[mpich2-commits] r7471 - in mpich2/trunk: doc/userguide maint src/pm src/pm/remshell
balaji at mcs.anl.gov
Mon Nov 22 09:51:54 CST 2010
Author: balaji
Date: 2010-11-22 09:51:53 -0600 (Mon, 22 Nov 2010)
New Revision: 7471
Removed:
mpich2/trunk/src/pm/remshell/Makefile.sm
mpich2/trunk/src/pm/remshell/configure.in
mpich2/trunk/src/pm/remshell/mpich2prereq
mpich2/trunk/src/pm/remshell/mpiexec.c
Modified:
mpich2/trunk/doc/userguide/user.tex.vin
mpich2/trunk/maint/checkbuilds.in
mpich2/trunk/src/pm/Makefile.sm
Log:
Remove the remshell process manager, which is no longer supported.
Modified: mpich2/trunk/doc/userguide/user.tex.vin
--- mpich2/trunk/doc/userguide/user.tex.vin 2010-11-22 15:51:16 UTC (rev 7470)
+++ mpich2/trunk/doc/userguide/user.tex.vin 2010-11-22 15:51:53 UTC (rev 7471)
@@ -741,29 +741,6 @@
but for standard error.
\end{description}
-\subsection{Restrictions of the remshell Process Management Environment}
-\label{sec:restrictions-remshell}
-The \texttt{remshell} ``process manager'' provides a very simple version of
-\texttt{mpiexec} that makes use of the secure shell command (\texttt{ssh}) to
-start processes on a collection of machines. As this is intended primarily as
-an illustration of how to build a version of \texttt{mpiexec} that works with
-other process managers, it does not implement all of the features of the other
-\texttt{mpiexec} programs described in this document. In particular, it
-ignores the command line options that control the environment variables given
-to the MPI programs. It does support the same output labeling features
-provided by the \texttt{gforker} version of \texttt{mpiexec}.
-However, this version of \texttt{mpiexec} can be used
-much like the \texttt{mpirun} for the \texttt{ch\_p4} device in MPICH-1 to run
-programs on a collection of machines that allow remote shells. A file by the
-name of \texttt{machines} should contain the names of machines on which
-processes can be run, one machine name per line. There must be enough
-machines listed to satisfy the requested number of processes; you can list the
-same machine name multiple times if necessary.
-For more complex needs or for faster startup, we recommend the use of the
-\texttt{mpd} process manager.
\subsection{Using MPICH2 with SLURM and PBS}
\label{sec:external_pm}
Modified: mpich2/trunk/maint/checkbuilds.in
--- mpich2/trunk/maint/checkbuilds.in 2010-11-22 15:51:16 UTC (rev 7470)
+++ mpich2/trunk/maint/checkbuilds.in 2010-11-22 15:51:53 UTC (rev 7471)
@@ -66,7 +66,7 @@
@with_array = (
'logging;none;rlog',
'pmi;simple;smpd', #; uni no longer supported
- 'pm;gforker;mpd', #;remshell
+ 'pm;gforker;mpd',
'namepublisher;no;file;mpd', #;ldap:ldapserver',
'device;ch3;ch3:sock',
Modified: mpich2/trunk/src/pm/Makefile.sm
--- mpich2/trunk/src/pm/Makefile.sm 2010-11-22 15:51:16 UTC (rev 7470)
+++ mpich2/trunk/src/pm/Makefile.sm 2010-11-22 15:51:53 UTC (rev 7471)
@@ -1,7 +1,7 @@
# SUBDIRS_pm_name are the names that @ pm_name @ can take in SUBDIRS
# (except for util, which is included so that simplemake will process
# the Makefile.sm in that directory)
-SUBDIRS_pm_name = mpd smpd gforker remshell
+SUBDIRS_pm_name = mpd smpd gforker
SUBDIRS = @pm_name@ @other_pm_names@ .
