[mpich2-commits] r6685 - in mpich2/trunk/src: include util/other
goodell at mcs.anl.gov
Thu May 20 13:11:04 CDT 2010
Author: goodell
Date: 2010-05-20 13:11:04 -0500 (Thu, 20 May 2010)
New Revision: 6685
Added:
mpich2/trunk/src/util/other/assert.c
Modified:
mpich2/trunk/src/include/mpiutil.h
mpich2/trunk/src/util/other/Makefile.sm
Log:
refactor MPIU_Assert* to use functions
This de-clutters post-processed code and reduces the chance that
the compiler will get confused and make a poor optimization decision.
Reviewed by buntinas at .
Modified: mpich2/trunk/src/include/mpiutil.h
--- mpich2/trunk/src/include/mpiutil.h 2010-05-19 20:56:52 UTC (rev 6684)
+++ mpich2/trunk/src/include/mpiutil.h 2010-05-20 18:11:04 UTC (rev 6685)
@@ -18,6 +18,10 @@
* Thread safe implementation of strerror(), whenever possible. */
const char *MPIU_Strerror(int errnum);
+/* prototypes for assertion implementation helpers */
+int MPIR_Assert_fail(const char *cond, const char *file_name, int line_num);
+int MPIR_Assert_fail_fmt(const char *cond, const char *file_name, int line_num, const char *fmt, ...);
* MPIU_Assert()
@@ -31,15 +35,12 @@
#if (!defined(NDEBUG) && defined(HAVE_ERROR_CHECKING))
# define MPIU_AssertDecl(a_) a_
# define MPIU_AssertDeclValue(_a,_b) _a = _b
-# define MPIU_Assert(a_) \
- if (!(a_)) \
- MPIU_Internal_error_printf("Assertion failed in file %s at line %d: %s\n", __FILE__, __LINE__, MPIU_QUOTE(a_)); \
- MPIU_DBG_MSG_FMT(ALL, TERSE, (MPIU_DBG_FDEST, "Assertion failed in file %s at line %d: %s\n", __FILE__, __LINE__, MPIU_QUOTE(a_))); \
- MPID_Abort(NULL, MPI_SUCCESS, 1, NULL); \
+# define MPIU_Assert(a_) \
+ do { \
+ if (!(a_)) { \
+ MPIR_Assert_fail(#a_, __FILE__, __LINE__); \
+ } while (0)
#else
/* Empty decls not allowed in C */
@@ -56,15 +57,12 @@
* converted real error checking and reporting once the
* prototype becomes part of the official and supported code base.
-#define MPIU_Assertp(a_) \
- if (!(a_)) \
+#define MPIU_Assertp(a_) \
+ do { \
+ if (!(a_)) { \
+ } while (0)
/* Define the MPIU_Assert_fmt_msg macro. This macro takes two arguments. The
* first is the condition to assert. The second is a parenthesized list of
@@ -94,54 +92,26 @@
# if defined(HAVE_MACRO_VA_ARGS)
-# include "mpl.h" /* for MPL_VG_ macros */
# define MPIU_ASSERT_FMT_MSG_MAX_SIZE 2048
-/* newlines are added internally by this macro, callers do not need to include them */
-# define MPIU_Assert_fmt_msg(cond_,fmt_arg_parens_) \
- do { \
- if (!(cond_)) { \
- char *msg_ = MPIU_Malloc(MPIU_ASSERT_FMT_MSG_MAX_SIZE); \
- MPIU_Assert_fmt_msg_snprintf_ fmt_arg_parens_; \
- MPL_VG_PRINTF_BACKTRACE("Assertion failed in file %s at line %d: %s\n", \
- __FILE__, __LINE__, MPIU_QUOTE(cond_)); \
- MPL_VG_PRINTF_BACKTRACE("%s\n", msg_); \
- MPIU_Internal_error_printf("Assertion failed in file %s at line %d: %s\n", \
- MPIU_Internal_error_printf("%s\n", msg_); \
- MPIU_DBG_MSG_FMT(ALL, TERSE, \
- (MPIU_DBG_FDEST, \
- "Assertion failed in file %s at line %d: %s\n", \
- __FILE__, __LINE__, MPIU_QUOTE(cond_))); \
