[mpich2-commits] r5548 - mpich2/trunk/maint
balaji at mcs.anl.gov balaji at mcs.anl.gov
Sat Oct 24 17:04:19 CDT 2009
Author: balaji
Date: 2009-10-24 17:04:19 -0500 (Sat, 24 Oct 2009)
New Revision: 5548
Modified:
   mpich2/trunk/maint/release.pl
Log:
Updates to the release script to remove unnecessary code. Also added
an extra option to append the svn revision number to the version
string.
Modified: mpich2/trunk/maint/release.pl
--- mpich2/trunk/maint/release.pl	2009-10-23 22:09:31 UTC (rev 5547)
+++ mpich2/trunk/maint/release.pl	2009-10-24 22:04:19 UTC (rev 5548)
@@ -1,4 +1,19 @@
 #!/usr/bin/env perl
+# (C) 2008 by Argonne National Laboratory.
+#     See COPYRIGHT in top-level directory.
+# Known limitations:
+#    1. This script assumes that it is the only client accessing the
+#    svn server. Version number verifications, diffs for ABI
+#    mismatches and other checks are run assuming atomicity.
+#    2. ABI mismatch checks are run using an svn diff in mpi.h.in and
+#    the binding directory. This can come up with false positives, and
+#    is only meant to be a worst-case guess.
 use strict;
 use warnings;
@@ -10,15 +25,14 @@
 my $source = "";
 my $psource = "";
 my $version = "";
-my $pack = "";
+my $append_svnrev;
 my $root = $ENV{PWD};
-# This path is the default for the MCS home directory mounts.  Pass
-# --with-autoconf='' and --with-automake='' options to this script to
-# use whatever is in your path.
 my $with_autoconf = "";
 my $with_automake = "";
+# Default to MPICH2
+my $pack = "mpich2";
 my $logfile = "release.log";
 sub usage
@@ -27,17 +41,20 @@
     print "OPTIONS:\n";
     # Source svn repository from where the package needs to be downloaded from
-    print "\t--source     source svn repository (required)\n";
+    print "\t--source          source svn repository (required)\n";
     # svn repository for the previous source in this series to ensure ABI compliance
     print "\t--psource    source repo for the previous version for ABI compliance (required)\n";
-    # what package we are creating (mpich2, romio, mpe)
-    print "\t--package    package to create (optional)\n";
+    # what package we are creating
+    print "\t--package         package to create (optional)\n";
-    # version number associated with the tarball
-    print "\t--version    tarball version (required)\n";
+    # version string associated with the tarball
+    print "\t--version         tarball version (required)\n";
+    # append svn revision
+    print "\t--append-svnrev   append svn revision number (optional)\n";
     print "\n";
     exit;
@@ -82,181 +99,12 @@
-sub debug
-    my $line = shift;
-    print "$line";
-sub create_docs
-    my $pack = shift;
-    if ($pack eq "romio") {
-	chdir("romio/doc");
-	run_cmd("make");
-	run_cmd("rm -f users-guide.blg users-guide.toc users-guide.aux users-guide.bbl users-guide.log users-guide.dvi");
-    elsif ($pack eq "mpe") {
-	chdir("mpe2/maint");
-	run_cmd("make -f Makefile4man");
-sub create_mpich2
-    # Check out the appropriate source
-    debug("===> Checking out mpich2 SVN source... ");
-    run_cmd("rm -rf mpich2-${version}");
-    run_cmd("svn export -q ${source} mpich2-${version}");
-    debug("done\n");
-    # Remove packages that are not being released
-    debug("===> Removing packages that are not being released... ");
-    chdir("${root}/mpich2-${version}");
-    run_cmd("rm -rf src/mpid/globus doc/notes src/pm/mpd/Zeroconf.py");
-    chdir("${root}/mpich2-${version}/src/mpid/ch3/channels/nemesis/nemesis/netmod");
-    my @nem_modules = qw(elan ib psm);
-    run_cmd("rm -rf ".join(' ', map({$_ . "/*"} @nem_modules)));
-    for my $module (@nem_modules) {
-	# system to avoid problems with shell redirect in run_cmd
-	system(qq(echo "# Stub Makefile" > ${module}/Makefile.sm));
-    debug("done\n");
-    # Create configure
-    debug("===> Creating configure in the main package... ");
-        my $cmd = "./maint/updatefiles";
