[mpich2-commits] r5620 - mpich2/trunk
jayesh at mcs.anl.gov
Thu Oct 29 16:38:32 CDT 2009
Author: jayesh
Date: 2009-10-29 16:38:32 -0500 (Thu, 29 Oct 2009)
New Revision: 5620
Modified:
mpich2/trunk/winconfigure.wsf
Log:
Adding C versions of MPI datatypes in fortran for windows - added in unix configure in r5479
Modified: mpich2/trunk/winconfigure.wsf
--- mpich2/trunk/winconfigure.wsf 2009-10-29 20:06:59 UTC (rev 5619)
+++ mpich2/trunk/winconfigure.wsf 2009-10-29 21:38:32 UTC (rev 5620)
@@ -1160,6 +1160,21 @@
F77_SHORT_INT = HexToInt(dtypes.Item("MPI_SHORT_INT"))
F77_2INT = HexToInt(dtypes.Item("MPI_2INT"))
F77_LONG_DOUBLE_INT = HexToInt(dtypes.Item("MPI_LONG_DOUBLE_INT"))
+F77_INT8_T = HexToInt(dtypes.Item("MPI_INT8_T"))
+F77_INT16_T = HexToInt(dtypes.Item("MPI_INT16_T"))
+F77_INT32_T = HexToInt(dtypes.Item("MPI_INT32_T"))
+F77_INT64_T = HexToInt(dtypes.Item("MPI_INT64_T"))
+F77_UINT8_T = HexToInt(dtypes.Item("MPI_UINT8_T"))
+F77_UINT16_T = HexToInt(dtypes.Item("MPI_UINT16_T"))
+F77_UINT32_T = HexToInt(dtypes.Item("MPI_UINT32_T"))
+F77_UINT64_T = HexToInt(dtypes.Item("MPI_UINT64_T"))
+F77_C_BOOL = HexToInt(dtypes.Item("MPI_C_BOOL"))
+F77_C_FLOAT_COMPLEX = HexToInt(dtypes.Item("MPI_C_FLOAT_COMPLEX"))
+F77_C_COMPLEX = HexToInt(dtypes.Item("MPI_C_COMPLEX"))
+F77_C_DOUBLE_COMPLEX = HexToInt(dtypes.Item("MPI_C_DOUBLE_COMPLEX"))
+F77_C_LONG_DOUBLE_COMPLEX = HexToInt(dtypes.Item("MPI_C_LONG_DOUBLE_COMPLEX"))
+F77_AINT = HexToInt(dtypes.Item("MPI_AINT"))
+F77_OFFSET = HexToInt(dtypes.Item("MPI_OFFSET"))
if false then
foo = ""
@@ -1858,6 +1873,36 @@
str = Replace(str, "@MPI_F77_2INT@", F77_2INT)
Case "@MPI_F77_LONG_DOUBLE_INT@"
str = Replace(str, "@MPI_F77_LONG_DOUBLE_INT@", F77_LONG_DOUBLE_INT)
+ Case "@MPI_F77_INT8_T@"
+ str = Replace(str, "@MPI_F77_INT8_T@", F77_INT8_T)
+ Case "@MPI_F77_INT16_T@"
+ str = Replace(str, "@MPI_F77_INT16_T@", F77_INT16_T)
+ Case "@MPI_F77_INT32_T@"
+ str = Replace(str, "@MPI_F77_INT32_T@", F77_INT32_T)
+ Case "@MPI_F77_INT64_T@"
+ str = Replace(str, "@MPI_F77_INT64_T@", F77_INT64_T)
+ Case "@MPI_F77_UINT8_T@"
+ str = Replace(str, "@MPI_F77_UINT8_T@", F77_UINT8_T)
+ Case "@MPI_F77_UINT16_T@"
+ str = Replace(str, "@MPI_F77_UINT16_T@", F77_UINT16_T)
+ Case "@MPI_F77_UINT32_T@"
+ str = Replace(str, "@MPI_F77_UINT32_T@", F77_UINT32_T)
+ Case "@MPI_F77_UINT64_T@"
+ str = Replace(str, "@MPI_F77_UINT64_T@", F77_UINT64_T)
+ Case "@MPI_F77_C_BOOL@"
+ str = Replace(str, "@MPI_F77_C_BOOL@", F77_C_BOOL)
+ Case "@MPI_F77_C_FLOAT_COMPLEX@"
+ str = Replace(str, "@MPI_F77_C_FLOAT_COMPLEX@", F77_C_FLOAT_COMPLEX)
+ Case "@MPI_F77_C_COMPLEX@"
+ str = Replace(str, "@MPI_F77_C_COMPLEX@", F77_C_COMPLEX)
+ Case "@MPI_F77_C_DOUBLE_COMPLEX@"
+ str = Replace(str, "@MPI_F77_C_DOUBLE_COMPLEX@", F77_C_DOUBLE_COMPLEX)
+ Case "@MPI_F77_C_LONG_DOUBLE_COMPLEX@"
+ str = Replace(str, "@MPI_F77_C_LONG_DOUBLE_COMPLEX@", F77_C_LONG_DOUBLE_COMPLEX)
+ Case "@MPI_F77_AINT@"
+ str = Replace(str, "@MPI_F77_AINT@", F77_AINT)
+ Case "@MPI_F77_OFFSET@"
+ str = Replace(str, "@MPI_F77_OFFSET@", F77_OFFSET)
Case "@MPI_STATUS_SIZE@"
str = Replace(str, "@MPI_STATUS_SIZE@", "5")
Case "@HAVE_CXX_EXCEPTIONS@"
More information about the mpich2-commits
