[mpich2-commits] r6665 - mpich2/trunk/src/mpid/dcmfd/include
goodell at mcs.anl.gov
Mon May 17 17:47:55 CDT 2010
Author: goodell
Date: 2010-05-17 17:47:55 -0500 (Mon, 17 May 2010)
New Revision: 6665
Modified:
mpich2/trunk/src/mpid/dcmfd/include/mpidthread.h
Log:
update the "dcmfd" device to use the overhauled thread macros
untested, includes some code from the bg-threads-1.1 branch
No reviewer.
Modified: mpich2/trunk/src/mpid/dcmfd/include/mpidthread.h
--- mpich2/trunk/src/mpid/dcmfd/include/mpidthread.h 2010-05-17 22:47:53 UTC (rev 6664)
+++ mpich2/trunk/src/mpid/dcmfd/include/mpidthread.h 2010-05-17 22:47:55 UTC (rev 6665)
@@ -19,75 +19,173 @@
+/* This file is included by mpidpre.h, so it is included before mpiimplthread.h.
+ * This is intentional because it lets us override the critical section macros */
-#ifdef MPID_CS_ENTER
-#error "MPID_CS_ENTER is already defined"
-#endif
-#define MPID_DEFINES_MPID_CS 1
-#if (MPICH_THREAD_LEVEL != MPI_THREAD_MULTIPLE)
+#if (MPICH_THREAD_LEVEL != MPI_THREAD_MULTIPLE) /* == !defined(MPICH_ISTHREADED) */
+/* suppress default macro definitions */
+#define MPID_DEFINES_MPIU_THREAD_CS 1
-#define MPID_CS_INITIALIZE() {}
-#define MPID_CS_FINALIZE() {}
-#define MPID_CS_ENTER() {}
-#define MPID_CS_EXIT() {}
-#define MPID_CS_CYCLE() {}
+/* FIXME this is set/unset by the MPICH2 top level configure, shouldn't be
+ * defined here as well... */
+#define HAVE_RUNTIME_THREADCHECK
-#define MPIU_THREAD_CHECK_BEGIN
-#define MPIU_THREAD_CHECK_END
-#define MPIU_THREAD_CS_ENTER(_name,_context)
-#define MPIU_THREAD_CS_EXIT(_name,_context)
-#define MPIU_THREAD_CS_YIELD(_name,_context)
-#define MPIU_THREADSAFE_INIT_DECL(_var) static int _var=1
-#define MPIU_THREADSAFE_INIT_STMT(_var,_stmt) if (_var) { _stmt; _var = 0; }
-#define MPIU_THREADSAFE_INIT_BLOCK_BEGIN(_var)
-#define MPIU_THREADSAFE_INIT_CLEAR(_var) _var=0
-#define MPIU_THREADSAFE_INIT_BLOCK_END(_var)
+/************** BEGIN PUBLIC INTERFACE ***************/
+/* assumes an MPIU_THREADPRIV_DECL is present in an enclosing scope */
+#define MPIU_THREAD_CS_INIT \
+ do { \
+ MPIU_THREADPRIV_INITKEY; \
+ MPIU_THREADPRIV_INIT; \
+ } while (0)
+#define MPIU_THREAD_CS_FINALIZE do{}while(0)
-#else
+/* definitions for main macro maze entry/exit */
+#define MPIU_THREAD_CS_ENTER(name_,context_) MPIU_THREAD_CS_ENTER_##name_(context_)
+#define MPIU_THREAD_CS_EXIT(name_,context_) MPIU_THREAD_CS_EXIT_##name_(context_)
+#define MPIU_THREAD_CS_YIELD(name_,context_) MPIU_THREAD_CS_YIELD_##name_(context_)
-#define HAVE_RUNTIME_THREADCHECK
-#define MPIU_THREAD_CHECK_BEGIN if (MPIR_ThreadInfo.isThreaded) {
-#define MPIU_THREAD_CHECK_END }
-#define MPIU_THREAD_CS_ENTER(_name,_context) DCMF_CriticalSection_enter(0);
-#define MPIU_THREAD_CS_EXIT(_name,_context) DCMF_CriticalSection_exit(0);
-#define MPIU_THREAD_CS_YIELD(_name,_context) DCMF_CriticalSection_cycle(0);
+/* see FIXME in mpiimplthread.h if you are hacking on THREADSAFE_INIT code */
