[mpich2-commits] r5603 - in mpich2/trunk: maint src/include
    buntinas at mcs.anl.gov
    Wed Oct 28 16:56:56 CDT 2009
Author: buntinas
Date: 2009-10-28 16:56:56 -0500 (Wed, 28 Oct 2009)
New Revision: 5603
Modified:
   mpich2/trunk/maint/extracterrmsgs
   mpich2/trunk/src/include/mpierrs.h
Log:
Added more fatal error macros.
Modified: mpich2/trunk/maint/extracterrmsgs
--- mpich2/trunk/maint/extracterrmsgs	2009-10-28 20:31:10 UTC (rev 5602)
+++ mpich2/trunk/maint/extracterrmsgs	2009-10-28 21:56:56 UTC (rev 5603)
@@ -593,14 +593,15 @@
 	# Match the known routines and macros.
 	# Then check that the arguments match if there is a
 	# specific string (number of args matches the number present)
-	# (MPIU_ERR_CHKANDJUMP[0-4]?(cond,code,class,gmsg[,smsg,args])
-	# (MPIU_ERR_SETANDJUMP[0-4]?(code,class,gmsg[,smsg,args])
-	# (MPIU_ERR_CHKANDSTMT[0-4]?(cond,code,class,stmt,gmsg[,smsg,args])
-	# (MPIU_ERR_SETANDSTMT[0-4]?(code,class,stmt,gmsg[,smsg,args])
+        # MPIU_ERR_CHK(FATAL)?ANDJUMP[1-4]?(cond,code,class,gmsg[,smsg,args])
+        # MPIU_ERR_SET(FATAL)?ANDJUMP[1-4]?(code,class,gmsg[,smsg,args])
+	# MPIU_ERR_CHK(FATAL)?ANDSTMT[1-4]?(cond,code,class,stmt,gmsg[,smsg,args])
+	# MPIU_ERR_SET(FATAL)?ANDSTMT[1-4]?(code,class,stmt,gmsg[,smsg,args])
 	# Value is a tuple of:
 	#  the count of args where the generic msg begins (starting from 0)
 	#  location of __LINE__ (-1 for none)
 	#  specific msg arg required (0 for no, > 0 for yes)
+	#  is the generic message an indirect from errnames.txt (1=yes 0=no)
 	%KnownErrRoutines = ( 'MPIR_Err_create_code'      => '5:3:1:1',
 			      'MPIO_Err_create_code'      => '5:3:1:0',
 			      'MPIU_ERR_SET'              => '2:-1:0:1',
@@ -608,18 +609,10 @@
 			      'MPIU_ERR_SET1'             => '2:-1:1:1',
 			      'MPIU_ERR_SET2'             => '2:-1:2:1',
 			      'MPIU_ERR_SETANDSTMT'       => '3:-1:0:1',
-			      'MPIU_ERR_SETFATALANDSTMT'  => '3:-1:0:1',
-			      'MPIU_ERR_SETFATALANDJUMP'  => '2:-1:0:1',
 			      'MPIU_ERR_SETANDSTMT1'      => '3:-1:1:1',
-			      'MPIU_ERR_SETFATALANDSTMT1' => '3:-1:1:1',
-			      'MPIU_ERR_SETFATALANDJUMP1' => '2:-1:1:1',
 			      'MPIU_ERR_SETANDSTMT2'      => '3:-1:1:1',
-			      'MPIU_ERR_SETFATALANDSTMT2' => '3:-1:1:1',
-			      'MPIU_ERR_SETFATALANDJUMP2' => '2:-1:1:1',
 			      'MPIU_ERR_SETANDSTMT3'      => '3:-1:1:1',
-			      'MPIU_ERR_SETFATALANDSTMT3' => '3:-1:1:1',
 			      'MPIU_ERR_SETANDSTMT4'      => '3:-1:1:1',
-			      'MPIU_ERR_SETFATALANDSTMT4' => '3:-1:1:1',
 			      'MPIU_ERR_SETANDJUMP'       => '2:-1:0:1',
 			      'MPIU_ERR_SETANDJUMP1'      => '2:-1:1:1',
 			      'MPIU_ERR_SETANDJUMP2'      => '2:-1:1:1',
