[mpich2-commits] r6694 - in mpich2/trunk/src: include mpi/coll mpid/ch3/src util/param
goodell at mcs.anl.gov
Thu May 20 22:34:31 CDT 2010
Author: goodell
Date: 2010-05-20 22:34:31 -0500 (Thu, 20 May 2010)
New Revision: 6694
Modified:
mpich2/trunk/src/include/mpiimpl.h
mpich2/trunk/src/mpi/coll/alltoall.c
mpich2/trunk/src/mpi/coll/alltoallv.c
mpich2/trunk/src/mpi/coll/alltoallw.c
mpich2/trunk/src/mpid/ch3/src/mpid_vc.c
mpich2/trunk/src/util/param/params.yml
Log:
use the new parameter interface for alltoall and NO_LOCAL
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h 2010-05-21 03:34:27 UTC (rev 6693)
+++ mpich2/trunk/src/include/mpiimpl.h 2010-05-21 03:34:31 UTC (rev 6694)
@@ -3155,11 +3155,6 @@
#define MPIR_BCAST_SHORT_MSG 12288
#define MPIR_BCAST_LONG_MSG 524288
#define MPIR_BCAST_MIN_PROCS 8
-#define MPIR_ALLTOALL_SHORT_MSG 256
-#define MPIR_ALLTOALL_MEDIUM_MSG 32768
-#define MPIR_ALLTOALL_THROTTLE 4 /* max no. of irecvs/isends posted at a
-time in some alltoall algorithms. Setting it to 0 causes all irecvs/isends to be
-posted at once. */
#define MPIR_REDSCAT_COMMUTATIVE_LONG_MSG 524288
#define MPIR_REDSCAT_NONCOMMUTATIVE_SHORT_MSG 512
#define MPIR_ALLGATHER_SHORT_MSG 81920
Modified: mpich2/trunk/src/mpi/coll/alltoall.c
--- mpich2/trunk/src/mpi/coll/alltoall.c 2010-05-21 03:34:27 UTC (rev 6693)
+++ mpich2/trunk/src/mpi/coll/alltoall.c 2010-05-21 03:34:31 UTC (rev 6694)
@@ -148,7 +148,7 @@
- else if ((nbytes <= MPIR_ALLTOALL_SHORT_MSG) && (comm_size >= 8)) {
+ else if ((nbytes <= MPIR_PARAM_ALLTOALL_SHORT_MSG_SIZE) && (comm_size >= 8)) {
/* use the indexing algorithm by Jehoshua Bruck et al,
* IEEE TPDS, Nov. 97 */
@@ -423,7 +423,7 @@
- else if (nbytes <= MPIR_ALLTOALL_MEDIUM_MSG) {
+ else if (nbytes <= MPIR_PARAM_ALLTOALL_MEDIUM_MSG_SIZE) {
/* Medium-size message. Use isend/irecv with scattered
destinations. Use Tony Ladd's modification to post only
a small number of isends/irecvs at a time. */
@@ -441,7 +441,7 @@
int ii, ss, bblock;
- bblock = MPIR_ALLTOALL_THROTTLE;
+ bblock = MPIR_PARAM_ALLTOALL_THROTTLE;
if (bblock == 0) bblock = comm_size;
/* FIXME: This should use the memory macros (there are storage
Modified: mpich2/trunk/src/mpi/coll/alltoallv.c
--- mpich2/trunk/src/mpi/coll/alltoallv.c 2010-05-21 03:34:27 UTC (rev 6693)
+++ mpich2/trunk/src/mpi/coll/alltoallv.c 2010-05-21 03:34:31 UTC (rev 6694)
@@ -122,7 +122,7 @@
else {
MPIU_CHKLMEM_MALLOC(starray, MPI_Status*, 2*bblock*sizeof(MPI_Status), mpi_errno, "starray");
Modified: mpich2/trunk/src/mpi/coll/alltoallw.c
--- mpich2/trunk/src/mpi/coll/alltoallw.c 2010-05-21 03:34:27 UTC (rev 6693)
+++ mpich2/trunk/src/mpi/coll/alltoallw.c 2010-05-21 03:34:31 UTC (rev 6694)
@@ -113,7 +113,7 @@
else {
Modified: mpich2/trunk/src/mpid/ch3/src/mpid_vc.c
--- mpich2/trunk/src/mpid/ch3/src/mpid_vc.c 2010-05-21 03:34:27 UTC (rev 6693)
+++ mpich2/trunk/src/mpid/ch3/src/mpid_vc.c 2010-05-21 03:34:31 UTC (rev 6694)
@@ -1101,9 +1101,7 @@
#ifdef ENABLED_NO_LOCAL
no_local = 1;
#else
- ret = MPL_env2bool("MPICH_NO_LOCAL", &val);
- if (ret == 1 && val)
- no_local = 1;
+ no_local = MPIR_PARAM_NOLOCAL;
#endif
/* Used for debugging on a single machine: Odd procs on a node are
Modified: mpich2/trunk/src/util/param/params.yml
--- mpich2/trunk/src/util/param/params.yml 2010-05-21 03:34:27 UTC (rev 6693)
+++ mpich2/trunk/src/util/param/params.yml 2010-05-21 03:34:31 UTC (rev 6694)
@@ -12,6 +12,10 @@
categories:
- name : collective
description : parameters that control collective communication behavior
+ - name : intranode
+ description : intranode communication parameters
+ - name : developer
+ description : useful for developers working on MPICH2 itself
parameters:
More information about the mpich2-commits
