[mpich2-commits] r6743 - in mpich2/trunk/src: include mpi/coll
thakur at mcs.anl.gov
Tue May 25 14:41:49 CDT 2010
Author: thakur
Date: 2010-05-25 14:41:49 -0500 (Tue, 25 May 2010)
New Revision: 6743
Modified:
mpich2/trunk/src/include/mpiimpl.h
mpich2/trunk/src/mpi/coll/red_scat_block.c
Log:
updated Reduce_scatter_block to use optimized Reduce_scatter algorithms
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h 2010-05-25 19:39:49 UTC (rev 6742)
+++ mpich2/trunk/src/include/mpiimpl.h 2010-05-25 19:41:49 UTC (rev 6743)
@@ -1730,6 +1730,8 @@
MPID_Comm *);
int (*Reduce_scatter) (void*, void*, int *, MPI_Datatype, MPI_Op,
MPID_Comm *);
+ int (*Reduce_scatter_block) (void*, void*, int, MPI_Datatype, MPI_Op,
+ MPID_Comm *);
int (*Scan) (void*, void*, int, MPI_Datatype, MPI_Op, MPID_Comm * );
int (*Exscan) (void*, void*, int, MPI_Datatype, MPI_Op, MPID_Comm * );
@@ -3198,6 +3200,7 @@
#define MPIR_ALLTOALLW_TAG 25
#define MPIR_TOPO_A_TAG 26
#define MPIR_TOPO_B_TAG 27
+#define MPIR_REDUCE_SCATTER_BLOCK_TAG 28
/* These functions are used in the implementation of collective
operations. They are wrappers around MPID send/recv functions. They do
Modified: mpich2/trunk/src/mpi/coll/red_scat_block.c
--- mpich2/trunk/src/mpi/coll/red_scat_block.c 2010-05-25 19:39:49 UTC (rev 6742)
+++ mpich2/trunk/src/mpi/coll/red_scat_block.c 2010-05-25 19:41:49 UTC (rev 6743)
@@ -1,10 +1,16 @@
-/* -*- Mode: C; c-basic-offset:4 ; indent-tabs-mode:nil ; -*- */
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
- * (C) 2009 by Argonne National Laboratory.
+ * (C) 2010 by Argonne National Laboratory.
* See COPYRIGHT in top-level directory.
+/* This implementation of MPI_Reduce_scatter_block was obtained by taking
+ the implementation of MPI_Reduce_scatter from red_scat.c and replacing
+ recvcnts[i] with recvcount everywhere. */
#include "mpiimpl.h"
/* -- Begin Profiling Symbol Block for routine MPI_Reduce_scatter_block */
@@ -22,26 +28,1087 @@
#ifndef MPICH_MPI_FROM_PMPI
#undef MPI_Reduce_scatter_block
#define MPI_Reduce_scatter_block PMPI_Reduce_scatter_block
-/* any utility functions should go here, usually prefixed with PMPI_LOCAL to
- * correctly handle weak symbols and the profiling interface */
+/* Implements the "mirror permutation" of "bits" bits of an integer "x".
+ positions 76543210, bits==3 yields 76543012.
+ This function could/should be moved to a common utility location for use in
+ other collectives as well. */
+ATTRIBUTE((const)) /* tells the compiler that this func only depends on its args
+ and may be optimized much more aggressively, similar to "pure" */
+static inline int mirror_permutation(unsigned int x, int bits)
+ /* a mask for the high order bits that should be copied as-is */
+ int high_mask = ~((0x1 << bits) - 1);
+ int retval = x & high_mask;
+ int i;
+ for (i = 0; i < bits; ++i) {
+ unsigned int bitval = (x & (0x1 << i)) >> i; /* 0x1 or 0x0 */
+ retval |= bitval << ((bits - i) - 1);
+ return retval;
+/* FIXME should we be checking the op_errno here? */
+#ifdef HAVE_CXX_BINDING
+/* NOTE: assumes 'uop' is the operator function pointer and
+ that 'is_cxx_uop' is is a boolean indicating the obvious */
+#define call_uop(in_, inout_, count_, datatype_) \
+do { \
+ if (is_cxx_uop) { \
+ (*MPIR_Process.cxx_call_op_fn)((in_), (inout_), (count_), (datatype_), uop); \
+ else { \
+ (*uop)((in_), (inout_), &(count_), &(datatype_)); \
+} while (0)
+#else
#endif
+/* Implements the reduce-scatter butterfly algorithm described in J. L. Traff's
+ * "An Improved Algorithm for (Non-commutative) Reduce-Scatter with an Application"
+ * from EuroPVM/MPI 2005. This function currently only implements support for
+ * the power-of-2 case. */
#undef FUNCNAME
+#define FUNCNAME MPIR_Reduce_scatter_block_noncomm
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+static int MPIR_Reduce_scatter_block_noncomm (
+ void *sendbuf,
+ void *recvbuf,
+ int recvcount,
+ MPI_Datatype datatype,
+ MPI_Op op,
+ MPID_Comm *comm_ptr )
+ int mpi_errno = MPI_SUCCESS;
+ int comm_size = comm_ptr->local_size;
+ int rank = comm_ptr->rank;
+ int pof2;
+ int log2_comm_size;
+ int i, k;
+ int recv_offset, send_offset;
+ int block_size, total_count, size;
+ MPI_Aint extent, true_extent, true_lb;
+ int is_commutative;
+ int buf0_was_inout;
+ void *tmp_buf0;
+ void *tmp_buf1;
+ void *result_ptr;
+ MPI_Comm comm = comm_ptr->handle;
+ MPI_User_function *uop;
+ MPID_Op *op_ptr;
+ int is_cxx_uop = 0;
+#endif
+ MPIU_CHKLMEM_DECL(3);
+ MPID_Datatype_get_extent_macro(datatype, extent);