@@ -635,6 +628,30 @@
 			      'MPIU_ERR_CHKANDJUMP2'      => '3:-1:1:1',
 			      'MPIU_ERR_CHKANDJUMP3'      => '3:-1:1:1',
 			      'MPIU_ERR_CHKANDJUMP4'      => '3:-1:1:1',
+			      'MPIU_ERR_SETFATAL'         => '2:-1:0:1',
+			      'MPIU_ERR_SETFATALSIMPLE'   => '2:-1:0:1',
+			      'MPIU_ERR_SETFATAL1'        => '2:-1:1:1',
+			      'MPIU_ERR_SETFATAL2'        => '2:-1:2:1',
+			      'MPIU_ERR_SETFATALANDSTMT'  => '3:-1:0:1',
+			      'MPIU_ERR_SETFATALANDSTMT1' => '3:-1:1:1',
+			      'MPIU_ERR_SETFATALANDSTMT2' => '3:-1:1:1',
+			      'MPIU_ERR_SETFATALANDSTMT3' => '3:-1:1:1',
+			      'MPIU_ERR_SETFATALANDSTMT4' => '3:-1:1:1',
+			      'MPIU_ERR_SETFATALANDJUMP'  => '2:-1:0:1',
+			      'MPIU_ERR_SETFATALANDJUMP1' => '2:-1:1:1',
+			      'MPIU_ERR_SETFATALANDJUMP2' => '2:-1:1:1',
+			      'MPIU_ERR_SETFATALANDJUMP3' => '2:-1:1:1',
+			      'MPIU_ERR_SETFATALANDJUMP4' => '2:-1:1:1',
+			      'MPIU_ERR_CHKFATALANDSTMT'  => '4:-1:0:1',
+			      'MPIU_ERR_CHKFATALANDSTMT1' => '4:-1:1:1',
+			      'MPIU_ERR_CHKFATALANDSTMT2' => '4:-1:1:1',
+			      'MPIU_ERR_CHKFATALANDSTMT3' => '4:-1:1:1',
+			      'MPIU_ERR_CHKFATALANDSTMT4' => '4:-1:1:1',
+			      'MPIU_ERR_CHKFATALANDJUMP'  => '3:-1:0:1',
+			      'MPIU_ERR_CHKFATALANDJUMP1' => '3:-1:1:1',
+			      'MPIU_ERR_CHKFATALANDJUMP2' => '3:-1:1:1',
+			      'MPIU_ERR_CHKFATALANDJUMP3' => '3:-1:1:1',
+			      'MPIU_ERR_CHKFATALANDJUMP4' => '3:-1:1:1',
 			      'MPIR_ERRTEST_VALID_HANDLE' => '4:-1:0:1',
 	while (/(MPI[OUR]_E[A-Za-z0-9_]+)\s*(\(.*)$/) {
Modified: mpich2/trunk/src/include/mpierrs.h
--- mpich2/trunk/src/include/mpierrs.h	2009-10-28 20:31:10 UTC (rev 5602)
+++ mpich2/trunk/src/include/mpierrs.h	2009-10-28 21:56:56 UTC (rev 5603)
@@ -425,6 +425,19 @@
 #define MPIU_ERR_SETANDSTMT4(err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_, arg3_, arg4_) \
     {err_ = MPIR_Err_create_code( err_,MPIR_ERR_RECOVERABLE,FCNAME,\
 	    __LINE__, class_, gmsg_, smsg_, arg1_, arg2_, arg3_, arg4_ ); stmt_ ;}
+#define MPIU_ERR_SETFATALSIMPLE(err_,class_,msg_) \
+    err_ = MPIR_Err_create_code( MPI_SUCCESS,MPIR_ERR_FATAL,FCNAME,     \
+           __LINE__, class_, msg_, 0 )
+#define MPIU_ERR_SETFATAL(err_,class_,msg_) \
+    err_ = MPIR_Err_create_code( err_,MPIR_ERR_FATAL,FCNAME,\
+#define MPIU_ERR_SETFATAL1(err_,class_,gmsg_,smsg_,arg1_) \
+           __LINE__, class_, gmsg_, smsg_, arg1_ )
+#define MPIU_ERR_SETFATAL2(err_,class_,gmsg_,smsg_,arg1_,arg2_) \
+           __LINE__, class_, gmsg_, smsg_, arg1_, arg2_ )
 #define MPIU_ERR_SETFATALANDSTMT(err_,class_,stmt_,msg_) \
     {err_ = MPIR_Err_create_code( err_,MPIR_ERR_FATAL,FCNAME,\