# Remove PMPILIBNAME from the common make variables for the mpid
# directories
Deleted: mpich2/trunk/src/pm/remshell/Makefile.sm
--- mpich2/trunk/src/pm/remshell/Makefile.sm 2010-11-22 15:51:16 UTC (rev 7470)
+++ mpich2/trunk/src/pm/remshell/Makefile.sm 2010-11-22 15:51:53 UTC (rev 7471)
@@ -1,37 +0,0 @@
-mpiexec_SOURCES = mpiexec.c
-mpiexec_LDADD = -L../util -lmpiexec
-INCLUDES = -I../../include -I${master_top_srcdir}/src/include \
- -I../../pmi/simple -I${master_top_srcdir}/src/pmi/simple \
- -I${master_top_srcdir}/src/pm/util
-install_BIN = mpiexec
-clean-local:
- @-(cd ../util && $(MAKE) clean)
-distclean-local:
- @-rm -f remshellconf.h
-# Use the mpich2-build-install target to include mpiexec in the build bin
-# directory (all pm's require these targets)
-mpich2-build-install: install
-mpich2-build-uninstall: uninstall
-# A special alternate installation target when using multiple process managers
-install-alt: mpiexec
- @if [ ! -d $(DESTDIR)${bindir} ] ; then \
- echo "mkdir -p $(DESTDIR)${bindir} " ;\
- mkdir -p $(DESTDIR)${bindir} ;\
- fi
- $(INSTALL_PROGRAM) $(INSTALL_STRIP_FLAG) mpiexec $(DESTDIR)${bindir}/mpiexec.remshell
-doc_sources = mpiexec.txt
-DOCDESTDIRS = html:www/www1,man:man/man1,latex:doc/refman
-docargs_ADD = ${master_top_srcdir}/doc/mansrc/cmdnotes
-doc_HTML_SOURCES = ${doc_sources}
-doc_MAN_SOURCES = ${doc_sources}
-doc_LATEX_SOURCES = ${doc_sources}
-# We use a dummy dependency to ensure that we always go to the util
-# directory to see if anything needs to be done
-../util/libmpiexec.a: dummy
-dummy:
- cd ../util && $(MAKE)
Deleted: mpich2/trunk/src/pm/remshell/configure.in
--- mpich2/trunk/src/pm/remshell/configure.in 2010-11-22 15:51:16 UTC (rev 7470)
+++ mpich2/trunk/src/pm/remshell/configure.in 2010-11-22 15:51:53 UTC (rev 7471)
@@ -1,255 +0,0 @@
-dnl Process this file with autoconf to produce a configure script.
-dnl
-dnl aclocal_cache.m4, included by sowing/confdb/aclocal.m4, fixes
-dnl bugs in autoconf caching.
-dnl
-dnl The file name here refers to a file in the source being configured
-AC_INIT(mpiexec.c)
-dnl Definitions will be placed in this file rather than in the DEFS variable
-AC_CONFIG_HEADER(remshellconf.h)
-AH_TOP([/* -*- Mode: C; c-basic-offset:4 ; -*- */
- * (C) 2001 by Argonne National Laboratory.
- * See COPYRIGHT in top-level directory.
-#ifndef REMSHELLCONF_H_INCLUDED
-#define REMSHELLCONF_H_INCLUDED
-AH_BOTTOM([#endif])
-dnl
-dnl Set the directory that contains support scripts such as install-sh and
-dnl config.guess
-AC_CONFIG_AUX_DIR(../../../confdb)
-dnl
-echo "RUNNING CONFIGURE FOR THE REMSHELL PM"
-dnl
-dnl Use AC_ARG_ENABLE to look for --enable-feature and AC_ARG_WITH to look for
-dnl --with-capability
-dnl
-dnl Enable better caching control
-PAC_ARG_CACHING
-dnl
-AC_ARG_ENABLE(echo,
-[--enable-echo - Turn on strong echoing. The default is enable=no.] ,set -x)
-AC_ARG_ENABLE(onsig,
-[--enable-onsig - Control the handling of processes that signal (e.g., SEGV)
- using ptrace. Disabled by default],,enable_onsig=no)
-AC_ARG_ENABLE(newsession,
-[--enable-newsession - Create a new process group session if standard in is
