[mpich2-commits] r6688 - mpich2/trunk/src/include
goodell at mcs.anl.gov goodell at mcs.anl.gov
Thu May 20 13:44:32 CDT 2010
Author: goodell
Date: 2010-05-20 13:44:32 -0500 (Thu, 20 May 2010)
New Revision: 6688
Added:
   mpich2/trunk/src/include/mpiimplthreadpost.h
Modified:
   mpich2/trunk/src/include/mpiimpl.h
   mpich2/trunk/src/include/mpiimplthread.h
   mpich2/trunk/src/include/mpishared.h
Log:
add mpiimplthreadpost.h for non-macro code, partly fix DECL scoping
We have definition ordering issues in the MPICH2 include files,
but they didn't show up until recently because they were always
preprocessor macros.  Trying to use an inline function instead causes
everything to blow up, so inline functions need to come later in the
include process.
The inline function implementations help us fix some of the scoping
issues introduced by the MPIU_THREADPRIV_DECL macros.
Reviewed by buntinas at .
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h	2010-05-20 18:44:31 UTC (rev 6687)
+++ mpich2/trunk/src/include/mpiimpl.h	2010-05-20 18:44:32 UTC (rev 6688)
@@ -3138,6 +3138,8 @@
 #define MPIU_CALL(context,funccall) context##_##funccall
 #endif
+#include "mpiimplthreadpost.h"
 /* Include definitions from the device which require items defined by this
    file (mpiimpl.h). */
 #include "mpidpost.h"
Modified: mpich2/trunk/src/include/mpiimplthread.h
--- mpich2/trunk/src/include/mpiimplthread.h	2010-05-20 18:44:31 UTC (rev 6687)
+++ mpich2/trunk/src/include/mpiimplthread.h	2010-05-20 18:44:32 UTC (rev 6688)
@@ -413,15 +413,19 @@
 /* Helper definitions for the default macro definitions */
 #if defined(MPICH_IS_THREADED) && !defined(MPID_DEVICE_DEFINES_THREAD_CS)
 #if MPIU_THREAD_GRANULARITY == MPIU_THREAD_GRANULARITY_GLOBAL
 /* FIXME what is this really supposed to do?  Is it supposed to check against
  * the "MPI nesting" or the critical section nesting? */
-#define MPIU_THREAD_CHECKNEST(_name)				\
-    MPIU_THREADPRIV_GET;                                        \
-    MPIU_DBG_MSG_D(THREAD,VERBOSE,"CHECKNEST, MPIR_Nest_value()=%d",MPIR_Nest_value());\
-    if (MPIR_Nest_value() == 0)
+/* It seems to just be a hook gating actual mutex lock/unlock for usage in
+ * _GLOBAL mode */
+/* should be followed by a {} block that will be conditionally executed */
+#define MPIU_THREAD_CHECKNEST(kind_, lockname_)                                         \
+    MPIU_THREADPRIV_GET;        \
+    MPIU_DBG_MSG_D(THREAD,VERBOSE,"CHECKNEST, MPIR_Nest_value()=%d",MPIR_Nest_value()); \
+    if (MPIR_Nest_value() == 0)
-#define MPIU_THREAD_CHECKDEPTH(_name,_value)
-#define MPIU_THREAD_UPDATEDEPTH(_name,_value)
+#define MPIU_THREAD_CHECKDEPTH(kind_, lockname_, value_)
+#define MPIU_THREAD_UPDATEDEPTH(kind_, lockname_, value_)
 #elif MPIU_THREAD_GRANULARITY == MPIU_THREAD_GRANULARITY_PER_OBJECT
@@ -432,12 +436,6 @@
    to the thread cs depth */
 #ifdef MPID_THREAD_DEBUG
-enum MPIU_Nest_mutexes {
-    MPIU_Nest_global_mutex = 0,
-    MPIU_Nest_handle_mutex,
-    MPIU_Nest_NUM_MUTEXES
 #define MPIU_THREAD_LOC_LEN 127
 #define MPIU_THREAD_FNAME_LEN 31
 typedef struct MPIU_ThreadDebug {
@@ -458,85 +456,75 @@
                 MPIU_Calloc(MPIU_Nest_NUM_MUTEXES, sizeof(MPIU_ThreadDebug_t)); \
     } while (0)
-#define MPIU_THREAD_CHECKDEPTH(name_,value_)                                               \
+#define MPIU_THREAD_CHECKDEPTH(kind_, lockname_, value_)                                   \
     do {        \
         MPIU_ThreadDebug_t *nest_ptr_ = NULL;                                              \
         MPIU_THREAD_INIT_NEST_CHECK_;                                                      \
         nest_ptr_ = MPIU_THREADPRIV_FIELD(nest_debug);                                     \
-        if (nest_ptr_[MPIU_Nest_##name_].count != value_) {                                \
+        if (nest_ptr_[kind_].count != value_) {                                            \