            __LINE__, class_, msg_, 0 ); stmt_ ;}
@@ -463,6 +476,15 @@
      MPIU_ERR_SETANDSTMT(err_,class_,stmt_,gmsg_)
 #define MPIU_ERR_SETANDSTMT4(err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_) \
+    {err_ = class_;}
+     {if (!err_){err_=class_;}}
+      MPIU_ERR_SET(err_,class_,msg_)
      MPIU_ERR_SETANDSTMT(err_,class_,stmt_,msg_)
 #define MPIU_ERR_SETFATALANDSTMT1(err_,class_,stmt_,gmsg_,smsg_,arg1_) \
@@ -485,8 +507,12 @@
      MPIU_ERR_SETFATALANDSTMT(err_,class_,goto fn_fail,msg_)
 #define MPIU_ERR_CHKANDSTMT(cond_,err_,class_,stmt_,msg_) \
     {if (cond_) { MPIU_ERR_SETANDSTMT(err_,class_,stmt_,msg_); }}
+#define MPIU_ERR_CHKFATALANDSTMT(cond_,err_,class_,stmt_,msg_) \
+    {if (cond_) { MPIU_ERR_SETFATALANDSTMT(err_,class_,stmt_,msg_); }}
 #define MPIU_ERR_CHKANDJUMP(cond_,err_,class_,msg_) \
      MPIU_ERR_CHKANDSTMT(cond_,err_,class_,goto fn_fail,msg_)
+#define MPIU_ERR_CHKFATALANDJUMP(cond_,err_,class_,msg_) \
+     MPIU_ERR_CHKFATALANDSTMT(cond_,err_,class_,goto fn_fail,msg_)
 #define MPIU_ERR_SETANDJUMP1(err_,class_,gmsg_,smsg_,arg1_) \
      MPIU_ERR_SETANDSTMT1(err_,class_,goto fn_fail,gmsg_,smsg_,arg1_)
@@ -494,8 +520,12 @@
      MPIU_ERR_SETFATALANDSTMT1(err_,class_,goto fn_fail,gmsg_,smsg_,arg1_)
 #define MPIU_ERR_CHKANDSTMT1(cond_,err_,class_,stmt_,gmsg_,smsg_,arg1_) \
     {if (cond_) { MPIU_ERR_SETANDSTMT1(err_,class_,stmt_,gmsg_,smsg_,arg1_); }}
+#define MPIU_ERR_CHKFATALANDSTMT1(cond_,err_,class_,stmt_,gmsg_,smsg_,arg1_) \
+    {if (cond_) { MPIU_ERR_SETFATALANDSTMT1(err_,class_,stmt_,gmsg_,smsg_,arg1_); }}
 #define MPIU_ERR_CHKANDJUMP1(cond_,err_,class_,gmsg_,smsg_,arg1_) \
      MPIU_ERR_CHKANDSTMT1(cond_,err_,class_,goto fn_fail,gmsg_,smsg_,arg1_)
+#define MPIU_ERR_CHKFATALANDJUMP1(cond_,err_,class_,gmsg_,smsg_,arg1_) \
+     MPIU_ERR_CHKFATALANDSTMT1(cond_,err_,class_,goto fn_fail,gmsg_,smsg_,arg1_)
 #define MPIU_ERR_SETANDJUMP2(err_,class_,gmsg_,smsg_,arg1_,arg2_) \
      MPIU_ERR_SETANDSTMT2(err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_)
@@ -503,22 +533,38 @@
      MPIU_ERR_SETFATALANDSTMT2(err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_)
 #define MPIU_ERR_CHKANDSTMT2(cond_,err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_) \
     {if (cond_) { MPIU_ERR_SETANDSTMT2(err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_); }}
+#define MPIU_ERR_CHKFATALANDSTMT2(cond_,err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_) \
+    {if (cond_) { MPIU_ERR_SETFATALANDSTMT2(err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_); }}
 #define MPIU_ERR_CHKANDJUMP2(cond_,err_,class_,gmsg_,smsg_,arg1_,arg2_) \
