[mpich2-commits] r5634 - mpich2/trunk/src/pm/smpd
    jayesh at mcs.anl.gov
    Fri Oct 30 12:40:10 CDT 2009
Author: jayesh
Date: 2009-10-30 12:40:10 -0500 (Fri, 30 Oct 2009)
New Revision: 5634
Modified:
   mpich2/trunk/src/pm/smpd/smpd.h
   mpich2/trunk/src/pm/smpd/smpd_affinitize.c
   mpich2/trunk/src/pm/smpd/smpd_cmd_args.c
Log:
Handling the case where we don't have info about logical procs on windows - eg: Win2K systems. If info about logical procs is not available we don't set proc affinity and allow these systems to continue working. See tickets 832,776
Modified: mpich2/trunk/src/pm/smpd/smpd.h
--- mpich2/trunk/src/pm/smpd/smpd.h	2009-10-30 16:24:47 UTC (rev 5633)
+++ mpich2/trunk/src/pm/smpd/smpd.h	2009-10-30 17:40:10 UTC (rev 5634)
@@ -980,7 +980,7 @@
 #ifdef HAVE_WINDOWS_H
 DWORD_PTR smpd_get_next_process_affinity_mask(void );
 DWORD_PTR smpd_get_processor_affinity_mask(int proc_num);
-void smpd_init_affinity_table(void );
+BOOL smpd_init_affinity_table(void );
 #endif
 #if defined(__cplusplus)
Modified: mpich2/trunk/src/pm/smpd/smpd_affinitize.c
--- mpich2/trunk/src/pm/smpd/smpd_affinitize.c	2009-10-30 16:24:47 UTC (rev 5633)
+++ mpich2/trunk/src/pm/smpd/smpd_affinitize.c	2009-10-30 17:40:10 UTC (rev 5634)
@@ -39,8 +39,10 @@
 DWORD_PTR smpd_get_next_process_affinity_mask()
     DWORD_PTR Mask;
-    if (s_affinity_max == 0)
+    if (s_affinity_max == 0){
+        smpd_dbg_printf("Affinity table not initialized. Returning invalid mask\n");
         return 0;
     Mask = s_affinity_table[s_affinity_idx % s_affinity_max];
     s_affinity_idx++;
@@ -245,45 +247,62 @@
     This function initilizes the affinity table.  The processor assignments to processes
     are distributed so as to balance the use of system resources.
-void smpd_init_affinity_table()
+typedef BOOL (WINAPI *LPFN_GetLogicalProcessorInformation)(PSYSTEM_LOGICAL_PROCESSOR_INFORMATION, PDWORD);
+BOOL smpd_init_affinity_table()
         Get this process affinity mask (the system mask is unused)
     int count, nTableEntries;
-    BOOL fSucc;
+    BOOL fSucc, retval = TRUE;
     DWORD Length;
     DWORD_PTR SystemMask, ReserveMask, PrimaryMask;
     DWORD_PTR UsableProcessorMask;
     SYSTEM_LOGICAL_PROCESSOR_INFORMATION* pInfo = NULL;
     ResourceTableEntry* pTable = NULL;
+    LPFN_GetLogicalProcessorInformation lpfn_get_logical_proc_info;
     fSucc = GetProcessAffinityMask(GetCurrentProcess(), &UsableProcessorMask, &SystemMask);
-    if(!fSucc)
-        return;
+    if(!fSucc){
+        return FALSE;
+    /* Check if GetLogicalProcessorInformation() is available */
+    lpfn_get_logical_proc_info =
+        (LPFN_GetLogicalProcessorInformation ) GetProcAddress(GetModuleHandle(TEXT("kernel32")),
+                                                    "GetLogicalProcessorInformation");
+    if(lpfn_get_logical_proc_info == NULL){
+        smpd_dbg_printf("GetLogicalProcessorInformation() not available\n");
+        return FALSE;
         Retrieve the length required to store the processor information data
     Length = 0;
-    /* FIXME: Check return val */
-    GetLogicalProcessorInformation(NULL, &Length);
-    if(Length == 0)
-        return;
+    /* This call will fail - however it will return the length reqd to store proc info*/
+    fSucc = lpfn_get_logical_proc_info(NULL, &Length);
+    if(Length == 0){
+        smpd_dbg_printf("GetLogicalProcessorInformation() returned invalid (0 bytes) length to store proc info\n");
+        return FALSE;
         Allocate the processor information buffer
     pInfo = (SYSTEM_LOGICAL_PROCESSOR_INFORMATION*) malloc(Length);
-    if(pInfo == NULL)
-        return;
+    if(pInfo == NULL){
+        smpd_err_printf("Allocating memory for system logical proc info failed\n");
+        return FALSE;
         Query for the processors information
-    fSucc = GetLogicalProcessorInformation(pInfo, &Length);
-    if(!fSucc)
-        goto fn_exit;
+    fSucc = lpfn_get_logical_proc_info(pInfo, &Length);
+    if(!fSucc){
+        smpd_err_printf("GetLogicalProcessorInformation() failed (error = %d)\n", GetLastError());
+        goto fn_fail;
     count = Length / sizeof(SYSTEM_LOGICAL_PROCESSOR_INFORMATION);
@@ -293,8 +312,10 @@
     qsort(pInfo, count, sizeof(SYSTEM_LOGICAL_PROCESSOR_INFORMATION), compare_proc_info);
     pTable = (ResourceTableEntry*) malloc(count * sizeof(ResourceTableEntry));
-    if (pTable == NULL)
-        goto fn_exit;
+    if (pTable == NULL){
+        smpd_err_printf("Allocating memory for Resourcetableentry failed\n");
+        goto fn_fail;
         Initialize resource table from the sorted PROCESSOR_INFORMATION array
@@ -325,8 +346,12 @@
     free(pTable);
-fn_exit:
+ fn_exit:
     free(pInfo);
+    return retval;
+fn_fail:
+    retval = FALSE;
+    goto fn_exit;
 /* This function returns an affinity mask corresponding to the logical processor
Modified: mpich2/trunk/src/pm/smpd/smpd_cmd_args.c
--- mpich2/trunk/src/pm/smpd/smpd_cmd_args.c	2009-10-30 16:24:47 UTC (rev 5633)
+++ mpich2/trunk/src/pm/smpd/smpd_cmd_args.c	2009-10-30 17:40:10 UTC (rev 5634)
@@ -445,8 +445,13 @@
 	    smpd_dbg_printf("unable to set the ctrl handler for the smpd manager, error %d.\n", result);
-    /* FIXME: smpd_init_affinity_table() Does not return error codes if it fails */
-    smpd_init_affinity_table();
+        BOOL ret;
+        ret = smpd_init_affinity_table();
+        if(!ret){
+            smpd_dbg_printf("Initializing smpd affinity table failed\n");
 #endif
 	smpd_process.bService = SMPD_FALSE;
More information about the mpich2-commits