+ /* assumes nesting is handled by the caller right now, may not be true in the future */
+ mpi_errno = NMPI_Type_get_true_extent(datatype, &true_lb, &true_extent);
+ if (HANDLE_GET_KIND(op) == HANDLE_KIND_BUILTIN) {
+ is_commutative = 1;
+ /* get the function by indexing into the op table */
+ uop = MPIR_Op_table[op%16 - 1];
+ else {
+ MPID_Op_get_ptr(op, op_ptr);
+ if (op_ptr->kind == MPID_OP_USER_NONCOMMUTE)
+ is_commutative = 0;
+ else
+ if (op_ptr->language == MPID_LANG_CXX) {
+ uop = (MPI_User_function *) op_ptr->function.c_function;
+ is_cxx_uop = 1;
+ else
+#endif
+ if ((op_ptr->language == MPID_LANG_C))
+ else
+ uop = (MPI_User_function *) op_ptr->function.f77_function;
+ pof2 = 1;
+ log2_comm_size = 0;
+ while (pof2 < comm_size) {
+ pof2 <<= 1;
+ ++log2_comm_size;
+ /* begin error checking */
+ MPIU_Assert(pof2 == comm_size); /* FIXME this version only works for power of 2 procs */
+ /* end error checking */
+ /* size of a block (count of datatype per block, NOT bytes per block) */
+ block_size = recvcount;
+ total_count = block_size * comm_size;
+ MPIU_CHKLMEM_MALLOC(tmp_buf0, void *, true_extent * total_count, mpi_errno, "tmp_buf0");
+ MPIU_CHKLMEM_MALLOC(tmp_buf1, void *, true_extent * total_count, mpi_errno, "tmp_buf1");
+ /* adjust for potential negative lower bound in datatype */
+ tmp_buf0 = (void *)((char*)tmp_buf0 - true_lb);
+ tmp_buf1 = (void *)((char*)tmp_buf1 - true_lb);
+ /* Copy our send data to tmp_buf0. We do this one block at a time and
+ permute the blocks as we go according to the mirror permutation. */
+ for (i = 0; i < comm_size; ++i) {
+ mpi_errno = MPIR_Localcopy((char *)(sendbuf == MPI_IN_PLACE ? recvbuf : sendbuf) + (i * true_extent * block_size), block_size, datatype,
+ (char *)tmp_buf0 + (mirror_permutation(i, log2_comm_size) * true_extent * block_size), block_size, datatype);
+ if (mpi_errno) MPIU_ERR_POP(mpi_errno);
+ buf0_was_inout = 1;
+ send_offset = 0;
+ recv_offset = 0;
+ size = total_count;
+ for (k = 0; k < log2_comm_size; ++k) {
+ /* use a double-buffering scheme to avoid local copies */
+ char *incoming_data = (buf0_was_inout ? tmp_buf1 : tmp_buf0);
+ char *outgoing_data = (buf0_was_inout ? tmp_buf0 : tmp_buf1);
+ int peer = rank ^ (0x1 << k);
+ size /= 2;
+ if (rank > peer) {
+ /* we have the higher rank: send top half, recv bottom half */
+ recv_offset += size;
+ else {
+ /* we have the lower rank: recv top half, send bottom half */
+ send_offset += size;
+ mpi_errno = MPIC_Sendrecv(outgoing_data + send_offset*true_extent,
+ size, datatype, peer, MPIR_REDUCE_SCATTER_BLOCK_TAG,
+ incoming_data + recv_offset*true_extent,
+ comm, MPI_STATUS_IGNORE);
+ /* always perform the reduction at recv_offset, the data at send_offset
+ is now our peer's responsibility */
+ /* higher ranked value so need to call op(received_data, my_data) */
+ call_uop(incoming_data + recv_offset*true_extent,
+ outgoing_data + recv_offset*true_extent,
+ size, datatype);
+ buf0_was_inout = buf0_was_inout;
+ else {
+ /* lower ranked value so need to call op(my_data, received_data) */
+ call_uop(outgoing_data + recv_offset*true_extent,
+ size, datatype);
+ buf0_was_inout = !buf0_was_inout;
+ /* the next round of send/recv needs to happen within the block (of size
+ "size") that we just received and reduced */
+ send_offset = recv_offset;
+ MPIU_Assert(size == recvcount);
+ /* copy the reduced data to the recvbuf */
+ result_ptr = (char *)(buf0_was_inout ? tmp_buf0 : tmp_buf1) + recv_offset * true_extent;
+ mpi_errno = MPIR_Localcopy(result_ptr, size, datatype,
+ recvbuf, size, datatype);
+fn_exit:
+ MPIU_CHKLMEM_FREEALL();
+ return mpi_errno;
+fn_fail:
+ goto fn_exit;
+/* This is the default implementation of reduce_scatter. The algorithm is:
+ Algorithm: MPI_Reduce_scatter
+ If the operation is commutative, for short and medium-size
+ messages, we use a recursive-halving
+ algorithm in which the first p/2 processes send the second n/2 data
+ to their counterparts in the other half and receive the first n/2
+ data from them. This procedure continues recursively, halving the
+ data communicated at each step, for a total of lgp steps. If the
+ number of processes is not a power-of-two, we convert it to the
+ nearest lower power-of-two by having the first few even-numbered
+ processes send their data to the neighboring odd-numbered process
+ at (rank+1). Those odd-numbered processes compute the result for
+ their left neighbor as well in the recursive halving algorithm, and
+ then at the end send the result back to the processes that didn't
+ participate.
