[mpich2-commits] r6612 - mpich2/trunk/src/util/multichannel
jayesh at mcs.anl.gov
Mon May 3 13:13:09 CDT 2010
Author: jayesh
Date: 2010-05-03 13:13:09 -0500 (Mon, 03 May 2010)
New Revision: 6612
Modified:
mpich2/trunk/src/util/multichannel/mpi.c
Log:
Make nemesis the default channel on windows
Modified: mpich2/trunk/src/util/multichannel/mpi.c
--- mpich2/trunk/src/util/multichannel/mpi.c 2010-05-03 15:38:32 UTC (rev 6611)
+++ mpich2/trunk/src/util/multichannel/mpi.c 2010-05-03 18:13:09 UTC (rev 6612)
@@ -59,16 +59,23 @@
#define MPI_ENV_CHANNEL_NAME "MPICH2_CHANNEL"
#define MPI_ENV_MPIWRAP_DLL_NAME "MPI_WRAP_DLL_NAME"
#ifdef _DEBUG
-#define MPI_DEFAULT_DLL_NAME "mpich2d.dll"
+#define MPI_DEFAULT_DLL_NAME "mpich2nemesisd.dll"
#define MPI_DEFAULT_WRAP_DLL_NAME "mpich2mped.dll"
#define DLL_FORMAT_STRING "mpich2%sd.dll"
#else
-#define MPI_DEFAULT_DLL_NAME "mpich2.dll"
+#define MPI_DEFAULT_DLL_NAME "mpich2nemesis.dll"
#define MPI_DEFAULT_WRAP_DLL_NAME "mpich2mpe.dll"
#define DLL_FORMAT_STRING "mpich2%s.dll"
#endif
#define MAX_DLL_NAME 100
+/* FIXME: Remove dlls without a channel token string */
+#ifdef _DEBUG
+#define MPI_SOCK_CHANNEL_DLL_NAME "mpich2d.dll"
+#else
+#define MPI_SOCK_CHANNEL_DLL_NAME "mpich2.dll"
+#endif
MPIU_DLL_SPEC MPI_Fint *MPI_F_STATUS_IGNORE = 0;
MPIU_DLL_SPEC MPI_Fint *MPI_F_STATUSES_IGNORE = 0;
@@ -1749,6 +1756,12 @@
MPIU_Snprintf(name, MAX_DLL_NAME, DLL_FORMAT_STRING, channel);
dll_name = name;
+ else
+ /* FIXME: Get rid of dlls without a channel substring in the name */
+ MPIU_Snprintf(name, MAX_DLL_NAME, "%s", MPI_SOCK_CHANNEL_DLL_NAME);
+ dll_name = name;
/* no dll or channel specified so use the default */
if (!dll_name)
More information about the mpich2-commits
