[mpich2-commits] r6667 - in mpich2/trunk/src: include mpi/errhan
goodell at mcs.anl.gov
Mon May 17 17:47:57 CDT 2010
Author: goodell
Date: 2010-05-17 17:47:57 -0500 (Mon, 17 May 2010)
New Revision: 6667
Modified:
mpich2/trunk/src/include/mpiimpl.h
mpich2/trunk/src/mpi/errhan/add_error_class.c
mpich2/trunk/src/mpi/errhan/dynerrutil.c
Log:
remove little-used, non-atomic macros
No reviewer.
Modified: mpich2/trunk/src/include/mpiimpl.h
--- mpich2/trunk/src/include/mpiimpl.h 2010-05-17 22:47:56 UTC (rev 6666)
+++ mpich2/trunk/src/include/mpiimpl.h 2010-05-17 22:47:57 UTC (rev 6667)
@@ -1909,47 +1909,8 @@
smpd. We may not want to export it. */
void MPIR_Err_print_stack(FILE *, int);
-/* XXX DJG FIXME delete this? */
-/* FIXME: Merge these with the object refcount update routines (perhaps as
- part of a general "atomic update" file */
- * Standardized general-purpose atomic update routines. Some comments:
- * Setmax atomically implements *a_ptr = max(b,*a_ptr) . This can
- * be implemented using compare-and-swap (form max, if new max is
- * larger, compare-and-swap against old max. if failure, restart).
- * Fetch_and_increment can be implemented in a similar way; for
- * example, in IA32,
- * loop:
- * mov eax, valptr
- * mov oldvalptr, eax
- * mov ebx, eax
- * inc ebx
- * lock: cmpxchg valptr, ebx
- * jnz loop
- * Implementations using LoadLink/StoreConditional are similar.
- * Question: can we use the simple code for MPI_THREAD_SERIALIZED?
- * If not, do we want a separate set of definitions that can be used
- * in the code where serialized is ok.
- * Currently, these are used only in the routines to create new error classes
- * and codes (src/mpi/errhan/dynerrutil.c and add_error_class.c).
- * Note that MPI object reference counts are handled with their own routines.
- * Because of the current use of these routines is within the SINGLE_CS
- * thread lock (for the THREAD_MULTIPLE case), we currently
- * do *not* include a separate Critical section for these operations.
-#define MPIR_Setmax(a_ptr,b) if (b>*(a_ptr)) { *(a_ptr) = b; }
-#define MPIR_Fetch_and_increment(count_ptr,value_ptr) \
- { *value_ptr = *count_ptr; *count_ptr += 1; }
/* FIXME: Move these to the communicator block; make sure that all
objects have such hooks */
#ifndef HAVE_DEV_COMM_HOOK
Modified: mpich2/trunk/src/mpi/errhan/add_error_class.c
--- mpich2/trunk/src/mpi/errhan/add_error_class.c 2010-05-17 22:47:56 UTC (rev 6666)
+++ mpich2/trunk/src/mpi/errhan/add_error_class.c 2010-05-17 22:47:57 UTC (rev 6667)
@@ -74,8 +74,12 @@
MPIU_ERR_CHKANDJUMP(new_class<0,mpi_errno,MPI_ERR_OTHER,"**noerrclasses");
*errorclass = ERROR_DYN_MASK | new_class;
- MPIR_Setmax( &MPIR_Process.attrs.lastusedcode, *errorclass );
+ /* FIXME why isn't this done in MPIR_Err_add_class? */
+ if (*errorclass > MPIR_Process.attrs.lastusedcode) {
+ MPIR_Process.attrs.lastusedcode = *errorclass;
/* ... end of body of routine ... */
fn_exit:
Modified: mpich2/trunk/src/mpi/errhan/dynerrutil.c
--- mpich2/trunk/src/mpi/errhan/dynerrutil.c 2010-05-17 22:47:56 UTC (rev 6666)
+++ mpich2/trunk/src/mpi/errhan/dynerrutil.c 2010-05-17 22:47:57 UTC (rev 6667)
@@ -202,7 +202,8 @@
MPIR_Init_err_dyncodes();
/* Get new class */
- MPIR_Fetch_and_increment( &first_free_class, &new_class );
+ new_class = first_free_class;
+ ++first_free_class;
/* --BEGIN ERROR HANDLING-- */
if (new_class >= ERROR_MAX_NCLASS) {
@@ -243,7 +244,9 @@
/* Get the new code */
- MPIR_Fetch_and_increment( &first_free_code, &new_code );
+ new_code = first_free_code;
+ ++first_free_code;
if (new_code >= ERROR_MAX_NCODE) {
/* Fail if out of codes */
More information about the mpich2-commits
