[mpich2-commits] r6680 - mpich2/trunk/test/mpi/coll
thakur at mcs.anl.gov thakur at mcs.anl.gov
Wed May 19 14:07:07 CDT 2010
Author: thakur
Date: 2010-05-19 14:07:07 -0500 (Wed, 19 May 2010)
New Revision: 6680
Added:
   mpich2/trunk/test/mpi/coll/red_scat_block2.c
Modified:
   mpich2/trunk/test/mpi/coll/Makefile.sm
   mpich2/trunk/test/mpi/coll/testlist
Log:
added reduce_scatter_block version of redscat2.c test in preparation for optimized version of reduce_scatter_block that uses the same algorithms as reduce_scatter
Modified: mpich2/trunk/test/mpi/coll/Makefile.sm
--- mpich2/trunk/test/mpi/coll/Makefile.sm	2010-05-19 15:51:05 UTC (rev 6679)
+++ mpich2/trunk/test/mpi/coll/Makefile.sm	2010-05-19 19:07:07 UTC (rev 6680)
@@ -43,6 +43,8 @@
 redscat2_LDADD = ../util/mtest.o
 red_scat_block_SOURCES = red_scat_block.c
 red_scat_block_LDADD = ../util/mtest.o
+red_scat_block2_SOURCES = red_scat_block2.c
+red_scat_block2_LDADD = ../util/mtest.o
 coll9_SOURCES = coll9.c
 coll7_SOURCES = coll7.c
 coll6_SOURCES = coll6.c
Added: mpich2/trunk/test/mpi/coll/red_scat_block2.c
--- mpich2/trunk/test/mpi/coll/red_scat_block2.c	                        (rev 0)
+++ mpich2/trunk/test/mpi/coll/red_scat_block2.c	2010-05-19 19:07:07 UTC (rev 6680)
@@ -0,0 +1,122 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ *  (C) 2010 by Argonne National Laboratory.
+ *      See COPYRIGHT in top-level directory.
+ * Test of reduce_scatter_block.
+ * Checks that non-commutative operations are not commuted and that
+ * all of the operations are performed.
+ * Can be called with any number of processors.
+#include "mpi.h"
+#include <stdio.h>
+#include <stdlib.h>
+#include "mpitest.h"
+int err = 0;
+/* left(x,y) ==> x */
+void left(void *a, void *b, int *count, MPI_Datatype *type)
+    int *in = a;
+    int *inout = b;
+    int i;
+    for (i = 0; i < *count; ++i)
+        if (in[i] > inout[i])
+            ++err;
+        inout[i] = in[i];
+/* right(x,y) ==> y */
+void right(void *a, void *b, int *count, MPI_Datatype *type)
+    int *in = a;
+    int *inout = b;
+    int i;
+            ++err;
+        inout[i] = inout[i];
+/* Just performs a simple sum but can be marked as non-commutative to
+   potentially tigger different logic in the implementation. */
+void nc_sum(void *a, void *b, int *count, MPI_Datatype *type)
+    int *in = a;
+    int *inout = b;
+    int i;
+        inout[i] = in[i] + inout[i];
+#define MAX_BLOCK_SIZE 256
+int main( int argc, char **argv )
+    int      *sendbuf;
+    int      block_size;
+    int      *recvbuf;
+    int      size, rank, i, sumval;
+    MPI_Comm comm;
+    MPI_Op left_op, right_op, nc_sum_op;
+    MTest_Init( &argc, &argv );
+    comm = MPI_COMM_WORLD;
+    MPI_Comm_size( comm, &size );
+    MPI_Comm_rank( comm, &rank );
+    MPI_Op_create(&left, 0/*non-commutative*/, &left_op);
+    MPI_Op_create(&right, 0/*non-commutative*/, &right_op);
+    MPI_Op_create(&nc_sum, 0/*non-commutative*/, &nc_sum_op);
+    for (block_size = 1; block_size < MAX_BLOCK_SIZE; block_size *= 2) {
+        sendbuf = (int *) malloc( block_size * size * sizeof(int) );
+        recvbuf = malloc( block_size * sizeof(int) );
+        for (i=0; i<(size*block_size); i++)
+            sendbuf[i] = rank + i;
+        for (i=0; i<block_size; i++)
+            recvbuf[i] = 0xdeadbeef;
+        MPI_Reduce_scatter_block( sendbuf, recvbuf, block_size, MPI_INT, left_op, comm );
+        for (i = 0; i < block_size; ++i)
+            if (recvbuf[i] != (rank * block_size + i)) ++err;
+        MPI_Reduce_scatter_block( sendbuf, recvbuf, block_size, MPI_INT, right_op, comm );
+            if (recvbuf[i] != ((size - 1) + (rank * block_size) + i)) ++err;
+        MPI_Reduce_scatter_block( sendbuf, recvbuf, block_size, MPI_INT, nc_sum_op, comm );
+        for (i = 0; i < block_size; ++i) {
+            int x = rank * block_size + i;
+            if (recvbuf[i] != (size*x + (size-1)*size/2)) ++err;
+        free(recvbuf);
+        free(sendbuf);
+    MPI_Op_free(&left_op);
+    MPI_Op_free(&right_op);
+    MPI_Op_free(&nc_sum_op);
+    MTest_Finalize( err );
+    MPI_Finalize( );
+    return err;
Modified: mpich2/trunk/test/mpi/coll/testlist
--- mpich2/trunk/test/mpi/coll/testlist	2010-05-19 15:51:05 UTC (rev 6679)
+++ mpich2/trunk/test/mpi/coll/testlist	2010-05-19 19:07:07 UTC (rev 6680)
@@ -51,6 +51,9 @@
 red_scat_block 4
 red_scat_block 5
 red_scat_block 8
+red_scat_block2 4
+red_scat_block2 5
+red_scat_block2 10
 scantst 4
 exscan 10
 exscan2 5
More information about the mpich2-commits mailing list