      MPIU_ERR_CHKANDSTMT2(cond_,err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_)
+#define MPIU_ERR_CHKFATALANDJUMP2(cond_,err_,class_,gmsg_,smsg_,arg1_,arg2_) \
+     MPIU_ERR_CHKFATALANDSTMT2(cond_,err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_)
 #define MPIU_ERR_SETANDJUMP3(err_,class_,gmsg_,smsg_,arg1_,arg2_,arg3_) \
      MPIU_ERR_SETANDSTMT3(err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_,arg3_)
+#define MPIU_ERR_SETFATALANDJUMP3(err_,class_,gmsg_,smsg_,arg1_,arg2_,arg3_) \
+     MPIU_ERR_SETFATALANDSTMT3(err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_,arg3_)
 #define MPIU_ERR_CHKANDSTMT3(cond_,err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_) \
     {if (cond_) { MPIU_ERR_SETANDSTMT3(err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_); }}
+#define MPIU_ERR_CHKFATALANDSTMT3(cond_,err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_) \
+    {if (cond_) { MPIU_ERR_SETFATALANDSTMT3(err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_); }}
 #define MPIU_ERR_CHKANDJUMP3(cond_,err_,class_,gmsg_,smsg_,arg1_,arg2_,arg3_) \
      MPIU_ERR_CHKANDSTMT3(cond_,err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_,arg3_)
+#define MPIU_ERR_CHKFATALANDJUMP3(cond_,err_,class_,gmsg_,smsg_,arg1_,arg2_,arg3_) \
+     MPIU_ERR_CHKFATALANDSTMT3(cond_,err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_,arg3_)
 #define MPIU_ERR_SETANDJUMP4(err_,class_,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_) \
      MPIU_ERR_SETANDSTMT4(err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_)
+#define MPIU_ERR_SETFATALANDJUMP4(err_,class_,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_) \
+     MPIU_ERR_SETFATALANDSTMT4(err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_)
 #define MPIU_ERR_CHKANDSTMT4(cond_,err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_, arg4_) \
     {if (cond_) { MPIU_ERR_SETANDSTMT4(err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_); }}
+#define MPIU_ERR_CHKFATALANDSTMT4(cond_,err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_, arg4_) \
+    {if (cond_) { MPIU_ERR_SETFATALANDSTMT4(err_,class_,stmt_,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_); }}
 #define MPIU_ERR_CHKANDJUMP4(cond_,err_,class_,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_) \
      MPIU_ERR_CHKANDSTMT4(cond_,err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_)
+#define MPIU_ERR_CHKFATALANDJUMP4(cond_,err_,class_,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_) \
+     MPIU_ERR_CHKFATALANDSTMT4(cond_,err_,class_,goto fn_fail,gmsg_,smsg_,arg1_,arg2_,arg3_,arg4_)
 /* --END ERROR MACROS-- */
More information about the mpich2-commits