- MPIU_DBG_MSG_FMT(ALL, TERSE, (MPIU_DBG_FDEST,"%s\n",msg_)); \
- MPIU_Free(msg_); \
+/* newlines are added internally by the impl function, callers do not need to include them */
+# define MPIU_Assert_fmt_msg(cond_,fmt_arg_parens_) \
+ do { \
+ if (!(cond_)) { \
+ MPIR_Assert_fail_fmt(#cond_, __FILE__, __LINE__, \
+ MPIU_Assert_fmt_msg_expand_ fmt_arg_parens_); \
} while (0)
-/* NOTE: tightly coupled to the above macro, make changes in either one carefullly! */
-# define MPIU_Assert_fmt_msg_snprintf_(...) \
- MPIU_Snprintf(msg_, MPIU_ASSERT_FMT_MSG_MAX_SIZE,__VA_ARGS__)
+/* helper to just expand the parens arg inline */
+# define MPIU_Assert_fmt_msg_expand_(...) __VA_ARGS__
# else /* defined(HAVE_MACRO_VA_ARGS) */
- do { \
- if (!(cond_)) { \
- const char *unable_msg_ = \
- "macro __VA_ARGS__ not supported, unable to print user message"; \
- MPL_VG_PRINTF_BACKTRACE("%s\n", unable_msg_); \
- MPIU_Internal_error_printf("%s\n", unable_msg_); \
- MPIU_DBG_MSG_FMT(ALL, TERSE, (MPIU_DBG_FDEST,"%s\n",unable_msg_)); \
+ do { \
+ if (!(cond_)) { \
+ "%s", "macro __VA_ARGS__ not supported, unable to print user message"); \
} while (0)
# endif
Modified: mpich2/trunk/src/util/other/Makefile.sm
--- mpich2/trunk/src/util/other/Makefile.sm 2010-05-19 20:56:52 UTC (rev 6684)
+++ mpich2/trunk/src/util/other/Makefile.sm 2010-05-20 18:11:04 UTC (rev 6685)
@@ -1,2 +1,2 @@
-lib${MPILIBNAME}_a_SOURCES = outliers.c
+lib${MPILIBNAME}_a_SOURCES = outliers.c assert.c
INCLUDES = -I../../include -I${top_srcdir}/src/include
Added: mpich2/trunk/src/util/other/assert.c
--- mpich2/trunk/src/util/other/assert.c (rev 0)
+++ mpich2/trunk/src/util/other/assert.c 2010-05-20 18:11:04 UTC (rev 6685)
@@ -0,0 +1,58 @@
+/* -*- Mode: C; c-basic-offset:4 ; indent-tabs-mode:nil ; -*- */
+ * (C) 2010 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#include "mpiimpl.h"
+/* assertion helper routines
+ * These exist to de-clutter the post-processed code and reduce the chance that
+ * all of the assertion code will confuse the compiler into making bad
+ * optimization decisions. By the time one of these functions is called, the
+ * assertion has already failed and we can do more-expensive things because we
+ * are on the way out anyway. */
+ MPL_VG_PRINTF_BACKTRACE("Assertion failed in file %s at line %d: %s\n",
+ file_name, line_num, cond);
+ MPIU_Internal_error_printf("Assertion failed in file %s at line %d: %s\n",
+ MPIU_DBG_MSG_FMT(ALL, TERSE,
+ (MPIU_DBG_FDEST,
+ "Assertion failed in file %s at line %d: %s\n",
+ file_name, line_num, cond));
+ MPID_Abort(NULL, MPI_SUCCESS, 1, NULL);
+ return MPI_ERR_INTERN; /* never get here, abort should kill us */
+ char msg[MPIU_ASSERT_FMT_MSG_MAX_SIZE] = {'\0'};
+ va_list vl;
+ va_start(vl,fmt);
+ vsnprintf(msg, sizeof(msg), fmt, vl); /* don't check rc, can't handle it anyway */
+ MPL_VG_PRINTF_BACKTRACE("%s\n", msg);
+ MPIU_Internal_error_printf("%s\n", msg);
+ (MPIU_DBG_FDEST,
+ MPIU_DBG_MSG_FMT(ALL, TERSE, (MPIU_DBG_FDEST,"%s\n",msg));
More information about the mpich2-commits