+ Therefore, if p is a power-of-two,
+ Cost = lgp.alpha + n.((p-1)/p).beta + n.((p-1)/p).gamma
+ If p is not a power-of-two,
+ Cost = (floor(lgp)+2).alpha + n.(1+(p-1+n)/p).beta + n.(1+(p-1)/p).gamma
+ The above cost in the non power-of-two case is approximate because
+ there is some imbalance in the amount of work each process does
+ because some processes do the work of their neighbors as well.
+ For commutative operations and very long messages we use
+ we use a pairwise exchange algorithm similar to
+ the one used in MPI_Alltoall. At step i, each process sends n/p
+ amount of data to (rank+i) and receives n/p amount of data from
+ (rank-i).
+ Cost = (p-1).alpha + n.((p-1)/p).beta + n.((p-1)/p).gamma
+ If the operation is not commutative, we do the following:
+ We use a recursive doubling algorithm, which
+ takes lgp steps. At step 1, processes exchange (n-n/p) amount of
+ data; at step 2, (n-2n/p) amount of data; at step 3, (n-4n/p)
+ amount of data, and so forth.
+ Cost = lgp.alpha + n.(lgp-(p-1)/p).beta + n.(lgp-(p-1)/p).gamma
+ Possible improvements:
+ End Algorithm: MPI_Reduce_scatter
+#undef FUNCNAME
+#undef FCNAME
+/* begin:nested */
+/* not declared static because a machine-specific function may call this one in some cases */
+int MPIR_Reduce_scatter_block (
+ void *sendbuf,
+ void *recvbuf,
+ int recvcount,
+ MPI_Op op,
+ int rank, comm_size, i;
+ int *disps;
+ void *tmp_recvbuf, *tmp_results;
+ int type_size, dis[2], blklens[2], total_count, nbytes, src, dst;
+ int mask, dst_tree_root, my_tree_root, j, k;
+ int *newcnts, *newdisps, rem, newdst, send_idx, recv_idx,
+ last_idx, send_cnt, recv_cnt;
+ int pof2, old_i, newrank, received;
+ MPI_Datatype sendtype, recvtype;
+ int nprocs_completed, tmp_mask, tree_root, is_commutative;
+ MPID_Op *op_ptr;
+ MPI_Comm comm;
+ MPIU_THREADPRIV_DECL;
+#endif
+ MPIU_CHKLMEM_DECL(5);
+ comm = comm_ptr->handle;
+ comm_size = comm_ptr->local_size;
+ rank = comm_ptr->rank;
+ /* set op_errno to 0. stored in perthread structure */
+ MPIU_THREADPRIV_GET;
+ MPIU_THREADPRIV_FIELD(op_errno) = 0;
+ MPIR_Nest_incr();
+ if (recvcount == 0) {
+ goto fn_exit;
+ &true_extent);
+ else {
+ else
+ is_cxx_uop = 1;
+ else
+#endif
+ else
+ MPIU_CHKLMEM_MALLOC(disps, int *, comm_size * sizeof(int), mpi_errno, "disps");
+ total_count = comm_size*recvcount;
+ for (i=0; i<comm_size; i++) {
+ disps[i] = i*recvcount;
+ MPID_Datatype_get_size_macro(datatype, type_size);
+ nbytes = total_count * type_size;
+ /* check if multiple threads are calling this collective function */
+ MPIDU_ERR_CHECK_MULTIPLE_THREADS_ENTER( comm_ptr );
+ /* total_count*extent eventually gets malloced. it isn't added to
+ * a user-passed in buffer */
+ MPID_Ensure_Aint_fits_in_pointer(total_count * MPIR_MAX(true_extent, extent));
+ if ((is_commutative) && (nbytes < MPIR_REDSCAT_COMMUTATIVE_LONG_MSG)) {
+ /* commutative and short. use recursive halving algorithm */
+ /* allocate temp. buffer to receive incoming data */
+ MPIU_CHKLMEM_MALLOC(tmp_recvbuf, void *, total_count*(MPIR_MAX(true_extent,extent)), mpi_errno, "tmp_recvbuf");
+ tmp_recvbuf = (void *)((char*)tmp_recvbuf - true_lb);
+ /* need to allocate another temporary buffer to accumulate
+ results because recvbuf may not be big enough */
+ MPIU_CHKLMEM_MALLOC(tmp_results, void *, total_count*(MPIR_MAX(true_extent,extent)), mpi_errno, "tmp_results");
+ tmp_results = (void *)((char*)tmp_results - true_lb);
+ /* copy sendbuf into tmp_results */
+ if (sendbuf != MPI_IN_PLACE)
+ mpi_errno = MPIR_Localcopy(sendbuf, total_count, datatype,