#define MPIU_THREADSAFE_INIT_DECL(_var) static volatile int _var=1
#define MPIU_THREADSAFE_INIT_STMT(_var,_stmt) \
- if (_var) { \
- MPIU_THREAD_CS_ENTER(INITFLAG,); \
- _stmt; _var=0; \
- MPIU_THREAD_CS_EXIT(INITFLAG,); \
+ do { \
+ if (_var) { \
+ MPIU_THREAD_CS_ENTER(INITFLAG,); \
+ _stmt; \
+ _var=0; \
+ MPIU_THREAD_CS_EXIT(INITFLAG,); \
+ while (0)
#define MPIU_THREADSAFE_INIT_BLOCK_BEGIN(_var) \
- if (_var) {
+ if (_var) {
#define MPIU_THREADSAFE_INIT_BLOCK_END(_var) \
+/************** END PUBLIC INTERFACE ***************/
+/* everything that follows is just implementation details */
-#define MPID_CS_INITIALIZE() \
- /* Create thread local storage for nest count that MPICH uses */ \
- MPID_Thread_tls_create(NULL, &MPIR_ThreadInfo.thread_storage, NULL); \
-#define MPID_CS_FINALIZE() \
- /* Destroy thread local storage created during MPID_CS_INITIALIZE */ \
- MPID_Thread_tls_destroy(&MPIR_ThreadInfo.thread_storage, NULL); \
-#define MPID_CS_ENTER() DCMF_CriticalSection_enter(0);
-#define MPID_CS_EXIT() DCMF_CriticalSection_exit(0);
-#define MPID_CS_CYCLE() DCMF_CriticalSection_cycle(0);
+#if HAVE_DMA_CHANNELS
+#define MPIDI_GetChannel(peerrank,contextid) ((((peerrank) + MPIR_Process.comm_world->rank-1) & (MPIDI_dma_channel_num - 1) ) + MPIDI_dma_channel_base)
+#else
+#define MPIDI_GetChannel(rank,contextid) 0
+#endif
+#define MPID_GLOBAL_MUTEX (0)
+#define MPID_DCMF_MUTEX (MPID_GLOBAL_MUTEX)
+#define MPID_HANDLE_MUTEX (1)
+#define MPID_RECVQ_MUTEX (2)
+#define MPID_RECVQ_MUTEX0 (MPID_RECVQ_MUTEX+0)
+#define MPID_RECVQ_MUTEX1 (MPID_RECVQ_MUTEX+1)
+#define MPID_RECVQ_MUTEX2 (MPID_RECVQ_MUTEX+2)
+#define MPID_RECVQ_MUTEX3 (MPID_RECVQ_MUTEX+3)
+#define MPID_RECVQ_MUTEX4 (MPID_RECVQ_MUTEX+4)
+#define MPID_RECVQ_MUTEX5 (MPID_RECVQ_MUTEX+5)
+#define MPIDI_MAX_NUM_CHANNELS (4)
-#endif
+/* helper macros to insert thread checks around LOCKNAME actions */
+#define MPIU_THREAD_CS_ENTER_LOCKNAME_CHECKED(name_) \
+ MPIU_THREAD_CHECK_BEGIN \
+ MPIU_THREAD_CS_ENTER_LOCKNAME(name_); \
+ MPIU_THREAD_CHECK_END
+#define MPIU_THREAD_CS_EXIT_LOCKNAME_CHECKED(name_) \
+ MPIU_THREAD_CS_EXIT_LOCKNAME(name_); \
+#define MPIU_THREAD_CS_YIELD_LOCKNAME_CHECKED(name_) \
+ MPIU_THREAD_CS_YIELD_LOCKNAME(name_); \
-/* NOTE, this is incompatible with the MPIU_ISTHREADED definition expected at
- * the top level */
-#define MPIU_ISTHREADED(_s) { MPIU_THREAD_CHECK_BEGIN _s MPIU_THREAD_CHECK_END }
+#if MPIU_THREAD_GRANULARITY == MPIU_THREAD_GRANULARITY_GLOBAL
+/* There is a single, global lock, held for the duration of an MPI call */
+#define MPIU_THREAD_CS_ENTER_ALLFUNC(_context) MPIU_THREAD_CS_ENTER_LOCKNAME_CHECKED(GLOBAL)
+#define MPIU_THREAD_CS_EXIT_ALLFUNC(_context) MPIU_THREAD_CS_EXIT_LOCKNAME_CHECKED(GLOBAL)
+#define MPIU_THREAD_CS_YIELD_ALLFUNC(_context) MPIU_THREAD_CS_YIELD_LOCKNAME_CHECKED(GLOBAL)
+#define MPIU_THREAD_CS_ENTER_HANDLE(_context)
+#define MPIU_THREAD_CS_EXIT_HANDLE(_context)
+#define MPIU_THREAD_CS_ENTER_HANDLEALLOC(_context)