-        $cmd .= " --with-autoconf=$with_autoconf" if $with_autoconf;
-        $cmd .= " --with-automake=$with_automake" if $with_automake;
-        run_cmd($cmd);
-    debug("done\n");
-    # Remove unnecessary files
-    debug("===> Removing unnecessary files in the main package... ");
-    run_cmd("rm -rf README.vin maint/config.log maint/config.status unusederr.txt src/mpe2/src/slog2sdk/doc/jumpshot-4/tex");
-    run_cmd("find . -name autom4te.cache | xargs rm -rf");
-    debug("done\n");
-    # Get docs
-    debug("===> Creating secondary package for the docs... ");
-    chdir("${root}");
-    run_cmd("cp -a mpich2-${version} mpich2-${version}-tmp");
-    debug("done\n");
-    debug("===> Configuring and making the secondary package... ");
-    chdir("${root}/mpich2-${version}-tmp");
-        run_cmd($cmd);
-    run_cmd("./configure --without-mpe --disable-f90 --disable-f77 --disable-cxx");
-    run_cmd("(make mandoc && make htmldoc && make latexdoc)");
-    debug("done\n");
-    debug("===> Copying docs over... ");
-    run_cmd("cp -a man ${root}/mpich2-${version}");
-    run_cmd("cp -a www ${root}/mpich2-${version}");
-    run_cmd("cp -a doc/userguide/user.pdf ${root}/mpich2-${version}/doc/userguide");
-    run_cmd("cp -a doc/installguide/install.pdf ${root}/mpich2-${version}/doc/installguide");
-    run_cmd("cp -a doc/smpd/smpd_pmi.pdf ${root}/mpich2-${version}/doc/smpd");
-    run_cmd("cp -a doc/logging/logging.pdf ${root}/mpich2-${version}/doc/logging");
-    run_cmd("cp -a doc/windev/windev.pdf ${root}/mpich2-${version}/doc/windev");
-    chdir("${root}");
-    run_cmd("rm -rf mpich2-${version}-tmp");
-    debug("done\n");
-    debug("===> Creating ROMIO docs... ");
-    chdir("${root}/mpich2-${version}/src/mpi");
-    create_docs("romio");
-    debug("done\n");
-    debug( "===> Creating MPE docs... ");
-    chdir("${root}/mpich2-${version}/src");
-    create_docs("mpe");
-    debug("done\n");
-    # Create the tarball
-    debug("===> Creating the final mpich2 tarball... ");
-    chdir("${root}");
-    run_cmd("tar -czvf mpich2-${version}.tar.gz mpich2-${version}");
-    debug("done\n\n");
-sub create_romio
-    debug("===> Checking out romio SVN source... ");
-    run_cmd("rm -rf romio-${version} romio");
-    run_cmd("svn export -q ${source}/src/mpi/romio");
-    debug("done\n");
-    debug("===> Creating configure... ");
-    chdir("${root}/romio");
-    run_cmd("autoreconf");
-    debug("done\n");
-    chdir("${root}");
-    debug("done\n");
-    debug("===> Creating the final romio tarball... ");
-    chdir("${root}");
-    run_cmd("mv romio romio-${version}");
-    run_cmd("tar -czvf romio-${version}.tar.gz romio-${version}");
-    run_cmd("rm -rf romio-${version}");
-sub create_mpe
-    debug("===> Checking out mpe2 SVN source... ");
-    run_cmd("rm -rf mpe2-${version} mpe2");
-    run_cmd("svn export -q ${source}/src/mpe2");
-    debug("done\n");
-    chdir("${root}/mpe2");
-        run_cmd($cmd);
-    debug("done\n");
-    debug("===> Creating MPE docs... ");
-    chdir("${root}");
-    debug("done\n");
-    debug("===> Creating the final mpe2 tarball... ");
-    chdir("${root}");
-    run_cmd("mv mpe2 mpe2-${version}");
-    run_cmd("tar -czvf mpe2-${version}.tar.gz mpe2-${version}");
-    run_cmd("rm -rf mpe2-${version}");
 GetOptions(
     "source=s" => \$source,
     "psource=s" => \$psource,
     "package:s"  => \$pack,
     "version=s" => \$version,
+    "append-svnrev!" => \$append_svnrev,
     "with-autoconf" => \$with_autoconf,
     "with-automake" => \$with_automake,
     "help"     => \&usage,
@@ -266,10 +114,6 @@
     usage();
-if (!$pack) {
-    $pack = "mpich2";
 if (!$source || !$version || !$psource) {
     usage();
@@ -279,12 +123,11 @@
 check_package("latex");
 check_package("autoconf");
 check_package("automake");
-debug "\n";
+print("\n");
 my $current_ver = `svn cat ${source}/maint/Version`;
 if ("$current_ver" ne "$version\n") {