+ tmp_results, total_count, datatype);
+ else
+ mpi_errno = MPIR_Localcopy(recvbuf, total_count, datatype,
+ pof2 = 1;
+ while (pof2 <= comm_size) pof2 <<= 1;
+ pof2 >>=1;
+ rem = comm_size - pof2;
+ /* In the non-power-of-two case, all even-numbered
+ processes of rank < 2*rem send their data to
+ (rank+1). These even-numbered processes no longer
+ participate in the algorithm until the very end. The
+ remaining processes form a nice power-of-two. */
+ if (rank < 2*rem) {
+ if (rank % 2 == 0) { /* even */
+ mpi_errno = MPIC_Send(tmp_results, total_count,
+ datatype, rank+1,
+ MPIR_REDUCE_SCATTER_BLOCK_TAG, comm);
+ /* --BEGIN ERROR HANDLING-- */
+ if (mpi_errno)
+ mpi_errno = MPIR_Err_create_code(mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**fail", 0);
+ return mpi_errno;
+ /* --END ERROR HANDLING-- */
+ /* temporarily set the rank to -1 so that this
+ process does not pariticipate in recursive
+ doubling */
+ newrank = -1;
+ else { /* odd */
+ mpi_errno = MPIC_Recv(tmp_recvbuf, total_count,
+ datatype, rank-1,
+ MPIR_REDUCE_SCATTER_BLOCK_TAG, comm,
+ MPI_STATUS_IGNORE);
+ if (mpi_errno)
+ return mpi_errno;
+ /* do the reduction on received data. since the
+ ordering is right, it doesn't matter whether
+ the operation is commutative or not. */
+ if (is_cxx_uop) {
+ (*MPIR_Process.cxx_call_op_fn)( tmp_recvbuf, tmp_results,
+ total_count,
+ datatype,
+ uop );
+ else
+#endif
+ (*uop)(tmp_recvbuf, tmp_results, &total_count, &datatype);
+ /* change the rank */
+ newrank = rank / 2;
+ else /* rank >= 2*rem */
+ newrank = rank - rem;
+ if (newrank != -1) {
+ /* recalculate the recvcnts and disps arrays because the
+ even-numbered processes who no longer participate will
+ have their result calculated by the process to their
+ right (rank+1). */
+ MPIU_CHKLMEM_MALLOC(newcnts, int *, pof2*sizeof(int), mpi_errno, "newcnts");
+ MPIU_CHKLMEM_MALLOC(newdisps, int *, pof2*sizeof(int), mpi_errno, "newdisps");
+ for (i=0; i<pof2; i++) {
+ /* what does i map to in the old ranking? */
+ old_i = (i < rem) ? i*2 + 1 : i + rem;
+ if (old_i < 2*rem) {
+ /* This process has to also do its left neighbor's
+ work */
+ newcnts[i] = 2 * recvcount;
+ else
+ newcnts[i] = recvcount;
+ newdisps[0] = 0;
+ for (i=1; i<pof2; i++)
+ newdisps[i] = newdisps[i-1] + newcnts[i-1];
+ mask = pof2 >> 1;
+ send_idx = recv_idx = 0;
+ last_idx = pof2;
+ while (mask > 0) {
+ newdst = newrank ^ mask;
+ /* find real rank of dest */
+ dst = (newdst < rem) ? newdst*2 + 1 : newdst + rem;
+ send_cnt = recv_cnt = 0;
+ if (newrank < newdst) {
+ send_idx = recv_idx + mask;
+ for (i=send_idx; i<last_idx; i++)
+ send_cnt += newcnts[i];
+ for (i=recv_idx; i<send_idx; i++)
+ recv_cnt += newcnts[i];
+ else {
+ recv_idx = send_idx + mask;
+ for (i=send_idx; i<recv_idx; i++)
+ for (i=recv_idx; i<last_idx; i++)
+/* printf("Rank %d, send_idx %d, recv_idx %d, send_cnt %d, recv_cnt %d, last_idx %d\n", newrank, send_idx, recv_idx,
+ send_cnt, recv_cnt, last_idx);
+ /* Send data from tmp_results. Recv into tmp_recvbuf */
+ if ((send_cnt != 0) && (recv_cnt != 0))
+ mpi_errno = MPIC_Sendrecv((char *) tmp_results +
+ newdisps[send_idx]*extent,
+ send_cnt, datatype,
+ dst, MPIR_REDUCE_SCATTER_BLOCK_TAG,
+ (char *) tmp_recvbuf +
+ newdisps[recv_idx]*extent,
+ recv_cnt, datatype, dst,
+ else if ((send_cnt == 0) && (recv_cnt != 0))
+ mpi_errno = MPIC_Recv((char *) tmp_recvbuf +
+ else if ((recv_cnt == 0) && (send_cnt != 0))
+ mpi_errno = MPIC_Send((char *) tmp_results +
+ comm);
+ /* tmp_recvbuf contains data received in this step.
