[mpich2-commits] r6697 - in mpich2/trunk/src: mpi/debugger mpi/errhan mpid/ch3/channels/nemesis/nemesis/src util/param
goodell at mcs.anl.gov
Thu May 20 22:34:41 CDT 2010
Author: goodell
Date: 2010-05-20 22:34:41 -0500 (Thu, 20 May 2010)
New Revision: 6697
Modified:
mpich2/trunk/src/mpi/debugger/dbginit.c
mpich2/trunk/src/mpi/errhan/errutil.c
mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_dma.c
mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network.c
mpich2/trunk/src/util/param/params.yml
Log:
convert several old-style params to the new mechanism
In MPICH2, ~25 remain to be converted, including a few that depend
on support for range types.
No reviewer.
Modified: mpich2/trunk/src/mpi/debugger/dbginit.c
--- mpich2/trunk/src/mpi/debugger/dbginit.c 2010-05-21 03:34:37 UTC (rev 6696)
+++ mpich2/trunk/src/mpi/debugger/dbginit.c 2010-05-21 03:34:41 UTC (rev 6697)
@@ -170,8 +170,7 @@
to access this. */
/* Also, to avoid scaling problems, we only populate the first 64
entries (default) */
- maxsize = 64;
- MPL_env2int( "MPICH_PROCTABLE_SIZE", &maxsize );
+ maxsize = MPIR_PARAM_PROCTABLE_SIZE;
if (maxsize > size) maxsize = size;
if (rank == 0) {
@@ -206,9 +205,7 @@
MPIR_proctable_size = size;
#if 0
/* Debugging hook */
- val = 0;
- MPL_env2bool( "MPICH_PROCTABLE_PRINT", &val );
- if (val) {
+ if (MPIR_PARAM_PROCTABLE_PRINT) {
for (i=0; i<maxsize; i++) {
printf( "PT[%d].pid = %d, .host_name = %s\n",
i, MPIR_proctable[i].pid, MPIR_proctable[i].host_name );
Modified: mpich2/trunk/src/mpi/errhan/errutil.c
--- mpich2/trunk/src/mpi/errhan/errutil.c 2010-05-21 03:34:37 UTC (rev 6696)
+++ mpich2/trunk/src/mpi/errhan/errutil.c 2010-05-21 03:34:41 UTC (rev 6697)
@@ -1747,46 +1747,28 @@
/* Manage the error reporting stack */
-/* FIXME: This flag wasn't documented in the release specs, and in any
- event shouldn't be controlled through source-code changes (i.e.,
- make it either a configure option or a runtime option) */
-/* turn this flag on until we debug and release mpich2 */
-static int MPIR_Err_print_stack_flag = TRUE;
-static int MPIR_Err_chop_error_stack = FALSE;
-static int MPIR_Err_chop_width = 80;
static void MPIR_Err_stack_init( void )
- int n, rc, mpi_errno = MPI_SUCCESS;
+ int mpi_errno = MPI_SUCCESS;
error_ring_mutex_create(&mpi_errno);
- MPIR_Err_chop_error_stack = FALSE;
- rc = MPL_env2bool( "MPICH_PRINT_ERROR_STACK",
- &MPIR_Err_print_stack_flag );
- rc = MPL_env2int( "MPICH_CHOP_ERROR_STACK", &n );
- if (rc == 1) {
+ if (MPIR_PARAM_CHOP_ERROR_STACK < 0) {
+ MPIR_PARAM_CHOP_ERROR_STACK = 80;
#ifdef HAVE_WINDOWS_H
- /* If windows, set the default width to the window size */
- HANDLE hConsole = GetStdHandle(STD_OUTPUT_HANDLE);
- if (hConsole != INVALID_HANDLE_VALUE)
- CONSOLE_SCREEN_BUFFER_INFO info;
- if (GetConsoleScreenBufferInfo(hConsole, &info))
- MPIR_Err_chop_width = info.dwMaximumWindowSize.X;
+ /* If windows, set the default width to the window size */
+ HANDLE hConsole = GetStdHandle(STD_OUTPUT_HANDLE);
+ if (hConsole != INVALID_HANDLE_VALUE)
+ CONSOLE_SCREEN_BUFFER_INFO info;
+ if (GetConsoleScreenBufferInfo(hConsole, &info))
+ /* override the parameter system in this case */
+ MPIR_PARAM_CHOP_ERROR_STACK = info.dwMaximumWindowSize.X;