-    debug("\n\tWARNING: Version mismatch\n\n");
+    print("\tWARNING: Version mismatch\n\n");
 if ($psource) {
@@ -292,26 +135,103 @@
     my $d = `svn diff ${psource}/src/include/mpi.h.in ${source}/src/include/mpi.h.in`;
     $d .= `svn diff ${psource}/src/binding ${source}/src/binding`;
     if ("$d" ne "") {
-	debug("\n\tWARNING: ABI mismatch\n\n");
+	print("\tWARNING: ABI mismatch\n\n");
+if ($append_svnrev) {
+    $version .= "-r";
+    $version .= `svn info ${source} | grep ^Revision: | cut -f2 -d' ' | xargs echo -n`;
+# Clean up the log file
 system("rm -f ${root}/$logfile");
-if ($pack eq "mpich2") {
-    create_mpich2();
+# Check out the appropriate source
+print("===> Checking out $pack SVN source... ");
+run_cmd("rm -rf ${pack}-${version}");
+run_cmd("svn export -q ${source} ${pack}-${version}");
+print("done\n");
+# Remove packages that are not being released
+print("===> Removing packages that are not being released... ");
+chdir("${root}/${pack}-${version}");
+run_cmd("rm -rf src/mpid/globus doc/notes src/pm/mpd/Zeroconf.py");
+chdir("${root}/${pack}-${version}/src/mpid/ch3/channels/nemesis/nemesis/netmod");
+my @nem_modules = qw(elan ib psm);
+run_cmd("rm -rf ".join(' ', map({$_ . "/*"} @nem_modules)));
+for my $module (@nem_modules) {
+    # system to avoid problems with shell redirect in run_cmd
+    system(qq(echo "# Stub Makefile" > ${module}/Makefile.sm));
-elsif ($pack eq "romio") {
-    create_romio();
+print("done\n");
+# Create configure
+print("===> Creating configure in the main package... ");
+    my $cmd = "./maint/updatefiles";
+    $cmd .= " --with-autoconf=$with_autoconf" if $with_autoconf;
+    $cmd .= " --with-automake=$with_automake" if $with_automake;
+    run_cmd($cmd);
-elsif ($pack eq "mpe") {
-    create_mpe();
+print("done\n");
+# Remove unnecessary files
+print("===> Removing unnecessary files in the main package... ");
+run_cmd("rm -rf README.vin maint/config.log maint/config.status unusederr.txt src/mpe2/src/slog2sdk/doc/jumpshot-4/tex");
+run_cmd("find . -name autom4te.cache | xargs rm -rf");
+print("done\n");
+# Get docs
+print("===> Creating secondary package for the docs... ");
+chdir("${root}");
+run_cmd("cp -a ${pack}-${version} ${pack}-${version}-tmp");
+print("done\n");
+print("===> Configuring and making the secondary package... ");
+chdir("${root}/${pack}-${version}-tmp");
+    run_cmd($cmd);
-elsif ($pack eq "all") {
-    create_mpich2();
-    create_romio();
-#     create_mpe();
-else {
-    die "Unknown package: $pack";
+run_cmd("./configure --disable-mpe --disable-romio --disable-f90 --disable-f77 --disable-cxx");
+run_cmd("(make mandoc && make htmldoc && make latexdoc)");
+print("done\n");
+print("===> Copying docs over... ");
+run_cmd("cp -a man ${root}/${pack}-${version}");
+run_cmd("cp -a www ${root}/${pack}-${version}");
+run_cmd("cp -a doc/userguide/user.pdf ${root}/${pack}-${version}/doc/userguide");
+run_cmd("cp -a doc/installguide/install.pdf ${root}/${pack}-${version}/doc/installguide");
+run_cmd("cp -a doc/smpd/smpd_pmi.pdf ${root}/${pack}-${version}/doc/smpd");
+run_cmd("cp -a doc/logging/logging.pdf ${root}/${pack}-${version}/doc/logging");
+run_cmd("cp -a doc/windev/windev.pdf ${root}/${pack}-${version}/doc/windev");
+chdir("${root}");
+run_cmd("rm -rf ${pack}-${version}-tmp");
+print("done\n");
+print("===> Creating ROMIO docs... ");
+chdir("${root}/${pack}-${version}/src/mpi");
+chdir("romio/doc");
+run_cmd("make");
+run_cmd("rm -f users-guide.blg users-guide.toc users-guide.aux users-guide.bbl users-guide.log users-guide.dvi");
+print("done\n");
+print( "===> Creating MPE docs... ");
+chdir("${root}/${pack}-${version}/src");
+chdir("mpe2/maint");
+run_cmd("make -f Makefile4man");
+print("done\n");
+# Create the tarball
+print("===> Creating the final ${pack} tarball... ");
+chdir("${root}");
+run_cmd("tar -czvf ${pack}-${version}.tar.gz ${pack}-${version}");
+print("done\n\n");
More information about the mpich2-commits mailing list
