[mpich2-commits] r5594 - mpich2/trunk/src/pm/hydra/tools/bind/hwloc
mercierg at mcs.anl.gov mercierg at mcs.anl.gov
Wed Oct 28 11:10:55 CDT 2009
Author: mercierg
Date: 2009-10-28 11:10:55 -0500 (Wed, 28 Oct 2009)
New Revision: 5594
Modified:
   mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
Log:
New version of the Hwloc binding file: lot of fixes!
Modified: mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c
--- mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c	2009-10-28 08:49:48 UTC (rev 5593)
+++ mpich2/trunk/src/pm/hydra/tools/bind/hwloc/bind_hwloc.c	2009-10-28 16:10:55 UTC (rev 5594)
@@ -14,15 +14,20 @@
 HYD_status HYDT_bind_hwloc_init(HYDT_bind_support_level_t * support_level)
-    int proc,sock,core,thread,i,j;
-    int num_cores = 0;
-    int my_num_cores;
-    int my_num_threads;
-    hwloc_obj_t    obj_sock,obj_core,obj_proc;
-    hwloc_obj_t    prev_obj = NULL;
-    hwloc_cpuset_t cpuset_sock,cpuset_core;
+    hwloc_obj_t    obj_sys;
+    hwloc_obj_t    obj_node;
+    hwloc_obj_t    obj_sock;
+    hwloc_obj_t    obj_core;
+    hwloc_obj_t    obj_proc;
+    hwloc_obj_t    prev_obj;
+    hwloc_cpuset_t cpuset_sys;
+    hwloc_cpuset_t cpuset_node;
+    hwloc_cpuset_t cpuset_sock;
+    hwloc_cpuset_t cpuset_core;
+    int node,sock,core,proc,thread;
+    int bound,bound2;
     HYD_status status = HYD_SUCCESS;
     HYDU_FUNC_ENTER();
@@ -32,107 +37,115 @@
     /* Get the max number of processing elements */
     HYDT_bind_info.num_procs = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_PROC);
     HYDU_MALLOC(HYDT_bind_info.topology, struct HYDT_topology *,
                 HYDT_bind_info.num_procs * sizeof(struct HYDT_topology), status);
-    for (i = 0; i < HYDT_bind_info.num_procs; i++) {
-        HYDT_bind_info.topology[i].processor_id = -1;
-        HYDT_bind_info.topology[i].socket_rank = -1;
-        HYDT_bind_info.topology[i].socket_id = -1;
-        HYDT_bind_info.topology[i].core_rank = -1;
-        HYDT_bind_info.topology[i].core_id = -1;
-        HYDT_bind_info.topology[i].thread_rank = -1;
-        HYDT_bind_info.topology[i].thread_id = -1;
+    for (proc = 0; proc < HYDT_bind_info.num_procs; proc++) {
+        HYDT_bind_info.topology[proc].processor_id = -1;
+        HYDT_bind_info.topology[proc].socket_rank  = -1;
+        HYDT_bind_info.topology[proc].socket_id    = -1;
+        HYDT_bind_info.topology[proc].core_rank    = -1;
+        HYDT_bind_info.topology[proc].core_id      = -1;
+        HYDT_bind_info.topology[proc].thread_rank  = -1;
+        HYDT_bind_info.topology[proc].thread_id    = -1;
-    do{
-	obj_proc = hwloc_get_next_obj_by_type(topology,HWLOC_OBJ_PROC,prev_obj);
-	if (!obj_proc) {
-            /* Unable to get processor ID */
-            HYDU_warn_printf("hwloc get processor id failed\n");
-            if (HYDT_bind_info.topology)
-                HYDU_FREE(HYDT_bind_info.topology);
-            goto fn_fail;
-	HYDT_bind_info.topology[i].processor_id = obj_proc->os_index;
-	prev_obj = obj_proc;
-    }while(prev_obj);
+    proc     = 0;
+    prev_obj = NULL;
+    while(obj_proc = hwloc_get_next_obj_by_type(topology,HWLOC_OBJ_PROC,prev_obj))
+            HYDT_bind_info.topology[proc].processor_id = obj_proc->os_index;
+            prev_obj = obj_proc;
+            proc++;
+    assert(proc == HYDT_bind_info.num_procs);
     /* We have qualified for basic binding support level */
     *support_level = HYDT_BIND_BASIC;
+    /* get the System object */
+    obj_sys = hwloc_get_system_obj(topology);
+    cpuset_sys = obj_sys->cpuset;
     /* Compute the total number of sockets */
-    HYDT_bind_info.num_sockets = hwloc_get_nbobjs_by_type(topology, HWLOC_OBJ_SOCKET);
-    assert(HYDT_bind_info.num_sockets);
+    /* FIX ME : We assume that the number of sockets is the same for each node (e.g node 0)!*/
+    obj_node = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sys,HWLOC_OBJ_NODE,0);
+    HYDT_bind_info.num_sockets = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_node->cpuset,HWLOC_OBJ_SOCKET);
-    /* Compute the total number of cores */
-    my_num_cores = hwloc_get_nbobjs_by_type(topology, HWLOC_OBJ_CORE);
-    assert(my_num_cores);
-    /* Compute again the total number of cores */
-    for(i=0; i< HYDT_bind_info.num_sockets ; i++)
-	    obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,i);
-	    num_cores += hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE);
+    /* Compute the number of cores per socket */
+    /* FIX ME : We assume that the number of CORES is the same for each SOCKET (e.g sock 0)!*/
+    obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,0);
+    HYDT_bind_info.num_cores = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE);
-    /* if this fails, it means that the number of cores */
-    /* per socket is not always the same !*/
-    assert(my_num_cores == num_cores);
+    HYDT_bind_info.num_threads = (HYDT_bind_info.num_procs/(hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_CORE)));
-    HYDT_bind_info.num_cores = my_num_cores/HYDT_bind_info.num_sockets;
-    /* Alternate version : We take the amount on socket 0 as the reference */