- not connected to a terminal],,enable_newsession=yes)
-dnl With options
-dnl
-dnl First check that we have a clean build if we are doing a VPATH build
-PAC_VPATH_CHECK()
-dnl
-dnl Process any enable or with values
-dnl This test is complicated by the fact that top_srcdir is not set until
-dnl the very end of configure. Instead, we get it ourselves
-if test -z "$top_srcdir" ; then
- use_top_srcdir=$srcdir
-else
- use_top_srcdir=$top_srcdir
-fi
-PAC_LOAD_BASE_CACHE
-dnl The recommended order for items in a configure.in file is
-dnl check for programs
-dnl check for libraries
-dnl check for header files
-dnl check for typedefs
-dnl check for structures
-dnl check for compiler characteristics
-dnl check for library functions
-dnl check for system services
-dnl Here are some sample tests
-dnl
-dnl Determine the executable and object file extensions. These
-dnl are needed for some operations under cygwin
-AC_EXEEXT
-AC_OBJEXT
-dnl Find a C compiler
-PAC_PROG_CC
-PAC_ARG_STRICT
-AC_PROG_INSTALL
-PAC_PROG_MKDIR_P
-PAC_PROG_MAKE
-dnl AC_CHECK_PROGS(AR,ar)
-dnl AC_PROG_RANLIB
-# Turn off creating shared libraries for any utility routines. If we *are*
-# building shared libaries, make sure that we create a static executable
-case "$ENABLE_SHLIB" in
- none) ;;
- gcc)
- LDFLAGS="$LDFLAGS -static"
- libtool)
-esac
-ENABLE_SHLIB=none
-AC_SUBST(ENABLE_SHLIB)
-dnl
-AC_C_CONST
-AC_C_VOLATILE
-AC_C_RESTRICT
-AC_C_INLINE
-dnl
-dnl AC_CHECK_FUNCS(strtol time gettimeofday)
-AC_CHECK_FUNCS(snprintf)
-if test "$ac_cv_func_snprintf" = "yes" ; then
- PAC_FUNC_NEEDS_DECL([#include <stdio.h>],snprintf)
-fi
-AC_CHECK_FUNCS(strdup)
-if test "$ac_cv_func_strdup" = "yes" ; then
- # Do we need to declare strdup?
- PAC_FUNC_NEEDS_DECL([#include <string.h>],strdup)
-fi
-if test "$enable_onsig" = "yes" ; then
- AC_CHECK_FUNCS(ptrace)
- # It isn't enough to find ptrace. We also need the ptrace
- # parameters, which some systems, such as IRIX, do not define.
- if test "$ac_cv_func_ptrace" = yes ; then
- AC_CACHE_CHECK([for ptrace named parameters],
-pac_cv_has_ptrace_parms,[
- AC_TRY_COMPILE([
-#include <sys/types.h>
-#include <sys/ptrace.h>],[int i = PTRACE_CONT;],pac_cv_has_ptrace_parms=yes,
-pac_cv_has_ptrace_parms=no)])
- if test "$pac_cv_has_ptrace_parms" = "yes" ; then
- AC_DEFINE(HAVE_PTRACE_CONT,,[Define if ptrace parameters available])
- fi
- fi
-fi
-# Check for the functions needed to create a new session.
-# Cygwin has setsid but not getsid
-AC_CHECK_FUNCS(setsid isatty getsid)
-if test "$enable_newsession" = "yes" ; then
- AC_DEFINE(USE_NEW_SESSION,1,[Define if mpiexec should create a new process group session])
-fi
-dnl
-dnl Check for special compile characteristics
-dnl
-dnl Is there libnsl needed for gethostbyname?
-dnl AC_SEARCH_LIBS(gethostbyname,nsl)
-AC_SEARCH_LIBS(socketpair,socket)
-dnl
-dnl Look for Standard headers
-AC_HEADER_STDC
-dnl Check for a specific header
-AC_CHECK_HEADERS(sys/types.h signal.h sys/ptrace.h)
-dnl
-dnl Check for functions. This invokes another test if the function is
-dnl found. The braces around the second test are essential.
