[mpich2-commits] r6623 - mpich2/trunk/confdb
balaji at mcs.anl.gov
Fri May 7 02:13:15 CDT 2010
Author: balaji
Date: 2010-05-07 02:13:15 -0500 (Fri, 07 May 2010)
New Revision: 6623
Modified:
mpich2/trunk/confdb/aclocal_shl.m4
Log:
Cleanup the C shared library support to be similar to the fortran
version.
Modified: mpich2/trunk/confdb/aclocal_shl.m4
--- mpich2/trunk/confdb/aclocal_shl.m4 2010-05-07 01:36:46 UTC (rev 6622)
+++ mpich2/trunk/confdb/aclocal_shl.m4 2010-05-07 07:13:15 UTC (rev 6623)
@@ -89,17 +89,13 @@
# For example, include the libname as ${LIBNAME_SHL}
#C_LINK_SHL='${CC} -shared -Wl,-h,<finallibname>'
# May need -fPIC . Test to see which one works.
- PAC_C_CHECK_COMPILER_OPTION(-fPIC,fPIC_ok=yes,fPIC_ok=no)
- if test "$fPIC_ok" != yes ; then
- PAC_C_CHECK_COMPILER_OPTION(-fpic,fpic_ok=yes,fpic_ok=no)
- if test "$fpic_ok" != yes ; then
- AC_MSG_ERROR([Neither -fpic nor -fPIC accepted by $CC])
- else
- CC_SHL='${CC} -fpic'
- fi
- else
- CC_SHL='${CC} -fPIC'
- fi
+ for sh_arg in "-fPIC" "-fpic" "-KPIC" ; do
+ PAC_C_CHECK_COMPILER_OPTION($sh_arg,works=yes,works=no)
+ if test "$works" = "yes" ; then
+ CC_SHL="${CC} ${sh_arg}"
+ break
+ fi
+ done
# This used to have -Wl,-rpath earlier, but that causes problems
# on many systems.
C_LINKPATH_SHL=""
More information about the mpich2-commits