+ tmp_results contains data accumulated so far */
+ if (recv_cnt) {
+ if (is_cxx_uop) {
+ (*MPIR_Process.cxx_call_op_fn)((char *) tmp_recvbuf +
+ (char *) tmp_results +
+ recv_cnt, datatype, uop);
+ else
+#endif
+ (*uop)((char *) tmp_recvbuf + newdisps[recv_idx]*extent,
+ (char *) tmp_results + newdisps[recv_idx]*extent,
+ &recv_cnt, &datatype);
+ /* update send_idx for next iteration */
+ send_idx = recv_idx;
+ last_idx = recv_idx + mask;
+ mask >>= 1;
+ /* copy this process's result from tmp_results to recvbuf */
+ mpi_errno = MPIR_Localcopy((char *)tmp_results +
+ disps[rank]*extent,
+ recvcount, datatype, recvbuf,
+ recvcount, datatype);
+ /* In the non-power-of-two case, all odd-numbered
+ processes of rank < 2*rem send to (rank-1) the result they
+ calculated for that process */
+ if (rank % 2) { /* odd */
+ disps[rank-1]*extent, recvcount,
+ datatype, rank-1,
+ else { /* even */
+ mpi_errno = MPIC_Recv(recvbuf, recvcount,
+ datatype, rank+1,
+ if (is_commutative && (nbytes >= MPIR_REDSCAT_COMMUTATIVE_LONG_MSG)) {
+ /* commutative and long message, or noncommutative and long message.
+ use (p-1) pairwise exchanges */
+ if (sendbuf != MPI_IN_PLACE) {
+ /* copy local data into recvbuf */
+ mpi_errno = MPIR_Localcopy(((char *)sendbuf+disps[rank]*extent),
+ /* allocate temporary buffer to store incoming data */
+ MPIU_CHKLMEM_MALLOC(tmp_recvbuf, void *, recvcount*(MPIR_MAX(true_extent,extent))+1, mpi_errno, "tmp_recvbuf");
+ for (i=1; i<comm_size; i++) {
+ src = (rank - i + comm_size) % comm_size;
+ dst = (rank + i) % comm_size;
+ /* send the data that dst needs. recv data that this process
+ needs from src into tmp_recvbuf */
+ mpi_errno = MPIC_Sendrecv(((char *)sendbuf+disps[dst]*extent),
+ recvcount, datatype, dst,
+ MPIR_REDUCE_SCATTER_BLOCK_TAG, tmp_recvbuf,
+ recvcount, datatype, src,
+ else
+ mpi_errno = MPIC_Sendrecv(((char *)recvbuf+disps[dst]*extent),
+ if (is_commutative || (src < rank)) {
+ if (is_cxx_uop) {
+ (*MPIR_Process.cxx_call_op_fn)(tmp_recvbuf,
+ recvbuf,
+ recvcount,
+ datatype, uop );
+ else
+#endif
+ (*uop)(tmp_recvbuf, recvbuf, &recvcount,
+ &datatype);
+ else {
+ if (is_cxx_uop) {
+ ((char *)recvbuf+disps[rank]*extent),
+ recvcount, datatype, uop );
+ else
+#endif
+ (*uop)(tmp_recvbuf, ((char *)recvbuf+disps[rank]*extent),
+ &recvcount, &datatype);
+ /* we can't store the result at the beginning of
+ recvbuf right here because there is useful data
+ there that other process/processes need. at the
+ end, we will copy back the result to the
+ beginning of recvbuf. */
+ else {
+ if (is_cxx_uop) {
+ (*MPIR_Process.cxx_call_op_fn)( recvbuf,
+ tmp_recvbuf,
+ recvcount,
+ datatype, uop );
+ else
+#endif
+ (*uop)(recvbuf, tmp_recvbuf, &recvcount, &datatype);
+ /* copy result back into recvbuf */
+ mpi_errno = MPIR_Localcopy(tmp_recvbuf, recvcount,
+ datatype, recvbuf,
+ else {
+ if (is_cxx_uop) {
+ tmp_recvbuf, recvcount, datatype, uop );
+ else
+#endif
+ (*uop)(((char *)recvbuf+disps[rank]*extent),
+ tmp_recvbuf, &recvcount, &datatype);
+ datatype,
+ ((char *)recvbuf +
+ disps[rank]*extent),
+ /* if MPI_IN_PLACE, move output data to the beginning of
+ recvbuf. already done for rank 0. */
+ if ((sendbuf == MPI_IN_PLACE) && (rank != 0)) {
+ mpi_errno = MPIR_Localcopy(((char *)recvbuf +
+ recvbuf,
+ if (!is_commutative) {
+ /* power of two check */
+ if (!(comm_size & (comm_size - 1))) {
+ /* noncommutative, pof2 size */
+ mpi_errno = MPIR_Reduce_scatter_block_noncomm(sendbuf, recvbuf, recvcount, datatype, op, comm_ptr);
+ else {
+ /* noncommutative and non-pof2, use recursive doubling. */
+ /* need to allocate temporary buffer to receive incoming data*/
+ results */
+ else
+ mask = 0x1;
+ i = 0;
+ while (mask < comm_size) {
+ dst = rank ^ mask;
+ dst_tree_root = dst >> i;
+ dst_tree_root <<= i;
+ my_tree_root = rank >> i;
+ my_tree_root <<= i;
+ /* At step 1, processes exchange (n-n/p) amount of
+ amount of data, and so forth. We use derived datatypes for this.