-dnl AC_CHECK_FUNC(setpgrp,[AC_FUNC_SETPGRP])
-AC_CHECK_FUNCS(strsignal)
-dnl
-dnl Check for signal handlers
-AC_CHECK_FUNCS(sigaction signal sigset)
-if test "$ac_cv_func_sigaction" = "yes" ; then
- AC_MSG_CHECKING(for struct sigaction)
- AC_TRY_COMPILE([#include <signal.h>],[
-struct sigaction act; sigaddset( &act.sa_mask, SIGINT );],sigaction_ok="yes",sigaction_ok="no")
- AC_MSG_RESULT($sigaction_ok)
- if test "$sigaction_ok" = "no" ; then
- AC_MSG_CHECKING(for struct sigaction with _POSIX_SOURCE)
- AC_TRY_COMPILE([#define _POSIX_SOURCE
-#include <signal.h>],[
-struct sigaction act; sigaddset( &act.sa_mask, SIGINT );],sigaction_with_posix_ok="yes",sigaction_with_posix_ok="no")
- AC_MSG_RESULT($sigaction_with_posix_ok)
- if test "$sigaction_with_posix_ok" = "yes" ; then
- sigaction_ok=yes
- sigaction_needs_posix=yes
- fi
- fi
-fi
-dnl
-# Decide on the signal handler to use
-if test "$ac_cv_func_sigaction" = "yes" -a "$sigaction_ok" = "yes" ; then
- if test "$sigaction_needs_posix" = yes ; then
- AC_DEFINE(NEEDS_POSIX_FOR_SIGACTION,1,[Define if _POSIX_SOURCE needed to get sigaction])
- fi
- AC_DEFINE(USE_SIGACTION,1,[Define if sigaction should be used to set signals])
-elif test "$ac_cv_func_signal" = "yes" ; then
- AC_DEFINE(USE_SIGNAL,1,[Define if signal should be used to set signals])
-fi
-dnl
-dnl Setup other replaceable values
-MPILIBNAME=${MPILIBNAME:-"mpich"}
-dnl
-dnl
-dnl Configure the pm utilities for mpiexec2 (which will eventually replace
-dnl mpiexec)
-PAC_SUBDIR_CACHE
-dnl
-dnl You can't configure a directory that isn't a strict subdirectory
-dnl reliably. For example, configure will set the cache file incorrectly
-dnl unless you set it explicitly
-dnl if test "$cache_file" != "/dev/null" ; then
-dnl # convert the cachefile to an absolute path
-dnl cachedir=`echo $cache_file | sed -e 's%/[^/]*$%%'`
-dnl fname=`basename $cache_file`
-dnl if test -d $cachedir ; then
-dnl cachedir=`(cd $cachedir && pwd)`
-dnl else
-dnl cachedir=`pwd`
-dnl fi
-dnl if test -f "$cachedir/$fname" ; then
-dnl cache_file=$cachedir/$fname
-dnl fi
-dnl fi
-if test -z "$master_top_srcdir" ; then
- master_top_srcdir='${srcdir}/../../..'
-fi
-dnl See setup_pm. The pm/util directory must also be configured
-PAC_CONFIG_SUBDIR(../util,,AC_ERROR(pm/utils configure failed))
-AC_CHECK_HEADERS(string.h sys/time.h unistd.h stdlib.h sys/socket.h wait.h errno.h)
-AC_PATH_PROG(SSH,ssh)
-if test -z "$SSH" ; then
- AC_PATH_PROG(RSH,rsh)
- if test -n "$RSH" ; then
- remshell="$RSH"
- fi
-else
- remshell="$SSH"
-fi
-AC_SUBST(MPILIBNAME)
-AC_SUBST(CC)
-AC_SUBST(CFLAGS)
-AC_SUBST(CC_SHL)
-AC_SUBST(C_LINK_SHL)
-AC_SUBST(master_top_srcdir)
-dnl
-dnl Dependency handling
-AC_SUBST(MAKE_DEPEND_C)
-dnl
-AC_DEFINE_UNQUOTED(DEFAULT_MACHINES_PATH,"$eval_datadir:.",[Define the search path for machines files])
-AC_DEFINE_UNQUOTED(DEFAULT_REMOTE_SHELL,"$remshell",[Define the default remote shell program to use])
-dnl
-dnl Etags
-AC_SUBST(ETAGS)
-AC_SUBST(ETAGSADD)
-export ETAGS
-export ETAGSADD
-dnl
-dnl Other autoconf variables that may be imported from the calling environment
-AC_SUBST(DOCTEXT)
-PAC_UPDATE_BASE_CACHE
-dnl Generate the Makefiles from Makefile.in
-AC_OUTPUT(Makefile)
Deleted: mpich2/trunk/src/pm/remshell/mpich2prereq
--- mpich2/trunk/src/pm/remshell/mpich2prereq 2010-11-22 15:51:16 UTC (rev 7470)
+++ mpich2/trunk/src/pm/remshell/mpich2prereq 2010-11-22 15:51:53 UTC (rev 7471)
@@ -1,10 +0,0 @@
-#! /bin/sh
-# Check that we are using the simple PMI implementation
-# (Selecting multiple PM's may require incompatible PMI implementations
-# (e.g., remshell and SMPD).
