[mpich2-commits] r7423 - mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad
mercierg at mcs.anl.gov
Mon Nov 8 04:27:52 CST 2010
Author: mercierg
Date: 2010-11-08 04:27:52 -0600 (Mon, 08 Nov 2010)
New Revision: 7423
Modified:
mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h
mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_init.c
Log:
Hostname is no longer needed for Newmad init.
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h 2010-11-06 15:34:56 UTC (rev 7422)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_impl.h 2010-11-08 10:27:52 UTC (rev 7423)
@@ -65,23 +65,17 @@
/* Connection management*/
int MPID_nem_newmad_send_conn_info (MPIDI_VC_t *vc);
-#define MPID_NEM_NMAD_MAX_SIZE (MPID_NEM_MAX_NETMOD_STRING_LEN)
+#define MPID_NEM_NMAD_MAX_SIZE 64
typedef nm_gate_t mpid_nem_newmad_p_gate_t;
-typedef struct MPID_nem_newmad_vc_area_internal
- char hostname[MPID_NEM_NMAD_MAX_SIZE];
- char url[MPID_NEM_NMAD_MAX_SIZE];
- mpid_nem_newmad_p_gate_t p_gate;
-} MPID_nem_newmad_vc_area_internal_t;
/* The current max size for the whole structure is 128 bytes */
typedef struct
- MPID_nem_newmad_vc_area_internal_t *area;
+ char url[MPID_NEM_NMAD_MAX_SIZE];
+ mpid_nem_newmad_p_gate_t p_gate;
} MPID_nem_newmad_vc_area;
/* accessor macro to private fields in VC */
-#define VC_FIELD(vcp, field) (((MPID_nem_newmad_vc_area *)((MPIDI_CH3I_VC *)((vcp)->channel_private))->netmod_area.padding)->area->field)
+#define VC_FIELD(vcp, field) (((MPID_nem_newmad_vc_area *)((MPIDI_CH3I_VC *)((vcp)->channel_private))->netmod_area.padding)->field)
/* The req provides a generic buffer in which network modules can store
private fields This removes all dependencies from the req structure
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_init.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_init.c 2010-11-06 15:34:56 UTC (rev 7422)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/netmod/newmad/newmad_init.c 2010-11-08 10:27:52 UTC (rev 7423)
@@ -6,9 +6,6 @@
#include "newmad_impl.h"
-#define MPIDI_CH3I_HOSTNAME_KEY "hostname_id"
-#define MPIDI_CH3I_URL_KEY "url_id"
MPID_nem_netmod_funcs_t MPIDI_nem_newmad_funcs = {
MPID_nem_newmad_init,
MPID_nem_newmad_finalize,
@@ -44,6 +41,7 @@
MPID_nem_newmad_iprobe /* iprobe */
+#define MPIDI_CH3I_URL_KEY "url_id"
static int mpid_nem_newmad_myrank;
static const char *label="mpich2";
@@ -112,7 +110,7 @@
int mpi_errno = MPI_SUCCESS ;
int index;
fprintf(stdout,"Size of MPID_nem_mad_module_vc_area_internal_t : %i | size of nm_sr_request_t :%i | Size of req_area : %i\n",
sizeof(MPID_nem_newmad_vc_area_internal_t),sizeof(nm_sr_request_t), sizeof(MPID_nem_newmad_req_area));
@@ -123,17 +121,16 @@
MPIU_Assert( sizeof(MPID_nem_newmad_req_area) <= MPID_NEM_REQ_NETMOD_AREA_LEN);
- if (sizeof(MPID_nem_newmad_vc_area_internal_t) > MPID_NEM_VC_NETMOD_AREA_LEN)
+ if (sizeof(MPID_nem_newmad_vc_area) > MPID_NEM_VC_NETMOD_AREA_LEN)
fprintf(stdout,"===========================================================\n");