             fprintf(stderr, "%s:%d %s = %d, required %d; previously set in %s:%d(%s)\n",   \
-                    __FILE__, __LINE__,  #name_,                                           \
-                    nest_ptr_[MPIU_Nest_##name_].count, value_,                            \
-                    nest_ptr_[MPIU_Nest_##name_].file,                                     \
-                    nest_ptr_[MPIU_Nest_##name_].line,                                     \
-                    nest_ptr_[MPIU_Nest_##name_].fname );                                  \
+                    __FILE__, __LINE__,  lockname_,                                        \
+                    nest_ptr_[kind_].count, value_,                                        \
+                    nest_ptr_[kind_].file,                                                 \
+                    nest_ptr_[kind_].line,                                                 \
+                    nest_ptr_[kind_].fname );                                              \
             fflush(stderr);        \
     } while (0)
-#define MPIU_THREAD_UPDATEDEPTH(name_,value_)                                              \
+#define MPIU_THREAD_UPDATEDEPTH(kind_, lockname_, value_)                                  \
     do {        \
-        if (nest_ptr_[MPIU_Nest_##name_].count + (value_) < 0) {                           \
+        if (nest_ptr_[kind_].count + (value_) < 0) {                                       \
             fprintf(stderr, "%s:%d %s = %d (<0); previously set in %s:%d(%s)\n",           \
-                    nest_ptr_[MPIU_Nest_##name_].count,                                    \
+                    nest_ptr_[kind_].count,                                                \
             fflush(stderr);        \
-        nest_ptr_[MPIU_Nest_##name_].count += value_;                                      \
-        nest_ptr_[MPIU_Nest_##name_].line = __LINE__;                                      \
-        MPIU_Strncpy( nest_ptr_[MPIU_Nest_##name_].file, __FILE__, MPIU_THREAD_LOC_LEN );  \
-        MPIU_Strncpy( nest_ptr_[MPIU_Nest_##name_].fname, FCNAME, MPIU_THREAD_FNAME_LEN ); \
+        nest_ptr_[kind_].count += value_;                                                  \
+        nest_ptr_[kind_].line = __LINE__;                                                  \
+        MPIU_Strncpy( nest_ptr_[kind_].file, __FILE__, MPIU_THREAD_LOC_LEN );              \
+        MPIU_Strncpy( nest_ptr_[kind_].fname, FCNAME, MPIU_THREAD_FNAME_LEN );             \
     } while (0)
 #else
 #endif /* MPID_THREAD_DEBUG */
 #else
 #endif /* test on THREAD_GRANULARITY */
-#define MPIU_THREAD_CS_ENTER_LOCKNAME(_name) \
-    MPIU_DBG_MSG(THREAD,VERBOSE,"attempting to ENTER " #_name); \
-    MPIU_THREAD_CHECKDEPTH(_name,0);                            \
-    MPIU_THREAD_CHECKNEST(_name)				\
-        MPIU_DBG_MSG(THREAD,TYPICAL,"Enter critical section "#_name);\
-	MPID_Thread_mutex_lock(&MPIR_ThreadInfo._name);	\
-	MPIU_THREAD_UPDATEDEPTH(_name,1);                        \
-#define MPIU_THREAD_CS_EXIT_LOCKNAME(_name)			\
-    MPIU_DBG_MSG(THREAD,VERBOSE,"attempting to EXIT " #_name);  \
-    MPIU_THREAD_CHECKDEPTH(_name,1);                            \
-        MPIU_DBG_MSG(THREAD,TYPICAL,"Exit critical section "#_name);\
-	MPID_Thread_mutex_unlock(&MPIR_ThreadInfo._name);	\
-	MPIU_THREAD_UPDATEDEPTH(_name,-1);                       \
-#define MPIU_THREAD_CS_YIELD_LOCKNAME(_name)                          \
-do {        \
-    MPIU_DBG_MSG(THREAD,VERBOSE,"attempting to YIELD " #_name);       \
-    /* don't CHECKNEST here, we want nesting to be >0 */              \
-    MPIU_DBG_MSG(THREAD,TYPICAL,"Yield critical section "#_name);     \
-} while (0)
+#define MPIU_THREAD_CS_ENTER_LOCKNAME(name_)                                                   \
+    do {        \