-if [ -z "$PM_REQUIRES_PMI" ] ; then
- PM_REQUIRES_PMI=simple
-elif [ "$PM_REQUIRES_PMI" != "simple" ] ; then
- echo "remshell requires the simple PMI implementation; $PM_REQUIRES_PMI has already been selected"
- exit 1
-fi
Deleted: mpich2/trunk/src/pm/remshell/mpiexec.c
--- mpich2/trunk/src/pm/remshell/mpiexec.c 2010-11-22 15:51:16 UTC (rev 7470)
+++ mpich2/trunk/src/pm/remshell/mpiexec.c 2010-11-22 15:51:53 UTC (rev 7471)
@@ -1,451 +0,0 @@
-/* -*- Mode: C; c-basic-offset:4 ; -*- */
- * (C) 2004 by Argonne National Laboratory.
-/* OWNER=gropp */
-/* An example mpiexec program that uses a remote shell program to create
- new processes on the selected hosts.
- This code also shows how to use the pmutil routines (in ../util)
- to provide many of the services required by mpiexec
- Steps:
- 1. Read and process that command line. Build a ProcessList. (A ProcessList
- may have one entry for a request to create n separate processes)
- 2. Convert the ProcessList into a ProcessTable. In the forker mpiexec,
- this simply expands the requested number of processes into an
- array with one entry per process. These entries contain information
- on both the setup of the processes and the file descriptors used for
- stdin,out,err, and for the PMI calls.
- 3. (Optionally) allow the forked processes to use a host:port to
- contact this program, rather than just sharing a pipe. This allows the
- forker to start other programs, such as debuggers.
- 4. Establish a signal handler for SIGCHLD. This will allow us to
- get information about process termination; in particular, the exit
- status.
- 5. Start the programs.
- 6. Process input from the programs; send stdin given to this process
- to the selected processes (usually rank 0 or everyone). Handle all
- PMI commands, including spawn. Another "input" is the expiration of the
- specified timelimit for the run, if any.
- 7. Process rundown commands and handle any abnormal termination.
- 8. Wait for any processes to exit; gather the exit status and reason
- for exit (if abnormal, such as signaled with SEGV or BUS)
- 9. Release all resources and compute the exit status for this program
- (using one of several approaches, such as taking the maximum of the
- exit statuses).
- Special Case to support Singleton Init:
- To support a singleton init of a process that then wants to
- create processes with MPI_Comm_spawn(_multiple), a special form of
- mpiexec is supported:
- mpiexec -pmi_args <port> <interfacename> <securitykey> <pid>
- The singleton process (in a routine in simple_pmi.c) forks a process and
- execs mpiexe with these arguments, where port is the port to which
- mpiexec should connect, interfacename is the name of the network interface
- (BUG: may not be correctly set as mpd currently ignores it), securitykey
- is a place-holder for a key used by the singleton init process to verify
- that the process connecting on the port is the one that was intended, and
- pid is the pid of the singleton init process.
- FIXME: The above has not been implemented yet.