+ At each step, a process does not need to send data
+ indexed from my_tree_root to
+ my_tree_root+mask-1. Similarly, a process won't receive
+ data indexed from dst_tree_root to dst_tree_root+mask-1. */
+ /* calculate sendtype */
+ blklens[0] = blklens[1] = 0;
+ for (j=0; j<my_tree_root; j++)
+ blklens[0] += recvcount;
+ for (j=my_tree_root+mask; j<comm_size; j++)
+ blklens[1] += recvcount;
+ dis[0] = 0;
+ dis[1] = blklens[0];
+ for (j=my_tree_root; (j<my_tree_root+mask) && (j<comm_size); j++)
+ dis[1] += recvcount;
+ NMPI_Type_indexed(2, blklens, dis, datatype, &sendtype);
+ NMPI_Type_commit(&sendtype);
+ /* calculate recvtype */
+ for (j=0; j<dst_tree_root && j<comm_size; j++)
+ for (j=dst_tree_root+mask; j<comm_size; j++)
+ dis[0] = 0;
+ for (j=dst_tree_root; (j<dst_tree_root+mask) && (j<comm_size); j++)
+ NMPI_Type_indexed(2, blklens, dis, datatype, &recvtype);
+ NMPI_Type_commit(&recvtype);
+ received = 0;
+ if (dst < comm_size) {
+ /* tmp_results contains data to be sent in each step. Data is
+ received in tmp_recvbuf and then accumulated into
+ tmp_results. accumulation is done later below. */
+ mpi_errno = MPIC_Sendrecv(tmp_results, 1, sendtype, dst,
+ tmp_recvbuf, 1, recvtype, dst,
+ received = 1;
+ /* if some processes in this process's subtree in this step
+ did not have any destination process to communicate with
+ because of non-power-of-two, we need to send them the
+ result. We use a logarithmic recursive-halfing algorithm
+ for this. */
+ if (dst_tree_root + mask > comm_size) {
+ nprocs_completed = comm_size - my_tree_root - mask;
+ /* nprocs_completed is the number of processes in this
+ subtree that have all the data. Send data to others
+ in a tree fashion. First find root of current tree
+ that is being divided into two. k is the number of
+ least-significant bits in this process's rank that
+ must be zeroed out to find the rank of the root */
+ j = mask;
+ k = 0;
+ while (j) {
+ j >>= 1;
+ k++;
+ k--;
+ tmp_mask = mask >> 1;
+ while (tmp_mask) {
+ dst = rank ^ tmp_mask;
+ tree_root = rank >> k;
+ tree_root <<= k;
+ /* send only if this proc has data and destination
+ doesn't have data. at any step, multiple processes
+ can send if they have the data */
+ if ((dst > rank) &&
+ (rank < tree_root + nprocs_completed)
+ && (dst >= tree_root + nprocs_completed)) {
+ /* send the current result */
+ mpi_errno = MPIC_Send(tmp_recvbuf, 1, recvtype,
+ comm);
+ /* recv only if this proc. doesn't have data and sender
+ has data */
+ else if ((dst < rank) &&
+ (dst < tree_root + nprocs_completed) &&
+ (rank >= tree_root + nprocs_completed)) {
+ mpi_errno = MPIC_Recv(tmp_recvbuf, 1, recvtype, dst,
+ received = 1;
+ tmp_mask >>= 1;
+ k--;
+ /* The following reduction is done here instead of after
+ the MPIC_Sendrecv or MPIC_Recv above. This is
+ because to do it above, in the noncommutative
+ case, we would need an extra temp buffer so as not to
+ overwrite temp_recvbuf, because temp_recvbuf may have
+ to be communicated to other processes in the
+ non-power-of-two case. To avoid that extra allocation,
+ we do the reduce here. */
+ if (received) {
+ if (is_commutative || (dst_tree_root < my_tree_root)) {
+ if (is_cxx_uop) {
+ tmp_results, blklens[0],
+ datatype, uop);
+ ((char *)tmp_recvbuf + dis[1]*extent),
+ ((char *)tmp_results + dis[1]*extent),
+ blklens[1], datatype, uop );
+ else
+#endif
+ (*uop)(tmp_recvbuf, tmp_results, &blklens[0],
+ &datatype);
+ (*uop)(((char *)tmp_recvbuf + dis[1]*extent),
+ &blklens[1], &datatype);
+ else {
+ if (is_cxx_uop) {
+ (*MPIR_Process.cxx_call_op_fn)( tmp_results,
+ tmp_recvbuf, blklens[0],
+ datatype, uop );
+ else
+#endif
+ (*uop)(tmp_results, tmp_recvbuf, &blklens[0],
+ &datatype);
+ (*uop)(((char *)tmp_results + dis[1]*extent),
+ /* copy result back into tmp_results */
+ mpi_errno = MPIR_Localcopy(tmp_recvbuf, 1, recvtype,
+ tmp_results, 1, recvtype);
+ NMPI_Type_free(&sendtype);
+ NMPI_Type_free(&recvtype);
+ mask <<= 1;
+ i++;
+ /* now copy final results from tmp_results to recvbuf */
+ mpi_errno = MPIR_Localcopy(((char *)tmp_results+disps[rank]*extent),
+fn_exit:
+ MPIR_Nest_decr();
+ MPIDU_ERR_CHECK_MULTIPLE_THREADS_EXIT( comm_ptr );
+ if (MPIU_THREADPRIV_FIELD(op_errno))
+ mpi_errno = MPIU_THREADPRIV_FIELD(op_errno);
+ return (mpi_errno);
+fn_fail:
+ goto fn_exit;
+/* end:nested */
+#undef FUNCNAME
+#undef FCNAME
+/* begin:nested */
+int MPIR_Reduce_scatter_block_inter (
+ void *sendbuf,
+ void *recvbuf,
+ int recvcount,
+ MPI_Op op,
+/* Intercommunicator Reduce_scatter_block.
