[mpich2-commits] r5591 - mpich2/trunk/src/pm/hydra/pm/pmiserv
balaji at mcs.anl.gov balaji at mcs.anl.gov
Tue Oct 27 18:10:58 CDT 2009
Author: balaji
Date: 2009-10-27 18:10:58 -0500 (Tue, 27 Oct 2009)
New Revision: 5591
Modified:
   mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_handle_v2.c
Log:
Get rid of the nesting code in PMI-2. This is unnecessary, and just an
artifact of the brokenness of the progress engine.
Modified: mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_handle_v2.c
--- mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_handle_v2.c	2009-10-27 23:10:56 UTC (rev 5590)
+++ mpich2/trunk/src/pm/hydra/pm/pmiserv/pmi_handle_v2.c	2009-10-27 23:10:58 UTC (rev 5591)
@@ -25,35 +25,18 @@
     char *val;
-static struct attr_reqs {
-    int fd;
-    char *thrid;
-    char **req;
-    enum req_type {
-        GET_NODE_ATTR,
+static struct reqs {
+    enum type {
+        NODE_ATTR_GET,
         KVS_GET
     } type;
-    struct attr_reqs *next;
-} *outstanding_attr_reqs = NULL;
-static void print_attr_reqs(void)
-    int i;
-    struct attr_reqs *areq;
+    int fd;
+    char *thrid;
+    char **args;
-    dprintf("Outstanding reqs: ");
-    for (areq = outstanding_attr_reqs; areq; areq = areq->next) {
-        dprintf("%d:%d(", areq->fd, areq->type);
-        for (i = 0; areq->req[i]; i++) {
-            dprintf("%s", areq->req[i]);
-            if (areq->req[i + 1]) {
-                dprintf(",");
-        dprintf(") ");
-    dprintf("\n");
+    struct reqs *next;
+} *pending_reqs = NULL;
 static HYD_status send_command(int fd, char *cmd)
@@ -100,37 +83,45 @@
     goto fn_exit;
-static int progress_nest_count = 0;
+static char *find_token_keyval(struct token *tokens, int count, const char *key)
+    int i;
+    for (i = 0; i < count; i++) {
+        if (!strcmp(tokens[i].key, key))
+            return tokens[i].val;
+    return NULL;
 static int req_complete = 0;
-static void free_attr_req(struct attr_reqs *areq)
+static void free_req(struct reqs *req)
-    HYDU_free_strlist(areq->req);
-    HYDU_FREE(areq);
+    HYDU_free_strlist(req->args);
+    HYDU_FREE(req);
-static HYD_status queue_outstanding_req(int fd, enum req_type req_type, char *args[])
+static HYD_status queue_req(int fd, enum type type, char *args[])
-    struct attr_reqs *attr_req, *a;
+    struct reqs *req, *tmp;
     HYD_status status = HYD_SUCCESS;
-    HYDU_MALLOC(attr_req, struct attr_reqs *, sizeof(struct attr_reqs), status);
-    attr_req->fd = fd;
-    attr_req->type = req_type;
-    attr_req->next = NULL;
+    HYDU_MALLOC(req, struct reqs *, sizeof(struct reqs), status);
+    req->fd = fd;
+    req->type = type;
+    req->next = NULL;
-    status = HYDU_strdup_list(args, &attr_req->req);
+    status = HYDU_strdup_list(args, &req->args);
     HYDU_ERR_POP(status, "unable to dup args\n");
-    if (outstanding_attr_reqs == NULL)
-        outstanding_attr_reqs = attr_req;
+    if (pending_reqs == NULL)
+        pending_reqs = req;
     else {
-        a = outstanding_attr_reqs;
-        while (a->next)
-            a = a->next;
-        a->next = attr_req;
+        for (tmp = pending_reqs; tmp->next; tmp = tmp->next);
+        tmp->next = req;
-    print_attr_reqs();
   fn_exit:
     return status;
@@ -139,65 +130,55 @@
     goto fn_exit;
+static struct reqs *dequeue_req_head(void)
+    struct reqs *req = pending_reqs;
+    if (pending_reqs) {
+        pending_reqs = pending_reqs->next;
+        req->next = NULL;
+    return req;