-#include "remshellconf.h"
-#include <stdio.h>
-#include <string.h>
-#ifdef HAVE_UNISTD_H
-#include <unistd.h>
-#endif
-#include <stdlib.h>
-#include "pmutil.h"
-#include "process.h"
-#include "cmnargs.h"
-#include "pmiserv.h"
-#include "ioloop.h"
-#include "labelout.h"
-#include "rm.h"
-#include "simple_pmiutil.h"
-#include "env.h" /* MPIE_Putenv */
-/* mpimem.h contains prototypes for MPIU_Strncpy etc. */
-/* We no longer can use these because they are MPI device specific */
-/* #include "mpimem.h" */
-typedef struct { PMISetup pmiinfo; IOLabelSetup labelinfo; } SetupInfo;
-/* Forward declarations */
-int mypreamble( void *, ProcessState* );
-int mypostfork( void *, void *, ProcessState* );
-int mypostamble( void *, void *, ProcessState* );
-int myspawn( ProcessWorld *, void * );
-static int AddEnvSetToCmdLine( const char *, const char *, const char ** );
-/* Set printFailure to 1 to get an explanation of the failure reason
- for each process when a process fails */
-static int printFailure = 0;
-#ifndef MAX_PORT_STRING
-#define MAX_PORT_STRING 1024
-#endif
-/* Note that envp is common but not standard */
-int main( int argc, char *argv[], char *envp[] )
- int rc;
- int erc = 0; /* Other (exceptional) return codes */
- int reason, signaled = 0;
- SetupInfo s;
- char portString[MAX_PORT_STRING];
- /* MPIE_ProcessInit initializes the global pUniv */
- MPIE_ProcessInit();
- /* Set a default for the universe size */
- pUniv.size = 64;
- /* Set defaults for any arguments that are options. Also check the
- environment for special options, such as debugging. Set
- some defaults in pUniv */
- MPIE_CheckEnv( &pUniv, 0, 0 );
- IOLabelCheckEnv( );
- /* Handle the command line arguments. Use the routine from util/cmnargs.c
- to fill in the universe */
- MPIE_Args( argc, argv, &pUniv, 0, 0 );
- /* If there were any soft arguments, we need to handle them now */
- rc = MPIE_InitWorldWithSoft( &pUniv.worlds[0], pUniv.size );
- if (!rc) {
- MPIU_Error_printf( "Unable to process soft arguments\n" );
- exit(1);
- if (pUniv.fromSingleton) {
- /* The MPI process is already running. We create a simple entry
- for a single process rather than creating the process */
- MPIE_SetupSingleton( &pUniv );
- rc = MPIE_ChooseHosts( &pUniv.worlds[0], MPIE_ReadMachines, 0 );
- if (rc) {
- MPIU_Error_printf( "Unable to assign hosts to processes\n" );
- exit(1);
- if (MPIE_Debug) MPIE_PrintProcessUniverse( stdout, &pUniv );
- DBG_PRINTF( ("timeout_seconds = %d\n", pUniv.timeout) );
- /* Get the common port for creating PMI connections to the created
- processes */
- rc = PMIServSetupPort( &pUniv, portString, sizeof(portString) );
- if (rc) {
- MPIU_Error_printf( "Unable to setup port for listener\n" );
- exit(1);
- s.pmiinfo.portName = portString;
-#ifdef USE_MPI_STAGE_EXECUTABLES
- /* Hook for later use in staging executables */
- if (?stageExes) {
- rc = MPIE_StageExecutables( &pUniv.worlds[0] );
- if (!rc) ...;
-#endif
- PMIServInit(myspawn,&s);
- s.pmiinfo.pWorld = &pUniv.worlds[0];
- PMISetupNewGroup( pUniv.worlds[0].nProcess, 0 );
- MPIE_ForwardCommonSignals();
- if (!pUniv.fromSingleton) {
- MPIE_ForkProcesses( &pUniv.worlds[0], envp, mypreamble, &s,
- mypostfork, 0, mypostamble, 0 );
- else {
- /* FIXME: The singleton code goes here */
- MPIU_Error_printf( "Singleton init not supported\n" );
- exit(1);
- reason = MPIE_IOLoop( pUniv.timeout );
- if (reason == IOLOOP_TIMEOUT) {
- /* Exited due to timeout. Generate an error message and
- terminate the children */
- if (pUniv.timeout > 60) {
- MPIU_Error_printf( "Timeout of %d minutes expired; job aborted\n",
- pUniv.timeout / 60 );
- else {
- MPIU_Error_printf( "Timeout of %d seconds expired; job aborted\n",
- pUniv.timeout );
- erc = 1;
- MPIE_KillUniverse( &pUniv );
- /* Wait for all processes to exit and gather information on them.