#endif
- if (n > 0) {
- MPIR_Err_chop_error_stack = TRUE;
- MPIR_Err_chop_width = n;
- else if (n == 0) {
- /* Use the default width */
@@ -1952,7 +1934,7 @@
maxlen--;
- if (MPIR_Err_chop_error_stack)
+ if (MPIR_PARAM_CHOP_ERROR_STACK > 0)
cur_pos = ErrorRing[ring_idx].msg;
len = (int)strlen(cur_pos);
@@ -1962,16 +1944,16 @@
while (len)
- if (len >= MPIR_Err_chop_width - max_location_len)
+ if (len >= MPIR_PARAM_CHOP_ERROR_STACK - max_location_len)
if (len > maxlen)
break;
/* FIXME: Don't use Snprint to append a string ! */
- MPIU_Snprintf(str, MPIR_Err_chop_width - 1 - max_location_len, "%s", cur_pos);
- str[MPIR_Err_chop_width - 1 - max_location_len] = '\n';
- cur_pos += MPIR_Err_chop_width - 1 - max_location_len;
- str += MPIR_Err_chop_width - max_location_len;
- maxlen -= MPIR_Err_chop_width - max_location_len;
+ MPIU_Snprintf(str, MPIR_PARAM_CHOP_ERROR_STACK - 1 - max_location_len, "%s", cur_pos);
+ str[MPIR_PARAM_CHOP_ERROR_STACK - 1 - max_location_len] = '\n';
+ cur_pos += MPIR_PARAM_CHOP_ERROR_STACK - 1 - max_location_len;
+ str += MPIR_PARAM_CHOP_ERROR_STACK - max_location_len;
+ maxlen -= MPIR_PARAM_CHOP_ERROR_STACK - max_location_len;
if (maxlen < max_location_len)
break;
for (i=0; i<max_location_len; i++)
@@ -2076,7 +2058,7 @@
int len;
- if (MPIR_Err_print_stack_flag) {
+ if (MPIR_PARAM_PRINT_ERROR_STACK) {
MPIU_Strncpy(msg, ", error stack:\n", num_remaining);
msg[num_remaining - 1] = '\0';
len = (int)strlen(msg);
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_dma.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_dma.c 2010-05-21 03:34:37 UTC (rev 6696)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_dma.c 2010-05-21 03:34:41 UTC (rev 6697)
@@ -20,8 +20,6 @@
* simpler. */
#define MPICH_NEW_KNEM_ABI_VERSION (0x0000000c)
-static size_t dma_threshold = 2048*1024;
/* These are for maintaining a linked-list of outstanding requests on which we
can make progress. */
struct lmt_dma_node {
@@ -62,10 +60,6 @@
int tmp_threshold = -1;
struct knem_cmd_info info;
- ret = MPL_env2int("MPICH_NEM_LMT_DMA_THRESHOLD", &tmp_threshold);
- if (ret == 1)
- dma_threshold = tmp_threshold;
knem_fd = open(KNEM_DEVICE_FILENAME, O_RDWR);
MPIU_ERR_CHKANDJUMP2(knem_fd < 0, mpi_errno, MPI_ERR_OTHER, "**shm_open",
"**shm_open %s %d", KNEM_DEVICE_FILENAME, errno);
@@ -334,8 +328,7 @@
MPIDI_Datatype_get_info(rreq->dev.user_count, rreq->dev.datatype,
dt_contig, data_sz, dt_ptr, dt_true_lb);
- /* this is where Stephanie might want to look at VC's local rank and shared cache size */
- nodma = !knem_has_dma || data_sz < dma_threshold;
+ nodma = !knem_has_dma || data_sz < MPIR_PARAM_NEM_LMT_DMA_THRESHOLD;
if (dt_contig) {
/* handle the iov creation ourselves */
Modified: mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network.c
--- mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network.c 2010-05-21 03:34:37 UTC (rev 6696)
+++ mpich2/trunk/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network.c 2010-05-21 03:34:41 UTC (rev 6697)
@@ -22,13 +22,12 @@
int MPID_nem_choose_netmod(void)
- const char *val;
int i;
MPIDI_STATE_DECL(MPID_STATE_MPID_NEM_CHOOSE_NETMOD);
MPIDI_FUNC_ENTER(MPID_STATE_MPID_NEM_CHOOSE_NETMOD);
