[mpich2-commits] r7412 - mpich2/trunk/confdb
gropp at mcs.anl.gov
Thu Nov 4 08:13:06 CDT 2010
Author: gropp
Date: 2010-11-04 08:13:05 -0500 (Thu, 04 Nov 2010)
New Revision: 7412
Modified:
mpich2/trunk/confdb/aclocal_mpi.m4
Log:
Update --with-mpi for IBM MPI+Fortran compiler mpfort
Modified: mpich2/trunk/confdb/aclocal_mpi.m4
--- mpich2/trunk/confdb/aclocal_mpi.m4 2010-11-03 18:35:55 UTC (rev 7411)
+++ mpich2/trunk/confdb/aclocal_mpi.m4 2010-11-04 13:13:05 UTC (rev 7412)
@@ -301,22 +301,22 @@
ibmmpi)
AC_CHECK_PROGS(MPCC,mpcc)
- AC_CHECK_PROGS(MPXLF,mpxlf)
+ AC_CHECK_PROGS(MPXLF,mpxlf mpfort)
if test -z "$MPCC" -o -z "$MPXLF" ; then
- AC_MSG_ERROR([Could not find IBM MPI compilation scripts. Either mpcc or mpxlf is missing])
+ AC_MSG_ERROR([Could not find IBM MPI compilation scripts. Either mpcc or mpxlf/mpfort is missing])
fi
if test -z "$TESTCC" ; then TESTCC=${CC-xlC} ; fi
if test -z "$TESTF77" ; then TESTF77=${F77-xlf}; fi
- CC=mpcc; F77=mpxlf
+ CC=mpcc; F77=$MPXLF
# There is no mpxlf90, but the options langlvl and free can
# select the Fortran 90 version of xlf
if test "$enable_f90" != no ; then
- AC_CHECK_PROGS(MPIXLF90,mpxlf90)
+ AC_CHECK_PROGS(MPIXLF90,mpxlf90 mpfort)
if test -z "$TESTFC" ; then TESTFC=${FC-xlf90}; fi
if test "X$MPIXLF90" != "X" ; then
- FC="mpxlf90"
+ FC="$MPIXLF90"
else
- FC="mpxlf -qlanglvl=90ext -qfree=f90"
+ FC="$MPXLF -qlanglvl=90ext -qfree=f90"
fi
fi
MPILIBNAME=""
More information about the mpich2-commits
