[mpich2-commits] r6752 - mpich2/trunk/src/include
goodell at mcs.anl.gov
Thu May 27 12:55:55 CDT 2010
Author: goodell
Date: 2010-05-27 12:55:55 -0500 (Thu, 27 May 2010)
New Revision: 6752
Modified:
mpich2/trunk/src/include/mpihandlemem.h
Log:
Make --enable-refcount=none never use a lock.
Adapted from r5920 on the bg-threads-1.1 branch.
No reviewer.
Modified: mpich2/trunk/src/include/mpihandlemem.h
--- mpich2/trunk/src/include/mpihandlemem.h 2010-05-27 04:51:46 UTC (rev 6751)
+++ mpich2/trunk/src/include/mpihandlemem.h 2010-05-27 17:55:55 UTC (rev 6752)
@@ -205,14 +205,37 @@
--enable-g=log is selected. MPIU_HANDLE_CHECK_REFCOUNT is
defined above, and adds an additional sanity check for the refcounts
-#if MPIU_THREAD_REFCOUNT == MPIU_REFCOUNT_NONE || \
- MPIU_THREAD_REFCOUNT == MPIU_REFCOUNT_LOCK
+#if MPIU_THREAD_REFCOUNT == MPIU_REFCOUNT_NONE
typedef int MPIU_Handle_ref_count;
+#define MPIU_HANDLE_REF_COUNT_INITIALIZER(val_) (val_)
+#define MPIU_Object_set_ref(objptr_,val) \
+ do { \
+ (objptr_)->ref_count = val; \
+ MPIU_HANDLE_LOG_REFCOUNT_CHANGE(objptr_, "set"); \
+ } while (0)
+/* must be used with care, since there is no synchronization for this read */
+#define MPIU_Object_get_ref(objptr_) \
+ ((objptr_)->ref_count)
+#define MPIU_Object_add_ref_always(objptr_) \
+ do { \
+ (objptr_)->ref_count++; \
+ MPIU_HANDLE_LOG_REFCOUNT_CHANGE(objptr_, "incr"); \
+ MPIU_HANDLE_CHECK_REFCOUNT(objptr_,"incr"); \
+ } while (0)
+#define MPIU_Object_release_ref_always(objptr_,inuse_ptr) \
+ do { \
+ *(inuse_ptr) = --((objptr_)->ref_count); \
+ MPIU_HANDLE_LOG_REFCOUNT_CHANGE(objptr_, "decr"); \
+ MPIU_HANDLE_CHECK_REFCOUNT(objptr_,"decr"); \
+ } while (0)
#elif MPIU_THREAD_REFCOUNT == MPIU_REFCOUNT_LOCK
typedef volatile int MPIU_Handle_ref_count;
-#endif
@@ -245,6 +268,7 @@
} while (0)
#elif MPIU_THREAD_REFCOUNT == MPIU_REFCOUNT_LOCKFREE
#include "opa_primitives.h"
typedef OPA_int_t MPIU_Handle_ref_count;
#define MPIU_HANDLE_REF_COUNT_INITIALIZER(val_) OPA_INT_T_INITIALIZER(val_)
More information about the mpich2-commits