 static HYD_status poke_progress(void)
-    struct attr_reqs *areq, *tmp;
+    struct reqs *req;
+    int i, count;
-    progress_nest_count++;
+    for (count = 0, req = pending_reqs; req; req = req->next)
+        count++;
-        goto fn_exit;
+        req = dequeue_req_head();
-    for (areq = outstanding_attr_reqs; areq;) {
         req_complete = 0;
-        if (areq->type == GET_NODE_ATTR) {
-            status = fn_info_getnodeattr(areq->fd, areq->req);
+        if (req->type == NODE_ATTR_GET) {
+            status = fn_info_getnodeattr(req->fd, req->args);
             HYDU_ERR_POP(status, "getnodeattr returned error\n");
-        else if (areq->type == KVS_GET) {
-            status = fn_kvs_get(areq->fd, areq->req);
+        else if (req->type == KVS_GET) {
+            status = fn_kvs_get(req->fd, req->args);
             HYDU_ERR_POP(status, "kvs_get returned error\n");
-        tmp = areq->next;
         if (req_complete) {
-            if (areq == outstanding_attr_reqs) {
-                outstanding_attr_reqs = areq->next;
-            else {
-                for (tmp = outstanding_attr_reqs; tmp->next != areq; tmp = tmp->next);
-                tmp->next = areq->next;
-            tmp = areq->next;
-            free_attr_req(areq);
+            status = queue_req(req->fd, req->type, req->args);
+            HYDU_ERR_POP(status, "error queueing request\n");
-        areq = tmp;
+        free_req(req);
   fn_exit:
-    progress_nest_count--;
     return status;
   fn_fail:
     goto fn_exit;
-static char *find_token_keyval(struct token *tokens, int count, const char *key)
-    int i;
-    for (i = 0; i < count; i++) {
-        if (!strcmp(tokens[i].key, key))
-            return tokens[i].val;
-    return NULL;
 static HYD_status fn_fullinit(int fd, char *args[])
     int id, rank, i;
@@ -412,14 +393,10 @@
     if (!found) {       /* We need to decide whether to return not found or queue up */
-        /* If we are already nested, get out of here */
-        if (progress_nest_count)
-            goto fn_exit;
         if (waitval && !strcmp(waitval, "TRUE")) {
             /* queue up */
-            status = queue_outstanding_req(fd, GET_NODE_ATTR, args);
-            HYDU_ERR_POP(status, "unable to queue outstanding request\n");
+            status = queue_req(fd, NODE_ATTR_GET, args);
+            HYDU_ERR_POP(status, "unable to queue request\n");
         else {
             /* Tell the client that we can't find the attribute */
@@ -463,8 +440,7 @@
         HYDU_ERR_POP(status, "send command failed\n");
         HYDU_FREE(cmd);
-            req_complete = 1;
+        req_complete = 1;
   fn_exit:
@@ -678,10 +654,6 @@
     if (!found) {
-            goto fn_exit;
         consistent_epoch = 1;
         node_count = 0;
         for (node = process->node->pg->node_list; node; node = node->next) {
@@ -698,14 +670,14 @@
         if (consistent_epoch == 0 ||
             ((process->epoch > 0) && (node_count != HYD_pg_list->num_procs))) {
             /* queue up */
-            status = queue_outstanding_req(fd, KVS_GET, args);
+            status = queue_req(fd, KVS_GET, args);
             /* We are done */
             goto fn_exit;
-    else if (progress_nest_count)
+    else
         req_complete = 1;
     i = 0;
@@ -790,7 +762,6 @@
   fn_exit:
     HYDU_FUNC_EXIT();
-    dprintf("[%d] out of fence\n", fd);
     return status;
   fn_fail:
More information about the mpich2-commits mailing list