+        MPIU_DBG_MSG_S(THREAD,VERBOSE,"attempting to ENTER lockname=%s", #name_);              \
+        MPIU_Thread_CS_enter_lockname_impl_(MPIU_Nest_##name_, #name_, &MPIR_ThreadInfo.name_); \
+    } while (0)
+#define MPIU_THREAD_CS_EXIT_LOCKNAME(name_)                                                    \
+    do {        \
+        MPIU_DBG_MSG_S(THREAD,VERBOSE,"attempting to EXIT lockname=%s", #name_);               \
+        MPIU_Thread_CS_exit_lockname_impl_(MPIU_Nest_##name_, #name_, &MPIR_ThreadInfo.name_);  \
+    } while (0)
+#define MPIU_THREAD_CS_YIELD_LOCKNAME(name_)                                                   \
+    do {        \
+        MPIU_DBG_MSG_S(THREAD,VERBOSE,"attempting to YIELD lockname=%s", #name_);              \
+        MPIU_Thread_CS_yield_lockname_impl_(MPIU_Nest_##name_, #name_, &MPIR_ThreadInfo.name_); \
+    } while (0)
+enum MPIU_Nest_mutexes {
+    MPIU_Nest_global_mutex = 0,
+    MPIU_Nest_handle_mutex,
+    MPIU_Nest_NUM_MUTEXES
 /* Some locks (such as the memory allocation locks) are needed to
  * bootstrap the lock checking code.  These macros provide a similar
  * interface to the MPIU_THREAD_CS_{ENTER,EXIT}_LOCKNAME macros but
@@ -552,7 +540,6 @@
     } while (0)
 #if defined(USE_MEMORY_TRACING)
     /* These are defined for all levels of thread granularity due to the
      * bootstrapping issue mentioned above */
Added: mpich2/trunk/src/include/mpiimplthreadpost.h
--- mpich2/trunk/src/include/mpiimplthreadpost.h	                        (rev 0)
+++ mpich2/trunk/src/include/mpiimplthreadpost.h	2010-05-20 18:44:32 UTC (rev 6688)
@@ -0,0 +1,77 @@
+/* -*- Mode: C; c-basic-offset:4 ; indent-tabs-mode:nil ; -*- */
+ *  (C) 2010 by Argonne National Laboratory.
+ *      See COPYRIGHT in top-level directory.
+/* this file contains definitions and declarations that would otherwise live in
+ * mpiimplthread.h but must come later in the mpiimpl.h include process because
+ * of the "big ball of wax" situation in our headers */
+#ifndef MPIIMPLTHREADPOST_H_INCLUDED
+#define MPIIMPLTHREADPOST_H_INCLUDED
+#undef FUNCNAME
+#define FUNCNAME MPIU_Thread_CS_enter_lockname_impl_
+#undef FCNAME
+#define FCNAME MPIU_QUOTE(FUNCNAME)
+/* these are inline functions instead of macros to avoid some of the
+ * MPIU_THREADPRIV_DECL scoping issues */
+static inline void
+MPIU_Thread_CS_enter_lockname_impl_(enum MPIU_Nest_mutexes kind,
+                                    const char *lockname,
+                                    MPID_Thread_mutex_t *mutex)
+    MPIU_THREADPRIV_DECL;
+    MPIU_THREAD_CHECKDEPTH(kind, lockname, 0);
+    MPIU_THREAD_CHECKNEST(kind, lockname)
+        MPIU_DBG_MSG_S(THREAD,TYPICAL,"locking %s", lockname);
+        MPID_Thread_mutex_lock(mutex);
+        MPIU_THREAD_UPDATEDEPTH(kind, lockname, 1);
+#undef FUNCNAME
+#define FUNCNAME MPIU_Thread_CS_exit_lockname_impl_
+#undef FCNAME
+static inline void
+MPIU_Thread_CS_exit_lockname_impl_(enum MPIU_Nest_mutexes kind,
+    MPIU_THREAD_CHECKDEPTH(kind, lockname, 1);
+        MPIU_DBG_MSG_S(THREAD,TYPICAL,"unlocking %s", lockname);
+        MPID_Thread_mutex_unlock(mutex);
+        MPIU_THREAD_UPDATEDEPTH(kind, lockname, -1);
+#undef FUNCNAME
+#define FUNCNAME MPIU_Thread_CS_yield_lockname_impl_
+#undef FCNAME
+static inline void
+MPIU_Thread_CS_yield_lockname_impl_(enum MPIU_Nest_mutexes kind,
+    /* don't CHECKNEST here, we want nesting to be >0 */
+    /* FIXME should we MPID_Thread_yield() here? */
+/* undef for safety, this is a commonly-included header */
+#undef FUNCNAME
+#undef FCNAME
+#endif /* defined(MPIIMPLTHREADPOST_H_INCLUDED) */
Modified: mpich2/trunk/src/include/mpishared.h
--- mpich2/trunk/src/include/mpishared.h	2010-05-20 18:44:31 UTC (rev 6687)
+++ mpich2/trunk/src/include/mpishared.h	2010-05-20 18:44:32 UTC (rev 6688)
@@ -142,4 +142,6 @@
 #define MPIU_UNREFERENCED_ARG(a)
 #endif
 #endif
More information about the mpich2-commits mailing list
