[mpich2-commits] r6619 - in mpich2/trunk/src/pm/hydra: . tools/rmk tools/rmk/lsf
balaji at mcs.anl.gov
Tue May 4 11:44:48 CDT 2010
Author: balaji
Date: 2010-05-04 11:44:48 -0500 (Tue, 04 May 2010)
New Revision: 6619
Added:
mpich2/trunk/src/pm/hydra/tools/rmk/lsf/
mpich2/trunk/src/pm/hydra/tools/rmk/lsf/Makefile.mk
mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf.h
mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf_init.c
mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf_query_node_list.c
Modified:
mpich2/trunk/src/pm/hydra/configure.in
mpich2/trunk/src/pm/hydra/tools/rmk/Makefile.mk
Log:
Initial draft of the LSF resource management kernel.
Modified: mpich2/trunk/src/pm/hydra/configure.in
--- mpich2/trunk/src/pm/hydra/configure.in 2010-05-04 15:48:06 UTC (rev 6618)
+++ mpich2/trunk/src/pm/hydra/configure.in 2010-05-04 16:44:48 UTC (rev 6619)
@@ -196,9 +196,9 @@
# Check what resource management kernel we should use
-AC_ARG_WITH(hydra-rmk, [ --with-hydra-rmk=name - Resource Management Kernel (pbs)],
+AC_ARG_WITH(hydra-rmk, [ --with-hydra-rmk=name - Resource Management Kernel (pbs, lsf)],
[ hydra_rmk=$withval ],
- [ hydra_rmk="dummy,pbs" ])
+ [ hydra_rmk="dummy,pbs,lsf" ])
AC_MSG_CHECKING(resource management kernel)
AC_MSG_RESULT($hydra_rmk)
hydra_rmk_names="`echo $hydra_rmk | sed -e 's/:/ /g' -e 's/,/ /g'`"
@@ -214,6 +214,10 @@
hydra_rmk_pbs=true
available_rmk=`echo $available_rmk pbs`
+ lsf)
+ hydra_rmk_lsf=true
+ available_rmk=`echo $available_rmk lsf`
esac
@@ -250,6 +254,7 @@
AC_SUBST(hydra_rmk_name_array)
AC_SUBST(hydra_rmk_init_array)
AM_CONDITIONAL([hydra_rmk_pbs], [$hydra_rmk_pbs])
+AM_CONDITIONAL([hydra_rmk_lsf], [$hydra_rmk_lsf])
Modified: mpich2/trunk/src/pm/hydra/tools/rmk/Makefile.mk
--- mpich2/trunk/src/pm/hydra/tools/rmk/Makefile.mk 2010-05-04 15:48:06 UTC (rev 6618)
+++ mpich2/trunk/src/pm/hydra/tools/rmk/Makefile.mk 2010-05-04 16:44:48 UTC (rev 6619)
@@ -12,3 +12,7 @@
if hydra_rmk_pbs
include tools/rmk/pbs/Makefile.mk
endif
+if hydra_rmk_lsf
+include tools/rmk/lsf/Makefile.mk
+endif
Added: mpich2/trunk/src/pm/hydra/tools/rmk/lsf/Makefile.mk
--- mpich2/trunk/src/pm/hydra/tools/rmk/lsf/Makefile.mk (rev 0)
+++ mpich2/trunk/src/pm/hydra/tools/rmk/lsf/Makefile.mk 2010-05-04 16:44:48 UTC (rev 6619)
@@ -0,0 +1,8 @@
+# -*- Mode: Makefile; -*-
+# (C) 2008 by Argonne National Laboratory.
+# See COPYRIGHT in top-level directory.
+libhydra_la_SOURCES += $(top_srcdir)/tools/rmk/lsf/rmk_lsf_init.c \
+ $(top_srcdir)/tools/rmk/lsf/rmk_lsf_query_node_list.c
Added: mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf.h
--- mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf.h (rev 0)
+++ mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf.h 2010-05-04 16:44:48 UTC (rev 6619)
@@ -0,0 +1,14 @@
+/* -*- Mode: C; c-basic-offset:4 ; -*- */
+ * (C) 2008 by Argonne National Laboratory.
+ * See COPYRIGHT in top-level directory.
+#ifndef RMK_LSF_H_INCLUDED
+#define RMK_LSF_H_INCLUDED
+#include "hydra_base.h"
+HYD_status HYDT_rmkd_lsf_query_node_list(struct HYD_node **node_list);
+#endif /* RMK_LSF_H_INCLUDED */
Added: mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf_init.c
--- mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf_init.c (rev 0)
+++ mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf_init.c 2010-05-04 16:44:48 UTC (rev 6619)
@@ -0,0 +1,22 @@
+#include "rmki.h"
+#include "rmk_lsf.h"
+HYD_status HYDT_rmki_lsf_init(void)
+ HYD_status status = HYD_SUCCESS;
+ HYDU_FUNC_ENTER();
+ HYDT_rmki_fns.query_node_list = HYDT_rmkd_lsf_query_node_list;
+ HYDU_FUNC_EXIT();
+ return status;
Added: mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf_query_node_list.c
--- mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf_query_node_list.c (rev 0)
+++ mpich2/trunk/src/pm/hydra/tools/rmk/lsf/rmk_lsf_query_node_list.c 2010-05-04 16:44:48 UTC (rev 6619)
@@ -0,0 +1,48 @@
+#include "rmki.h"
+ char *hosts, *hostname, *num_procs_str;
+ int num_procs;
+ if (MPL_env2str("LSB_MCPU_HOSTS", (const char **) &hosts) == 0)
+ hosts = NULL;
+ if (hosts == NULL) {
+ *node_list = NULL;
+ HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "No LSF node list found\n");
+ else {
+ while (1) {
+ hostname = strtok(hosts, " ");
+ if (hostname == NULL)
+ break;
+ num_procs_str = strtok(hosts, " ");
+ HYDU_ASSERT(num_procs_str, status);
+ num_procs = atoi(num_procs_str);
+ status = HYDU_add_to_node_list(hostname, num_procs, node_list);
+ HYDU_ERR_POP(status, "unable to add to node list\n");
+ fn_exit:
+ HYDU_FUNC_EXIT();
+ return status;
+ fn_fail:
+ goto fn_exit;
More information about the mpich2-commits