+ We first do an intercommunicator reduce to rank 0 on left group,
+ then an intercommunicator reduce to rank 0 on right group, followed
+ by local intracommunicator scattervs in each group.
+ int rank, mpi_errno, root, local_size, total_count, i;
+ MPI_Aint true_extent, true_lb = 0, extent;
+ void *tmp_buf=NULL;
+ MPID_Comm *newcomm_ptr = NULL;
+ local_size = comm_ptr->local_size;
+ total_count = local_size * recvcount;
+ if (rank == 0) {
+ /* In each group, rank 0 allocates a temp. buffer for the
+ reduce */
+ &true_extent);
+ if (mpi_errno)
+ return mpi_errno;
+ tmp_buf = MPIU_Malloc(total_count*(MPIR_MAX(extent,true_extent)));
+ if (!tmp_buf) {
+ mpi_errno = MPIR_Err_create_code( MPI_SUCCESS, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**nomem", 0 );
+ return mpi_errno;
+ tmp_buf = (void *)((char*)tmp_buf - true_lb);
+ /* first do a reduce from right group to rank 0 in left group,
+ then from left group to rank 0 in right group*/
+ if (comm_ptr->is_low_group) {
+ /* reduce from right group to rank 0*/
+ root = (rank == 0) ? MPI_ROOT : MPI_PROC_NULL;
+ mpi_errno = MPIR_Reduce_inter(sendbuf, tmp_buf, total_count, datatype, op,
+ root, comm_ptr);
+ if (mpi_errno)
+ return mpi_errno;
+ /* reduce to rank 0 of right group */
+ root = 0;
+ root, comm_ptr);
+ if (mpi_errno)
+ return mpi_errno;
+ else {
+ /* reduce to rank 0 of left group */
+ root = 0;
+ root, comm_ptr);
+ if (mpi_errno)
+ return mpi_errno;
+ /* reduce from right group to rank 0 */
+ root, comm_ptr);
+ if (mpi_errno)
+ return mpi_errno;
+ /* Get the local intracommunicator */
+ if (!comm_ptr->local_comm)
+ MPIR_Setup_intercomm_localcomm( comm_ptr );
+ newcomm_ptr = comm_ptr->local_comm;
+ mpi_errno = MPIR_Scatter(tmp_buf, recvcount, datatype, recvbuf,
+ recvcount, datatype, 0, newcomm_ptr);
+ if (mpi_errno)
+ return mpi_errno;
+ if (rank == 0) {
+ MPIU_Free((char*)tmp_buf+true_lb);
+ return mpi_errno;
+/* end:nested */
+#endif
+#undef FUNCNAME
#define FUNCNAME MPI_Reduce_scatter_block
#undef FCNAME
MPI_Reduce_scatter_block - Combines values and scatters the results
Input Parameters:
-+ sendbuf - starting address of send buffer (choice)
++ sendbuf - starting address of send buffer (choice)
. recvcount - element count per block (non-negative integer)
-. datatype - datatype of elements of send and receive buffers (handle)
-. op - operation (handle)
-- comm - communicator (handle)
+. datatype - data type of elements of input buffer (handle)
+. op - operation (handle)
+- comm - communicator (handle)
Output Parameter:
-. recvbuf - starting address of receive buffer (choice)
+. recvbuf - starting address of receive buffer (choice)
.N ThreadSafe
@@ -58,20 +1125,16 @@
.N MPI_ERR_OP
.N MPI_ERR_BUFFER_ALIAS
-int MPI_Reduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
- MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
+int MPI_Reduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
+ MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
MPID_Comm *comm_ptr = NULL;
- MPID_Comm *scatter_comm_ptr = NULL;
- void *tmp_buf;
- MPI_Aint extent, true_extent, true_lb;
- MPIU_CHKLMEM_DECL(1);
MPID_MPI_STATE_DECL(MPID_STATE_MPI_REDUCE_SCATTER_BLOCK);
MPIR_ERRTEST_INITIALIZED_ORDIE();
MPIU_THREAD_CS_ENTER(ALLFUNC,);
MPID_MPI_COLL_FUNC_ENTER(MPID_STATE_MPI_REDUCE_SCATTER_BLOCK);
@@ -80,55 +1143,55 @@
MPID_BEGIN_ERROR_CHECKS;
- MPIR_ERRTEST_COMM(comm, mpi_errno);
+ MPIR_ERRTEST_COMM(comm, mpi_errno);
if (mpi_errno != MPI_SUCCESS) goto fn_fail;
MPID_END_ERROR_CHECKS;
# endif /* HAVE_ERROR_CHECKING */
/* Convert MPI object handles to object pointers */
- MPID_Comm_get_ptr(comm, comm_ptr);
+ MPID_Comm_get_ptr( comm, comm_ptr );
/* Validate parameters and objects (post conversion) */
# ifdef HAVE_ERROR_CHECKING
- MPID_Datatype *datatype_ptr = NULL;
+ MPID_Datatype *datatype_ptr = NULL;
