[mpich2-commits] r6692 - in mpich2/trunk: maint src/util/param
goodell at mcs.anl.gov
Thu May 20 22:34:24 CDT 2010
Author: goodell
Date: 2010-05-20 22:34:24 -0500 (Thu, 20 May 2010)
New Revision: 6692
Added:
mpich2/trunk/maint/genparams
mpich2/trunk/src/util/param/params.yml
Log:
new parameter handling script and config file
Added: mpich2/trunk/maint/genparams
--- mpich2/trunk/maint/genparams (rev 0)
+++ mpich2/trunk/maint/genparams 2010-05-21 03:34:24 UTC (rev 6692)
@@ -0,0 +1,419 @@
+#!/usr/bin/env perl
+# (C) 2010 by Argonne National Laboratory.
+# See COPYRIGHT in top-level directory.
+# script TODO:
+# - generate initialization function to read vals from env vars
+# - deal with string escaping in generated C strings
+# - add support for "range" types (see MPL_env2range)
+# - sort/collate paramters by name/category
+use strict;
+use warnings;
+# help perl find the YAML parsing module
+use lib 'maint/local_perl/lib';
+use YAML::Tiny qw();
+use File::Basename qw(basename);
+use Data::Dumper;
+use Getopt::Long;
+# I'm pretty sure this is a standard lib module across all perl5
+# installs, but we can work around this easily if that doesn't turn out
+# to be true. [goodell@ 2010-04-26]
+use Digest::MD5 qw();
+# set true to enable debug output
+my $debug = 0;
+# namespace prefix for variable and type names
+my $ns = "MPIR_Param";
+# parameter description file
+my $param_file = "src/util/param/params.yml";
+# output source files
+my $header_file = "src/include/mpich_param_vals.h";
+my $c_file = "src/util/param/param_vals.c";
+GetOptions(
+ "help!" => \&print_usage_and_exit,
+ "debug!" => \$debug,
+ "namespace=s" => \$ns,
+ "param-file" => \$param_file,
+ "header=s" => \$header_file,
+ "c-file=s" => \$c_file,
+) or die "unable to parse options, stopped";
+sub print_usage_and_exit {
+ print <<EOT;
+Usage: $0 [OPTIONS]
+Supported options:
+ --help - this output
+ --debug - enable some debugging output
+ --namespace=STR - use STR as variable/type prefix in generated code
+ --param-file=FILE - use FILE as input describing parameters
+EOT
+ exit 1;
+my $run_timestamp = localtime;
+my $uc_ns = uc($ns);
+# read the config file and turn it into a perl hash/array object
+# NOTE: if multiple configuration files are supported in the future,
+# this is the place that should be modified to read them all in and
+# merge them into a single consistent configuration object
+my $yaml = YAML::Tiny->new();
+my $params = ($yaml->read($param_file))->[0]; # [0] is for the first document
+print Dumper($params)."\n" if $debug;
+die "not a HASH, stopped" unless ref($params) eq "HASH";
+# validate the config file
+# only simple checks for now, just make sure that all categories
+# referenced by parameters actually exist
+my %cat_hash = (map { ($_->{name} => 1) } @{$params->{categories}});
+foreach my $p (@{$params->{parameters}}) {
+ unless (exists $cat_hash{$p->{category}}) {
+ warn "category '".$p->{category}."' referenced by '".$p->{name}."' was not found";
+# setup output files
+open(PARAM_HDR, '>', $header_file);
+open(PARAM_C, '>', $c_file);
+my $hdr_guard = header_to_incl_guard($header_file);
+my $param_file_md5 = md5sum($param_file);
+print PARAM_HDR <<EOT;
+/* -*- Mode: C; c-basic-offset:4 ; indent-tabs-mode:nil ; -*- */
+ * (C) 2010 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+/* automatically generated
+ * by: $0
+ * on: $run_timestamp
+ * from: $param_file (md5sum $param_file_md5)
+ * DO NOT EDIT!!!
+#if !defined($hdr_guard)
+#define $hdr_guard
+EOT
+print PARAM_C <<EOT;
+ * by: $0
+ * at: $run_timestamp
+ * DO NOT EDIT!!!
