[mpich2-commits] r7425 - in mpich2/trunk/src/mpid/ch3: include src
gropp at mcs.anl.gov gropp at mcs.anl.gov
Mon Nov 8 09:06:34 CST 2010
Author: gropp
Date: 2010-11-08 09:06:34 -0600 (Mon, 08 Nov 2010)
New Revision: 7425
Modified:
   mpich2/trunk/src/mpid/ch3/include/mpidrma.h
   mpich2/trunk/src/mpid/ch3/src/ch3u_rma_sync.c
Log:
Fixed error in computing previous pointer location in RMA list and adding missing checks on error returns
Modified: mpich2/trunk/src/mpid/ch3/include/mpidrma.h
--- mpich2/trunk/src/mpid/ch3/include/mpidrma.h	2010-11-08 12:18:39 UTC (rev 7424)
+++ mpich2/trunk/src/mpid/ch3/include/mpidrma.h	2010-11-08 15:06:34 UTC (rev 7425)
@@ -68,4 +68,8 @@
     MPIDI_VC_t * vc;
     struct MPIDI_PT_single_op *pt_single_op;  /* to store info for lock-put-unlock optimization */
 } MPIDI_Win_lock_queue;
+/* Routine use to tune RMA optimizations */
+void MPIDI_CH3_RMA_SetAccImmed( int flag );
 #endif
Modified: mpich2/trunk/src/mpid/ch3/src/ch3u_rma_sync.c
--- mpich2/trunk/src/mpid/ch3/src/ch3u_rma_sync.c	2010-11-08 12:18:39 UTC (rev 7424)
+++ mpich2/trunk/src/mpid/ch3/src/ch3u_rma_sync.c	2010-11-08 15:06:34 UTC (rev 7425)
@@ -228,7 +228,7 @@
 	MPIU_INSTR_DURATION_INCR(winfence_issue,0,total_op_count);
 	MPIU_INSTR_DURATION_MAX(winfence_issue,1,total_op_count);
 	i = 0;
-	curr_ptr = win_ptr->rma_ops_list_head;
+	curr_ptr    = win_ptr->rma_ops_list_head;
 	prevNextPtr = &win_ptr->rma_ops_list_head;
 	while (curr_ptr != NULL)
@@ -259,6 +259,7 @@
 		mpi_errno = MPIDI_CH3I_Send_contig_acc_msg(curr_ptr, win_ptr,
 				   source_win_handle, target_win_handle,
 				   &curr_ptr->request );
+		if (mpi_errno) { MPIU_ERR_POP(mpi_errno); }
 		break;
 	    case (MPIDI_RMA_GET):
 		mpi_errno = MPIDI_CH3I_Recv_rma_msg(curr_ptr, win_ptr,
@@ -284,8 +285,8 @@
 		curr_ptr     = tmpptr;
 	    else  {
+		prevNextPtr = &curr_ptr->next;
 		curr_ptr    = curr_ptr->next;
-		prevNextPtr = &curr_ptr->next;
 		/* FIXME: We could at least occassionally try to wait
 		   on completion of the pending send requests rather than
 		   focus on filling the queues.  */
@@ -1322,7 +1323,7 @@
     i = 0;
 	/* The completion counter at the target is decremented only on
@@ -1352,6 +1353,7 @@
 	    break;
@@ -1377,8 +1379,8 @@
 	    curr_ptr     = tmpptr;
 	else  {
     MPIU_INSTR_DURATION_END(wincomplete_issue);
@@ -1427,7 +1429,9 @@
 		/* Its hard to use the automatic allocator here, as those
 		   macros are optimized for a known maximum number of items. */
 		MPIDI_RMA_ops *new_ptr;
+		MPIU_INSTR_DURATION_START(rmaqueue_alloc);
 		new_ptr = (MPIDI_RMA_ops *)MPIU_Malloc(sizeof(MPIDI_RMA_ops) );
+		MPIU_INSTR_DURATION_END(rmaqueue_alloc);
 		/* --BEGIN ERROR HANDLING-- */
 		if (!new_ptr) {
 		    MPIU_CHKMEM_SETERR(mpi_errno,sizeof(MPIDI_RMA_ops),
@@ -1986,6 +1990,7 @@
 	    break;
@@ -2010,8 +2015,8 @@
 	    curr_ptr     = tmpptr;
 	else  {
     MPIU_INSTR_DURATION_END(winunlock_issue);
More information about the mpich2-commits mailing list
