[mpich2-commits] r5605 - mpich2/trunk/src/mpi/errhan
goodell at mcs.anl.gov goodell at mcs.anl.gov
Wed Oct 28 18:24:44 CDT 2009
Author: goodell
Date: 2009-10-28 18:24:44 -0500 (Wed, 28 Oct 2009)
New Revision: 5605
Modified:
   mpich2/trunk/src/mpi/errhan/comm_set_errhandler.c
   mpich2/trunk/src/mpi/errhan/win_set_errhandler.c
Log:
Fix MPI_Comm/MPI_Win errhandler leak.
Prior to this commit we only released references to previously set comm
and win errhandlers in MPI_{Comm,Win}_set_errhandler if the newly set
errhandler was *not* builtin.  This resulted in an errhandler object
leak if a user-defined errhandler was set and then a predefined
errhandler was set afterwards.
Reviewed by buntinas at .
Modified: mpich2/trunk/src/mpi/errhan/comm_set_errhandler.c
--- mpich2/trunk/src/mpi/errhan/comm_set_errhandler.c	2009-10-28 23:24:42 UTC (rev 5604)
+++ mpich2/trunk/src/mpi/errhan/comm_set_errhandler.c	2009-10-28 23:24:44 UTC (rev 5605)
@@ -97,19 +97,17 @@
 #   endif /* HAVE_ERROR_CHECKING */
     /* ... body of routine ...  */
     /* We don't bother with the case where the errhandler is NULL;
        in this case, the error handler was the original, MPI_ERRORS_ARE_FATAL,
        which is builtin and can never be freed. */
     if (comm_ptr->errhandler != NULL) {
-	if (HANDLE_GET_KIND(errhandler) != HANDLE_KIND_BUILTIN) {
-	    MPIR_Errhandler_release_ref(comm_ptr->errhandler,&in_use);
-	    if (!in_use) {
-		MPID_Errhandler_free( comm_ptr->errhandler );
+        MPIR_Errhandler_release_ref(comm_ptr->errhandler,&in_use);
+        if (!in_use) {
+            MPID_Errhandler_free( comm_ptr->errhandler );
     MPIR_Errhandler_add_ref(errhan_ptr);
     comm_ptr->errhandler = errhan_ptr;
Modified: mpich2/trunk/src/mpi/errhan/win_set_errhandler.c
--- mpich2/trunk/src/mpi/errhan/win_set_errhandler.c	2009-10-28 23:24:42 UTC (rev 5604)
+++ mpich2/trunk/src/mpi/errhan/win_set_errhandler.c	2009-10-28 23:24:44 UTC (rev 5605)
@@ -102,19 +102,17 @@
     if (win_ptr->errhandler != NULL) {
-	    MPIR_Errhandler_release_ref(win_ptr->errhandler,&in_use);
-	    if (!in_use) {
-		MPID_Errhandler_free( win_ptr->errhandler );
+        MPIR_Errhandler_release_ref(win_ptr->errhandler,&in_use);
+        if (!in_use) {
+            MPID_Errhandler_free( win_ptr->errhandler );
     win_ptr->errhandler = errhan_ptr;
     /* ... end of body of routine ... */
 #ifdef HAVE_ERROR_CHECKING
More information about the mpich2-commits mailing list