+#include "mpiimpl.h"
+EOT
+# actually process file contents, starting w/ categories
+die "missing 'categories', stopped" unless exists $params->{categories};
+# write enum first
+/* parameter categories */
+enum ${ns}_category_id_t {
+EOT
+my $num_categories = scalar @{$params->{categories}};
+foreach my $cat (@{$params->{categories}}) {
+ printf PARAM_HDR " ${uc_ns}_CATEGORY_ID_%s,\n", $cat->{name};
+# then write full contents tuple
+ ${uc_ns}_NUM_CATEGORIES
+struct ${ns}_category_t {
+ const enum ${ns}_category_id_t id;
+ const char *name;
+ const char *description;
+/* array of category info for runtime usage */
+extern struct ${ns}_category_t ${ns}_categories[${uc_ns}_NUM_CATEGORIES];
+EOT
+struct ${ns}_category_t ${ns}_categories[${uc_ns}_NUM_CATEGORIES] = {
+EOT
+ my $desc = $cat->{description};
+ $desc =~ s/"/\\"/g;
+ printf PARAM_C qq( { ) .
+ qq(${uc_ns}_CATEGORY_ID_%s,\n) .
+ qq( "%s",\n) .
+ qq( "%s" },\n),
+ $cat->{name}, $cat->{name}, $desc;
+EOT
+# now the actual parameters
+die "missing 'parameters', stopped" unless exists $params->{parameters};
+/* parameter values */
+enum ${ns}_id_t {
+EOT
+my $num_params = @{$params->{parameters}};
+# XXX DJG TODO collate and separate by category
+ printf PARAM_HDR " ${uc_ns}_ID_%s,\n", $p->{name};
+ ${uc_ns}_NUM_PARAMS
+/* initializes parameter values from the environment */
+int ${ns}_init_params(void);
+enum ${ns}_type_t {
+ ${uc_ns}_TYPE_INVALID = 0,
+ ${uc_ns}_TYPE_INT,
+ ${uc_ns}_TYPE_DOUBLE,
+ ${uc_ns}_TYPE_BOOLEAN,
+ ${uc_ns}_TYPE_STRING
+/* used to represent default values */
+struct ${ns}_param_default_val_t {
+ const enum ${ns}_type_t type;
+ /* not a union b/c of initialization portability issues */
+ const int i_val; /* also used for booleans */
+ const double d_val;
+ const char *s_val;
+struct ${ns}_t {
+ const enum ${ns}_id_t id;
+ const char *name;
+ const struct ${ns}_param_default_val_t default_val;
+ /* TODO other fields here */
+/* array of parameter info for runtime usage */
+extern struct ${ns}_t ${ns}_params[${uc_ns}_NUM_PARAMS];
+/* extern declarations for each parameter
+ * (definitions in $c_file) */
+EOT
+ printf PARAM_HDR "extern %s ${uc_ns}_%s;\n",
+ type2ctype($p->{type}), $p->{name};
+struct ${ns}_t ${ns}_params[${uc_ns}_NUM_PARAMS] = {
+EOT
+ my $type_enum_val = "${uc_ns}_TYPE_".uc($p->{type});
+ my ($int_val, $str_val, $double_val) = (-1, qq(""), "0.0");
+ if ($p->{type} eq "string") {
+ $str_val = fmt_default($p->{default}, $p->{type});
+ elsif ($p->{type} eq "int") {
+ $int_val = fmt_default($p->{default}, $p->{type});
+ elsif ($p->{type} eq "double") {
+ $double_val = fmt_default($p->{default}, $p->{type});
+ elsif ($p->{type} eq "boolean") {
+ else {
+ die "unknown type $p->{type}, stopped";
+ my $desc = $p->{description};
+ qq(${uc_ns}_ID_%s,\n) .
+ qq( "%s",\n) .
+ qq( "%s",\n) .
