424,7429-7433,7435,7437-7438,7442-7446,7448,7459-7460,7462,7469-7470,7473-7478,7484-7485
More information about the mpich2-commits