- We do this through the SIGCHLD handler. We also bound the length
- of time that we wait to 2 seconds.
- MPIE_WaitForProcesses( &pUniv, 2 );
- /* Compute the return code (max for now) */
- rc = MPIE_ProcessGetExitStatus( &signaled );
- /* Optionally provide detailed information about failed processes */
- if ( (rc && printFailure) || signaled)
- MPIE_PrintFailureReasons( stderr );
- /* If the processes exited normally (or were already gone) but we
- had an exceptional exit, such as a timeout, use the erc value */
- if (!rc && erc) rc = erc;
- return( rc );
-void mpiexec_usage( const char *msg )
- if (msg) {
- MPIU_Error_printf( msg );
- if (msg[strlen(msg)-1] != '\n') {
- MPIU_Error_printf( "\n" );
- MPIU_Usage_printf( "Usage: mpiexec %s\n", MPIE_ArgDescription() );
- exit( -1 );
-/* Redirect stdout and stderr to a handler */
-int mypreamble( void *data, ProcessState *pState )
- SetupInfo *s = (SetupInfo *)data;
- int rc;
- IOLabelSetupFDs( &s->labelinfo );
- rc = PMISetupSockets( 1, &s->pmiinfo );
- /* We must use communication over the socket, rather than the
- environment, to pass initialization data */
- pState->initWithEnv = 0;
- return rc;
-/* Close one side of each pipe pair and replace stdout/err with the pipes */
-int mypostfork( void *predata, void *data, ProcessState *pState )
- SetupInfo *s = (SetupInfo *)predata;
- int curarg=0;
- IOLabelSetupInClient( &s->labelinfo );
- PMISetupInClient( 1, &s->pmiinfo );
- /* Now, we *also* change the process state to insert the
- interposed remote shell routine. This is probably not
- where we want this in the final version (because MPIE_ExecProgram
- does a lot under the assumption that the started program will
- know what to do with new environment variables), but this
- will allow us to start. */
- ProcessApp *app = pState->app;
- const char **newargs = 0;
- char *pmiDebugStr = 0;
- int j;
- char rankStr[12];
- /* Insert into app->args */
- newargs = (const char **) MPIU_Malloc( (app->nArgs + 14 + 1) *
- sizeof(char *) );
- if (!pState->hostname) {
- MPIU_Error_printf( "No hostname avaliable for %s\n", app->exename );
- exit(1);
- snprintf( rankStr, sizeof(rankStr)-1, "%d", pState->id );
- rankStr[12-1] = 0;
- curarg = 0;
- newargs[curarg++] = MPIU_Strdup( "-Y" );
- newargs[curarg++] = pState->hostname;
- curarg += AddEnvSetToCmdLine( "PMI_PORT", s->pmiinfo.portName,
- newargs + curarg );
- curarg += AddEnvSetToCmdLine( "PMI_ID", rankStr, newargs + curarg );
- pmiDebugStr = getenv( "PMI_DEBUG" );
- if (pmiDebugStr) {
- /* Use this to help debug the connection process */
- curarg += AddEnvSetToCmdLine( "PMI_DEBUG", pmiDebugStr,
- newargs[curarg++] = app->exename;
- for (j=0; j<app->nArgs; j++) {
- newargs[j+curarg] = app->args[j];
- newargs[j+curarg] = 0;
- app->exename = MPIU_Strdup( "/usr/bin/ssh" );
- app->args = newargs;
- app->nArgs += curarg;
- if (MPIE_Debug) {
- printf( "cmd = %s\n", app->exename ); fflush(stdout);
- printf( "Number of args = %d\n", app->nArgs );
- printf( "argv[%d] = %s\n", j, app->args[j] ); fflush(stdout);
- return 0;
-/* Close one side of the pipe pair and register a handler for the I/O */
-int mypostamble( void *predata, void *data, ProcessState *pState )
- IOLabelSetupFinishInServer( &s->labelinfo, pState );
- PMISetupFinishInServer( 1, &s->pmiinfo, pState );
- return 0;
-int myspawn( ProcessWorld *pWorld, void *data )
- ProcessWorld *p, **pPtr;
- p = pUniv.worlds;
- pPtr = &(pUniv.worlds);
- while (p) {
- pPtr = &p->nextWorld;
- p = *pPtr;
- *pPtr = pWorld;
- /* Fork Processes may call a routine that is passed s but not pWorld;
- this makes sure that all routines can access the current world */
- s->pmiinfo.pWorld = pWorld;
- /* FIXME: This should be part of the PMI initialization in the clients */
- MPIE_Putenv( pWorld, "PMI_SPAWNED=1" );
- MPIE_ForkProcesses( pWorld, 0, mypreamble, s,
- return 0;
-/* Temp test for the replacement for the simple "spawn == fork" */
- * Approach:
- * Processes are created using a remote shell program. This requires
- * changing the command line from
- * a.out args ...
