[mpich2-commits] r7435 - mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config
balaji at mcs.anl.gov
Wed Nov 10 19:37:08 CST 2010
Author: balaji
Date: 2010-11-10 19:37:08 -0600 (Wed, 10 Nov 2010)
New Revision: 7435
Modified:
mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/hwloc.m4
mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/hwloc_internal.m4
Log:
Do not automatically enable debugging or picky compiler options in
hwloc unless the user asked for it.
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/hwloc.m4
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/hwloc.m4 2010-11-10 23:06:48 UTC (rev 7434)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/hwloc.m4 2010-11-11 01:37:08 UTC (rev 7435)
@@ -93,12 +93,6 @@
AS_IF([test "$hwloc_debug" = "" -a "$enable_debug" = "yes"],
[hwloc_debug=1
hwloc_debug_msg="enabled"])
- AS_IF([test "$hwloc_debug" = "" -a "$enable_debug" = "" -a -d .svn],
- [hwloc_debug=1
- hwloc_debug_msg="enabled (SVN checkout default)"])
- AS_IF([test "$hwloc_debug" = "" -a "$enable_debug" = "" -a -d .hg],
- [hwloc_debug=1
- hwloc_debug_msg="enabled (HG clone default)"])
AS_IF([test "$hwloc_debug" = ""],
[hwloc_debug=0
hwloc_debug_msg="disabled"])
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/hwloc_internal.m4
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/hwloc_internal.m4 2010-11-10 23:06:48 UTC (rev 7434)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/hwloc/config/hwloc_internal.m4 2010-11-11 01:37:08 UTC (rev 7435)
@@ -135,9 +135,6 @@
# specifically disabled by the user.
AC_MSG_CHECKING([whether to enable "picky" compiler mode])
hwloc_want_picky=0
- AS_IF([test "$GCC" = "yes"],
- [AS_IF([test -d "$srcdir/.svn" -o -d "$srcdir/.hg"],
- [hwloc_want_picky=1])])
if test "$enable_picky" = "yes"; then
if test "$GCC" = "yes"; then
AC_MSG_RESULT([yes])
More information about the mpich2-commits
