[mpich2-commits] r7485 - in mpich2/trunk/src/pm/hydra: tools/bootstrap/utils tools/demux ui/mpich utils/signals utils/sock
balaji at mcs.anl.gov
Tue Nov 23 01:21:56 CST 2010
Author: balaji
Date: 2010-11-23 01:21:56 -0600 (Tue, 23 Nov 2010)
New Revision: 7485
Modified:
mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_cb.c
mpich2/trunk/src/pm/hydra/tools/demux/demux_poll.c
mpich2/trunk/src/pm/hydra/tools/demux/demux_select.c
mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
mpich2/trunk/src/pm/hydra/utils/signals/signals.c
mpich2/trunk/src/pm/hydra/utils/sock/sock.c
Log:
Disable reading stdin from the command-line when running in the
background.
Modified: mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_cb.c
--- mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_cb.c 2010-11-23 07:21:38 UTC (rev 7484)
+++ mpich2/trunk/src/pm/hydra/tools/bootstrap/utils/bscu_cb.c 2010-11-23 07:21:56 UTC (rev 7485)
@@ -32,6 +32,8 @@
close(fd);
+ if (fd == STDIN_FILENO)
+ close(stdfd);
fn_exit:
Modified: mpich2/trunk/src/pm/hydra/tools/demux/demux_poll.c
--- mpich2/trunk/src/pm/hydra/tools/demux/demux_poll.c 2010-11-23 07:21:38 UTC (rev 7484)
+++ mpich2/trunk/src/pm/hydra/tools/demux/demux_poll.c 2010-11-23 07:21:56 UTC (rev 7485)
@@ -120,6 +120,16 @@
else
*out = 1;
+ /* This is an extremely round-about way of solving a simple
+ * problem. isatty(STDIN_FILENO) seems to return 1, even when
+ * mpiexec is run in the background. So, instead of relying on
+ * that, we catch SIGTTIN and ignore it. But that causes the
+ * read() call to return an error (with errno == EINTR) when we
+ * are not attached to the terminal. */
+ ret = read(STDIN_FILENO, NULL, 0);
+ if (ret < 0 && errno == EINTR)
+ *out = 0;
fn_exit:
HYDU_FUNC_EXIT();
return status;
Modified: mpich2/trunk/src/pm/hydra/tools/demux/demux_select.c
--- mpich2/trunk/src/pm/hydra/tools/demux/demux_select.c 2010-11-23 07:21:38 UTC (rev 7484)
+++ mpich2/trunk/src/pm/hydra/tools/demux/demux_select.c 2010-11-23 07:21:56 UTC (rev 7485)
@@ -113,6 +113,16 @@
else
*out = 1;
+ *out = 0;
fn_exit:
HYDU_FUNC_EXIT();
return status;
Modified: mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c
--- mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2010-11-23 07:21:38 UTC (rev 7484)
+++ mpich2/trunk/src/pm/hydra/ui/mpich/mpiexec.c 2010-11-23 07:21:56 UTC (rev 7485)
@@ -143,7 +143,7 @@
cmd = HYD_CKPOINT;
HYDU_sock_write(HYD_handle.cleanup_pipe[1], &cmd, sizeof(cmd), &sent, &closed);
- /* Ignore other signals for now */
+ /* Ignore all other signals, including SIGTTIN */
HYDU_FUNC_EXIT();
return;
Modified: mpich2/trunk/src/pm/hydra/utils/signals/signals.c
--- mpich2/trunk/src/pm/hydra/utils/signals/signals.c 2010-11-23 07:21:38 UTC (rev 7484)
+++ mpich2/trunk/src/pm/hydra/utils/signals/signals.c 2010-11-23 07:21:56 UTC (rev 7485)
@@ -59,6 +59,11 @@
status = HYDU_set_signal(SIGALRM, handler);
HYDU_ERR_POP(status, "unable to set SIGALRM\n");
+#ifdef SIGTTIN
+ status = HYDU_set_signal(SIGTTIN, handler);
+ HYDU_ERR_POP(status, "unable to set SIGTTIN\n");
+#endif /* SIGTTIN */
fn_exit:
HYDU_FUNC_EXIT();
return status;
Modified: mpich2/trunk/src/pm/hydra/utils/sock/sock.c
--- mpich2/trunk/src/pm/hydra/utils/sock/sock.c 2010-11-23 07:21:38 UTC (rev 7484)
+++ mpich2/trunk/src/pm/hydra/utils/sock/sock.c 2010-11-23 07:21:56 UTC (rev 7485)
@@ -205,6 +205,13 @@
while (1) {
do {
tmp = read(fd, (char *) buf + *recvd, maxlen - *recvd);
+ if (tmp < 0 && errno == EINTR && fd == STDIN_FILENO) {
+ /* If we get an EINTR on stdin, set the socket to be
+ * closed and jump out */
+ *closed = 1;
+ status = HYD_SUCCESS;
+ goto fn_exit;
} while (tmp < 0 && errno == EINTR);
if (tmp < 0) {
More information about the mpich2-commits