- * to
- * remshell-program remshell-args /bin/sh -c PMI_PORT=string &&
- * export PMI_PORT && PMI_ID=rank-in-world && export PMI_ID &&
- * a.out args
- * (the export PMI_PORT=string syntax is not valid in all versions of sh)
- * Using PMI_ID ensures that we correctly identify each process (this was
- * a major problem in the setup used by the p4 device in MPICH1).
- * Using environment variables instead of command line arguments keeps
- * the commaand line clean.
- * Two alternatives should be considered
- * 1) Use an intermediate manager. This would allow us to set up the
- * environment as well:
- * remshell-program remshell-args manager -port string
- * One possibilty for the manager is the mpd manager
- * 2) Use the secure server (even the same one as in MPICH1); then
- * there is no remote shell command.
- * We can handle the transformation of the command line by adding a
- * to the postfork routine; this is called after the fork but before the
- * exec, and it can change the command line by making a copy of the app
- * structure, changing the command line, and setting the pState structure
- * to point to this new app (after the fork, these changes are visable only
- * to the forked process).
- * Enhancements:
- * Allow the code to avoid the remote shell if the process is being created
- * on the local host.
- * Handle the user of -l username and -n options to remshell
- * (-n makes stdin /dev/null, necessary for backgrounding).
- * (-l username allows login to hosts where the user's username is
- * different)
- * Provide an option to add a backslash before any - to deal with the
- * serious bug in the GNU inetutils remote shell programs that process
- * *all* arguments on the remote shell command line, even those for the
- * *program*!
- * To best support the errcodes return from MPI_Comm_spawn,
- * we need a way to communicate the array of error codes back to the
- * spawn and spawn multiple commands. Query: how is that done in
- * PMI?
-static int AddEnvSetToCmdLine( const char *envName, const char *envValue,
- const char **args )
- int nArgs = 0;
- static int useCSHFormat = -1;
- /* Determine the Shell type the first time*/
- if (useCSHFormat == -1) {
- char *shell = getenv( "SHELL" ), *sname;
- if (shell) {
-/* printf( "Shell is %s\n", shell ); */
- sname = strrchr( shell, '/' );
- if (!sname) sname = shell;
- else sname++;
-/* printf( "Sname is %s\n", sname ); */
- if (strcmp( sname, "bash" ) == 0 || strcmp( sname, "sh" ) ||
- strcmp( sname, "ash" ) == 0) useCSHFormat = 0;
- else
- useCSHFormat = 1;
- else {
- /* Default is to assume csh (setenv) format */
- useCSHFormat = 1;
- if (useCSHFormat) {
- args[nArgs++] = MPIU_Strdup( "setenv" );
- args[nArgs++] = MPIU_Strdup( envName );
- args[nArgs++] = MPIU_Strdup( envValue );
- args[nArgs++] = MPIU_Strdup( ";" );
- else {
- char tmpBuf[1024];
- args[nArgs++] = MPIU_Strdup( "export" );
- MPIU_Strncpy( tmpBuf, envName, sizeof(tmpBuf) );
- MPIU_Strnapp( tmpBuf, "=", sizeof(tmpBuf) );
- MPIU_Strnapp( tmpBuf, envValue, sizeof(tmpBuf) );
- args[nArgs++] = MPIU_Strdup( tmpBuf );
- return nArgs;
More information about the mpich2-commits