MPID_Op *op_ptr = NULL;
- int size;
- MPID_Comm_valid_ptr(comm_ptr, mpi_errno);
+ MPID_Comm_valid_ptr( comm_ptr, mpi_errno );
- size = comm_ptr->local_size;
+ MPIR_ERRTEST_COUNT(recvcount,mpi_errno);
- MPIR_ERRTEST_DATATYPE(datatype, "datatype", mpi_errno);
+ MPIR_ERRTEST_DATATYPE(datatype, "datatype", mpi_errno);
if (HANDLE_GET_KIND(datatype) != HANDLE_KIND_BUILTIN) {
MPID_Datatype_get_ptr(datatype, datatype_ptr);
- MPID_Datatype_valid_ptr(datatype_ptr, mpi_errno);
- MPID_Datatype_committed_ptr(datatype_ptr, mpi_errno);
+ MPID_Datatype_valid_ptr( datatype_ptr, mpi_errno );
+ MPID_Datatype_committed_ptr( datatype_ptr, mpi_errno );
MPIR_ERRTEST_RECVBUF_INPLACE(recvbuf, recvcount, mpi_errno);
- if (comm_ptr->comm_kind == MPID_INTERCOMM)
+ if (comm_ptr->comm_kind == MPID_INTERCOMM)
MPIR_ERRTEST_SENDBUF_INPLACE(sendbuf, recvcount, mpi_errno);
MPIR_ERRTEST_USERBUFFER(recvbuf,recvcount,datatype,mpi_errno);
- MPIR_ERRTEST_USERBUFFER(sendbuf,recvcount*size,datatype,mpi_errno);
+ MPIR_ERRTEST_USERBUFFER(sendbuf,recvcount,datatype,mpi_errno);
- MPIR_ERRTEST_OP(op, mpi_errno);
+ MPIR_ERRTEST_OP(op, mpi_errno);
if (HANDLE_GET_KIND(op) != HANDLE_KIND_BUILTIN) {
- MPID_Op_valid_ptr(op_ptr, mpi_errno);
+ MPID_Op_valid_ptr( op_ptr, mpi_errno );
- mpi_errno = (*MPIR_Op_check_dtype_table[op%16 - 1])(datatype);
+ mpi_errno =
+ ( * MPIR_Op_check_dtype_table[op%16 - 1] )(datatype);
- if (mpi_errno) MPIU_ERR_POP(mpi_errno);
+ if (mpi_errno != MPI_SUCCESS) goto fn_fail;
@@ -136,41 +1199,36 @@
/* ... body of routine ... */
- /* Use a naive implementation for now (reduce followed by scatter).
- * FIXME We should adapt one or more of the existing MPI_Reduce_scatter
- * algorithms to work here as well. */
- MPIU_THREADPRIV_GET;
- MPIR_Nest_incr();
+ if (comm_ptr->coll_fns != NULL && comm_ptr->coll_fns->Reduce_scatter_block != NULL)
+ mpi_errno = comm_ptr->coll_fns->Reduce_scatter_block(sendbuf, recvbuf,
+ op, comm_ptr);
+ else
- MPID_Datatype_get_extent_macro(datatype, extent);
- mpi_errno = NMPI_Type_get_true_extent(datatype, &true_lb, &true_extent);
+ MPIR_Nest_incr();
+ if (comm_ptr->comm_kind == MPID_INTRACOMM)
+ /* intracommunicator */
+ mpi_errno = MPIR_Reduce_scatter_block(sendbuf, recvbuf,
+ op, comm_ptr);
+ else {
+ /* intercommunicator */
+ mpi_errno = MPIR_Reduce_scatter_block_inter(sendbuf, recvbuf,
+ op, comm_ptr);
+ MPIR_Nest_decr();
- MPIU_CHKLMEM_MALLOC(tmp_buf, void *, true_extent * recvcount * comm_ptr->local_size, mpi_errno, "tmp_buf");
- tmp_buf = (void *)((char*)tmp_buf - true_lb);
- mpi_errno = NMPI_Reduce((sendbuf == MPI_IN_PLACE ? recvbuf : sendbuf), tmp_buf,
- (recvcount * comm_ptr->local_size), datatype, op,
- 0/*root*/, comm);
- scatter_comm_ptr = comm_ptr;
- if (comm_ptr->comm_kind == MPID_INTERCOMM) {
- /* Get the local intracommunicator */
- if (!comm_ptr->local_comm)
- MPIR_Setup_intercomm_localcomm(comm_ptr);
- scatter_comm_ptr = comm_ptr->local_comm;
- mpi_errno = NMPI_Scatter(tmp_buf, recvcount, datatype,
- recvbuf, recvcount, datatype,
- 0/*root*/, scatter_comm_ptr->handle);
/* ... end of body of routine ... */
fn_exit:
- MPIU_CHKLMEM_FREEALL();
- MPIR_Nest_decr();
MPID_MPI_COLL_FUNC_EXIT(MPID_STATE_MPI_REDUCE_SCATTER_BLOCK);
MPIU_THREAD_CS_EXIT(ALLFUNC,);
return mpi_errno;
@@ -179,14 +1237,12 @@
- mpi_errno = MPIR_Err_create_code(mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__,
- MPI_ERR_OTHER, "**mpi_reduce_scatter_block",
- "**mpi_reduce_scatter_block %p %p %d %D %O %C",
- sendbuf, recvbuf, recvcount, datatype, op, comm);
+ mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_reduce_scatter_block",
+ "**mpi_reduce_scatter_block %p %p %d %D %O %C", sendbuf, recvbuf, recvcount, datatype, op, comm);
# endif
mpi_errno = MPIR_Err_return_comm( comm_ptr, FCNAME, mpi_errno );
goto fn_exit;
More information about the mpich2-commits
