[mpich2-commits] r6641 - in mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer: timelines zoomable
chan at mcs.anl.gov
chan at mcs.anl.gov
Mon May 10 22:46:13 CDT 2010
Author: chan
Date: 2010-05-10 22:46:13 -0500 (Mon, 10 May 2010)
New Revision: 6641
Modified:
mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/timelines/CanvasTimeline.java
mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/timelines/InfoDialogForDrawable.java
mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/zoomable/ModelTime.java
Log:
added preliminary support to locate start and final vertices of very long drawable which happens when one zooms very deep into seeing details. This is added to address ticket #552.
Modified: mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/timelines/CanvasTimeline.java
--- mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/timelines/CanvasTimeline.java 2010-05-11 02:58:35 UTC (rev 6640)
+++ mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/timelines/CanvasTimeline.java 2010-05-11 03:46:13 UTC (rev 6641)
@@ -62,6 +62,7 @@
private YaxisMaps y_maps;
private YaxisTree tree_view;
private BoundedRangeModel y_model;
+ private ModelTime t_model;
private Method[] methods;
private String[] y_colnames;
@@ -95,6 +96,7 @@
TreeNode treeroot;
short depth_max, depth_init;
+ t_model = time_model;
treetrunk = treebody;
y_maps = yaxis_maps;
tree_view = y_maps.getTreeView();
@@ -435,6 +437,7 @@
clicked_time,
map_line2treeleaf,
y_colnames,
+ t_model,
clicked_dobj );
@@ -457,6 +460,7 @@
clicked_time,
map_line2treeleaf,
y_colnames,
+ t_model,
clicked_dobj );
@@ -479,6 +483,7 @@
clicked_time,
map_line2treeleaf,
y_colnames,
+ t_model,
clicked_dobj );
@@ -501,6 +506,7 @@
clicked_time,
map_line2treeleaf,
y_colnames,
+ t_model,
clicked_dobj );
Modified: mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/timelines/InfoDialogForDrawable.java
--- mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/timelines/InfoDialogForDrawable.java 2010-05-11 02:58:35 UTC (rev 6640)
+++ mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/timelines/InfoDialogForDrawable.java 2010-05-11 03:46:13 UTC (rev 6641)
@@ -11,22 +11,33 @@
import java.awt.*;
import javax.swing.*;
+import java.awt.event.ActionEvent;
+import java.awt.event.ActionListener;
import java.util.Map;
import base.drawable.Drawable;
import viewer.zoomable.InfoDialog;
+import viewer.zoomable.ModelTime;
public class InfoDialogForDrawable extends InfoDialog
private static final long serialVersionUID = 13200L;
+ private ModelTime time_model;
+ private double clk_time_pos;
+ private JButton left_btn;
+ private JButton home_btn;
+ private JButton right_btn;
public InfoDialogForDrawable( final Frame frame,
final double clicked_time,
final Map map_line2treenodes,
final String[] y_colnames,
+ ModelTime tmodel,
final Drawable clicked_dobj )
super( frame, "Drawable Info Box", clicked_time );
+ time_model = tmodel;
+ clk_time_pos = clicked_time;
Container root_panel = this.getContentPane();
root_panel.setLayout( new BoxLayout( root_panel, BoxLayout.Y_AXIS ) );
@@ -34,6 +45,36 @@
root_panel.add( new InfoPanelForDrawable( map_line2treenodes,
y_colnames, clicked_dobj ) );
- root_panel.add( super.getCloseButtonPanel() );
+ JPanel btn_panel = super.getCloseButtonPanel();
+ left_btn = new JButton( "left" );
+ home_btn = new JButton( "home" );
+ right_btn = new JButton( "right" );
+ left_btn.setAlignmentX( Component.LEFT_ALIGNMENT );
+ home_btn.setAlignmentX( Component.LEFT_ALIGNMENT );
+ right_btn.setAlignmentX( Component.RIGHT_ALIGNMENT );
+ left_btn.addActionListener( new ActionListener() {
+ public void actionPerformed( ActionEvent evt )
+ double time = clicked_dobj.getStartVertex().time;
+ time_model.centerTimeViewPosition( time );
+ home_btn.addActionListener( new ActionListener() {
+ time_model.centerTimeViewPosition( clk_time_pos );
+ right_btn.addActionListener( new ActionListener() {
+ double time = clicked_dobj.getFinalVertex().time;
+ btn_panel.add( left_btn );
+ btn_panel.add( home_btn );
+ btn_panel.add( right_btn );
+ root_panel.add( btn_panel );
Modified: mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/zoomable/ModelTime.java
--- mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/zoomable/ModelTime.java 2010-05-11 02:58:35 UTC (rev 6640)
+++ mpich2/trunk/src/mpe2/src/slog2sdk/src/viewer/zoomable/ModelTime.java 2010-05-11 03:46:13 UTC (rev 6641)
@@ -399,6 +399,14 @@
+ // tView_pos is the time measured in second.
+ public void centerTimeViewPosition( double tView_pos )
+ this.setTimeViewPosition( tView_pos - (tView_extent/2.0) );
+ this.updatePixelCoords();
+ // this.setScrollBarIncrements();
// tView_change is the time measured in second.
public void scroll( double tView_change )
More information about the mpich2-commits