-    obj_sock = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,0);
-    HYDT_bind_info.num_cores = hwloc_get_nbobjs_inside_cpuset_by_type(topology,&(obj_sock->cpuset),HWLOC_OBJ_CORE);
+            for(node = 0, bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_NODE); node < bound ; node++)
+                    obj_node = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sys,HWLOC_OBJ_NODE,node);
+                    cpuset_node = obj_node->cpuset;
-    my_num_threads = HYDT_bind_info.num_procs/my_num_cores;
-    /* Alternate version */
-    HYDT_bind_info.num_threads = HYDT_bind_info.num_procs /
-        (HYDT_bind_info.num_sockets * HYDT_bind_info.num_cores);
+                    if(hwloc_cpuset_isset (cpuset_node, HYDT_bind_info.topology[proc].processor_id))
+                            for(sock = 0, bound = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_node->cpuset,HWLOC_OBJ_SOCKET) ; sock < bound ; sock++)
+                                    obj_sock = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_node,HWLOC_OBJ_SOCKET,sock);
+                                    cpuset_sock  = obj_sock->cpuset;
-    /* these should be the same */
-    assert(HYDT_bind_info.num_threads == my_num_threads);
+                                    if(hwloc_cpuset_isset (cpuset_sock, HYDT_bind_info.topology[proc].processor_id))
+                                            for(core = 0, bound2 = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE) ; core < bound2; core+\
+                                                    obj_core = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sock,HWLOC_OBJ_CORE,core);
+                                                    cpuset_core  = obj_core->cpuset;
-    /* Find the socket and core IDs for all processor IDs */
-    for(sock = 0 ; sock < HYDT_bind_info.num_sockets; sock++)
-	    obj_sock  = hwloc_get_obj_by_type(topology,HWLOC_OBJ_SOCKET,sock);
-	    cpuset_sock  = obj_sock->cpuset;
-	    num_cores = hwloc_get_nbobjs_inside_cpuset_by_type(topology,obj_sock->cpuset,HWLOC_OBJ_CORE);
+                                                    if (hwloc_cpuset_isset (cpuset_core, HYDT_bind_info.topology[proc].processor_id))
+							    int j;
+                                                            /* HYDT_bind_info.topology[proc].node_id   = obj_node->os_index;*/
+                                                            HYDT_bind_info.topology[proc].socket_id = obj_sock->os_index;
+                                                            HYDT_bind_info.topology[proc].core_id   = obj_core->os_index;
-	    for(core = 0 ; core < num_cores; core++)
-		    obj_core = hwloc_get_obj_inside_cpuset_by_type(topology,cpuset_sock,HWLOC_OBJ_CORE,core);
-		    cpuset_core  = obj_core->cpuset;
-		    for (proc = 0; proc < HYDT_bind_info.num_procs; proc++)
-			    if((hwloc_cpuset_isset (cpuset_sock, proc)) &&
-			       (hwloc_cpuset_isset (cpuset_core, proc)))
-				    HYDT_bind_info.topology[proc].socket_id = sock;
-				    HYDT_bind_info.topology[proc].core_id   = core;
-				    thread = -1;
-				    for (j = 0; j < proc; j++)
-					if ((HYDT_bind_info.topology[j].socket_id == sock) &&
-					    (HYDT_bind_info.topology[j].core_id   == core))
-					    thread = HYDT_bind_info.topology[j].thread_id;
-				    thread++;
-				    HYDT_bind_info.topology[proc].thread_id = thread;
-				    HYDT_bind_info.topology[proc].thread_rank = thread;
-				    break;
+                                                            thread = -1;
+                                                            for (j = 0; j < proc; j++)
+								/*  if ((HYDT_bind_info.topology[j].node_id   == obj_node->os_index) &&
+        (HYDT_bind_info.topology[j].socket_id == obj_sock->os_index) &&
+        (HYDT_bind_info.topology[j].core_id   == obj_core->os_index))
+								  if ((HYDT_bind_info.topology[j].socket_id == obj_sock->os_index) &&
+								      thread = HYDT_bind_info.topology[j].thread_id;
+                                                            thread++;
+							    HYDT_bind_info.topology[proc].thread_id   = thread;
+                                                            HYDT_bind_info.topology[proc].thread_rank = thread;
+                                                            break;
+    /* Get the rank of each node ID */
+    for(node = 0, bound  = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_NODE) ; node < bound ; node++)
+            obj_node  = hwloc_get_obj_by_type(topology,HWLOC_OBJ_NODE,node);
+                if (HYDT_bind_info.topology[proc].node_id == obj_node->os_index)
+                    HYDT_bind_info.topology[proc].node_rank = node;
     /* Get the rank of each socket ID */
+    for(sock = 0, bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_SOCKET) ; sock < bound; sock++)
@@ -141,7 +154,7 @@
     /* Find the rank of each core ID */
-    for (core = 0; core < my_num_cores ; core++)
+    for (core = 0, bound = hwloc_get_nbobjs_by_type(topology,HWLOC_OBJ_CORE); core < bound ; core++)
 	    obj_core  = hwloc_get_obj_by_type(topology,HWLOC_OBJ_CORE,core);
More information about the mpich2-commits mailing list
