[mpich2-commits] r5639 - mpich2/trunk/src/pm/mpd
goodell at mcs.anl.gov
Fri Oct 30 17:56:01 CDT 2009
Author: goodell
Date: 2009-10-30 17:56:01 -0500 (Fri, 30 Oct 2009)
New Revision: 5639
Modified:
mpich2/trunk/src/pm/mpd/mpd.py
Log:
Fix mpd process_mapping in another case (ticket #905).
This is yet another band-aid on mpd's process mapping support. The
right fix is probably just to use hydra and remove this functionality
from mpd.
Reviewed by balaji at .
Modified: mpich2/trunk/src/pm/mpd/mpd.py
--- mpich2/trunk/src/pm/mpd/mpd.py 2009-10-30 21:40:24 UTC (rev 5638)
+++ mpich2/trunk/src/pm/mpd/mpd.py 2009-10-30 22:56:01 UTC (rev 5639)
@@ -864,7 +864,7 @@
# we only handle two cases for now:
# 1. block regular
# 2. round-robin regular
- # we do handle a "remainder node" that might not be full
+ # we do handle "remainder nodes" that might not be full
delta = -1
max_ranks_per_node = 0
for node_id in node_to_ranks.keys():
@@ -888,6 +888,31 @@
return ''
last_rank = rank
+ # another check (case caught in ticket #905) for layouts like {0:A,1:A,2:B,3:B,4:B}
+ if len(node_to_ranks.keys()) > 1:
+ first_size = len(node_to_ranks[0])
+ last_size = len(node_to_ranks[len(node_to_ranks.keys())-1])
+ if (last_size > first_size):
+ mpd_print(1, "irregular case C1 detected")
+ return ''
+ in_remainder = False
+ node_ids = node_to_ranks.keys()
+ node_ids.sort()
+ for node_id in node_ids:
+ node_size = len(node_to_ranks[node_id])
+ if not in_remainder:
+ if node_size == first_size:
+ pass # OK
+ elif node_size == last_size:
+ in_remainder = True
+ else:
+ mpd_print(1, "irregular case C2 detected")
+ return ''
+ else: # in_remainder
+ if node_size != last_size:
+ mpd_print(1, "irregular case C3 detected")
+ return ''
num_nodes = len(node_to_ranks.keys())
if delta == 1:
return '(vector,(%d,%d,%d))' % (0,num_nodes,max_ranks_per_node)
More information about the mpich2-commits
