[mpich2-commits] r6727 - mpich2/trunk/maint
gropp at mcs.anl.gov
Mon May 24 14:52:25 CDT 2010
Author: gropp
Date: 2010-05-24 14:52:25 -0500 (Mon, 24 May 2010)
New Revision: 6727
Modified:
mpich2/trunk/maint/simplemake.in
Log:
Fix handling of dependency information creation for source files in a different directory
Modified: mpich2/trunk/maint/simplemake.in
--- mpich2/trunk/maint/simplemake.in 2010-05-24 19:21:06 UTC (rev 6726)
+++ mpich2/trunk/maint/simplemake.in 2010-05-24 19:52:25 UTC (rev 6727)
@@ -4365,6 +4365,14 @@
$ext =~ s/^.*\.//g;
$sourcebasename = $sourcefile;
$sourcebasename =~ s/\.\w*$//;
+ # The file name for the dependencies output is derived
+ # from the source file. In some cases, the source file
+ # may be drawn from a different directory; in that case,
+ # we need to remove directory specs from the name
+ $depfilename = $sourcebasename;
+ $depfilename =~ s/.*\///;
$objfiles = "_$sourcebasename.o $sourcebasename.o";
if ($do_sharedlibs || $found_sharedlib) {
$objfiles .= " $sourcebasename.lo _$sourcebasename.lo";
@@ -4385,8 +4393,8 @@
in the build directory\n";
$srcdirloc = '';
- print FD "\$(DEPS_DIR)/$sourcebasename.d: $srcdirloc$sourcefile$newline";
- &PrintVerboseOptionCommand( "\$(MAKE_DEPEND_C) $targetOpts $srcdirloc$sourcefile >\$(DEPS_DIR)/$sourcebasename.d", "-", "MAKE_DEPEND_C $sourcefile > \$(DEPS_DIR)/$sourcebasename.d" );
+ print FD "\$(DEPS_DIR)/$depfilename.d: $srcdirloc$sourcefile$newline";
+ &PrintVerboseOptionCommand( "\$(MAKE_DEPEND_C) $targetOpts $srcdirloc$sourcefile >\$(DEPS_DIR)/$depfilename.d", "-", "MAKE_DEPEND_C $sourcefile > \$(DEPS_DIR)/$depfilename.d" );
@@ -4422,6 +4430,8 @@
$ext =~ s/^.*\.//g;
if ($ext eq "c") {
if (! -s $sourcefile) {
$srcdirloc = '';
@@ -4434,8 +4444,8 @@
if (!$found_profilelib) {
$targetOpts = "";
- print FD "\techo \"$makeInclude \$(DEPS_DIR)/$sourcebasename.d\" >>\$(DEPS_DIR)/newalldeps$newline";
+ print FD "\techo \"$makeInclude \$(DEPS_DIR)/$depfilename.d\" >>\$(DEPS_DIR)/newalldeps$newline";
@@ -4451,6 +4461,8 @@
$ext =~ s/^.*\.//g;
if ($ext eq "c") {
$srcdirloc = '';
@@ -4463,8 +4475,8 @@
$targetOpts = "";
More information about the mpich2-commits