fprintf(stdout,"=== Error : Newmad data structure size is too long ===\n");
fprintf(stdout,"=== VC netmod area is %4i | Nmad struct size is %4i ===\n",
MPID_NEM_VC_NETMOD_AREA_LEN, sizeof(MPID_nem_newmad_vc_area_internal_t));
- MPIU_Abort();
+ exit(0);
if (sizeof(MPID_nem_newmad_req_area) > MPID_NEM_REQ_NETMOD_AREA_LEN)
@@ -142,7 +139,7 @@
fprintf(stdout,"=== Req netmod area is %4i | Nmad struct size is %4i ===\n",
MPID_NEM_REQ_NETMOD_AREA_LEN, sizeof(MPID_nem_newmad_req_area));
- /* MPIU_Abort(); */
+ exit(0);
mpid_nem_newmad_myrank = pg_rank;
@@ -172,16 +169,7 @@
int mpi_errno = MPI_SUCCESS;
int str_errno = MPIU_STR_SUCCESS;
- char name[MPID_NEM_NMAD_MAX_SIZE];
- gethostname(name,MPID_NEM_NMAD_MAX_SIZE);
- str_errno = MPIU_Str_add_binary_arg (bc_val_p, val_max_sz_p, MPIDI_CH3I_HOSTNAME_KEY, name, strlen(name));
- if (str_errno) {
- MPIU_ERR_CHKANDJUMP(str_errno == MPIU_STR_NOMEM, mpi_errno, MPI_ERR_OTHER, "**buscard_len");
- MPIU_ERR_SETANDJUMP(mpi_errno, MPI_ERR_OTHER, "**buscard");
str_errno = MPIU_Str_add_binary_arg (bc_val_p, val_max_sz_p, MPIDI_CH3I_URL_KEY, local_session_url, strlen(local_session_url));
if (str_errno) {
@@ -199,20 +187,12 @@
#undef FCNAME
#define FCNAME MPIDI_QUOTE(FUNCNAME)
int
-MPID_nem_newmad_get_from_bc (const char *business_card, char *hostname, char *url)
+MPID_nem_newmad_get_from_bc (const char *business_card, char *url)
int len;
- str_errno = MPIU_Str_get_binary_arg (business_card, MPIDI_CH3I_HOSTNAME_KEY, hostname,
- MPID_NEM_NMAD_MAX_SIZE, &len);
- if (str_errno != MPIU_STR_SUCCESS)
- /* FIXME: create a real error string for this */
- MPIU_ERR_CHKANDJUMP(str_errno, mpi_errno, MPI_ERR_OTHER, "**argstr_hostd");
str_errno = MPIU_Str_get_binary_arg (business_card, MPIDI_CH3I_URL_KEY, url,
@@ -263,15 +243,10 @@
mpi_errno = vc->pg->getConnInfo(vc->pg_rank, business_card,val_max_sz,vc->pg);
if (mpi_errno) MPIU_ERR_POP(mpi_errno);
- (((MPID_nem_newmad_vc_area *)((MPIDI_CH3I_VC *)(vc)->channel_private)->netmod_area.padding)->area) =
- (MPID_nem_newmad_vc_area_internal_t *)MPIU_Malloc(sizeof(MPID_nem_newmad_vc_area_internal_t));
- MPIU_Assert( (((MPID_nem_newmad_vc_area *)((MPIDI_CH3I_VC *)(vc)->channel_private)->netmod_area.padding)->area) != NULL);
/* Very important */
- memset(VC_FIELD(vc, hostname),0,MPID_NEM_NMAD_MAX_SIZE);
memset(VC_FIELD(vc, url),0,MPID_NEM_NMAD_MAX_SIZE);
- mpi_errno = MPID_nem_newmad_get_from_bc (business_card, VC_FIELD(vc, hostname), VC_FIELD(vc, url));
+ mpi_errno = MPID_nem_newmad_get_from_bc (business_card, VC_FIELD(vc, url));
if (mpi_errno) MPIU_ERR_POP (mpi_errno);
MPIU_Free(business_card);
@@ -280,7 +255,6 @@
if (ret != NM_ESUCCESS) fprintf(stdout,"nm_session_connect returned ret = %d\n", ret);
nm_gate_ref_set(VC_FIELD(vc, p_gate),(void*)vc);
MPIDI_CHANGE_VC_STATE(vc, ACTIVE);
vc->eager_max_msg_sz = 32768;
@@ -305,8 +279,6 @@
- MPIU_Free((((MPID_nem_newmad_vc_area *)((MPIDI_CH3I_VC *)(vc)->channel_private)->netmod_area.padding)->area));
fn_exit:
return mpi_errno;
fn_fail: ATTRIBUTE((unused))
More information about the mpich2-commits
