[mpich2-commits] r5617 - mpich2/trunk/maint
balaji at mcs.anl.gov
Thu Oct 29 14:40:01 CDT 2009
Author: balaji
Date: 2009-10-29 14:40:01 -0500 (Thu, 29 Oct 2009)
New Revision: 5617
Modified:
mpich2/trunk/maint/updatefiles
Log:
Allow --with-libtool option and MPICH2_LIBTOOL_DIR environment for
maint/updatefiles.
Modified: mpich2/trunk/maint/updatefiles
--- mpich2/trunk/maint/updatefiles 2009-10-29 19:35:24 UTC (rev 5616)
+++ mpich2/trunk/maint/updatefiles 2009-10-29 19:40:01 UTC (rev 5617)
@@ -38,6 +38,7 @@
# Allow MAKE to be set from the environment
MAKE=${MAKE-make}
+ltdirs="src/pm/hydra/tools/bind/hwloc/hwloc"
amdirs="src/openpa src/pm/hydra src/mpl"
# List of steps that we will consider
@@ -45,21 +46,12 @@
AllSteps="geterrmsgs bindings f77 f77tof90 build_configure genstates makefiles smpdversion getparms"
stepsCleared=no
-# Options for some steps
-autoconfdir=""
-automakedir=""
-autotoolsdir=""
# Extract defaults from the environment
-if [ "x$MPICH2_AUTOCONF_DIR" != "x" ] ; then
- autoconfdir=$MPICH2_AUTOCONF_DIR
-fi
-if [ "x$MPICH2_AUTOMAKE_DIR" != "x" ] ; then
- automakedir=$MPICH2_AUTOMAKE_DIR
-fi
-if [ "x$MPICH2_AUTOTOOLS_DIR" != "x" ] ; then
- autotoolsdir=$MPICH2_AUTOTOOLS_DIR
-fi
+autoconfdir=$MPICH2_AUTOCONF_DIR
+automakedir=$MPICH2_AUTOMAKE_DIR
+libtooldir=$MPICH2_LIBTOOL_DIR
+autotoolsdir=$MPICH2_AUTOTOOLS_DIR
# Extract the arguments intended for updatefiles. Any others are
# given to simplemake.
temp_args=""
@@ -130,6 +122,9 @@
-with-automake=*|--with-automake=*)
automakedir=`echo "A$arg" | sed -e 's/.*=//'`
+ -with-libtool=*|--with-libtool=*)
+ libtooldir=`echo "A$arg" | sed -e 's/.*=//'`
-with-autotools=*|--with-autotools=*)
autotoolsdir=`echo "A$arg" | sed -e 's/.*=//'`
@@ -143,17 +138,18 @@
-help|--help|-usage|--usage)
cat <<EOF
updatefiles [ --with-autoconf=dir ] [ --with-automake=dir ] \\
- [ --with-autotools=dir ] [ --do=stepname ] \\
- [ args for simplemake ]
+ [ --with-libtool=dir ] [ --with-autotools=dir ] \\
+ [ --do=stepname ] [ args for simplemake ]
Update the files in the MPICH2 build tree. This file builds the
configure files, creates the Makefile.in files (using the simplemake
program), extracts the error messages.
- You can use --with-autoconf=dir to specify a directory that contains
- an alternate autoconf and autoheader. Similarly --with-automake can
- be used to specify the location of automake and aclocal. If
- autoconf and automake are installed in the same location, they can
- be specified by the --with-autotools option.
+ You can use --with-autoconf=dir to specify a directory that
+ contains an alternate autoconf and autoheader. Similarly
+ --with-automake can be used to specify the location of automake
+ and aclocal and --with-libtool to specify the location of
+ libtoolize. If all the autotools are installed in the same
+ location, they can be specified by the --with-autotools option.
Use --do=stepname to update only a single step. For example,
--do=build_configure only updates the configure scripts. The available
@@ -172,22 +168,24 @@
done
if [ -n "$autotoolsdir" ] ; then
- if [ -n "$autoconfdir" -o -n "$automakedir" ] ; then
- # Don't permit --with-autotools together with either --with-autoconf or
- # --with-automake because which argument takes precedence is not obvious
- # without immediate explanation. --with-autotools is really only
- # present to make life a little easier for those who preferred the old
- # behavior where --with-autoconf was used to specify the location of
- # both autoconf and automake.
+ if [ -n "$autoconfdir" -o -n "$automakedir" -o -n "$libtooldir" ] ; then
+ # Don't permit --with-autotools together with --with-autoconf,
+ # --with-automake or --with-libtool because which argument
+ # takes precedence is not obvious without immediate
+ # explanation. --with-autotools is really only present to
+ # make life a little easier for those who preferred the old
+ # behavior where --with-autoconf was used to specify the
+ # location of both autoconf and automake.
cat <<EOT
-Error: --with-autotools was specified together with either
---with-autoconf or --with-automake. --with-autotools is incompatible
-with the other two options. Please specify only one set or the other.
+Error: --with-autotools was specified together with --with-autoconf,
+--with-automake or --with-libtool. --with-autotools is incompatible
+with the other options. Please specify only one set or the other.
EOT
exit 1
else
autoconfdir=$autotoolsdir
automakedir=$autotoolsdir
+ libtooldir=$autotoolsdir
fi
fi
@@ -269,6 +267,18 @@
automake=${AUTOMAKE:-automake}
aclocal=${ACLOCAL:-aclocal}
fi
+if [ -n "$libtooldir" ] ; then
+ if [ -x "$libtooldir/libtoolize" ] ; then
+ libtoolize=$libtooldir/libtoolize
+ LIBTOOLIZE=$libtoolize
+ export LIBTOOLIZE
+ else
+ echo "could not find executable libtoolize in $libtooldir"
+ exit 1
+ fi
+else
+ libtoolize=${LIBTOOLIZE:-libtoolize}
+fi
# Check that you have a working autoconf. Autoconf 2.57 is not compatible with
@@ -874,6 +884,14 @@
if [ "$do_build_configure" = "yes" -o "$do_makefiles" = "yes" ] ; then
# must come after the above autoreconf-like logic because the above
# logic will delete the results of this actual autoreconf
+ for ltdir in $ltdirs ; do
+ if [ -d "$ltdir" -o -L "$ltdir" ] ; then
+ echo "running $libtoolize in $ltdir"
+ (cd $ltdir && $libtoolize) || exit 1
+ fi
+ done
for amdir in $amdirs ; do
if [ -d "$amdir" -o -L "$amdir" ] ; then
echo "running $autoreconf in $amdir"
More information about the mpich2-commits