- if (! MPL_env2str("MPICH_NEMESIS_NETMOD", &val))
+ if (strcmp(MPIR_PARAM_NEMESIS_NETMOD, "") == 0)
/* netmod not specified, using the default */
MPID_nem_netmod_func = MPID_nem_netmod_funcs[0];
@@ -38,7 +37,7 @@
for (i = 0; i < MPID_nem_num_netmods; ++i)
- if (!MPIU_Strncasecmp(val, MPID_nem_netmod_strings[i], MPID_NEM_MAX_NETMOD_STRING_LEN))
+ if (!MPIU_Strncasecmp(MPIR_PARAM_NEMESIS_NETMOD, MPID_nem_netmod_strings[i], MPID_NEM_MAX_NETMOD_STRING_LEN))
MPID_nem_netmod_func = MPID_nem_netmod_funcs[i];
MPID_nem_netmod_id = i;
@@ -46,8 +45,8 @@
- MPIU_ERR_SETANDJUMP1(mpi_errno, MPI_ERR_OTHER, "**invalid_netmod", "**invalid_netmod %s", val);
+ MPIU_ERR_SETANDJUMP1(mpi_errno, MPI_ERR_OTHER, "**invalid_netmod", "**invalid_netmod %s", MPIR_PARAM_NEMESIS_NETMOD);
fn_exit:
MPIDI_FUNC_EXIT(MPID_STATE_MPID_NEM_CHOOSE_NETMOD);
return mpi_errno;
Modified: mpich2/trunk/src/util/param/params.yml
--- mpich2/trunk/src/util/param/params.yml 2010-05-21 03:34:37 UTC (rev 6696)
+++ mpich2/trunk/src/util/param/params.yml 2010-05-21 03:34:41 UTC (rev 6697)
@@ -16,10 +16,20 @@
categories:
- name : collective
description : parameters that control collective communication behavior
+ - name : pt2pt
+ description : parameters that control point-to-point communication behavior
- name : intranode
description : intranode communication parameters
- name : developer
description : useful for developers working on MPICH2 itself
+ - name : error_handling
+ description : parameters that control error handling behavior (stack traces, aborts, etc)
+ - name : debugger
+ description : parameters relevant to the "MPIR" debugger interface
+ - name : threads
+ description : multi-threading parameters
+ - name : nemesis
+ description : "parameters that control behavior of the ch3:nemesis channel"
parameters:
@@ -79,4 +89,51 @@
description : >-
If true, list any memory that was allocated by MPICH2 and that
remains allocated when MPI_Finalize completes.
+ - category : debugger
+ name : PROCTABLE_SIZE
+ type : int
+ default : 64
+ description : >-
+ Size of the "MPIR" debugger interface proctable (process table).
+ name : PROCTABLE_PRINT
+ type : boolean
+ default : true
+ description : >-
+ If true, dump the proctable entries at MPIR_WaitForDebugger-time.
+ (currently compile-time disabled by "#if 0")
+ - category : error_handling
+ name : PRINT_ERROR_STACK
+ type : boolean
+ default : true
+ description : >-
+ If true, print an error stack trace at error handling time.
+ name : CHOP_ERROR_STACK
+ type : int
+ default : 0
+ description : >-
+ If >0, truncate error stack output lines this many characters
+ wide. If 0, do not truncate, and if <0 use a sensible default.
+ - category : intranode
+ name : NEM_LMT_DMA_THRESHOLD
+ type : int
+ # 2048*1024 == 2MiB
+ default : 2097152
+ description : >-
+ Messages larger than this size will use the "dma" (knem)
+ intranode LMT implementation, if it is enabled and available.
+ - category : nemesis
+ name : NEMESIS_NETMOD
+ type : string
+ default : ""
+ description : >-
+ If non-empty, this parameter specifies which network module
+ should be used for communication.
More information about the mpich2-commits