+ # T I D S
+ qq( { %s, %d, %s, %s } },\n),
+ $p->{name}, $p->{name}, $desc,
+ $type_enum_val, $int_val, $double_val, $str_val;
+/* actual storage for parameters */
+EOT
+ printf PARAM_C "%s ${uc_ns}_%s = %s;\n",
+ $p->{name},
+ fmt_default($p->{default}, $p->{type});
+# FIXME the mpi_errno bit is MPICH-specific
+#undef FUNCNAME
+#define FUNCNAME ${ns}_init_params
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+ int mpi_errno = MPI_SUCCESS;
+ int rc;
+EOT
+ my $env_fn = type_to_env_fn($p->{type});
+ my @env_names = ();
+ # process extra envs first so the primary always wins
+ push @env_names, @{$p->{'abs-alt-env'}} if $p->{'abs-alt-env'};
+ push @env_names, map { "${uc_ns}_$_" } @{$p->{'alt-env'}};
+ push @env_names, "${uc_ns}_" . $p->{name};
+ foreach my $env_name (@env_names) {
+ # assumes rc is defined
+ my $var_name = "${uc_ns}_" . $p->{name};
+ print PARAM_C <<EOT;
+ rc = MPL_env2${env_fn}("$env_name", &($var_name));
+ MPIU_ERR_CHKANDJUMP1((-1 == rc),mpi_errno,MPI_ERR_OTHER,"**envvarparse","**envvarparse %s","$env_name");
+EOT
+ print PARAM_C "\n";
+fn_fail:
+ return mpi_errno;
+EOT
+# clean up
+close(PARAM_C);
+print PARAM_HDR "\n#endif /* $hdr_guard */\n";
+close(PARAM_HDR);
+# helper subroutines
+# transform a parameter type to a C-language type
+sub type2ctype {
+ my $type = shift;
+ my %typemap = (
+ 'int' => 'int',
+ 'double' => 'double',
+ 'string' => 'const char *',
+ 'boolean' => 'int',
+ die "unknown type '$type', stopped" unless exists $typemap{$type};
+ return $typemap{$type};
+# transform a default value into a C value
+sub fmt_default {
+ my $val = shift;
+ my $type = shift;
+ if ($type eq "string") {
+ $val =~ s/"/\\"/g;
+ return qq("$val");
+ elsif ($type eq "boolean") {
+ if ($val =~ m/^(0|f(alse)?|no?)$/i) { return qq(0); }
+ elsif ($val =~ m/^(1|t(rue)?|y(es)?)$/i) { return qq(1); }
+ else {
+ warn "WARNING: type='$type', bad val='$val', continuing";
+ return qq(0); # fail-false
+ else {
+ return qq($val);
+# turns foo_BAR-baz.h into FOO_BAR_BAZ_H_INCLUDED
+sub header_to_incl_guard {
+ my $header_file = shift;
+ my $guard = basename($header_file);
+ $guard =~ tr/a-z\-./A-Z__/;
+ $guard .= "_INCLUDED";
+ die "guard contains whitespace, stopped" if ($guard =~ m/\s/);
+ return $guard;
+sub md5sum {
+ my $file = shift;
+ my $md5 = Digest::MD5->new();
+ open FILE, '<', $file;
+ binmode(FILE);
+ $md5->addfile(*FILE);
+ close FILE;
+ return $md5->hexdigest;
+sub type_to_env_fn {
+ my $type = shift;
+ my %typemap = (
+ 'int' => 'int',
+ 'string' => 'str',
+ 'boolean' => 'bool',
Property changes on: mpich2/trunk/maint/genparams
___________________________________________________________________
Added: svn:executable
Added: mpich2/trunk/src/util/param/params.yml
--- mpich2/trunk/src/util/param/params.yml (rev 0)
+++ mpich2/trunk/src/util/param/params.yml 2010-05-21 03:34:24 UTC (rev 6692)
@@ -0,0 +1,60 @@
+--- #YAML:1.0
+# This is a YAML formatted file with '#'-style comments. This file
+# *must* be parseable by the YAML::Tiny perl module. So don't use
+# the inline list or map forms and don't try to use any really fancy
+# features like tagging or anchors.
+# The only tricky bit is that long reflowed text (such as a description)
+# should use ">-" to both fold newlines and remove the trailing newline.
+# It is used to generate parameter-handling code for MPICH2.
+# See the maint/genparams script for more information.
+categories:
+ - name : collective
+ description : parameters that control collective communication behavior
+parameters:
+ # collective parameters
+ - category : collective
+ name : ALLTOALL_SHORT_MSG_SIZE
+ type : int
+ default : 256
+ description : >-
+ the short message algorithm will be used if the per-destination
+ message size (sendcount*size(sendtype)) is <= this value
+ name : ALLTOALL_MEDIUM_MSG_SIZE
+ type : int
+ default : 32768
+ description : >-
+ the medium message algorithm will be used if the per-destination
+ message size (sendcount*size(sendtype)) is <= this value and
+ larger than ALLTOALL_SHORT_MSG_SIZE
+ name : ALLTOALL_THROTTLE
+ type : int
+ default : 4
+ description : >-
+ max no. of irecvs/isends posted at a time in some alltoall
+ algorithms. Setting it to 0 causes all irecvs/isends to be
+ posted at once.
+ # intranode communication parameters
+ - category : intranode
+ name : NOLOCAL
+ alt-env :
+ - NO_LOCAL
+ abs-alt-env :
+ - MPICH_NOLOCAL
+ - MPICH_NO_LOCAL
+ type : boolean
+ default : false
+ description : >-
+ If true, force all processes to operate as though all processes
+ are located on another node. For example, this disables shared
+ memory communication hierarchical collectives.
More information about the mpich2-commits