+#define MPIU_THREAD_CS_EXIT_HANDLEALLOC(_context)
+#define MPIU_THREAD_CS_ENTER_CONTEXTID(_context)
+#define MPIU_THREAD_CS_EXIT_CONTEXTID(_context)
+#define MPIU_THREAD_CS_YIELD_CONTEXTID(_context)
+#define MPIU_THREAD_CS_ENTER_DCMF(_context)
+#define MPIU_THREAD_CS_EXIT_DCMF(_context)
+#define MPIU_THREAD_CS_YIELD_DCMF(_context)
+#define MPIU_THREAD_CS_ENTER_RECVQ(_context)
+#define MPIU_THREAD_CS_EXIT_RECVQ(_context)
+#elif MPIU_THREAD_GRANULARITY == MPIU_THREAD_GRANULARITY_PER_OBJECT
+/* We use the handle mutex to avoid conflicts with the global mutex */
+#define MPIU_THREAD_CS_ENTER_HANDLE(_context) MPIU_THREAD_CS_ENTER_LOCKNAME_CHECKED(HANDLE)
+#define MPIU_THREAD_CS_EXIT_HANDLE(_context) MPIU_THREAD_CS_EXIT_LOCKNAME_CHECKED(HANDLE)
+/* The request handles may be allocated, and many other handles might
+ be deallocated, within the communication routines. To avoid
+ problems with lock nesting, for this particular case, we use a
+ separate lock (similar to the per-object lock) */
+#define MPIU_THREAD_CS_ENTER_HANDLEALLOC(_context) MPIU_THREAD_CS_ENTER_LOCKNAME_CHECKED(HANDLE)
+#define MPIU_THREAD_CS_EXIT_HANDLEALLOC(_context) MPIU_THREAD_CS_EXIT_LOCKNAME_CHECKED(HANDLE)
+#define MPIU_THREAD_CS_ENTER_CONTEXTID(_context) MPIU_THREAD_CS_ENTER_LOCKNAME_CHECKED(GLOBAL)
+#define MPIU_THREAD_CS_EXIT_CONTEXTID(_context) MPIU_THREAD_CS_EXIT_LOCKNAME_CHECKED(GLOBAL)
+#define MPIU_THREAD_CS_YIELD_CONTEXTID(_context) MPIU_THREAD_CS_YIELD_LOCKNAME_CHECKED(GLOBAL)
+ /* DG : DCMF global lock is not used in multichannel dcmf mode */
+# define MPIU_THREAD_CS_ENTER_DCMF(_context)
+# define MPIU_THREAD_CS_EXIT_DCMF(_context)
+# define MPIU_THREAD_CS_YIELD_DCMF(_context)
+#else /* !HAVE_DMA_CHANNELS */
+# define MPIU_THREAD_CS_ENTER_DCMF(_context) MPIU_THREAD_CS_ENTER_LOCKNAME_CHECKED(DCMF)
+# define MPIU_THREAD_CS_EXIT_DCMF(_context) MPIU_THREAD_CS_EXIT_LOCKNAME_CHECKED(DCMF)
+# define MPIU_THREAD_CS_YIELD_DCMF(_context) MPIU_THREAD_CS_YIELD_LOCKNAME_CHECKED(DCMF)
+#endif /* HAVE_DMA_CHANNELS */
+#define MPIDI_TS_INCR_RECVQ(_context) do {} while (0)
+#define MPIU_THREAD_CS_ENTER_RECVQ(_context) \
+ do { \
+ DCMF_CriticalSection_enter(MPID_RECVQ_MUTEX + (_context)); \
+ MPIDI_TS_INCR_RECVQ(_context); \
+ } while (0); \
+#define MPIU_THREAD_CS_EXIT_RECVQ(_context) \
+ do { \
+ DCMF_CriticalSection_exit(MPID_RECVQ_MUTEX + (_context)); \
+ } while (0); \
+#define MPIU_THREAD_CS_ENTER_LOCKNAME(name_) \
+ do { \
+ DCMF_CriticalSection_enter(MPID_##name_##_MUTEX); \
+ MPIDI_TS_INCR(name_); \
+ } while (0)
+#define MPIU_THREAD_CS_EXIT_LOCKNAME(name_) \
+ do { \
+ DCMF_CriticalSection_exit(MPID_##name_##_MUTEX); \
+ } while (0)
+#define MPIU_THREAD_CS_YIELD_LOCKNAME(name_) \
+ do { \
+ DCMF_CriticalSection_cycle(MPID_##name_##_MUTEX); \
+ } while (0)
+#else
+#error "unhandled thread granularity"
+#endif /* MPIU_THREAD_GRANULARITY == ... */
#endif /* !MPICH_MPIDTHREAD_H_INCLUDED */
More information about the mpich2-commits
